Novice » Android » Huaweijevi novi telefoni kljub ameriškim sankcijam s sodobno strojno opremo
fulk ::
Je možno, da china hajda svoj power level?
Jaz vseeno ne bi podcenjeval največjega proizvodnika vseh časev.
Četudi nima kreativnosti nas lahko pokoplje s sheer mass.
Glugy ::
Gagatronix je izjavil:
Kitajci so nesposobni inovativnosti, niti nimajo tehnoloskih sposobnosti.
To je totaln mit ki je mogoče držal v 90ih pa 00. Zdej pa že en cajt niso brezzobi tud na tem področju. Še vedno ima pa ZDA primat s tem ko pobere smetano najboljših inovatorjev ki jih iz vseh celin pripelje k sebi domov.
- spremenilo: Glugy ()
TezkoDihanje ::
ROFL - nova kitajska kampanja - in osli, ki padate nanjo
"There is literally no possible way a phone was doing that level of zoom. You'd need a telescoping lens, and a pretty powerful one at that, to go as far as they were there. This is just more blatant lies from a society that doesn't seem to understand that blatantly lying does the exact opposite of what they want. I feel for the average person in China, because they are so surrounded by this sort of behavior, it'd be impossible not to get caught up in it...but this makes ALL of them look terrible. It makes all of them look untrustworthy and sleazy. And worst of all, it makes all of them look very foolish, thinking that no one would see through it."
@Puharjev že spet misli, da imam 100 accountov na tem forumu. AHAHA
- spremenil: TezkoDihanje ()
TezkoDihanje je izjavil:
Ah se je ze pojavila tvoja obsesija s kitajsko in puharjevo...
A samungov zoom nisi videl ?
Ah ne enako kot nisi komentiral, da 7nm ali kakorkoli ze to imenujejo kitajci, je se en fake..
od tu dalje ba ene dva bronhija, pa raje mamico poslusaj, in se zadri blamiranja...
TezkoDihanje ::
zopet si tukaj in zopet prodajaš kitajska jajca
če so ga naredili, so ga naredili na mašinah, ki so jih uvozili nekaj mesecev nazaj
vprašanje je, kakšen yield imajo - verjetno smešno nizek, telefon pa prodajajo z izgubo
mamica, ujguri, silikonski vložki, blamiranje.. samo projiciraš (povej svoji mamici, da silikona ne bo zmanjkalo)
No vidis,
samo ena objava je bila potrebna,
da si pokazal vulgarnost tvojega mentalnega dosega v vse oblikah.
Najbolj smesno je pa to, da uporabis click bait naslov, in se ti ne sanja o Samongovem zoomu. Ej to je tehnična tema ne Ukrajinska tema, kjer pije vodo tvoja objava shrink inflaciji ducat ruskih jajc.
Vemo tudi da nisi nasel klik bat vira za kitajski 7nm fake.
No ko bi vsaj prijavil, recimo da niso sposobni izdelat kolicin razen samo vzorcev. Bi bilo vsaj na nivoju.
PS: sej vem da ti je tezko pri genocidu. V koncni fazi USA bazira na poceni delovni sili zaceli so s suznji, sedaj upajo da se jim bo izslo z Indijci, samo da korporacije bolj jokajo, sploh ko morajo odpreti zadeve, ki zaradi brana pred otrosko pornografijo, na zahodi ni mozno.
- predlagal izbris: TezkoDihanje ()
49106 ::
Zakaj tebe tako moti, da Mr. B z vsakim prispevkom zasluži 50 centov?
Pa kjub temu,
nisi sposoben zanikati novice. Zanimivo.
PS:
Lahko pa podam tvojo objavo moralno gledanje skozi globino denarnice v temi kitajskega genocida, potem pa vam disney tako zahvalno servira da so bili fantjr v regiji pridni s kvalitetno delovno silo v fimu izdanega leta 2023. Morda pa nisi prevec bral, kaj se dogaja.
Zimonem ::
Dragi odrešenik , ali ga lahko nehaš dozirati. Jezus je spremenil vodo v vino ti si pa očitno na žganjicah, kakor tvoj alterego.
Colt1911 ::
Tajvan ni Kitajska.
A bejž no. Kje si pa to prebral, v Cicibanu?
Tajvan kot državo priznavajo samo ene par shithole country ali bolje rečeno Krajevnih skupnosti:
Belize (1989)
Gvatemala (1960)
Haiti (1956)
Marshallovi otoki Marshallovi otoki (1998)
Nauru Nauru (1980–2002, 2005)
Palav (1999)
Paragvaj (1957)
Sveti Krištof in Nevis (1983)
Sveti Vincencij in Grenadine (1981)
Sveta Lucija (1984–1997, 2007)
Vatikan (1942)
Esvatini (1968)
Tuvalu (1979)
vir: Wilipedia.si
Ja Ciciban , tudi ZDA jih priznavajo kot del Kitajske , kot Kitajsko pokrajino.
Zato pričakujem da se držiš istih meril kot pri Ukrajini in najstrožje obsodiš tajvanske secesijske težnje.
Saj si vendar človek visokih načel , kajne?
49106 ::
Niti ne le da si zabit kočak. Sem dal gor link. Pa ne očitno prezahtevno branje.
Petdesetcentaš, ne se razburjat, zgolj pojasnil sem, zakaj neumorno zagovarjata CCP propagando.
- spremenilo: 49106 ()
Colt1911 ::
Jao, ste se zapel. Kitajci gredo velikrat z glavo čez zid. Tako se da marsikaj narest, vendar je to lahko zelo drago. Za Kirin so mogoče naredili svojo 7nm proizvodnjo linijo, za katero pa ne vemo kako kvalitetna je. Imajo lahko zelo slab izplen in so taki čipi zelo dragi, kar pa lahko subvencionira država v upanju, da se popravijo. Lahko pa so čipi hendikapirani pa jih vseeno uporabljajo. Samo SW mora podpirat, da dela na račun performansa. Za review-erje bodo že poslali dobre verzije.
Spomin pa so že kje na trgu našli preprodajalca, ki jim ga je prodal za primeren keš. Zdaj bo pač malo po prstih dobil, sam če ima bančni poln, se ne bo sekiral. Kitajci pa bodo našli koga drugega za naslednjč, da jim bo preprodal. Sej k Kitajcem gre ogromno Tajvanske/Korejske robe, sam k Huaweju direk kao ne sme. Mali obvoz pa pride, enkrat. Naljednjič pa po drugi poti.
Kaj spet tebe boli kurac za činezi slab izplen.
Tudi mi ga imamo ko moramo plačevati socialno takim genijem kot si ti , vedno ki prav vse veste in čisto nič ne znate.
Kaj pa tebe žuli, razen tega, da blatim vajinega delorajalca?
No kot si se v kitajski temi genocida jasno izrazil in pokazal solidarnost z asepticnim dihanjem...
Bi vedel,
da je to kar je nekultiviran gospodič napisal, cista oslarja..
Lepo da si se postavil na pravo jasno stran.
Ce bi bilo temu res, potem bi v eu ze imeli v vsaki vasi 7nm litogfijo. V koncni fazi eu izvaza nekaj na to temo... ane..
Ce beres kaj od tsmc-ja bi vedel da rabijo kar nekaj casa da je hala primerno posusena, da ko nadzirajo klimo v hali proizvodnjega postopka, da ni problem ne smo vodo ki bi se izlocala iz cementa ampak tudi plini... potem rabijo kar nekaj casa , da se stevilo partiklov na kubicni cm zmanja na nivokrepko pod kirursko sterilnosti, preden grejo sploh dati masine v vago, ki zagotovo ne delajo to z vodno vago iz OBI-ja, ce ne drugega delajo na nivoju nanometrov, kjer ze sprememba tempetature pomeni... potem sele zacno s kalibracijo plosce kjer se fiksira rezina kaj sele kalibracija laserjev tistih ki skrbijo da uparijo in nato primerno kolicino ohladijo oz. utekocinijo plin, da tocno dolocena kolicina zlahtnega plina v tekoci obliki pada v komoro kjer le ta plin vzburijo... verjetno ko delas litografijo na nivoju desetih atomskih enot, resnicno ne mislis da ni pomembno koliko fotonov, pod katero valovno dolzino, itd.. potem sele pridejo prvi testni primeri.....
Da po asepticnem dihanju so kitajci resnicni supermeni, da so v parih mesecih, uspeli cipe spraviti v telefonih na prodajne police.
Malo inteligence v tehnicni temi je pa le potrebno imeti. Preden zacnes s sarkazmom, ane?
mertseger ::
Tajvan ni Kitajska.
Seveda da je saj ga ni nobena država priznala razen tistih nekaj ki so tako revne da so jim lahko plačali pa ti še zanje niso nikoli slišal.Ko boš višjo stopnjo osnovne naredil še boš tudi geografijo učil če prideš do tja.
Tajvan seveda ni Kitajska. To se je zahod po 2. sv. vojni par desetletij pretvarjal, da je, ker američani niso mogli preboleti kitajske osamosvojitve.
Tajvan je preprosto zgolj en od kitajskih otokov, precej podoben HK-ju in ostalim, ter na isti, neizbežni trajektoriji dekolonizacije.
Tako da izgleda, da so kitajci deloma že samozadostni na 7nm.
Medtem ko smo v EU, kjer uživamo svobodo s pripadajočo kreativnostjo ter stoletje ali dve prednosti, sposobni narediti kaj? Kaj pa, ko nam američani nabijejo sankcije, če se hipotetično odločimo Iranu poslati zdravila?
- spremenil: Poldi112 ()
EU ima tehnologije brez katerih TSMC ne more. TSMC ima tovarne brez katerih EU ne more.
Skratka ni lih črnobelo. EU je tehnološko čisto pri vrhu, je pa vedno bolj zadaj industrijsko. Low-tech industrijo sicer dokaj komot dopolneš z uvozom, ker pri low tech je veliko konkurence. High tech industrija pa je malo bolj problem ja, ker glede čipov jo ima zgolj par držav na svetu. Tak da ja dobro bi bilo to met, ampak EU ima hujše probleme kot pa zgolj industrija čipov.
Gagatronix ::
Vi si kar zatiskajte oci pa gagajte po svoje, dejstvo je, da 60 Pro ne more tekmovat niti s telefoni iz leta 2020. Ampak neeeee CHINA THIS CHINA THAT. Pizda, od tech foruma bi clovek pricakoval kaj vec zdrave pameti. Aja, NITI NORMALNE VERZIJE ANDROIDA NE LAUFA! HARMONY OS! HAHAHA!
- spremenilo: Gagatronix ()
Tudi low tech je problem. Saj ni osnov. Če ni osnovnih zadev, ti tudi high tech ne koristi.
Pozabljaš pa še eno stvar: pri ASML imajo kremplje zraven še useki (na žalost).
Da trolcek.
Novica sploh ni v tem kako dolgega imajo, ampak da imajo tehnologijo, o kateri evropejci samo sanjamo.
Od tu dalje sploh ne razumes poante, kam trolajo kitajci.
Gagatronix ::
Nimajo nobene tehnologije. Ker Kitajska ne zna nic sama iz sebe naredit. Vse kar imajo je ukraden IP in blatantno kopiranje pri cemer pa usekajo vse mogoce bliznjice.
Od TECH foruma bi pricakoval kaj vec zdrave pameti, ampak vi kar se naprej uzivajte ob zajtrku CCP Cheerios kornflejks-ov.
Mi bi že uživali kitajsko tehnologijo, pa nam gospodar ne dovoli, ker ni konkurenčen na prostem trgu. Zanimivo, mar ne, kako zelo konkurenčni in samozadostni so kitajci, ki bojda ne znajo narediti nič.
Gagatronix ::
Kitajci so odlicni pri kopiranju in kraji IP-ja, tu jim ni zive sile na svetu, ki bi jim bila podobna. Domaca inovativnost jim je pa tako tuja kot je nam tuj Mars.
No, tebi se zdi, da se še nisi dovolj blamiral?
Že v 2022 je kitajska prijavila več patentov kot ZDA:
https://www.scmp.com/tech/tech-trends/a...
Res, prav zabaven si
Pa še bralno razumevanje te daje.
Kitajska je drzava fasad in bliznjic. Ves zakaj jim vse poplavlja kot blesavo ? Ker so sli po bliznjici in dal samo resetke na neobstojece odtoke za meteorne vode. In se in se je takih tofu bedarij.
Seveda Slovebnija dobro prenese večje količine vode...
Grem stavit, da bi bila škoda 80% manjša, če bi se ustrezno skrbelo za vodotoke, in ne bi ustvarjali gradbenih parcel v rdečih conah...
Gagatronix ::
Ja, zahvala za to gre pa vladam 30 let nazaj.
Medtem Kitajska veselo gradi velemesta iz betona ki razpada kot moka, z odtoki, ki imajo samo resetke.
Gagatronix, kaže da imaš nočne more in travme na temo Kitajske. Pojdi k psihologu, mogoče bo pomagalo, da boš argumentirano pisal, kako so Kitajci zanič.
Nasedel si pa Usa propagandi.
Lep dan.
Lep dan.
Pa kjub temu eu ni niti na 90nm samozadostna, kaj sele sposobna zadovoliti potrebe auo industrije.
Zanimivo.
Pa kljub inovativnosti nivoja Marsa, superlativnost kot jo predstavljas ti ni sposobna delat cipe niti na priblizno isti tehnologiji ? Verjetno si mislil, evropejce ne marsovce, ker nam v eu je ta tehnologija bolj tam iz marsa..
Gagatronix ::
O lej, "eni so boljsi drugi so slabsi" idiotizem.
Tipicno za bele koze.
Ne sekiraj se, nihce te ne jemlje resno.
Ena iz wikipedije, kdo vse dela čipe.
List of semiconductor fabrication plants @ Wikipedia
Oglejte si, kaj se dela v EU.
link_up ::
Jaz jim ne verjamem, ker imam prevec izkusenj s tem, da so me hoteli nadrajsati. Bo cas povedal kako dalec so s tem, bodite pa prepricani, da so se vseeno kar nekaj generacij "prekratki".
In and Out
Se strinjam... Leto 2035 je, po nemških cestah se vozijo samo še električni štirikolesniki, v EU smo končno postali samooskrbni z 90nm litografijo, in lahko proizvedemo lahko da zadovoljimo azijski trg. In mimogrede so Kitajci odprli še eno sub 1nm litografijo na osnovi gemnija.... Gagatronixpa üe vedno joka, da Azija vse znaje pokrade.
Zimonem ::
Da človek tako zgodaj pije je žalostno. Glede presoje in informiranosti so pa že prej. Zaupaj strokovnjakom in poišči pomoč.
Gagatronix ::
Katerim strokovnjakom ? Tistim ki propagirajo tri leta star tajvanski cip kot nov izum kitajske ? Aja sorry, zgleda ne pijeva iz istega korita.
Gagatronix ::
PovemVfaco ::
Kitajci raje barvajo opustošena območja na zeleno
To ni ravno kitajska posebnost, hamburgerji že dolgo to delajo:
Dihaj, herba bonboni pomagajo pri tezavah globokega vdiha...
Trenutno evropejci nismo sposobni niti 90nm procesa za nekaj vec kot drobiz kosov potreb trga, kaj sele da bi bili sposobni narediti 20 let star proc. to so sele trokovnjki.. Verjetno je tam notri cel kup takih kot ti, ki iscejo vzroke, kako so kitajci ukradli njihov neobstojec ipo
Zimonem ::
U bistvu smo ga le vložiti nočemo zadosti denarja poleg asml je ti še imec kateri je testna platforma za litografijo. Je pa to precejšen vložek , da narediš fabrko. Ampak tudi tu uporabljajo tako ameriške kot kitajske naprave.
- spremenilo: Zimonem ()
Da samo to spada v isti miselni koncept, kaj pa posiljamo v vesolje €$£...medtem ko se nismo resili lakote... Prej ali slej postanes izoliran otocek, odvisen od drugih... Zato pa je potrebno misliti dolgorocno ali pa imeti print masino...
Je pa, da je to prislo ven, ravno po obisku sefice v usa, kot posledica ping pong med kitajsko, tajvanom in usa in je vse skupaj zgolj predstava...
Zimonem ::
Bolj pomoje je problem kar kitajska ne zaupa več zahodu , kam to pelje sicer ne vem. Ampak kitajska je v svoje tovarne zmetala miljarde ne kar so ZDA prekinile dobavo in vplivale še na druge države. Izgube so enormne. Delajo na svoji verigi ampak to ni od danes na jutri.
Dobro, gremo se prosim držati zgodovinskih dejstev. Tajvanci so seveda Kitajci, le z drugo politiko oz. politično oblastjo in vrednotami (beri: niso komunisti) in pa so prebegnili s celine na ta (kitajski) otok, ki si ga želi seveda imeti nazaj pod svojo oblastjo tudi matična kitajska komunistična oblast.
Iz Wikipedije:
Iz Wikipedije:
Država je de facto nastala leta 1949, ko so se po zmagi revolucije na Kitajskem privrženci generala Čangkajška umaknili pred komunisti na otok Tajvan. Država Tajvan ni splošno mednarodno priznana. Do sedaj jo je priznalo 15 držav. Mednarodno priznanje ovira predvsem nerazrešen politični status ozemlja.
Tajvan je kitajska dinastija Čing prepustila Japonskemu imperiju po prvi kitajsko-japonski vojni leta 1895. Ponovno je prešel pod kitajsko upravo ob koncu druge svetovne vojne.
Štiri leta kasneje se je po porazu proti Komunistični partiji Kitajske v kitajski državljanski vojni vlada Republike Kitajske umaknila na Tajvan in ga razglasila za svoj začasni sedež. Republika Kitajska ni splošno mednarodno priznana in otok si lasti tudi leta 1949 ustanovljena Ljudska republika Kitajska, ki se razglaša za pravnega naslednika Republike Kitajske.
- spremenil: Gregor P ()
| » | Proizvodni procesi za čipe v različnih podjetjih (strani: 1 2 3 )Oddelek: Strojna oprema | 18836 (2017) | pegasus |
| » | ZDA gredo v popolno blokado HuaweijaOddelek: Novice / Tožbe | 12980 (7489) | Poldi112 |
| » | EU do leta 2030 s proizvodnjo čipov v 5 nm (strani: 1 2 )Oddelek: Novice / Ostale najave | 21001 (17493) | Zimonem |
| » | Intelovi procesorji Rocket Lake res v 14 nanometrih (strani: 1 2 )Oddelek: Novice / Procesorji | 31907 (29319) | Zimonem |
