Forum » Izdelava spletišč » Apache Config
Apache Config
BimboBoy ::
Folk pomagajte mi preden znorim, ker mi noce in noce stvar zazivet.
OK, nalozim Apacheja, PHP, MYSql, vse ok! Vse po navodilih. Ko pa nastavljam httpd mi explorer noce in noce prikazati pagea (btw: upor. W2000). Javi pac Forbidden
You don't have permission to access / on this server.
v httpd sm spreminju samo:
[VirtualHost 127.0.0.1]
ServerAdmin gherder@email.si
DocumentRoot "C:/homepage"
ServerName www.matjaz.com
ErrorLog logs/matjaz-error_log
CustomLog logs/matjaz-access_log common
AddType application/x-httpd-php .php
[/VirtualHost]
v host pa imam dva zadetka:
127.0.0.1 localhost
127.0.0.1 www.matjaz.com
Kaj je torej wrong? Thx
[/VirtualHost]
127.0.0.1 localhost
darh ::
v direktorij (C:/homepage) dej filetek index.html...
Excuses are useless! Results are priceless!
Brane2 ::
O verziji za Winse ne vem veliko, ampak ali je mozno,da program (torej Apache) nima dovoljenja za dostop v mapo, od koder naj bi serviral strani ?
Pri Linux verziji bi najprej pomislil na to...
- spremenil: Brane2 ()
darh ::
poglej v log fajle od apacha, mogoče tam kaj piše.
Packač ::
lahko jebe ker imaš nastavljeno User nobody => nemst nobody dj tvoj username al pa grupo nastav.
BimboBoy ::
v error log mi javlja:
[Sat Nov 01 20:28:25 2003] [notice] Child 3520: Child process is running
[Sat Nov 01 20:28:25 2003] [notice] Child 3520: Acquired the start mutex.
[Sat Nov 01 20:28:25 2003] [notice] Child 3520: Starting 250 worker threads.
[Sat Nov 01 20:28:26 2003] [notice] Child 560: Waiting for 250 worker threads to exit.
[Sat Nov 01 20:28:26 2003] [notice] Child 560: All worker threads have exited.
[Sat Nov 01 20:28:26 2003] [notice] Child 560: Child process is exiting
[Sat Nov 01 20:29:44 2003] [notice] Parent: Received restart signal -- Restarting the server.
[Sat Nov 01 20:29:44 2003] [notice] Child 3520: Exit event signaled. Child process is ending.
[Sat Nov 01 20:29:44 2003] [notice] Parent: Created child process 828
[Sat Nov 01 20:29:44 2003] [notice] Child 828: Child process is running
[Sat Nov 01 20:29:45 2003] [notice] Child 828: Acquired the start mutex.
[Sat Nov 01 20:29:45 2003] [notice] Child 3520: Released the start mutex
[Sat Nov 01 20:29:45 2003] [notice] Child 828: Starting 250 worker threads.
[Sat Nov 01 20:29:46 2003] [notice] Child 3520: Waiting for 250 worker threads to exit.
[Sat Nov 01 20:29:46 2003] [notice] Child 3520: All worker threads have exited.
[Sat Nov 01 20:29:46 2003] [notice] Child 3520: Child process is exiting
[Sat Nov 01 20:30:31 2003] [notice] Parent: Received restart signal -- Restarting the server.
[Sat Nov 01 20:30:31 2003] [notice] Child 828: Exit event signaled. Child process is ending.
[Sat Nov 01 20:30:31 2003] [notice] Parent: Created child process 2516
[Sat Nov 01 20:30:32 2003] [notice] Child 2516: Child process is running
[Sat Nov 01 20:30:32 2003] [notice] Child 2516: Acquired the start mutex.
[Sat Nov 01 20:30:32 2003] [notice] Child 828: Released the start mutex
[Sat Nov 01 20:30:32 2003] [notice] Child 2516: Starting 250 worker threads.
[Sat Nov 01 20:30:33 2003] [notice] Child 828: Waiting for 250 worker threads to exit.
[Sat Nov 01 20:30:33 2003] [notice] Child 828: All worker threads have exited.
[Sat Nov 01 20:30:33 2003] [notice] Child 828: Child process is exiting
access log pa:
127.0.0.1 - - [31/Oct/2003:23:10:00 +0100] "GET /apache_pb.gif HTTP/1.1" 304 -
127.0.0.1 - - [31/Oct/2003:23:10:00 +0100] "GET / HTTP/1.1" 200 1494
127.0.0.1 - - [01/Nov/2003:19:54:22 +0100] "GET / HTTP/1.1" 200 1494
127.0.0.1 - - [01/Nov/2003:19:54:22 +0100] "GET /apache_pb.gif HTTP/1.1" 304 -
127.0.0.1 - - [01/Nov/2003:19:59:31 +0100] "GET / HTTP/1.1" 200 1494
127.0.0.1 - - [01/Nov/2003:19:59:31 +0100] "GET /apache_pb.gif HTTP/1.1" 304 -
127.0.0.1 - - [01/Nov/2003:20:00:03 +0100] "GET / HTTP/1.1" 200 1494
127.0.0.1 - - [01/Nov/2003:20:00:03 +0100] "GET /apache_pb.gif HTTP/1.1" 304 -
127.0.0.1 - - [01/Nov/2003:20:05:06 +0100] "GET / HTTP/1.1" 200 1494
127.0.0.1 - - [01/Nov/2003:20:05:06 +0100] "GET /apache_pb.gif HTTP/1.1" 304 -
Kr neki...
A je treba mogoc kake extra porte ofnat?
access log pa:
Kr neki...
| ! | Postavitev Apache serverja s podporo za PHP in MySQL (strani: 1 2 3 4 5 6 7 )Oddelek: Izdelava spletišč | 276804 (20705) | miko22 |
| » | Pobegla baza z osebnimi in finančnimi podatki več kot polovice ameriških gospodinjsteOddelek: Novice / Zasebnost | 11950 (9592) | MrStein |
| » | agej hadžiselimovićOddelek: Loža | 6158 (2818) | Yohan del Sud |
| » | kako usposbim sslOddelek: Izdelava spletišč | 2321 (2050) | pan |
| » | Zanimiv server LOGOddelek: Omrežja in internet | 2412 (1980) | TheHijacker |
