sql
sql
BRBR ::
Avto
master
a
b
detail
a   kolo
a   vrata
b   kolo
Kako dobim ven B na osnovi pogoja, da mora imeti kolo, ne sme pa imet vrat. Join. Kajpak spiski delov/pogojev-on/off so daljši.
Never underestimate the power of idiots in large groups.
  • spremenil: BRBR ()
imena polj?
prvi stolpec 1, drugi 2
select b.1 , b.2 from detail b , master a
where b.2 <> 'vrata'
and b.2 = 'kolo'
and a.1 = b.1
and a.1 = b
BRBR ::
Zadnja vrstica ?
BRBR ::
BRBR je izjavil:
Zadnja vrstica ?
Test tabele;
CREATE TABLE IF NOT EXISTS `1_detail` (
  `id` varchar(50) COLLATE utf8_slovenian_ci DEFAULT NULL,
  `prop` varchar(50) COLLATE utf8_slovenian_ci DEFAULT NULL
) ENGINE=MyISAM DEFAULT CHARSET=utf8 COLLATE=utf8_slovenian_ci;
INSERT INTO `1_detail` (`id`, `prop`) VALUES
	('a', 'kolo'),
	('a', 'vrata'),
	('b', 'kolo');
CREATE TABLE IF NOT EXISTS `1_master` (
INSERT INTO `1_master` (`id`) VALUES
	('a'),
	('b');
sql kao, ki pa ne dela:
select b.id , b.prop from 1_detail b , 1_master a
where b.prop <> 'vrata'
and b.prop = 'kolo'
and a.id = b.id
Probaj potem samo to:
select id , prop from 1_detail
where prop <> 'vrata'
bemfa ::
Najlepša rešitev bi bila nosql baza, najenostavnejša pa subquery.
SELECT m.id
FROM master m
LEFT JOIN detail AS d1 ON d1.id = m.id
WHERE (SELECT d2.id FROM detail d2 WHERE d2.id=m.id AND d2.prop='vrata') IS NULL
Če je performančno problem, pa kak dodatn view, ki predprocesira podatke (označi vsakemu masteru 0/1 kot has_vrata).
[php] encoding niza
Oddelek: Izdelava spletišč
174549 (2464) BivšiUser2
Šumniki v php-ju
215171 (3674) JoSmo
Šumniki in php
81940 (1730) shadeX
Java - Problem zarad šumnikov pri SQL
Oddelek: Programiranje
51929 (1680) DiTi
kako spreminiti vse php fajle in celo bazo v utf-8
161602 (1382) Senzacionale
