Volkswagen bo zgradil manj tovarn za baterije
1 2
3
4
Fluido ::
brbr21 je izjavil:
DamijanD je izjavil:
Po drugi strani pa dobimo take novice: BMW prvič prehitel Teslo
https://www.rtvslo.si/zabava-in-slog/av...
Saj ne, da ti nebi verjel, ampak bi bilo vseeno dobro,da naklamfaš sem nekaj fizike, ki bi to potrdila.
Ufff.... idiots, keep on idioting ;(
Tole pustim, potem pa lahko noč... aja še za manj razgledane (pa čeprav mogoče celo izobražene): črka "m" v formuli predstavlja maso. Tistih 100kg npr.
 a
a
Brrrrrr.... Mimo si pihnil z barvanjem.
PS je še zračni upor, kotalni upor,....
grimmir3 je izjavil:
Da ne govorimo da ima elektro motor izkoristek ~95% ICE pa 25%.
ICE rešuje ogromna energijska gostota fosilnih goriv.
12200 Wh/kg za bencin in 12700 Wh/kg za dizel. Baterijo so pa pri ~200 Wh/kg.
Za ICE si blizu povprečnega izkoristka, za EV oz. EM je pa 95% nekje zgornja meja, povprecni je nekaj nižje.
Izkoristek elektromotorja je lahko tudi nad 99 %, daleč od tega da bi bila 95 % zgornja meja.
https://www.powerpro.ng/pages/abb-motor...
During factory acceptance tests carried out in the presence of the customer, ABB recorded a result of 99.05% full load efficiency on a 44 megawatt, 6-pole, synchronous motor. The motor was included in a contract for six motors of the same design and they all had test results above 99% efficiency.
Tesla model 3 uporablja motorje z 97 % izkoristka:
"As Electrek reports, both the Model S and X use AC induction electric motors, which achieve an efficiency of 93 percent. However, for the more recently developed Model 3, Tesla switched to using permanent magnet reluctance motors, which achieve an efficiency of 97 percent."
https://www.pcmag.com/news/report-tesla...
Povprečni izkoristek ICE motorja v avtu je nekje med 16 in 20 %:
"The TTW efficiency for combustion engines is about 16%–20% when all driving situations are included, as reported by
[4]. However, this number varies depending on the driving situation. According to [5], typical values are 10%–13% on urban cycles and about 28% for highway cycles. [6]
https://www.sciencedirect.com/science/a...
Fluido ::
starfotr je izjavil:
Ne eno in ne drugo ni izvedljivo.
Pri cestah je to precej drago in izgube pri polnjenju bi bile strahotne.
Pri vlaku (če zanemarim vse ostalo in se fokusiram samo na polnjenje) je problem, ker tok skozi pentagraf tudi ne more biti neskončen.
https://www.mersen.com/sites/default/fi...
Zakaj si idejo zavrgel preden si sploh poračunal koliko električnih avtov z kakšno močjo bi se sploh lahko polnilo na takšnem vlaku? Morda zato ker si deep down tako želiš da izvedba ne bi bila mogoča? Če je temu tako, zakaj si to želiš? Maximalni continuous tok za en pantograf za 25 kV AC omrežje je 2000 A (spodaj na spodnjem linku maš specifikacije).
https://www.richardag.ch/en/mainline-ra...
Torej to pomeni da je maksimalna moč 50 MW na en pantograf (nikjer ne piše da bi se morali omejiti samo na enega). Ampak za enkrat ostanimo pri enem. Glede na to da pot traja sigurno preko dobro uro (johnnyyy omenja da bi avtovlake uvedel na daljših relacijah), to pomeni da je 50 kW moči na en avto vrh glave, kar pomeni da 50 MW zadostuje da se med vožnjo napolni kar 1000 avtov (tisti nekaj MW moči za lokomotivo sem zanemaril zaradi lepših bolj predstavljivih številk). Torej 1000 avtov na en vlak. Povsem zadosti. Če vožnja traja dobri 2 urci pa 2000 avtov. Skratka zadeva je povsem tehnično možna za izvedbo.
In daleč od tega da bi bila 25kV omrežje zgornja meja, to je pač trenutno najbolj razširjena napetost na železniškem omrežju, vendar če bi bila potreba se lahko na račun kakšnega procenta večjih izgub ta napetost še poveča za nekajkrat (kar tudi moč in število avtov poveča še za nekajkrat), skratka vse to je možno. In kot pravim, nikjer ne piše da bi se morali omejiti samo na en pantograf. Ampak v praksi pa že en več kot zadostuje.
  • spremenilo: Fluido ()
Fluido ::
ps: pa v zgornjem postu sem računal kot da VSI avti na avtovlak prispejo skoraj čisto prazni in ga zapustijo skoraj čisto napolnjeni, kar v povprečju sigurno ne drži. V povprečju bo procent baterije ob vkrcanju sigurno večji (ocenjujem da nekje med 30 in 50 % SoC), kar potrebno moč na avto ŠE ZNIŽA in število avtov ki bi jih lahko filal takšen vlak ŠE POVEČA.
BTW, pri nas imamo 3 kV DC.
Tako, da malo manj sanjaj. Ker 25 kV ne bomo imeli se vsaj 50 do 100 let.
Fluido ::
V večini Evrope je 25 kV AC (zemljevid spodaj). Pri 3 kV DC pa dovoljen kontinuiran tok naraste na 3000 A (iz prejšnjih 2000 A, glej link par postov nazaj kjer imaš specifikacije). Torej to je 9 MW pri našem 3 kV omrežju. Če odštejem še porabo lokomotive to pomeni da v 3 urah vožnje tudi pri našem zastarelem 3 kV omrežju lahko nafilamo za približno 300 Tesel long range (70 kWh na eno). 300 električnih avtov bi se lahko nafilalo od čisto praznega do čisto polnega tudi na našem zastarelem 3 kV omrežju. Ker pa v praksi ne bodo gor prišli čisto prazni, pa nekih 450. Skratka več kot zadost. In to je vse računano na en pantograf. Damo 2, pa smo že na 900 avtih na en vlak. Skratka viška zadost. Koliko avtov že lahko naloži un naš avtovlak na mostu na soči? Dvomim da preko 100. Skratka tudi pri nas je zadeva možna za izvedbo. Skratka omejitev toka na en pantograf sploh ni nobena resna omejitev za ta namen uporabe, tudi na našem zastarelem 3 kV železniškem omrežju ne.
Tukaj imaš javno naročilo obnove ENP.
https://www.enarocanje.si/#/pregled-obj...
Povezava se izvede s pomočjo dveh enožilnih kablov N2XSY 0,6/10 kV preseka bakrenega vodnika 300 mm2, in zbiralnic iz ploščatega bakra dimenzij 100 x 10 mm, Kabli so v horizontalni razporeditvi in so, po podatki proizvajalca "Waskonig+Walter" lahko trajno obremenjeni s skupnim tokom 1662 A (velja za kable položene v zraku in temperaturo okolice +30 stopinj Celzija), kar zadošča glede tokovne obremenitve vleke na posamezni napajalni liniji. Bakrena zbiralnica navedenega preseka in pobarvana je lahko trajno obremenjena z enosmernim tokom 1940 A (priročnik Končar/1991, str. 800, tab. 1).
Wander ::
V čem je problem? Če so se pač na nakem mikro odseku proge (3 kV stikališče ENP Poljčane) odločili da dimenzionirajo ta odsek na 1662 A, kar kot pravi tvoj lasten vir zadošča glede tokovne obremenitve vleke na posamezni napajalni liniji, če ZADOŠČA, potem pač ZADOŠČA! Ko ne bi več zadoščalo bi pa to dotično specifično stikališče iz tvojega primera pač nadgradili. In tudi teh tvojih 1662 A je še vedno več kot zadost (torej niti nadgradit ne bi rabli tudi enega stikališča ne). Daš 2 pantografa gor na isti vlak, kar pomeni da se lahko v 3 urah vožnje napolni 500 električnih avtov na en vlak. Maš še 2 pantografov v bistvu ne rabiš, glede na slovenske vlake se mi zdi 250 avtov na en vlak čist ok številka (samo za oris, avtovlak ki gre od Mosta na Soči do Bohinjske bistrice ima kapaciteto 16 do 20 avtov).Skratka tehničnih ovir ni, ovire so samo v glavi.
  • spremenilo: Wander ()
Fluido, izkoristek EM je lahko....
Bistveno je boldano, 99% je preveč, oz. če znaš narediti takšen EM, si takoj lahko bogat! Sem delal na EM in vem, da nekateri prodajajo pravljice!
Že zaradi same izdelave, dizajna, EM ne more imeti 100% izkoristka, potem so se izgube v bakru, elektroniki,...
250 ali pa 500 avtov je pljunek v morje.
V Ljubljano se vsak dan pripelje 100 000 vozil.
https://www.dars.si/Prometne_obremenitv...
In polnjenje vozil se bi izvajalo zjutraj, ko je obremenitev omrežja zelo visoka. Vsi EV navdušenci govorijo o tem, kako se bodo avti polnili takrat, ko bo omrežje manj obremenjeno.
Wander ::
Ne samo da je lahko, ampak tudi JE. V tem primeru so neodvisne meritve pokazale da je izkoristek preko 99 % (trenutno svetovni rekord). Tesla model 3 ima pa motorje z 97 % izkoristka. Beri spodnji sestavek:
"During factory acceptance tests carried out in the presence of the customer, ABB recorded a result of 99.05% full load efficiency on a 44 megawatt, 6-pole, synchronous motor. The motor was included in a contract for six motors of the same design and they all had test results above 99% efficiency.The contract had guaranteed an efficiency of 98.80%, meaning that the efficiency on this motor is 0.25% greater than anticipated. Over the lifetime of a motor, the 0.25% higher efficiency can be very significant in terms of money and energy savings, as well as profitability and environmental impact."
Na kratko, firma je zahtevala izkoristek 98,8 % ali boljši, izvajalec jim je dostavil izdelek z še 0,25 % višjim izkoristkom od njihove zahteve (izkoristek je bil 99,05 %).
Nihče razen tebe ni omenjal 100 % izkoristka. Vsem je jasno da 100 % izkoristka pri EM pač ne more bit.
Varius ::
Pazi, to je število avtov na en vlak. Številke ki jih lahko ena taka proga (z večimi vlaki) lahko pripelje v enem dnevu so mnogo višje. Računej 15 vlakov x 500 avtov na vlak je že 7500. In 7500 je skoraj polovica vseh avtov ki se dnevno v službo peljejo iz Maribora v Ljubljano, niso to majhne številke. Ko omrežje nadgradimo na 25 kV tako kot v večini Evrope pa se bo večih pantografih na vlak že lahko približamo ali celo presežemo številko 100.000 avtov na dan.
Fluido=Wender????
Ti piseš o svetovnem rekordu 99% izkoristek, ali samo električen EM, ali se kaj drugega?!?!?!?
Teslinih 97% je pri nekih optimalnih vrtljajoh EM, kzven tega območja manj!
Ti piseš podobno, kot kaksni nategunski prodajniki, ce je v zvezi z elektriko je vse cudovito.
holesander ::
Celoten skupen izkoristek elektromotorja je bil v tem primeru 99,05 %, ne samo elektromagnetni del. Zgooglaj, saj ni težko.
Seveda, vendar pri neki povprečni vožnji je nek povprečni izkoristek EM pri Tesli še vedno okrog 94 do 95 %.
Nikakor ne, niti približno ne. Povem kakšne stvari realne so. Ti pa pišeš kot nek nejeverni tomaž, ki se je ravnokar zbudil v jami iz 10.000 letnega spanca in misli da smo sredi kamene dobe.
johnnyyy ::
Izvedljivo je, vprašanje pa je tehnologija in izkoristek.
Odvisno od implementacije. So delali poizkuse tako wireless kot z povezavo.
Nihče ne pričakuje da je neskončen, ampak imaš lahko več pentagrafov. Poleg tega ni nujno da so vsi avtomobili "prazni" ko vstopijo. Če ima avto doseg 500km lahko brez dodatnega polnenja pride od Nurnberga do Zadra, če se z vlakom pelje od Munchna do Reke.
DamijanD ::
Ampak ne moreš dati neskončno pentagrafov na isti drot...
johnnyyy ::
Saj tudi neskončno vozil ne moreš dati na vlak :). Pač nekje vedno pridemo do tehničnih omejitev. In neke rešitve bo potrebno najti in implementirati, kot vedno.
Saj če pogledaš so ICE in električni avtomobili izjemno neuporabni - saj brez ceste in bencina/dizla/elektrike si z njimi nimaš kaj dosti pomagati. In v izjemno kriznih razmerah je konj bolj uporaben od vsakega avta. Ampak mi smo v zadnih 100 letih celotno infrastrukturo priredili avtomobilom, zakaj ne bi še dodali par malenkosti?
Markoff je izjavil:
Merkelca in njena strategija zanašanja na Putlerjeve poceni energente je ob prvem resnem geopolitičnem preizkusu (napadu ruSSov na UA) Nemčijo pretresla v temeljih.
Neumnost - poceni ruski energenti so omogočili konkurenčno industrijo.
Zato, ker ni treba. Evo zato.
johnnyyy ::
Kaj je treba in kaj ne pokaže trg in sproti se bo potrebno prilagajati. EV oz. njihov šibki del - baterije - se razvijajo in tehnologija gre naprej. Če je bila pred 20 leti znanstvena fantastika skupaj spravit 100kWh baterijo, danes to ni več takšna umetnost, kaj pa bo čez 20 let pa nihče ne ve. Pri takšni tehnologiji je vedno pomembno, da ji sledimo, ker če ne lahko ostanemo zadaj.
Da ostanemo zadaj pa mislim na to, da se lahko zgodi da bodo kitajci čez n-let preplavili naš trg s poceni EV, mi pa bomo kupovali drage stare dizelaše, saj bo infrastruktura polnilnic slaba.
johnnyyy je izjavil:
Saj to se je že zgodilo, pa je EU blokirala s carinami...
Poldi112 je izjavil:
Saj niso bili poceni. Se vedno so bili drazji kot v ZDA. Itak pa je geostrateska komponenta tukaj zelo pomembna. Evropa mora delati na zmanjsanju energetske odvisnosti od ZDA in predvsem Rusije - ki nam je izrazito sovrazna.
Za ZDA podjetja...
Če bi to izvažali v EU, bi bilo precej dražje od Rusov, kar vidimo sedaj...
Kar vidimo sedaj ni "postena" primerjava, ker nimamo (dovolj) infrastrukture za uvoz iz ZDA. Pa tudi oni nimajo (dovolj) infrastrukture za izvoz. V vsakem primeru je v interesu EU, da razvija nefosilno domaco proizvodnjo.
Dvajset let nazaj je bila znanstvena fantastika delat tako težke avte za mase. Takrat je bila povprečna teža okoli ene tone. S takim tempom bo itak vsak novi avto imel kmalu več kot dve toni. Kaj pa je problem potem 100kWh baterije. Tesla S je imela že desetletje nazaj 85kWh baterijo. Težka pa je bila 2500kg. Lahko bi imel komot 200kWh baterijo, samo teža bi bila na meji dovoljene.8-O
  • spremenil: Magic1 ()
Imas 200kwh pickupe. Dragi so kot zafran, prodajajo se slabo.
Chevrolet Silverado EV @ Wikipedia
johnnyyy ::
Magic1 je izjavil:
Seveda, a tehnologija je šla naprej. Pred leti se je šlo precej v razvoj Li-ion baterij (večja kapaciteta, višja cena). Trenutno se se precej napora vlaga v Na-ion baterij (nižja kapaciteta, nižja cena). V katero smer bodo stvari zavile je danes težko reči. Bomo imeli v prihodnosti višjo kapaciteteto baterij in manj polnilnic, obratno ali bo kompromis nekje vmes?
Stvari me spominjajo na mobilno telefonijo. Stare Nokije so zdržale 7 dni z enim polnjenjem in ko so prišli pametni telefoni, si moral polnit vsak (drugi) dan. A okolje se je prilagodilo, univerzalni polnilci, hitro polnjenje, SW možnost varčevanja z energijo, USB vtičnice integrirane povsod, power bank, brezžično polnjenje itd. Danes so telefoni ki zdržijo 7dni z enim polnjenjem izjemno redki - ker večina tega ne potrebuje.
Ne, da ne potrebuje, sploh ne moreš imeti. Pač pameten telefon ob redni uporabi pač zahteva svoje in smo ga prisiljeni polniti vsak dan - če ga rabiš pa službeno zares, potem pa pol dneva oz. ti večkratno polnjenje ali power bank ne uide (torej še dodatna naprava poleg, ki jo moraš spet polniti). Ne bom pa seveda za enormne denarje kupoval "vesoljske" telefone, ki zmorejo več.
Skratka za mene je to dnevno polnjenje nazadovanje.
  • spremenil: Gregor P ()
Magic1 je izjavil:
Čist si zabluzil. Telefoni so včasih zdržali en teden in so bili težki 100g (imel si tudi 70g, a so držali dva dni). Potem pa so prišli pametni, ki so imeli dosti večje potrebe po bateriji. Na srečo tudi po večjem displaju in tako imamo danes skoraj 7inch telefone cca. 200g in zdržijo dva dni (težke cigle s švoh CPU pa lahko tudi teden). Tehnologija Li-ion ni šla nič bistveno naprej, so jo izpilili da je za odtenek bolša. Ni pa to kakšnih večjih preskokov. Se jih pa danes enormno več dela.
Pa kdo ve, koliko časa se taka baterija fila?
Gregor P je izjavil:
Mene niti ne moti "dnevno polnenje". Me moti bolj cena. Jaz rabim avto za v službo in skakanje naokoli, max 50km dnevno. Ali za daljše poti 20x na leto. Ne bom jajčka za 30k€ kupil za se fjakat 20km, še manj pa nekaj večjega za 50k€, da bo zmogel daljše fure.
Invictus je izjavil:
Kao 1h15min na max. Samo za to rabiš 200kW Chrevolet polnilnico:)). Realno boš pa polnil doma s 10kW. Torej 20h.
Polnit moraš toliko časa koliko km si tist dan, ali boš naslednji, porabil.
To je jasno vsakomur. Vendar se moraš zavedat, koliko časa bo avto nedosegljiv ob daljši vožnji. Jaz da grem na vikend, ga moram tam polnit dva dni za nazaj. Lahko pa rečem elektru, da mi pojača na trofazno 10kW pa jim plačujem potem po novem zimskem režimu 30EUR več mesečno, da imam opcijo hitrejšega polnenja. Seveda elektiko še vedno dodatno plačam. Jej.
Če bi imel 50 kwh baterijo namesto 200 kwh, bi bil kaj manj časa "nedosegljiv"? Ja ne bi, ker če ti 50 kwh ni dovolj za naslednji dan, ti nič ne pomaga, da je že poln. Če ti je dovolj, potem pač ne rabiš polnit do 200.
Še vedno ne štekaš. Ponavadi porabiš največ, ko greš nekam dlje in tam si odvisen od polnilnic tam. Večjo kot imaš baterijo, dlje lahko greš, samo tudi potreba po močnejši polnilnici ali dolgemu polnenju se poveča. Se da it na road trip s EVjem, samo se hitro potovanje odvija bolj okoli EVja, kot pa kam hočeš res it. Jaz ko grem kam s bencincem, o avtu ne kalkuliram nič. Avto je zgolj prevozno sredstvo, o katerem najraje ne razmišljam.
Ti ne štekaš, da čas polnjenja ni odvisen od velikosti baterije, ampak od tega kako daleč moraš it. Še posebej ko greš nekam zares daleč.
Če greš na 2000 km dolgo pot s teslo s 60 kwh baterijo ali s 75 kwh baterijo, boš polnil praktično enako časa, razen za tistih 15 kwh s katerimi si več štartal, kar pa pomeni 6-7 min.
J.McLane ::
A se lahko vrnemo k novici.
Namesto 6 tovarn bodo zgradili samo 3, sliši se kot 50% rezanje. Ampak če pa beremo dalje koliko GWh letno želijo narediti pa so iz prejšnjih 240 GWh sedaj padli na 170 Gwh, z možnostjo povečanja na 200 Gwh do 2030.
Se pravi cela drama zaradi tega ker bodo svoje prvotne ambiciozne plane znižali za 17%-29%.
Saj ni nobene drame. Trenutno je na trgu veliko povprasevanje po novicah o slabi prodaji BEV. Ceprav so dejstva precej drugacna.
Definiraj dobro/slabo prodajo EV.
Jaz lahko napišem, da bo prodaja vsako leto najmanj 30,3% večja, če do-/pre-sežem, super, sicer ni po planu. potem znižam plan in je spet vse ok.
Preberi se enkrat kaj sem napisal. Gre za povprasevanje po negativnih NOVICAH. Ljudje povprasujejo po novicah kjer bodo prebrali, da so bili BEV samo modna muha ipd.
J.McLane ::
To je vse jasno, ampak neumen folk to prežveči kot, da so EVji zaključili svoj pohod in lahko mirno kupijo še enega dizla.
Edit, pod neumne mislim tiste, ki niso pripravljani niti na enem papirčku dati številke skupaj.
  • spremenil: J.McLane ()
Torej tiste ki kupijo dizla proglasiš/označiš za neumne?!
Po isti analogiji bi lahko za neumne proglasili/označili kupce EV.
Bo potrebno napisat kakšen argument, da ne bo pisanje kar v 3 dni.
Samo če hočejo leta 2030 prepovedat klasiko, mora bit letna rast EV kolikšna, da ne bo takrat ogromen padec prodaje avtomobilov? Mal bo huda, če bo leta 2029 še vedno 50%+ prodaje klasike, potem pa konc. Načeloma bi morala rast bit taka, da se leta 2029 proda večinoma EVje. Rast prodaje EVjev je bila do letos visoka, sam kaj če se se trg zdaj že nasičil (pač tist, ki je imel željo, si ga je že kupil) in prodaja zdaj ne bo več občutneje rastla? Trenutni kazalci kažejo, da prodaja več ne sledi proizvodnji in posledično proizvajalci bremzajo. Ne kaže, da bo 2030 lahko prešlo do ukinitve klasike, brez da ubiješ avto industrijo.
Saj so že prestavili na 2035.
Sej verjetno tudi 2035 ni realno.
Kdaj in kdo je "prestavil" na 2035?
  • spremenil: Utk ()
J.McLane ::
Ne, kot sem napisal, za neumne smatram tiste, ki niti na en robček ne dajo cifer skupaj, da bi videli kje stroškovno in uporabniško kakšna stvar stoji.
djabi ::
Bencinski/dizelski motorji so rabili 100+ let, da so prilezli do sem, kjer so danes.
Električni motor je sicer starejši, ampak je bil zaradi različnih razlogov bolj potisnjen v ozadje, zato rabi še nekaj let. Res pa je, da je v različnih strojih deloval že dolgo, ampak tam do sedaj elektromotor ni bil odvisen od akumulatorjev, saj je deloval pretežno priklopljen na štrom (pa naj bo to domača majhna hidroelektrarna ali karkoli drugega).
 tramvaj
tramvaj
 šivalni stroj
šivalni stroj
Zimonem ::
Zakaj bi se človek sekiral za VW. Sicer ga še imam ampak zadnji in najbrž edini je bil golf I. Svojo strategijo bodo že obvladovali sami. Saj niso od včeraj.
drovenik ::
Evropska unija je imela letnico ukinitve prodaje novih ICE avtov že od nekdaj postavljeno na 2035, nič niso prestavljali.
1 2
3
4
Volkswagen bo zgradil manj tovarn za baterije (strani: 1 2 3 4 )
19929344 (19905) J.McLane
Tesla dobila uporabno dovoljenje za tovarno v Nemčiji
4013299 (11371) Gregor P
Tesla lani dobavila pol milijona električnih vozil (strani: 1 2 3 4 5 )
Oddelek: Novice / Rezultati
20862473 (57695) kow
Tesla predstavila baterije za napajanje hiše (strani: 1 2 3 )
13555476 (41542) Spajky
