Osebni server in bnc-ji
Mulc ::
Imam star računalnik, povezan z routerjam in adsl-jom. Nanj sem namestil linuxe, zradi željenih zahtev. Postavil bi ftp server in bnc-je. Zanima me kako to narediti, po možnosti brez apačija. Prosim za bolj natančen postopek, saj sem čisto nov v tem. (kako se bncje naredi???)
Prosim da odgovarjajo samo resni.
CCfly ::
Za ftp si moraš naložiti proftpd in ga skonfigurirati.
Povej kateri linux (pazi tisti e na koncu je občutljiva zadeva, kmalu te bo nekdo nadrl zaradi njega) si si naložil, potem pa ti lahko pomagamo naprej. Enako velja za bnc.
Mulc ::
Ja imam MandrakeLinux 10 al neki tazga. Dons sm inštaliru pa obkljukal vse možnosti (za ftp server). Zanimajo me bolj natančna navodila.
CCfly ::
Si pogledal kateri ftp strežnik si si namestil ?
Bolj natančna navodila ti bo moral dati kdo od Mandrake-ovcev.
Tukaj imaš pa še primer konfiguracijske datoteke za anonimni ftp strežnik (proftpd).
# This is a basic ProFTPD configuration file (rename it to
# 'proftpd.conf' for actual use. It establishes a single server
# and a single anonymous login. It assumes that you have a user/group
# "nobody" and "ftp" for normal operation and anon.
ServerName "CC lair"
ServerType standalone
DefaultServer on
RequireValidShell off
AuthPAM off
AuthPAMConfig ftp
# Port 21 is the standard FTP port.
Port 21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask 022
# To prevent DoS attacks, set the maximum number of child processes
# to 30. If you need to allow more than 30 concurrent connections
# at once, simply increase this value. Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd).
MaxInstances 30
# Set the user and group under which the server will run.
User proftpd
Group proftpd
# A basic anonymous configuration, no upload directories.
<Anonymous /home/ftp>
User ftp
Group ftp
# We want clients to be able to login with "anonymous" as well as "ftp"
UserAlias anonymous ftp
# Limit the maximum number of anonymous logins
MaxClients 10
# We want 'welcome.msg' displayed at login, and '.message' displayed
# in each newly chdired directory.
#DisplayLogin welcome.msg
#DisplayFirstChdir .message
# Limit WRITE everywhere in the anonymous chroot
<Limit WRITE>
DenyAll
</Limit>
</Anonymous>
CCfly ::
Aja datoteka je v /etc/proftpd/proftpd.conf. Ko boš zagnal strežnik bo prebral nastavitve iz te datoteke.
Mulc ::
Hm ja dobr kt bi to vedu kaj mislš, pa kva narest u čem. A se to ne da po slovensk povedat bl podroben kt še ne znam tolk?
CCfly ::
Prvo poglej kateri strežnik za FTP si dal gor.
pivmik ::
Fora Linxa je da nikjer ne boš našel podrpobnih ali specifičnih navodil.
Samo na splošno piše, cele manuale, dokumentacije in helpe boš moral predelat, da boš znal naredit tiste 3 ukaze, ki so bili za tvojo zahtevo potrebni.
Ena stvar več zakaj Linux sux na Desktopu.
LP, Gregor GRE^
CCfly ::
Če te moti pisanje v tekstovno datoteko in si sploh ne moreš predstavljati življenja brez grafičnega vmesnika:
http://mange.dynup.net/linux.html#Screenshots
kihc ::
x
Jebiveter ::
Jao!:\
1. "Gremo postavit en server pa dat gor linuxe, pa ftp server, pa bncje,..."
2. "Ja, kako bos pa to naredu? A poznas linux?"
1. "Sej, linuxe instalirat ni problem, ostalo mi bodo pa na forumu povedali."
2. "Zakaj pa sploh potrebujes bnc?"
1. "Zato, ker sem 1337 ker bom imel server z linuxi in gor bncje in bom p0wnal na ircu!":( :( :( :( :\
Mulc, 3 nasvete imam zate:
1. Primi v roke kaksno knjigo o linuxu za zacetnike - pobrskaj v knjiznici, tega je kr dosti.
2. Nauci se anglesko, mnogo stvari v how-to-jih ti bo postalo mnogo hitreje jasno.
3. Nauci se uporabljat slovenscino. Besede "routerjam in adsl-jom." ter "apačija" niso ravno vzor le-te.
PS: Linuxi ne obstajajo! Obstaja samo en linux ter vec linux distribucij...
PicNiK: Niti ne. Sux samo za tiste, ki jim je MS opral mozgane. Probaj posadit dva popolna racunalniskega analfabeta, enega za Windows drugega pa Linux masino. Vsakemu daj po 3 knjige za zacetnike in Google. Stavit bi sel, da enega "300-klikov" in enega "1-how-to-in-1-vrstica-kode" userja, pri istem opravilu seveda. Pri naslednji ponovitvi istega opravila bos pa imel spet "300-klikov", na drugi strani pa "1-vrstica-kode". In tukaj lahko govorimo o cisto vsakdanjih opravilih. Ampak to je ze OffTopic (se opravicujem).
Certainty of death. Small chance of success. What are we waiting for?
  • spremenilo: Jebiveter ()
Sploh je pa v tej temi govora o serverjih, tako da je Picnik ne samo v zmoti ampak tudi offtopic.
pivmik ::
Čudno meni Linuxi suxajo, pa mi M$ ni množganov opral.
Na Desktopu uporabnik ne naredi dvakrat teh 300 klikov, ker to je desktop.
300 klikov pa v praksi ni, ker če je zadeva zakomplicirana se pojavi na desktopu(win) nov program s katerim narediš spet samo s par kliki.
Če pa ne obstaja program pa plača mazohista ki ima znanje in bo naredil to namesto njega - se mu bolj splača kot pa sedet in se j*bat za računalnikom in brat knjige in zgubljat cajt. Folk na desktopu ima bolj pomembne reči za delat kot pa se pustit j*bat u glavo by the računalnik, raje grej brcat žogo, spit pijačo ali v kino.
A ti si moral prebrati kako deluje motor od avta, da si lahko začel vozit? NE!
Samo interface si se naučil in si znal vozit.
Očitno pa Linuxaši ne znajo/niso zmožni vozit avta ne da bi vedeli točno delovanje njega.
LP, Gregor GRE^
CCfly ::
Mi to imenujemo skripta. Podobna zadeva samo neprimerno močnejše orožje.
Govorimo o ekonomiki ?
Govorimo o strežnikih ali o uporabniških vmesnikih ?
Je to pohvala ali bodica ?
b ::
Kaj pa vem, mene je zmeraj zanimalo kako stvari delajo. In definitivno sem prej vedel kako avto deluje, kot pa znal vozit. Hudica, se presraufal sem en kup avtov, preden sem znal vozit.
Mulc ::
Hm glede linuxov nasploh, sicer sem navajen na splošno uporabo linuxov, le da sem mel prej preizkusno različico linoxov, ki sem jo brez težav pogruntal (osnovne stvari). Tole s serverjam pa ni kar tako. Če je apači res najboljši server in najlažji za postavit, kako pa se to potem naredi. Kaj priporočate?
Fukomuko ::
linoxov, apači...:\
Preberi dokumentacijo. Apache ni ravno tezak za nastaviti, vseeno pa moras prebrati navodila. Nihce tu ti ne bo napisal kaj vse moras napisati ukaz za ukazom. Ce se bos potrudil in prebral navodila, ti bo uspelo. Ce ti ne bo ti bo gotovo kdo tu pomagal. Ce bos pa spraseval v stilu: Nic ne znam, dejte mi vse povedati, bos pa zelo zelo dolgo cakal.
Pa pravilno pisi linux, apache,...
Picknik
Seveda, ce ne isces ne najdes.
Protislovje?
Sploh pa ne vem kaj se sekiras, ce si zadovoljen kot nezahteven uporabnik, ki mu sede klikati in placevati ljudi za vsako stvar, ki je ne znas narediti z manj kot 10 kliki.
  • spremenil: Poldi112 ()
pivmik ::
Jazst nisem nezahteven uporabnik. A sem kdaj to napisal? A sem?!
Če že obstajajo slučajno kaka navodila jih težko najdeš, ali pa rabiš met še pririočnik za ta navodila.
Nezahteven uporabnik pa valda ne bo plaleval drugega da gleda po porničih.
LP, Gregor GRE^
To da si nezahteven uporabnik sklepam iz tega, da ugotovis da Linux sux, ceprav ga ocitno nikoli nisi konkretno pogledal. In po tem da ti ne uspe najti navodil. Dokumentacija v veciji primerov je zakon. Imas tudi step by spet tutoriale pa prakticno vse aplikacije.
S takimi spet by step navodili sem jaz postavil routing, iptables (firewall), ftp, apache in kompleten desktop. Ko reces: "Očitno pa Linuxaši ne znajo/niso zmožni vozit avta ne da bi vedeli točno delovanje njega." mi ni jasno kaj hoces povedati. A mogoce rabis kaj vec znanja za instalirat in/ali uporabljat Fedoro, Mandrake, ST-Linux,... od znanja, ki ga rabis za winxp? Ok, jaz sem zdaj na gentoo, ga je tezje instalirat, ga je pa zato kasneje lazje vzdrzevati. Bistvo je v tem, da imas moznost, ce zelis, da pogledas pod havbo. Ne vem zakaj te to moti?
Mulc ::
Ja glede Apache pa Linuxov, sem drugače že iskal navodila. Po jokerju, sem našel ogromno koristnih informacij. Za Apache pišejo točna naodila, za programiranje serverja. Ker vem, da ste na forumu sami profesionalci, sem sklenil, da vprašam rajši vas.
No, potem poskusi najprej po navodilih iz jokerja, ce se ti bo pa ustavilo pa vprasaj tu, pa malo bolj opisi problem (kateri linux, kateri ftp server, kaksna napaka, kaj si ze sam poskusil,..)
Pa veliko srece.
Gandalfar ::
kaksen Apache Overview Howto ne bi bil slab zacetek
CaqKa ::
ona navodila v jokerju so ful čudna.
picnik in ostala pro linux grupa: TIHO
bejžte v drugo temo.
vse nadalnje offtopic odgovorebrišem.
advanced userji pa se dajte zamislit, če je res vredno ves čas eno in isto tumbat, nebi raje ta čas za pravili.. pa nemara za pijačo :)
  • spremenil: CaqKa ()
Mulc ::
Hm, to s linuxi sem opustil, sedaj sem naložil gor Windows 200 server gor. Naredil sem že nekaj funkcij pa teh stvari za server, a mi skos neke napake javla, dal sem že gor apache, a nikjer ne najdem nobene .exe ali podobne datoteke, ki bi ahko zagnala program, ja napačen fajl?
Microsoft ::
Ce ne bos napisal (al pa dal slike) tocno za kako napako gre, lahko se napises mali miljon postov, pa se ne bo premaknilo niti za milimeter.
by Miha
Mulc ::
Hm, težava je odpravljena.. Iz težave v novo težavo :D. Une userje sem že naredil, znaima pa me kaj morm kliknit da se skonektam, in kakšen je moj ftp naslov, če hočem iz drugje pogledati fajle.
Microsoft ::
Tvoj FTP naslov je lahko recimo ftp://193.179.134.256/Britni_spirs_nude.jpg. Lahko pa tudi kar ftp://193.179.134.256, pa bos videl vsebino.
BTW, ce mas se firewall, potem mores ponavadi pustiti porta 20 in 21, da bo FTP delal.
by Miha
p.s.:256 sm dal zato, da ni bi res od koga napisal IP. :)
Screamboy ::
ok z ukazom ./psybnc sem zagnal bnc kako ga pa killan?
CCfly ::
killal psybnc
Drugič pa uporabi zagonske skripte:
/etc/init.d/psybnc start
/etc/init.d/psybnc stop
/etc/init.d/psybnc restart
"My goodness, we forgot generics!" -- Danny Kalev
Debian Gnu/Linux kot workstation (strani: 1 2 3 4 … 37 38 39 40 )
Oddelek: Operacijski sistemi
1960128015 (43689) RedDrake
clarkconnect rabim poomoč pri inštaliranju! (strani: 1 2 3 4 5 )
23018914 (10453) Gapi
ProtFtp Passive mode in iptables
Oddelek: Programska oprema
252688 (2510) SasoS
kako dolociti koliko baz, koliko prostora...
131640 (1463) Senzacionale
FTP strežnik
Oddelek: Omrežja in internet
182013 (1716) SubOrbit
