Razlaga timingov pri ramih...
SkyNet ::
Lepo prosim če bi bil kdo tako prijazen in mi razložil kaj je kateri od timingov pri ramih. CAS, T(RAS), T(RP) in T(RCD). In kateri izmed teh je najpomembnejši?
right minus opens, into bump easy left, flat out right, into mcdrive 3 bigmacs
boštjan ::
Precharge to Activate Latency: This setting relates to the rows in DDR. This setting deals with the delay between two states, the activate and precharge. Lowering it also improves performance.
RAS to CAS Latency: This setting controls the delay between the RAS command and the CAS command. Once again, lower is better.
CAS Latency: This term is otherwise known as Column Access Strobe delay. DDR ram can be described with columns and rows. A "strobe" is what finds the correct column or row of data. Therefore, the CAS latency is the delay between the chipset read command, and the time that the data becomes available. Lower is better!
RAS Precharge Latency: This last setting controls the number of idle clocks after issuing a precharge command.
Najbolj je važna CAS latency,čim bolj nižje je bolj hitri so rami
  • spremenil: boštjan ()
nadgradnja?
232160 (1682) gddr85
RAM povzroča "zrušitve sistema"!
152234 (1947) Pyr0Beast
navijanje voltaže rama
Oddelek: Navijanje
81354 (1271) dxx
časi na ramih (strani: 1 2 )
Oddelek: Navijanje
534787 (4012) Boki_
BIOS Nastavitve za Ram! KT7A
92471 (2350) MaD_Mavr0
