Forum » Problemi človeštva » Družinski zakonik in referendum [ex: Homoseksualne poroke]
WireMess ::
Jaz sem napisal prvega. Drugi je zrastel v tvoji pravicniski glavi.Ne, ta drugi je zrasel kvečjemu v tvoji glavi, ker jaz ga nikjer nisem omenjal.
Tudi jaz ne trdim, da so vsi ljudje po vrsti zagrenjeni in nezadovoljni s svojimi življenji. Samo taki, ki se, tako kot ti, vtikajo v zasebna življenja drugih, čeprav se jih čisto nič ne tičejo.
O.
Mene sploh ne zanima, ali si le tako kratke pameti, da nisi dojel, kaj sem hotel reci (skozi nekaj nabijas o vtikanjih v tuja zivljenja in podobne kozlarije), ali pa se le sprenevedas (bolj verjetno). Vsekakor drugega stavka nisi napisal, mi ga pa implicitno podtikas. Ja, ja, kar sprenevadaj se se naprej, malo se zgrazaj... ne ljubi se mi diskutirati s tabo, hinavec.
Me zanima, kako bodo instant psihologi obrazložili primere, ko bodo tak posvojen otrok, postrelil oba očkata ko bo nekoliko starejši.Ne vem, lahko pa ti povem, kaj poklicni psihologijo pravijo, ko ustreli očkata in mamico.
... about 10% of adopted children exhibit serious behavioral symptoms that are sometimes mistaken for Oppositional Defiant Disorder or Conduct Disorder, Childhood Onset Type. These children are angry, argumentative, and often refuse to accept any personal responsibility for their aggressive actions or outbursts of rage.
In a healthy adoptive situation, parents are open and honest about the child's adoptive status. In dysfunctional situations, parents either wildly overcompensate by showering the child with intrusive attention and material things; or utterly ignore the fact of adoption as much as possibly, refusing to discuss birth parents or the adoptive process with the child.
The adopted child thus never develops an adequate conscience because there is a proposed schism between good and "evil" self-images. Often, the child believes that a "good adoptee" would never want to know about or meet his birth parents. At the same time, hostility toward the adopted parents builds, leading to explosions of fury. (In less than 1% of such cases, the adopted child eventually murders one or both of his parents.
O.
Double_J ::
Ja ja... raje ne bomo preverjali procentov, še v tem primeru. Bolje da samo špekuliramo, kot da bi to preizkušali na otrocih, koliko bo samo/morilcev.
Dve šivanki...
raje ne bomo preverjali procentov,Prav res, ker bi se utegnilo izkazati, da rezultati ne ustrezajo predsodkom.
O.
Double_J ::
Se bi utegnilo ja... samo hude škode nebi bilo. Bi pa bila huda škoda, če bi se pokazalo kaj drugega. Potem bi takšni trmoglavci kot si ti bili odgovorni za nepotrebne smrti.
Nič nerazumnega ni predpostavljati, da bo več samomorilcev ali pa morilcev staršev. Sej to je jasno... par let ga bodo spraševali, iz čigave riti je prilezel. Potem bo fental ali pedra, ali pa sebe.
Sploh ne bomo to preizkušali... koliko več jih bo zato zagrenjenih ali pa samo/morilcev. To naj za vedno ostane akademska razprava.
Dve šivanki...
Homoseksualni pari lahko otroke posvajajo v naslednjih državah: Andora, Argentina, Belgija, Brazilija, Danska, Islandija, Nizozemska, Norveška, Južna Afrika, Španija, Švedska, Velika Britanija, Urugvaj in v nekaterih delih ZDA, Mehike, Kanade in Avstralije. Otroka svojega homoseksualnega partnerja lahko drugi partner posvoji tudi v Nemčiji, Izraelu in na Finskem.
Druge države pa bodo naprednejšim pač sledile z manjšim ali večjim zaostankom, kot pri vseh drugih stvareh.
O.
O.
- spremenil: Okapi ()
Thomas ::
"Naprednost" ni apriori dobra reč. Tudi "predsodki" niso apriorno slabi.
Tlele jurišate dost na hitro in na silo, da bi dosegli svoj cilj. Izenačenje homoseksualne s heteroseksualno zvezo. Dobronamerno, verjamem, nepremišljeno pa tudi. Zelo.
Thomas je pač še en od tistih, ki ne vedo, da lahko otroka posvoji eden od homoseksualnega para - in je vse, kar bi radi sedaj dosegli, da bi ga lahko posvojil tudi drugi. Jebiga, ni tako zelo razgledan, kot misli, da je.
O.
O.
Thomas ::
zakaj je za druzbo dobro, da se tveganje za otroka ne zminimizira?
Tile otroci so samo en aspekt, pomemben, ampak ne edini.
Mipe ::
Pyr0Beast ::
Primer. Ko so v Ameriki izenačili pravice neporočenih mater s pravicami poročenih - kar je bilo očitno humano dejanje - se je število neporočenih mater v nekaterih okoljih dvignilo do 80%.
To ne pove čisto ničesar. Od katere cifre se je dvignilo ? 20?, 78% ?
In tudi, če so matere hotele postati samske, pa prej zaradi ugodnosti to niso, je bil ta zakon samo pozitivne narave.
imagodei ::
Me zanima, kako bodo instant psihologi obrazložili primere, ko bo tak posvojen otrok, postrelil oba očkata ko bo nekoliko starejši.
Kako pa jih razložijo, ko neposvojeni otrok v straight familiji ubije svoje starše? Ko 45-letnik zabode svojega 70-let starega očeta? Ko napade mamo s sekiro?
Polna usta so vas nekih predsodkov. Sposobnost koherentnega logičnega mišljenja pada s količino čustvenega naboja v debati.
Še ena taka cvetka je da otroci, ki živijo v homoseksualnih familijah, prevzemajo "napačne" vrednote in navade, ter bodo odrasli v homoseksualce... No shit, a res? Kako so pa potem otroci v straight familijah odrasli v geje in lezbijke? Od kod to "napačno mišljenje", kdo ga je vcepil "nepokvarjeni" mladini?
- Hoc est qui sumus -
Sem enkrat že povedal, da tale človk - Loooooka - prov razmišlja.
Kdor je realen, to vidi.
Čaki malo, Thomas, v čem se njegovo razmišljanje razlikuje od razmišljanja, da ne smemo risat karikatur mohameda, ker bo par norcev iz tega naredilo jihad? Al boš spet imel dvojna merila, glede na to, kdo je "razjarjen"?
Če bo Looooookov ali Thomasov otrok vrgel kamen v glavo otroku geja, bo za to kriv Looooooka ali Thomas, ne gej, ker je posvojil otroka, ali jaz, ki sem se zavzemal za to, da ga lahko posvoji.
Ja, žal mentaliteta premnogih - ker nisem sposoben bit strpen in otroke vzgojit v strpne ljudi, dejmo raje odstranit vse, kar bi mene in moje otroke lahko provociralo. Hecno je, da ne uporabljajo enake logike takrat, ko gre za muslimane...verjamem, da kakega fundija tudi moti, da se pri nas sprehajajo dekleta v minikah, pa sem kar zelo prepričan, da jim Thomas ne bo stopil v bran, ko bodo zahtevali burke za vse.
Sploh pa oba veva, da ne gre za pravico (niti za iskreno zeljo), kajne, temvec za kaprico. Za strezenje bolanim egom. Zakaj se sprenevedas? Ali res ne stekas?
V Sloveniji je _že sedaj_ ca. 100 otrok, ki imajo istospolna starša. In to, da želiš, da ta otrok deduje po tebi, da želiš, da ga boš lahko obiskal v bolnici, če se mu kaj zgodi, to ni nobena kaprica.
Tu imas delno prav (delno, ker mislim, da to nikakor ni edina razlika), ampak, kot receno - bos zrtvoval otroke, da se "ne bos dal tem zaostalim primatom"? Na njihov racun bi dokazoval svoj strpniski prav?
Boste tako zelo mislili na dobro otrok tudi takrat, ko bodo fundiji zahtevali burke? Ali boste na račun deklic dokazovali svoj prav?
Prepričanje, da je treba odpraviti dovolj starih tabujev, pa bo vse (spet) lepo in prav, je fundamentalna predpostavka (levičarskega) progresivizma.
Kaj te potem naredi tvoja predpostavka, da je treba muslimanom odpravit stare tabuje? Levičarskega fundija?
In to je slabo ker...?
Družba, ki on the fly spreminja pravila svojega delovanja, je kakor program, ki si med izvajanje spreminja kodo. Zelo hitro gre kaj narobe.
Ja, kot v Afganistanu in Iraku, ne?
Jap. Par let bodo žalili mohameda s karikaturami. Potem bodo pa fundiji pa fental vse naokrog. Dejmo raje odstranit provokativne karikaturiste, kot da bi odstranili fundije. Ane?
Jep. Zakaj bi preizkušali, koliko fundijev imamo že v Evropi. Dejmo preventivno uvest šeriatsko pravo, da se jim ne utrga in bodo postali samo/morilci. Ane??
Kako boste "desničarji" opravičili zagovarjanje "civiliziranja fundijev" v enem primeru in "prepovedjo provokacije fundijev" v drugem?
nurmaln ::
Tole se meni sicer zdi kot neka statistika katero lahko prikažeš kot pač želiš tko da (prosto po Thomasu) RAW DATA PLEASE.
Sicer pa tudi če drži točno tako kot je predstavljeno. So what? Je bolje dati neporočenim materam toliko pravic kot ostalim ali je bolje da jih zakonodaja sili v vztrajanje v zakonu z npr. kriminalci, nasilneži, odvisiniki ali pa v neuspešni vezi s sicer povsem normanim moškim?
Pravice so pravice in je prav da so porazdeljene enakomerno. Ogrožena "družba" ali ogrožene "tradicionalne družinske vrednote" pač nimajo pravic.
USS Liberty ::
V bistvu me zanima, od kje pride tako vroče sovraštvo do homoseksualcev? Opažam, da ljudi naredi prav primarno besne in jim zamegli um, kot redko katera stvar. Mora biti genetsko, ampak zakaj? Homoseksualci vendar niso nikoli predstavljali konkurence v neki skupini in družbi. Selfish gene ne razloži. :D
Nobenega sovraštva ni… gre samo za logično negativno reakcijo, ko homoseksualci hočejo nekaj kar jim ne pripada. Heteroseksualci pač nismo vsi mazohisti, ki bomo v nedogled prenašali žaljive provokacije homoseksualcev. Heteroseksualci smo tisti, ki dejansko prispevamo, da se rojevajo naslednji rodovi, da družba obstane, smo tisti, ki otroke dejansko ustvarjamo, jim od malega brišemo riti, jih hranimo, vozimo v šolo, se marsičemu tudi odrekamo, samo zato, da bi našim otrokom bilo lepo, na koncu pa poslušamo neke žaljive homoseksualne psihoanalize od gejevskih aktivistov, da pa v resnici smo pa heteroseksualci tista družbena skupina, ki je neusposobljena in neprimerna za vzgojo otrok, da smo vsi po vrsti neki neuravnovešeni neumni pijanci, nasilneži, ki bi nam socialne službe morale pobrati otroke in jih dati v posvojitev homoseksualcem, ki pa so vsi po vrsti pametni, strpni, ljubeči, inteligentni, skratka edini primerni za vzgojo otrok…
Homoseksualci imajo čisto vse pravice kot vsi ostali v tej družbi, tudi otroke lahko delajo, če jim to paše. Če so se pa odločili, da se ne bodo parili z osebki nasprotnega spola, je pa to njihov problem in ne bomo heteroseksualci delali otroke za homoseksualce, samo zato, da bo zadovoljen njihov prepotentni ego, da se bodo lahko potem na gej paradah slikali z njimi…
Take forumske debate imajo samo eno dobro plat - da nas od časa do časa opomnijo, v kako primitivni družbi v resnici še vedno živimo, in da se je treba za civilizacijske in humanistične pridobitve ves čas boriti, ker je že trenutek nepazljivosti dovolj, in nam lahko spolzijo iz rok.
Homoseksualnost, ki se je razširila v vse pore neke družbe, ni nobena civilizacijska pridobitev, ampak odraz totalne družbene dekadence in eno od znamenj, da je ta družba v svojem zatonu...
Ja, ja, tako kot je cel svet sledil homoseksualnim starim Grkom, kajnede?? V resnici bo ravno obratno. Tretji svet bo spremenil te dekadentne zahodne države in ne one tretjega sveta… Samo malo poglej demografske podatke, koliko otrok se rodi v Evropi in koliko Afriki in Aziji. Homoseksualni lobij bo pa izgubil svojo moč, ko bosta namesto ZDA prvi svetovni velesili postali Kitajska in Indija.
http://en.wikipedia.org/wiki/USS_Liberty_%28AGTR-5%29
Tear_DR0P ::
Mislil sem na povsem osnovno funkcionalno ekvivalentnost v smislu, da te lahko tudi krava ponese na hrbtu.
no in če sedaj preidem nazaj na temo - funkcionalno gledano lahko tudi 2+ moških ali 2+ žensk vzgaja otroka, povsem zadovoljivo oziroma primerljivo dobro "tradicionalni" družini. povsem osnovna funkcionalna ekvivalentnost - še boljša kot tista pri govedu :)
Samuel Clemens aka Mark Twain
ahac ::
Nobenega sovraštva ni... gre samo za logično negativno reakcijo, ko homoseksualci hočejo nekaj kar jim ne pripada.
A ni zanimivo kako USS in ostali z veseljem spregledajo to, da so večinoma tisti otroci že rojeni... enemu od teh homoseksualcev?
Mislim, da bi kak muslimanski fundi imel precej podobnega za povedat o marsičem "zahodnem"
Ja, nekateri že ploskate, kako bodo muslimanski fundiji končno postavili stvari na svoje mesto na dekadentnem zahodu.
Temu se reče "selektivna bralna slepota". Zanjo je značilno to, da oboleli ne zmore sprocesirat stavkov in besed, ki rušijo njegova prepričanja in nima odgovora nanje.
dbevfat ::
USS Liberty je izjavil:
Ti, kot zdrav primerek svoje vrste, imaš torej pravico odločati, kaj komu pripada? A ženskam pripada volilna pravica? Pa črnci se lahko vozijo spredaj na avtobusu? Btw, kakšne žaljive provokacije homoseksualcev?
Povsem narobe si razlagaš argument pijanih in nasilnih heteroseksualcev, zato pa si tako paranoičen. V bistvu se mi zdi, zanalašč izkrivljaš protiargumente. Nikakor nihče ne trdi, da so kar vsi heteroseksualci neprimerni starši in vsi homoseksualci idealni in ne vem, kaj še. Gre za vašo trditev: dva heteroseksualca se lahko poročita in imata otroka, ker je to zgledna družina, homoseksualca pa ne, ker to ni zgledna družina. To je argument, s katerim vi želite racionalizirati svoje predsodke. No, ta argument se enostavno izpodbija s tem, da pokažeš na cel kup heteroseksualnih družin, ki niso zgledne (alkoholizem je resen problem v družinah, nasilje prav tako) in jih je pri nas vse polno (nikakor to ne pomeni, da so vse, niti večina!), hkrati pa pokažeš, da obstajajo homoseksualci, ki takih problemov v svoji družini ne bi imeli (spet: to ne pomeni vsi). Point: družina ni kar avtomatično zgledna, če je heteroseksualna, in avtomatično slaba, če je homoseksualna. Lahko imaš slabe starše heteroseksualce in dobre starše homoseksualce. Poudarek na LAHKO IMAŠ, kar ni isto kot VSI SO. Razumeš? Gre za prav enostavno logično spodbijanje napačnih trditev, nič drugega. Mi je prav žal, da moram razlagati osnovne mehanizme argumentacije in protiargumentacije, namesto, da bi se osredotočal na vsebino, ampak če ne razumeš, sem ti lepo razložil.
nvr2fat
ahac ::
Pa saj nekateri so se parili z osebni nasprotnega spola. Zato pa imajo otroke. Zdaj bi pa radi, da imajo njihovi otroci tudi uradno še enega atija ali še eno mamico.
imagodei ::
> "Heteroseksualci smo tisti, ki dejansko prispevamo, da se rojevajo naslednji rodovi, da družba obstane, smo tisti, ki otroke dejansko ustvarjamo, jim od malega brišemo riti, jih hranimo, vozimo v šolo, se marsičemu tudi odrekamo, samo zato, da bi našim otrokom bilo lepo,"
Ma ja... Sej si tisti homoseksualci, ki želijo posvojiti otroka, tudi želijo točno to. Previjat in brisat otroške riti, jih vozit v šolo, se odrekat. Najbolj debilno pri celi stvari je pa to, da ne sprevidite, da se to že itak dogaja, ne glede na to, ali drugi homoseksualni partner lahko posvoji otroke prvega ali ne.
Hudič je v detajlih, seveda. Predvsem ko je treba urejat pravne zadeve.
Gandalfar ::
No daj. Odgovori na vprasanje. Lahko tudi druge aspekte vkljucis v ekonomsko analizo. Ni to tisto kar je najbolj pomembno na koncu?
Double_J> Sej to je jasno... par let ga bodo spraševali, iz čigave riti je prilezel. Potem bo fental ali pedra, ali pa sebe.
Samo če bo imel tako zarukane starše, kot si jih glede na projekcijo očitno imel ti. Če ga bodo starši znali potolažiti, mu razložiti situacijo (in to homoseksualne družine statistično gledano opravljajo _bistveno_ bolje kot heteroseksualne, ker v homoseksualnih družinah pač ni prostora za debilne tradicionalistične paradigme kot so "otroka je treba pustit jokat" in "otrok se mora sam ubranit pred družbo", ki znanstveno dokazano, s kontrolnimi skupinami in vso ostalo znanstveno navlako, otroku pustijo približno enake posledice kot odraščanje v romunskih sirotišnicah), ga bo tako šovinistično sranje precej manj prizadelo.
USS Nimitz> Homoseksualci imajo čisto vse pravice kot vsi ostali v tej družbi, tudi otroke lahko delajo, če jim to paše.
Ampak ko otroke enkrat naredijo, ti otroci nimajo dveh staršev (in jih po zakonu sploh ne morejo dobiti). Pomislite na otroke, kakšne travme imajo, ko jih v šoli zafrkavajo, "če ti napačnga avto zbije, te bojo poslal v državno oskrbo, hahaha!", čeprav otrok ima dva ljubeča starša, od katerih sta oba sposobna skrbeti zanj.
- spremenilo: jype ()
imagodei ::
jype> "pač ni prostora za debilne tradicionalistične paradigme kot so "otroka je treba pustit jokat""
Offtopic: Well, odvisno, zakaj se otrok dere. Če se dere, ker mu ne pustiš 300 EUR vrednega GSM aparata metat v tla, potem naj se kar dere. In če bo zaradi takšnih prepovedi imel travme, primerljive z odraščanjem v romunskih sirotišnicah, naj me kar vrag pocitra.
imagodei> Če se dere, ker mu ne pustiš 300 EUR vrednega GSM aparata metat v tla, potem naj se kar dere.
Nope. Če je histeričen, potem seveda počakaš, da se neha dret, ko se pa pomiri pa razložiš v besedah, ki jih razume. Težko je, ampak če ne zmoreš, bo najebal otrok (pa GSM aparat tudi).
imagodei> In če bo zaradi takšnih prepovedi imel travme, primerljive z odraščanjem v romunskih sirotišnicah, naj me kar vrag pocitra.
Ne, tega ne trdim. Otroka, ki ga _vedno_ pustiš jokat (kot je pri nas še vedno pogosta navada, ki temelji na tradiciji in nasvetih naših staršev in starih staršev), močno depriviligiraš, saj mu na zelo naraven (in ekološki!) način administriraš elektrošoke, ki inhibirajo sinaptične povezave v možganskih centrih, ki eventuelno pomagajo pri nadzoru nad odzivom na čustvene dražljaje, močno pa ojačajo dražljaje, ki sprožajo reakcije v tistih možganskih centrih, ki so sorodni s centri za preživetje v možganih nižje razvitih živalskih vrst (in orkestrirajo delovanje t.i. fight or flight mehanizmov in paralize, podobne spalni). Trening, ki takšne sinaptične povezave spreminja, je zelo težaven in naporen (zato praktično ni upanja, da bi bili določeni sodelujoči v tej temi sposobni dovolj empatije, da bi razumeli, čemu si homoseksualni partnerji tako močno želijo pravic, ki bi jim v sodobnem svetu omogočale skrbeti za otroka, da so pripravljeni mirno prenašat verbalno nasilje in tisočkrat ponoviti svoje stališče).
ahac ::
Ko ga enkrat razvadiš tolk, da resno pričakuje GSM aparat za 300€... je verjento že mal prepozno.
energetik ::
V takih primerih naj se samo pravno uredi, da lahko tudi drugi partner obišče otroka v bolnišnici oz. da lahko otrok podeduje po njem. Nekako kot sedaj v zunajzakonskih skupnostih. To je logično, da če ima eden od partnerjev svojega otroka, da naj ta partner še naprej skrbi zanj, ker je verjetno otrok navezanj nanj. Ni pa logično, da lahko 2 "atija" posvojita kar tako nekega tujega otroka. Otrok potrebuje tako zgled moškega kot ženske - vsak da nekaj otroku. Samo 2 moška ali samo 2 ženski pač ne moreta ponuditi take vzgoje otroku, kot mu lahko hetero starša. Po definiciji ne moreta, ker istega spola. Morebiti bi pa z zvezo 2 moški in 1 ženske oz. 2 žensk in 1 moškega šlo. Poznam vsaj 2 človeka, ki sta imela že od zgodnjega otroštva mamo samohranilko - oba sta na nek način malo posebna. Nekaj jima manjka, in to je oče.Nobenega sovraštva ni... gre samo za logično negativno reakcijo, ko homoseksualci hočejo nekaj kar jim ne pripada.
energetik> Samo 2 moška ali samo 2 ženski pač ne moreta ponuditi take vzgoje otroku, kot mu lahko hetero starša.
Skratka, samohranilkam je treba otroke odvzet in jih dat v rejo družinam, kjer so "take" vzgoje lahko deležni?
energetik> Poznam vsaj 2 človeka, ki sta imela že od zgodnjega otroštva mamo samohranilko - oba sta na nek način malo posebna. Nekaj jima manjka, in to je oče.
Al pa še ena mamica? Ne? Hecno, da se znanost, ki ne temelji na anekdotah, predsodkih in tradiciji, s tem ne strinja - statistično gledano so otroci iz homoseksualnih družin dejansko deležni bistveno širšega spektra vzgojnih elementov, pa še zelo pogosto jim je prihranjena ideološka indoktrinacija na podlagi predsodkov v političnih in verskih organizacijah.
energetik ::
Nisem tega napisal. Sigurno je bolje, da otrok ostane pri samohranilcu/ki (ki je to postal s smrtjo, ločitvijo itd), kot da se ga da nekam v rejo. Tudi če ta samohranilec/ka potem postane homoseksualec.
Ni pa to optimalno. Prav tako ne popolnoma normalno, kot nekateri razglašate. Dejtvo je, da otroku smrt/ločitev/... staršev škodi, že zaradi tega ni optimalno.
Pri primeru, da ima eden od homoseksualnih partnerjev otroka že iz prejšnjega zakona in recimo umre, bi pa jaz postopal tako, da bi ta partner postal njegov rejnik v določenih pogojih (da se otrok strinja, da so živeli v skupnem gospodinjstvu N-let itd). Ne more pa postati njegov starš.
imagodei ::
jype> "Ne, tega ne trdim. Otroka, ki ga _vedno_ pustiš jokat (kot je pri nas še vedno pogosta navada, ki temelji na tradiciji in nasvetih naših staršev in starih staršev), močno depriviligiraš, saj mu na zelo naraven (in ekološki!) način administriraš elektrošoke, ki inhibirajo sinaptične povezave v možganskih centrih, ki eventuelno pomagajo pri nadzoru nad odzivom na čustvene dražljaje, močno pa ojačajo dražljaje, ki sprožajo reakcije v tistih možganskih centrih, ki so sorodni s centri za preživetje v možganih nižje razvitih živalskih vrst (in orkestrirajo delovanje t.i. fight or flight mehanizmov in paralize, podobne spalni) ... ... ..."
Zelo strokovna razlaga, ni kaj. S povedanim se lahko seveda samo strinjam. Želel sem predvsem izpostaviti drugo skrajnost, ko današnji moderni starši otrokom ne znajo postaviti meja in z njimi "parlamentirajo" že od najbolj nežne starosti dalje, pustijo pa jim praktično da se "obešajo iz lustra", samo da ni trmarjenja in joka.
ahac> "Ko ga enkrat razvadiš tolk, da resno pričakuje GSM aparat za 300EUR... je verjento že mal prepozno. "
V mislih sem imel manjše otroke... Npr. mlajše od dveh, treh let, ki se jim jako fino zdi igrati z mobilci od staršev, pri tem pa jim le-ti vztrajno padajo po tleh. Videl sem že tudi primere, ko so otroci te starostne skupine kar tako, "zaradi lepšega", metali mobilce v tla. Starši pa jim kar pustijo igrati se z več 100 EUR vredno napravo, ker pač "otrok potem da mir, drugače pa trmari" (vsaj tako pojasnjujejo). Kakšna vzgoja je to, mi ni jasno.
energetik> Pri primeru, da ima eden od homoseksualnih partnerjev otroka že iz prejšnjega zakona in recimo umre, bi pa jaz postopal tako, da bi ta partner postal njegov rejnik v določenih pogojih (da se otrok strinja, da so živeli v skupnem gospodinjstvu N-let itd). Ne more pa postati njegov starš.
Razumem, da to koristi tebi in tvojim predstavam o svetu, ne razumem pa, zakaj se tebe (in zakona) to sploh tiče. Lahko to utemeljiš?
energetik> Ni pa to optimalno. Prav tako ne popolnoma normalno, kot nekateri razglašate.
Po tej poti stopaj izjemno previdno - odraščanje otroka v preobilju (po mnenju mnogih) ni normalno in ni optimalno, zato bi bilo smiselno premožnim staršem (po mnenju mnogih) odvzeti premoženje za čas, v katerem otrok odrašča.
Razumeš?
Razumeš?
dbevfat ::
Pred časom ni bilo normalno, da so se črnci lahko vozili spredaj na avtobusu. Pa da so ženske volile. Mnogim družbam se že zdaj ne zdi.
nvr2fat
energetik ::
Po tej poti stopaj izjemno previdno - odraščanje otroka v preobilju (po mnenju mnogih) ni normalno in ni optimalno, zato bi bilo smiselno premožnim staršem (po mnenju mnogih) odvzeti premoženje za čas, v katerem otrok odrašča.Marsikomu bi bilo pametno odvzeti kar otroka, problem je samo, ker bi bilo to totalitaristično dejanje, ki bi se lahko hitro sprevrglo v kaj hujšega. S tega vidika razumem.
Razumeš?
Pred časom ni bilo normalno, da so se črnci lahko vozili spredaj na avtobusu. Pa da so ženske volile. Mnogim družbam se že zdaj ne zdi.Še enkrat - tega se ne da enačiti. Ampak otrok je domena hetero skupnosti, zaradi samega dejstva, da drugače ne more nastati. To, da otroka pač vzgaja samohranilec/-ka, magari v istospolni skupnosti, ali pa tudi heterostarši, ki so nezmožni vzgoje iz različnih vzrokov, to je pač neoptimalen slučaj, ki ga je potrebno tolerirati.
Da bi pa zavestno dajali v posvojitev otroke homoseksualnim parom, se mi zdi pa skregano z naravo in logiko.
Še enkrat - noben od tukaj pisočih nikakor ne stigmatizira homoseksualcev, razen s stališča posvojitev.
- spremenilo: energetik ()
Otrok potrebuje tako zgled moškega kot ženske -Energetik, tudi ti očitno ne veš, da zakon ne prepoveduje samski osebi posvojiti otroka. V zakonu piše:
Nihče ne more biti posvojen od več oseb, razen če sta posvojitelja zakonca.
Lahko si torej posvojen od ene osebe, in ta oseba je lahko gej. Do tu vse lepo in prav. Zatakne se pri zakoncih, ker dva geja ne moreta biti zakonca, zaradi enega drugega člena, ki pravi:
"Za sklenitev zakonske zveze je potrebno, da dve osebi različnega spola izjavita ..."
Iz tega člena je potrebno črtati "različnega spola" in je vse urejeno.
O.
Še enkrat - noben od tukaj pisočih nikakor ne stigmatizira homoseksualcev, razen s stališča posvojitev.Da se ne boš v jezik vgriznil. Eni recimo razlagajo, da geji ne bi smeli po šolah širiti svoje "propagande". Ali pa da je ne bi smeli širiti po medijih. Tudi parade ponosa gredo nekaterim močno v nos, ker kalijo njihov duševni mir.
Prišli smo samo tako daleč, da večina vsaj javno izjavlja, da proti pedrom nimajo nič, dokler svojo "dejavnost" opravljajo na skrivaj pri sebi doma. Vse, kar je več od tega, pa marsikoga moti dovolj, da je to pripravljen tudi javno povedati.
O.
energetik ::
Če je res, da po šolah in vrtcih razlagajo tole:
saj trdijo, da ima človek pravico, da si sam izbere spol oz. ima pravico tudi do nespola oz. do spolne neopredelitve: »Zapomnimo si, da je spol nekaj, kar moramo imeti pravico ter možnost ustvarjati sami in ne po nareku naših genitalij, ki naj bi silile človeka biti ženska ali biti moški!« »Podobno kot spol ni vnaprej določeno ali samoumevno dejstvo ob rojstvu in ga moramo imeti pravico opredeliti sami ali ga spremeniti, velja isto za spolno usmerjenost
potem je to dejansko škodljiva propaganda, ki se ne bi smela širiti povrtcih in OŠ.
Škodljiva zakaj? Ker uboge nedolžne otročiče uči, da ni nobena stvar od boga dana, in da je vsak svojega telesa gospodar?
O.
O.
energetik> Če je res, da po šolah in vrtcih razlagajo tole:
Kaj si ti misliš? Da je res, ali da je zgolj nek tradicionalist (najbrž vernik) zblaznel, ko mu je otrok povedal, da so v šoli v okviru pouka o človekovih pravicah razpravljali tudi o različnih oblikah spolnosti in kako to kljub jasnim določilom v ustavi in splošni deklaraciji o človekovih pravicah še vedno močno vpliva na te pravice?
energetik> potem je to dejansko škodljiva propaganda
Ja? Na kakšen način škodljiva?
energetik ::
Ja, na nevtralen način razložiti, da obstajajo tudi drugačne spolne usmeritve, ki so neke vrste deviacija, to že; druga stvar je pa dobesedno učiti malčke, kako je povsem običajno če si dajo odrezati določene organe. Heh, še celo srednjega spola lahko ratajo, če se jim zalušta...
Nekaj je samo poučitev o dejstvih, drugo pa je tupiti jim v glavo, da so take deviacije nekaj normalnega. Ne morejo biti, ker take deviacije ne podpira evolucija.
Ne morejo biti, ker take deviacije ne podpira evolucija.Če jih ne bi podpirala, jih ne bi bilo. Evolucijo notri mešati je itak mimo. Ljudje se diktaturi svojih genov lahko upremo.
V glavnem, energetik, tudi ti si očitno eden od tistih, ki ima v resnici probleme z geji, čeprav tega nočeš priznati, in ki bi moral najprej stvari povsem razčistiti pri sebi, potem pa se šele vmešavati v življenja drugih.
O.
dbevfat ::
Meni se zdi precej podobno. Volilna pravica je bila nekoč domena moških in ravno tako so takrat obstajali goreči zagovorniki tega, da mora tako ostati, drugače bo konec sveta. In ne mešaj spočetja otroka z vzgajanjem. Če heteroseksualni par ne more spočeti, se mu nudi pomoč, če želita posvojiti, imata možnost. Kljub temu, da par ne more spočeti otroka, tako kot ga ne morejo homoseksualci po "naravni" poti.
Torej zdi se ti ok, da toleriraš "neoptimalne slučaje", ne pa, da bi kakšnemu otroku lahko zagotovil boljše pogoje, kot jih ima? Recimo odraščanje v homoseksualni družini proti odraščanju v sirotišnici?
Kot prvo, z logiko ni skregano. Mogoče imaš napačno predstavo o tem, kaj je logika, ampak gre za zelo natančno definirano miselno orodje in v vsem tem ni nikjer nobenega logičnega nesosledja.
Kot drugo; zakaj postavljaš mejo, kaj je skregano z naravo? Zdravila so skregana z naravo. Če daš paraplegiku voziček, delaš "proti naravi". Če ti zamenjajo notranji organ in pravzaprav že plombe v zobeh - to je vse skregano z naravo. Mobiteli in računalnik tudi. Ne bluzi s tem, kaj skregano z naravo, ker smo se z njo (če jo pojmuješ kot nek okvir, izven katerega si "skregan") že zdavnaj skregali. Če pa pojmuješ kot to, kar je, potem pa smo v celoti rezultat narave, prav tako pa tudi vse, kar naredimo.
nvr2fat
Vajenc ::
Namišljenim borcem za človekove pravice je nemogoče razjasniti sliko, ker je namišljeno prav vse v kar "verjamejo".
Gejem svojo "dejavnost" doma ni potrebno skrivati, ravno tako kot jo ni potrebno javno razkazovati, ker je to v bistvu prepovedano tudi heteroseksualcem.
Heteroseksualec se socialni delavki ne predstavi po imenu, priimku in spolni usmerjenosti. In tako bi moralo biti tudi za geje. In če je človek gej, pač ne more uživati vseh "privilegijev" strejta in obratno seveda. Če dokažejo, da je homoseksualnost prirojena, bi zadevo z mojega vidika malo spremenilo, ampak ne tako bistveno, da bi se začel boriti za posebne pravice gejev. Gejevske zahteve po izenačitvi njihove zveze s hetero obliko zaobljube je zame podobno, kot bi slep človek zahteval, da se ostali, ki dobro vidijo, izenačijo z njim tako, da tudi oni oslepijo.
Povdarjate, kako geji že imajo svoje otroke, po drugi strani pa razlagate kako, da geji ne morejo drugače do otrok, kot, da se poročijo po starih običajih z novo vsebino in s tem dobijo blagoslov za posvojitev.
Woody Allen
Woody Allen
Vajenc> Povdarjate, kako geji že imajo svoje otroke, po drugi strani pa razlagate kako, da geji ne morejo drugače do otrok, kot, da se poročijo po starih običajih z novo vsebino in s tem dobijo blagoslov za posvojitev.
Ti mešaš prazne protiargumente nasprotnikov sprememb zakonodaje z argumenti strani, ki se zavzema za to, da zakon ne sme različno obravnavati ljudi na podlagi katerekoli osebne okoliščine (med katere spadajo spol, spolna usmerjenost in barva oči).
Vajenc> ker je to v bistvu prepovedano tudi heteroseksualcem.
Ne, ni jim. Geji (vsaj kolikor jaz vem) v javnosti ne izvajajo spolnega občevanja, s shodi pa, tako kot delavke v muri, legalno opozarjajo na svoj položaj, zoper katerega ne morejo storiti ničesar, dokler se zakonodajalec ne zresni (kar se ravnokar dogaja).
dbevfat ::
Hahaha, kje le vidiš podobnost v tej primerjavi? Še enkrat razmisli, potem pa poizkusi odgovoriti na vprašanje: kaj izgubijo heteroseksualci, če geji pridobijo pravico do poroke in posvojitve? Pa res si vzemi par minut, preden odpišeš, me prav zanima tvoj odgovor. :D
nvr2fat
Vajenc ::
Edinstvenost poroke in obliko družine ata, mama, otrok.
Edit, za boljše razumevanje. Vprašanje oz. skrb je, kaj prinese tak poseg v bistvo moderne človeške reprodukcije.
Woody Allen
Woody Allen
- spremenilo: Vajenc ()
Vajenc> Edinstvenost poroke in obliko družine ata, mama, otrok.
Me zanima kolk ljudi matra dejstvo, da imajo enako obliko zakonske zveze kot Hitler, Mao, Stalin in Pol Pot.
Vajenc> Edit, za boljše razumevanje. Vprašanje oz. skrb je, kaj prinese tak poseg v bistvo moderne človeške reprodukcije.
Popolnoma ničesar, ker se človeška reprodukcija ne spremeni na noben način. Država že itak ne posega kaj dosti v reprodukcijo, ker ne more, vse kar se dogaja (pa se včasih ni) je zdravljenje neplodnosti in zunajmaternične (in vitro) oploditve.
Vse, kar država skuša, je olajšati odločitev za snovanje družine, pri čemer spol partnerjev dejansko nima opaznega vpliva na odraščanje otrok v taki družini, zato tudi ni ustrezno, da obstaja diskriminacija med različnimi oblikami družine.
dbevfat ::
Predvidevam, da misliš resno. Torej govoriš o osebnih idealih, ker heteroseksualna družina popolnoma nič ne izgubi, če se par ulic stran poročita dva geja. Kaj misliš, da se heteroseksualnemu zakonskemu paru zdi potem njuna poroka manj vredna, ker jo lahko imajo tudi geji? A se poročita zato, ker ju to na nek način elitizira, ali kaj? A imata kaj manj rada svojega otroka in on njiju? Je njihova družina res kakorkoli na slabšem? Saj pa oni vendar še vedno imajo obliko družine ata+mama+otrok, njim se to prav nič ne spremeni.
nvr2fat
Vajenc ::
Drži, če bi bili sami geji že prej, naštetih diktatorjev ne bi bilo.
Nekako logično je deliti ljudi na dobre in manj dobre. Nelogično pa jih je deliti na geje in manj geje. Gej je ravno tako lahko dober ali slab človek. Težko pa je gej dober starš, tako kot je slep človek težko dober fotograf.
Woody Allen
Woody Allen
| » | "Sovražni govor" oziroma cenzura (strani: 1 2 3 4 5 6 )Oddelek: Problemi človeštva | 19277 (10100) | riba43 |
