Forum » Programska oprema » cygwin in gcc instalacija
OmegaM ::
Pozdravljeni!
Imam eno tezavico
Instaliral sem si CYGWIN, vendar nisem zravenm instaliral gcc, sedaj pa hocem posebej instalirat pa se mi naredim vse lepo kot pise:
# Install Cygwin, including the gcc and make packages, if you have not already done so.
# Download the W3C libwww libraries, as sources or precompiled binaries, and save them in your Cygwin home directory (normally this will be c:\cygwin\home\your-Windows-login-name).
Perform the remainder of the installation from within a Cygwin terminal window.
# If you downloaded the sources: Unpack, compile, and install them using these commands:
tar xfvz w3c-libwww-5.4.0.tar.gz
cd w3c-libwww-5.4.0
./configure --with-zlib //do sem mi vse lepo uspe
make //od make naprej pa ne, ker mi ukaza ne najde
make install
Kaj storiti?
Hvala
Imam eno tezavico
cd w3c-libwww-5.4.0
make install
Kaj storiti?
Hvala
Ni nam lahko, bo pa boljše!!!
| » | Windows 10 bo dobil bash! (strani: 1 2 3 )Oddelek: Novice / Operacijski sistemi | 63923 (56190) | Jst |
| » | Microsoft odgovoril Evropski komisiji (strani: 1 2 )Oddelek: Novice / Tožbe | 9228 (8136) | MrStein |
| » | [C] random do poljubne številkeOddelek: Programiranje | 2508 (2175) | napsy |
| » | [Flamewar] Firefox in mogočna vrnitev IE (strani: 1 2 )Oddelek: Loža | 6187 (5443) | veteran |
| » | Suse 9.0 (strani: 1 2 )Oddelek: Operacijski sistemi | 6365 (5651) | moj_nick |
