P2P anti-spam vtičnik za Outlook
SiOL - Danes sem na SiOLovi domači strani zapazil zanimivo novičko. Neki friki so se namreč odločili lastnosti P2P omrežji izrabiti za boj proti spamu (masovnemu pošiljanju elektronske pošte proti želji prejemnika) in tako smo dobili prvi P2P vtičnik za Outlook2000/XP. Vsak uporabnik ima namreč možnost določiti pošiljatelja za spammerja in ga s tem dodati na seznam teh zlobnih ljudi. To počnejo seveda tudi ostali uporabniki vtičnika in tako gradijo veliko bazo podatkov neželenih elektronskih naslovov. Pa kaj bi klobasali, najbolje je da si zadevo preberete sami in naložite dotični vtičnik. Če seveda sploh še uporabljate Outlook [:D].
3 komentarji
Jeebs ::
Outlook? A ja, sej res, to je tista stvarca k mi je pol leta nazaj delala sive lase.;( Nein danke! :(
Press any key to continue... RESET. Didn't you say ANY key?!?!?!
Uporabnik ::
neuporabno, pol pa en napiše npr @slo-tech.com in pol noben več ne dobi pošte iz slotecha
darh ::
To assure that you never lose email, no messages are ever deleted or blocked. If a message is identified as a known spam message, it is simply tagged as spam and moved to your Spam box. This process allows you to verify that all the messages in the Spam box are really spam.
Cloudmark SpamNet maintains the integrity of the pool of user-reported spam messages through its Truth Evaluation System (TES). Each SpamNet user is rated according to a number of factors including volume of spam reported, report accuracy and relevance. Simply, long-time, trusted-user reports carry more weight in spam identification than new, untested reports. When a SpamNet member makes a good report, their trust rating is increased. Occasionally, a trusted SpamNet user may incorrectly identify a legitimate message as spam. To resolve this rare problem, trusted spam reporters may also revoke incorrect submissions. This process removes the mistaken report from the system and reduces the mistaken-report member's TES rating.
kul...
Uporabnik.. mal preberi preden zines traparijo...
Excuses are useless! Results are priceless!
Širjenje trojancev s Facebook statusi
Oddelek: Novice / Varnost
148733 (6167) Elysium
Google Apps tudi brez povezave z internetom
2511537 (9829) hamax
RTVSLO MMC mutlimedija
92062 (1954) Izi
Ad-Blockerji - kraja?
Oddelek: Omrežja in internet
92800 (2579) poweroff
Razlozite nekaj glede varnosti na internetu
191841 (1580) Ziga Dolhar
