Grand Theft Auto: San Andreas (PC)
15 / 30
bzp ::
a pa so modelcki-misije obvezne? Na PS2 vem da niso :) Ce je slucajno kdo obupal pa ni sel naprej probat ...
alum ::
NRG 500 "cupa" asfalt ;)
marnit ::
Misije pri unemu Zerotu (aka modelčki) niso obvezne. Jez osebno sem jih šel delat potem ko sem končal šolo letenja.
KnOw FeAr ::
end of the line...pa kok douga misija je to.sm ze biv vesel ko sm komi iz bajte vn prsu
pol pa se tist....;(( ;(( ;(( ;(( ;(( ;((
bluefish ::
ali je v san fierru kakšna stavnica za konjske dirke, kje?
KnOw FeAr ::
Two player mode
Successfully complete the Burning Desire mission where you rescue Denise. A red two player free roam icon will now appear on Denise's porch near the door. The icon will appear there when she is home and will go on a date. Note: If both enter a car, the passenger will have free aim with a machine gun. Do not try to kill Denise, because you will never be able to date her again or play in two player mode at her house. Additionally, once you get your girlfriend, take her on a date. After you drop her off, there will be a rotating icon of two people directly in front of the door. Walk into it. It will tell you to push any button on the controller two. Do so to start two player mode, involving CJ and his girlfriend in a free roam.
For more fun in two player mode, start the two player mission. Then, enable the "Spawn Jetpack" code and remove the Jetpack. Then, have player two get the Jetpack. Enable the Jetpack code again, then have player one get it. Both players can now fly around and do the two player missions this way.
Pegaz ::
A kdo ve, kaj moram naredit pri Driving School ko tiščim W in S. Če pritisnem še D ali A mi začne računalnik piskat. Preveč tipk na enkrat. Kaj naj naredim?
Xplicit ::
ce kdo rabi dost kesa se ga da dobit tud v igralnicah na avtomatih - ene 10x sm stavu (po 50$) in 2x dobu po 20k :D, sam to je sele v tretjem mestu
roli ::
Če narediš za zeroota misije te pred njegovo trgovino čaka ikona $.
Pa ne zavzemat teritorijev,ker jih v drugem mestu itak izgubiš.
http://www.r00li.com
]Fusion[ ::
Mogoče ima kdo enak problem, da ko začnem driving school, mi takoj ko pritisnem na gas prekine vso zadevo kao da nisem naredil preizkusa. Sem bral nekaj FAQ pa piše da pomaga če si spremeniš kontrole, samo sem že vse mogoče kombinacije sprobal, pa še vedno enako.
"I am not an animal! I am a human being! I... am... a man!" - John Merrick
KnOw FeAr ::
a ve kdo za kako hišo ko ma čim več garaž,8-)
hiša pa cena ni pomembna.:D pomembne so garaže.:P
steev ::
Fusion: Pr kermu testu pa. Če je taprvi mors gas in bremzo skp tišat + še ena smerna tipka, da se zavrtiš (oblika krofa, kot ga jejo policaji v filmih:))).
marnit ::
Oba smerna kazalca (pospečevanje in zaviranje) moraš stisniti hkrati. Potem pa še smer vrtenja.
keko ::
Mene pa zanima kako odpre padalo oziroma kako se ga uporablja?
KnOw FeAr ::
morš it na določeno višino potem pa skočiš dol pa prtisneš lev gumb na miški da se ti padalo aktivira:D
Xplicit ::
nkosec2 - v 2. mestu je en 'blok' kjer mas spodi eno OGROMNO garazo (tm k je mislm da prva tocka od prve misije za unga pimpa jizziy-ja k enga druzga pimpa pretepes)
sicer pa ce se potruds gre v vsako garazo veliko stevilo vozil :D
a v las venturasu so pr hotelih ksne garaze?
Paramedic ::
Še enkrat sprašujem, ker je zgleda moj post prej neviden. Kako importaš vozila, za katera pravi "one more car is now available for import", ko dostaviš avto na ladjo?
End transmission.
]Fusion[ ::
Pa res. Za pismene piše ne :8)
stealth ::
Evo neki za tiste ko mate probleme z letenjem....
Follow the example :P
http://www2.arnes.si/~njurce/flying_for_dummies.wmv
dxx ::
Obvladaš, ni kej.
Xplicit ::
Paramedic - ce misls kje se da dobit avtomobile - tm pr ladji mas na levi eno tablo, prides do tja in stisnes enter, pol pa lahko izbiras kej avto/motor bos nabavu
Pegaz ::
Lahko kdo pove, prosim?
darkydarker ::
STEALTH a ti to z joystikom pilotiraš
turk
tt2 ::
Mene zanima, če v igri možno igrati košarko???
Brudol ::
Seveda, sam igrišče z žogo najdi :D .
LP Brudol
stealth ::
@ darkydarker:
ne, vse s tipkovnico. sm probu z joystickom, pa ne gre tak gladk ko bi mogl.
]Fusion[ ::
Pekaz probaj spremenit tipke...
alum ::
kaj pomeni tisti rdeci znak target?
krivec ::
Pegaz: tisci W in S potem pa ne A ali D ampak smerne tipke za levo ali desno. Dvomim da ti comp ne zdrži treh tipk na enkrat... :\
Bite my shiney metal ass !
Xplicit ::
Pegaz & vsi ostali - kaj vas je tolk levicarjev da vozite na W,S, A & D tipkah? :\
kolikor vem je ze po defoultu nastavljen na smerne tipke... to zihr ne bi smelo stekat
stealth ::
@ wakum:
Če misliš tist pri hydri, ko space stisneš, pol je tak:
ko je krogec zelen, maš tarčo zaklenjeno, ampak je izven dosega, ko pa se spremeni v rdečga, pa stisneš levo CTRL tipko, in izstreliš 2 raketi, ki potem sledita tisti tarči.
Pegaz ::
@krivec: Hvala
@Xplicit: Sem desničar, vendar vozim na W, S, D in A.
roli ::
Kako bi izboljšal skill level za orožja???
Strelišče v ammu-nationu je nekaj časa pomagalo zdaj pa ne več.
Myth ::
Da greš ven pa streljaš ko teritorije osvajaš. Tako sem postal jaz hitman za smg, shootgun, ak47 in navadno pistolco. 8-)
edit: pa nisem nobenga strelišča v ammu-nationu uporabljal oz. na njem treniral
edit2: a ve mogoče kateri čeat te vklopiš, če zletiš z motorja? 8-O Zdaj ko sn neki v gorah, ko moram neko misijo naredit da pofotkam enga ki ga morm ubit... sem padno z motorja pa je napisalo, cheat activated... wtf??? btw, še vedno sn v "prvem" mestu :D
¤ Space is Mystery. And Myth is on Earth. ¤
  • spremenilo: Myth ()
strictom ::
Mogoče si pa pravo zaporedje tipk pritisno. Poglej če je kakšen tank kje za tabo :D
SebaR ::
MrIce meni se je to zgodilo pri vstopanju v avto z rožami v rokah :D
gfighter ::
rolihandrej: Jaz sem to naredu tako: V San Fieru, ko začneš dejtat Kate, te ona spravi iz bolnice za đabe z vsemi orožji. No, kupil sem si orožja na tone in delal pokole pred njeno hišo... Ene pol ure kasneje sem bil že skor vse hitman.
Tilen ::
Marsikdo ni levicar pa igra z W S A D tipkami. je precej prakticno ko se navadis.
Myth ::
Mene samo zanima kateri cheat sem vklopil "pomotoma". Any one with an idea? :)
btw, jaz sn desničar, pa mi kar ugajajo tiste tipke. Če pa kdo z yojpadom špila, bi bil zelo hvaležen, če mi pove kako si je nastavil v igri? Ker sem poskusal vse vkluciti (on), izkluciti(off) pa ne morem prok**** kamere zrihtat. Ali mi sledi iz poda al pa z lufta? :\
V-i-p ::
Slike so sicer malo slabše kvalitete, ker sem igral na enem bolj slabem PC-ju, pa vseeno :).
bla
Pogled v globino iz ene najvišjih stolpnic v mestu. Cmok v grlu ;)
bla
Še pogled navzdol...
bla
...in skok v globino, ter jadranje v zraku.
bla
Ko se naveličamo jadrati, gremo malček hitreje...
bla
Odpremo padalo in že smo tik nad tlemi!
bla
Uff, jebempti, od kod sem skočil ;)
P.s.: špil res trga...
Myth ::
Adijo... kakšen pogled... a še prpopaš slikco od mape , kje je ta stolpnca? 8-O
V-i-p ::
bla
Je pa tako, jst sem se j.ebal in pristal na njej z letalom, nisem vedel, da se lahko zapelješ do nje, greš do vhoda in skozi vrata, pa te vrže direkt na streho stolpnice. Tam imaš pa padalo, pa že pikiraš dol :). Je pa fino, lahko greš "prosti pad", lahko jadraš, greš levo desno, ko ga pa odpreš, pa lahko spet, greš malo sem in tja, se spuščaš počasi, ali pa hitreje. Ker obožujem skoke s padalom, prosim za info, ako kdo najde še višjo stolpnico v mestu ;).
P.s.: obvezno je treba probat skok s padalom iz letala, nekje nad oblaki, občutek je fantastičen, kot bi skakal v resnici =).
tx-z ::
Mau nerealistično, ko se z motorjem vržeš s te stavbe, pa se ti nč ne zgodi;)
Bl zanimiu pa je z motorjm dol skočt, pa pol z motorja dol pa s padalom naprej(hitr morš z motorja skočt drgač je prepozn) :D
tx-z
roli ::
Problem hujše klase:D :
Kar na enkrat igra grozno ali pa malo šteka.
Sem probal restartat comp pa ne pomaga.
Včeraj zvečer,ko sem dal quit game in dal yes se je pojavil
črn zaslon in nekaj je delal po disku in nič drugega.
Pa se comp ugasnil z 4 sekundnim pritiskom na gumb power, danes pa
mi to dela.
Kaj je narobe??
darkydarker ::
mene pa zanima mam joystick fighter thrustmaster pa mi ga ne zazna pc ali morm kaj naštimat na pc-ju driverja nism dobu zravn .... hvala,da bi probal če je kej laži pilotirat =)
turk
steev ::
rolihandrej: enak problem, dam quit, pridem cez minuto nazaj, črn zaslon... Wtf? restart je pomagu, sej itk skos.
cerber ::
spremen si tipko levo al pa desno (a ali d) u tipko na miški pol pa prtisn vse tri hkrati
Myth ::
Kake brezvezne misije so pa zdaj na vrsti pri meni. Neki TT se mi je javo tam iz gor, pa trucker misije bom naredo... v glavnem tuga...kak dugo se bom mogo fijakat po teh travniskih in gorskih poteh, mi lahko pove kdo kolko je teh "tumastih" misij? Čeprav truck misije zacenjajo postajati zanimive... lih preden sem hotel koncat 3 furo, se mi odcepi ovo sranje, prokleti policisti so krivi, da nisn priso do skladisca... pa tak gladko mi je slo sicer... :D
KnOw FeAr ::
sej truck missions ti ni mus delat:D
steev ::
Mr|ce, sej ni tok teh misij, pol mors se z eno zensko neki ropat pol pa pride SanFiero (če se ne motm) na vrsto.
15 / 30
GTA 4 PC (strani: 1 2 3 4 … 29 30 31 32 )
Oddelek: Igre
1591157770 (10671) oo7
Grand Theft Auto V (strani: 1 2 3 4 … 45 46 47 48 )
Oddelek: Igre
2390603988 (170604) Kayzon
gta vice city (strani: 1 2 3 4 … 11 12 13 14 )
Oddelek: Igre
69257040 (21643) Heavy
Gta san andreas kode
Oddelek: Igre
3816205 (4642) Cold1
GTA: IV (strani: 1 2 )
Oddelek: Novice / Igre
5010712 (8990) roli
