Phantom Blade Zero
Phantom Blade Zero
Gregor459 ::
Phantom Blade Zero - Year of the Snake Gameplay Trailer | PS5 Games
Engine Unreal Engine 5
Platform(s) PlayStation 5 in PC
Genre(s) Action role-playing
Mode(s) Single-player, multiplayer
The assassin Soul is framed for the murder of The Order's patriarch. He is fatally wounded in the manhunt that ensued, but a mystic healer manages to keep him alive with a cure that lasts for 66 days. With time running out, he must uncover the truth behind the conspiracy
Gregor459 ::
Phantom Blade Zero - Official Hellwalker Difficulty & Secret Duo Boss Battle Demo Gameplay
Phantom Blade Zero - Official Release Date Trailer
Igra izide 9 seprembra 2026.
Gregor459 ::
Phantom Blade Zero - Special Teaser Phantom Blade Zero releases September 9, 2026.
abiz ::
največji problem je to, da vam moram tiča v lape dat
no, tak tota slika xgleda:)
  • spremenilo: abiz ()
Gregor459 ::
Phantom Blade Zero: 11-Minute Extended Gameplay Trailer
Gregor459 ::
Phantom Blade Zero - Official PS5 Features Trailer 29 oktober.
Gregor459 ::
Phantom Blade Zero GAMEPLAY Impressions - I LOVE This GAME!
Gregor459 ::
Phantom Blade Zero - Official Launch Trailer čez 1 teden
dronyx ::
Kot kaže ima igra visoke ocene in na srečo ni spet nek soulslike z eno samo težavnostjo. Sem pogledal par ocen in se nekateri pritožujejo, da je celo prelahka tudi na najvišji težavnosti. Na srečo imajo bosi QoL, da če uspešno končaš prvo fazo, ponavljaš drugo, ne spet vse od začetka. To mi gre pri teh igrah najbolj na živce, da je ogromno nekega ponavljanja brez veze. To je zame samo izguba časa, ne izziv.
Predsednik11 ::
Aja ni souls kaj je potem bolj Ghost of tushima varjanta ?
Phantom Blade Zero | Reviews
10 - TheGamer
10 - PCGamesN
10 - SteamDeckHQ
9.5 - CGM
9.5 - PSX Brasil
9.5 - Dualshockers
9 - IGN
9 - GamePro
9 - RPGamer
9 - Press Start
9 - GamingBolt
9 - ScreenRant
9 - Push Square
9 - GamesRadar
8 - VGC
8 - Gamespot
6 - Eurogamer
Metacritic: 88
Opencritic: 90
Eurogamer ne mara Kitajskih iger.
Phantom Blade Zero -60/100
Black Myth: Wukong -60/100
Wuchang: Fallen Feathers -60/100
Dragon Age: The Veilguard 100/100 :)):)):)) važno, da so dali popolno oceno Failguardu.
  • spremenil: oo7 ()
dronyx ::
Predsednik11 je izjavil:
Po videnem ne bi rekel. Souls template, samo nižja težavnost in več akcije. Videti zelo dobro. Jaz sicer občasno preigram kakšen soulslike (nazadnje Valor Mortis), samo taka težavnost me dela živčnega, ker je vsaka napaka kaznovana (psihično se pripravljam za Mortal Shell 2, samo nisem še pripravljen za še eno soulslike).
  • spremenil: dronyx ()
JH84 ::
oo7 je izjavil:
10 - TheGamer
10 - PCGamesN
10 - SteamDeckHQ
9.5 - CGM
9.5 - PSX Brasil
9.5 - Dualshockers
9 - IGN
9 - GamePro
9 - RPGamer
9 - Press Start
9 - GamingBolt
9 - ScreenRant
9 - Push Square
9 - GamesRadar
8 - VGC
8 - Gamespot
6 - Eurogamer
Metacritic: 88
Opencritic: 90
Eurogamer je pa pravo woke gnojišče že par let, vsi ocenjalvci so "tisto" oz srednji spol.
jijetelu ::
dronyx je izjavil:
Mortal Shell 2 je lazji kot Valor Mortis. Ubistvu je lahko zelo zelo lahek.
Drugače pa škoda za Phantom, da ni težavnost nekako v rangu souls iger.
  • spremenilo: jijetelu ()
Gregor459 ::
jijetelu je izjavil:
dronyx je izjavil:
Za kaj težjega bo treba počakat na začetek 2027 Lords of the Fallen 2.
dronyx ::
Po moje ni nujno, da ima vsaka akcijska igra sedaj samo souls težavnost. Phantom bi po moje lahko imel še custom težavnost, kjer bi lahko nastavil posamezne parametre težavnosti. Recimo šefi brez checkpointov, respawn itd. Razumem pa, da je pri taki igri to nekoliko težje izvedljivo, ker je potem težko testirati vse možne scenarije. Meni je všeč to, kar so naredili pri Lies of P. Ob izzidu je igra imela samo souls težavnost in je bila vsaj zame po težavnosti kar dosti blizu Sekira, čez čas so pa s popravkom dodali še lažjo težavnost.
jijetelu ::
Glede same težavnosti iger je vedno veliko debate. Jst sem mnenja, da ima sama težavnost precejšen vpliv na samo izkušnjo igranja. Če igra ne nudi zadostnega odpora, da ima igralec sploh potrebo ali motivacijo, da izkoristi dodatne načine, bodisi z dodatnimi skilli, upgradi, consumables ipd... bo mnenje večine ljdui, da je igra enolična ali prazna.
Zelo lep primer ene take igre je Elden Ring, verjetno najbolj popularna in najbolj uspešna souls igra. Načeloma je Elden Ring smatran kot težka igra, ko pa dejansko dojameš celoten spekter, obseg igre, se pa vsi strinjajo, da je igra ena od najlažjih souls iger. Večina ljudi, ki so mnenja, da je Elden Ring težek, pač enostavno ni nikoli šla čez klasičen koncept igranja tovrstnih iger, torej prvo pametno orožje, ki so ga dobil in oklep, osnovne nadgradnje, mogoče kak urok, pa praviloma so vsi dojeli precejšnjo uporabnost Spiritov, po možnostni Mimika. Tak pristop k igranju postavi Elden Ring med sorazmerno težke souls igre ja. Če že odstranimo uporabo Spirtov, postane Elden Ring precej težji. Vendar sama igra ponuja cel prepad enih dodatnih opcij, od nenormalno veliko urokov, do uporabe consumables, od katerih nekateri povsem trivializirajo posamezne bosse, tudi najtežje bosse v igri. Upoštevajoč samo kakšno 1/3 vsega, naredi igro trivialno lahko, za katero sem prepričan, da jo je vsak normalen človek sposoben preigrati brez nekih posebnih težav in trme.
Lies of P, tak kot je prišel ven ob izidu, ne omogoča niti približno takšne širine igranja, in za določene težke stvari v igri, pač ni bilo drugega, kot postati dovolj dober, zato pri taki igri definitivno ima smisel uvesti t.i. različne težavnostne stopnje. Ker se strinjam, da nek povprečen igralec, ne bo 50 in večkrat poskušal pri enem in istem bossu, katerega je zasnova bila v večini narejena, samo zato da je težka. Namerno ne-intuitivni udarci, ki silijo v parry mehanike bojevanja, s sorazmerno ozkim časovnim intervalom. Vedno več je takih iger, ker je razkol med samimi igralci vedno večji, na eni strani imaš gejmerje, ki gejmajo po 10+ ur na dan, katerim so tudi najbolj zahtevne igre prelahke, na drugi pa 40+ starešine, ki bi radi malo sprostitve po 10 urnem delovniku.
Zniževanje težavnosti in sploh uvedba več težavnosti definitivno precej razširi krog ljudi, ki igro na koncu preigrajo, in tudi tistih, ki se igre sploh lotijo, pa zdej že leta opažam, da te igre nikoli ne doživijo iste stopnje priljubljenosti in priznanosti. Zato jst še vedno mislim, da mora biti igra zahtevna na prav način, da mora biti zgolj ena težavnost za vse, ker avtorji oz. direktor, če vejo kaj počnejo, imajo v glavi točno speficično izkušnjo, namenjeno igralcu. Tudi mene zadnja leta motijo igre, ki so težke na butast način, težke, samo zato da so težke, določene tudi zahtevajo od igralca odzivni čas, ki je na spodnji meji človeških zmogljivosti (TeamNinja tega kr ne more dojet), kar pomeni, da večina ljudi tega nikoli ne bo zmožna, ne glede od količine treninga, ki ga vložijo.
dronyx ::
Kar se mene tiče vem, da če ima igra več stopenj težavnosti ne bom prvič nikdar igral na najtežji, ampak srednja oz. privzeta. Saj God of War bi bil po težavnosti verjetno souls like, če bi imel samo najtežjo, enako obe Jedi Star Wars igri. Iz tega vidika razumem, zakaj imajo nekatere od teh iger samo eno težavnost in zahtevajo od igralca da postane dovolj dober, da pride lahko sploh do konca. Ampak vsaj zame so pri teh igrah izziv samo šefi. Ostalo pač ni nekega problema, edino kar me motijo so razne zasede oz. situacije, ki so nateg in te prvič ubije, nakar ponavljaš del igre, drugič pa poznaš nateg in ni več problem. Pri šefih velikokrat pomagajo razni "consumables", ampak problem je, če jih uporabljaš in velikokrat ponavljaš nekega šefa jih prej ali slej enkrat zmanjka. Jaz ta problem rešim tako, da shranim save od igre, kjer imam tega še dovolj in vrnem save, če mi ne uspe nekega šefa premagat v N poskusih. Pri Lies of P sem uspel tako pri par šefih, tudi pri Sekiru na enem mestu in celo Valor Mortis sem za drugo fazo zadnjega šefa enostavno uporabil consumables, ker se mi ni ljubilo več trenirat obrambe (ima combo udarce ki se kar ne končajo, po 8 ali celo več in vsaka napaka pomeni praktično takoj konec).
jijetelu ::
Ni vsaka težavnost ista. Ene težavnosti so pač neumne, tko kot omenjeni GOW. Najtežja težavnost je bolj suffer kot kej drugega, ker so vsi sovragi zgolj HP spužve, pa ubijejo te v enem ali dveh udarcih.
Pametna, oz. za igranje zanimiva težavnost naj bi bila dovolj stimulirajoča ampak fer. Kar danes pomeni dovolj zanimivo kompleksnost napadov, ki pa se jih, ko jih enkrat razumeš, je moč ubraniti.
Nobena genialnost ni danes narediti pretezke igre, zgolj zaradi tega, dvigneš dmg, hp bossov, do te mere da je vsak boj maraton brez napake, ali naredis napade take, da se jih ne da ubraniti, ali prehiter odzivni čas, ali raznorazne dodge trape, izredno ozke parry timinge ipd... Te stvari so načeloma nepriljubljene.
Valor mortis ni preveč posrečena igra glede tezavnosti. Večina napadov je izredno preprostih in glede na sistem igranja nimas praktično početi nič drugega kot cakati na parry. In sem mnenja, da so razvijali prav zaradi zagotavljanja težavnostni, dvignili DMG vseh sovragov na kr visoko raven. Navaden lulček iz zacetnih stopenj te ubije tudi pri lvl 50 v par udarcih.
In tudi pri dolocenih sefih, zadnji boss, pa oni kao specialci z zlatimi čeladami, imajo zelo ozke casovne intervale za parry, četudi poznaš celoten movset, je se vedno izziv zadeti vse, DMG pa itak na nivoju, da če falis si mrtev. Ne vem kdaj sem dobil amber za povečanje parry časov, od takrat je igra postala bistveno lažja, vključno z zadnjim sefom.
dronyx ::
Valor Mortis je bil vsaj zame na začetku kar težak, nekje od sredine dalje pa težavnost konkretno pade, ker dobiš poleg tega amberja za povečanje parry window še transmutacijo, ki upočasni, ali lahko celo povsem ustavi nasprotnika. Ko enkrat veš, kaj vse imaš na razpolago in vse to pametno uporabljaš, ni več neke visoke težavnosti. Jaz sem pozabil, da v tisti bazi (cerkev) lahko nadgrajuješ tudi orožja in transmutacije, tako da sem večji del igre preigral brez tega. Potem ko sem se na to spomnil, je pa vse skupaj postalo še lažje. Mi pa gredo v teh souls (like) igrah poleg raznih pasti na živce tudi zakasnjeni napadi. Torej recimo šef par sekund čaka, potem pa praktično v hipu sledi udarec, ali celo več hitrih udarcev. To sem opazil tako pri Lies of P, kot pri Valor Mortis, pa verjetno to tehniko zlorablja večina teh iger za dvig težavnosti.
Gregor459 ::
Masiven štart na Steamu trenutno več kot 600k igralcev.
jijetelu ::
Kaka polomija od igre. Zgleda se grejo Kitajci masoven hype. Definition tukaj nekaj ne štima glede realnosti in t.i. internet statistik. Me prav zanima kakšno bo stanje in mnenje zahoda po par mesecih.
10 - SteamDeckHQ
Tukaj bi dodal, da je igra strojno precej zahtevna (UE5), ampak neki srednji razred grafičnih kartic bi zmogel dostojne hitrosti pri 1440 + medium + upscaling.
StemaDeck pa s težavo dosega 30 FPS pri minimalnih nastavitvah, potem je igralnost že na ravni, če igri tega ne štejejo v minus.
Predsednik11 ::
Se odlocam za nakup lahko poveš kaj več ?
jijetelu ::
Večina opisov hvali tako ali tako predvsem bojevanje, zgodba pa samo raziskovanje nista nič posebnega.
Moje mnenje o samem bojevanju je, da je tok ovehyped, da mi ni jasno, kako je lahko celoten gaming community zgubil kompas tako hudo, ali pa meni očitno veliko stvari ni jasnih. Kot jst vidim bojevanje v tej igri je tko, vse kar niso bossi je itak brezveze, nepomembno, pride in gre, itak se ne respawnajo. Bossov je kar veliko, menda cez 50, stem da gre bojevanje praktično vedno po istem scenariju. od prvega pa verjetno do zadnjega. Boss bo imel svoj del, svoj combo udarcev od 20+ pa naprej, od katerega je zadni ali moder ali rdec. Ce narediš prsv counter ali če bossu zmanjk stamine oz. chija, mas potem ti svojih par sekund, za svoje combote, torej klofanje po gumbih. In to je več ali manj to. Teh boss combotov je verjetno toliko, da si pomojem razen res ekstremnih zagnancev, ne bo nobeden zapomnil tud enga ne. Ubistvu pa lahko chain blockas vse, vazen je samo tist oznacen udarec. Bossi potrebujejo vec kot 100 udarcev, tudi na najlažji stopnji, da poginejo. Igra načeloma ni tako zelo enostavna na najtežji stopnji, kot so se pritoževali nekateri opisovalci.
Kolega, ki precej igra soulslike igre, combat hvali bolj kot sveže žemljice.
jijetelu ::
Zmajc je izjavil:
Ja, sem se maksimalno trudil razumeti to genialnost tega combata, glede na to, da se moje mnenje precej razlikuje, ki ga hvali ogromno ljudi, praktično vsi youtuberji, instragramovci, pa mi ni uspelo.
Sej combat zgleda fenomenalno, prideš do gruče ljudi, pa jih animejsko prefukaš, samo naredil nisi pa nič, po možnosti si pritiskal en gumb, al pa tist prompt, ki si ga videl na zaslonu, no skill. In po mojem mnenju, so vsi fighti z bossi isti.
Vsak movset vsakega bossa, ki sem ga do zdej srečal, je tako kompleksen, da bi pri igri souls igrah, igrah tipa Sekiro, Lies of P, Onimusha, potreboval kar nekaj borb, verjetno celo ur, da bi razumel udarce. To so comboti po 20 in več udarcev. Zdej glede na to, da se tega verjetno 99.9% ljudi ne bi šlo, je pač sistem bojevanja narejen tako, da se igra praktično igra sama. Ko boss izvaja svoje combote, praktično vsi, kar sem jih uspel gledat, manično stiskajo gumb za parry/block, 90% udarcev uspešno parryjo, ostale blockajo, edino kar paziš je, da zamenjaš orožje, ko ti zmanjka chija/stamine. Edin kao skill issue je, da imaš vmeš udarce, ki jih moreš dodgat. To je pa praktično vse kar moreš pazit pri bojevanju in to je edin razlog, a boš neuspešen ali ne. Zdej če je to top combat ever, okey, jst mislim da ne. Combat postane pointless. To je tako, kot igrati streljačino z auto-aim, auto-fire, pa se počutit bogovsko, ko si dober. Pa sem prepričan da bi jih 80% ljudi hvalilo kok je top :D.
Igre (brez lastne teme) (strani: 1 2 3 4 … 40 41 42 43 )
Oddelek: Igre
2142420884 (1183) oo7
Dark Souls 3 (strani: 1 2 3 4 … 7 8 9 10 )
Oddelek: Igre
468120639 (3180) oo7
Dark Souls II (strani: 1 2 3 4 5 )
Oddelek: Igre
21596259 (5339) oo7
Bloodborne (strani: 1 2 3 4 )
Oddelek: Konzole
15829233 (5449) oo7
Sekiro: Shadows Die Twice (strani: 1 2 3 4 5 )
Oddelek: Igre
24425582 (16546) Argica
