Forum » Operacijski sistemi » Windows 11 LTSC Recall
Ijus ::
evo. jaz imam windows 11 home 24h2 inštaliran (sicer brez recall - sicer ne vem zakaj ga nimam ampak okey me ne moti načeloma tudi če ga imam ali nimam...) in sem sedaj vprašal kopilota (Copilot aplikacija ki je implementirana v windows os za AI pogovarjanje ipd)... in sem dobl odgovor da Windows 11 Long-Term Servicing Channel ima Recall.
sicer tko piše, če kopi/pejstam odgovor:
moje vprašnje:
"does Windows 11 LTSC have a Recall"
kopilotov odgovor:
"Yes, Windows 11 LTSC (Long-Term Servicing Channel) does include the Recall feature1. Recall is designed to take snapshots of your screen activities every few seconds, allowing you to revisit past actions on your computer2. This feature is part of the broader set of tools available in Windows 11, including on LTSC and Server editions1.
If you have any concerns or need help with this feature, feel free to ask!"
upam, da ti je bilo v pomoč
moje vprašnje:
kopilotov odgovor:
Rad21 ::
Check If Recall Is ON : Dism /Online /Get-Featureinfo /Featurename:Recall
Disable RECALL: Dism /Online /Disable-Feature /Featurename:Recall
Enable RECALL: Dism /Online /Enable-Feature /Featurename:Recall
Zakaj ne bi?
acookook ::
Ali ima Windows 11 LTSC Recall?
A rabiš ti še eno temo odpreti, ko imamo https://slo-tech.com/forum/t786836/0 Isti troll k vroč burek.
| ! | [Windows 11] Debate, vprašanja in težave (strani: 1 2 3 4 … 25 26 27 28 )Oddelek: Operacijski sistemi | 304546 (1279) | strom_15 |
| » | Zgolj še eno leto podpore za Windows 10 (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 15706 (12050) | bciciban_ |
| » | Windows 11 24H2 na voljo za vse (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 21327 (13074) | _Denny_ |
| » | Windows 10 22H2 je bila zadnja večja posodobitev (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 24288 (20619) | LightBit |
| » | Internet Explorer pregnan iz Windows 10Oddelek: Novice / Brskalniki | 6046 (4415) | Key Quest |
