Forum » Loža » Windows 11 autounattend.xml
Rad21 ::
https://schneegans.de/windows/unattend-...
Namestil sem Windows 11 24H2 clean install z autounattend.xml na novemu gaming prenosniku. Kopiral sem autounattend.xml na Windows 11 USB ključ, namestil ampak sem imel bloatware in novi desni klik namesto stari.
Če namestim iz ISO normalno deluje ampak ne deluje če ustvarim Windows 11 Bootable USB z Rufus in kopiram autounattend.xml.
24H2 Setup now calls SetupPrep.exe to perform the actual install. This workflow is incompatible with Schneegan's method for embedding scripts or files inside the autounattend.xml.
If you're not familiar with that process, I would suggest taking a 23H2 ISO and overwriting its sources\install.wim with the 24H2 version.
Just have Rufus prepare a normal 23H2 ISO. Copy your autounattend.xml to the finished USB drive.
From the PC, have File Explorer mount the 24H2 ISO file (.iso). Browse to the mount folder's \sources folder, copy the 24H2 install.wim to the USB drive's \sources folder. It's easier when everything is treated as a normal file instead of being inside an archive (ISO).
When done, unmount the 24H2 ISO from Explorer.
To sem našel na spletu. Ali je kakšna druga rešitev?
| ! | [Windows 11] Debate, vprašanja in težave (strani: 1 2 3 4 … 25 26 27 28 )Oddelek: Operacijski sistemi | 304571 (1304) | strom_15 |
| » | Windows 11 24H2 na voljo za vse (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 21328 (13075) | _Denny_ |
| » | Ryzen 4600G in BSOD (strani: 1 2 3 )Oddelek: Pomoč in nasveti | 8888 (6574) | Bye |
| » | Nalaganje windows 10Oddelek: Operacijski sistemi | 2039 (1430) | pegasus |
| » | Kateri WindowsOddelek: Pomoč in nasveti | 1754 (1448) | Riff |
