Windows 11 LTSC Recall
Rad21 ::
Ali ima Windows 11 LTSC Recall?
Ijus ::
evo. jaz imam windows 11 home 24h2 inštaliran (sicer brez recall - sicer ne vem zakaj ga nimam ampak okey me ne moti načeloma tudi če ga imam ali nimam...) in sem sedaj vprašal kopilota (Copilot aplikacija ki je implementirana v windows os za AI pogovarjanje ipd)... in sem dobl odgovor da Windows 11 Long-Term Servicing Channel ima Recall.
sicer tko piše, če kopi/pejstam odgovor:
moje vprašnje:
"does Windows 11 LTSC have a Recall"
kopilotov odgovor:
"Yes, Windows 11 LTSC (Long-Term Servicing Channel) does include the Recall feature1. Recall is designed to take snapshots of your screen activities every few seconds, allowing you to revisit past actions on your computer2. This feature is part of the broader set of tools available in Windows 11, including on LTSC and Server editions1.
If you have any concerns or need help with this feature, feel free to ask!"
upam, da ti je bilo v pomoč
Rad21 ::
Check If Recall Is ON : Dism /Online /Get-Featureinfo /Featurename:Recall
Disable RECALL: Dism /Online /Disable-Feature /Featurename:Recall
Enable RECALL: Dism /Online /Enable-Feature /Featurename:Recall
In vi zaupate da če je "off" da je res off? Pls.
Zakaj ne bi?
beta1 ::
mtosev je izjavil:
Zakaj ne bi?
Zakaj bi?
Huawei LTE CPE master.
acookook ::
Rad21 je izjavil:
A rabiš ti še eno temo odpreti, ko imamo https://slo-tech.com/forum/t786836/0 Isti troll k vroč burek.
[Windows 11] Debate, vprašanja in težave (strani: 1 2 3 4 … 25 26 27 28 )
Oddelek: Operacijski sistemi
1390304637 (1370) strom_15
Zgolj še eno leto podpore za Windows 10 (strani: 1 2 )
6415715 (12059) bciciban_
Windows 11 24H2 na voljo za vse (strani: 1 2 )
6821339 (13086) _Denny_
Windows 10 22H2 je bila zadnja večja posodobitev (strani: 1 2 )
7424297 (20628) LightBit
Internet Explorer pregnan iz Windows 10
Oddelek: Novice / Brskalniki
166049 (4418) Key Quest
