Forum » Igre » Alan Wake 2
Alan Wake 2
Skyman ::
Alan Wake 2 Interview with Sam Lake | Summer Game Fest 2023
Alan Wake 2 Official Gameplay Trailer
- spremenil: Skyman ()
yayo ::
yup
Alan Wake 2 had been due to release on October 17th, three days before the release of Spider-Man 2 on PlayStation 5 and Super Mario Wonder on Nintendo Switch. I don't know how much difference a ten day shift will make, but it still puts it within days of Cities Skylines 2 and Metal Gear Solid: Master Collection, both of which release on October 24th. Assassin's Creed Mirage and Lords Of The Fallen are both due for release earlier in the month.
ahac ::
Alan Wake 2: 11 Minutes of New Gameplay - IGN First
btw. Zanimivo je, da igra stane 50€, ko je veliko novih AAA iger 60 ali 70€ (nekatere celo 80€).
https://store.epicgames.com/en-US/p/ala...
- spremenil: ahac ()
ahac ::
Govori se da 3/4 igre preigras kot crnka. Kdo ve ce je to res?To ni res.
Pravijo, da ima vsak character približno pol igre.
They are unique stories to both characters, they highlight different mechanics, they have different tones. Alan represents approximately 50% of the experience.https://www.videogameschronicle.com/fea...
yayo ::
ja, 70 je z dlcji, ki izidejo kasneje. Kot AW/ Remedy fen je to verzija katero bom vzel.
EDIT,
opaaaa, hišnik Aahti iz Control nastopi takoj na začetku videa.
- spremenil: yayo ()
ahac ::
Alan Wake 2 Exclusive: Alan Meets Alex Casey Gameplay Clip (4K RTX) - IGN First
ahac ::
Povzetek zgodbe prvega dela:
Previously On... Alan Wake
Kayzon ::
3070RTX za 1080p medium setings, brez ray tracing in DLSS-a (540p rendering). Noro.
Pa glede na to da je bil prvi Alan Wake dokaj neuspesen:
Epic only and requirements far beyond an average gaming PC. Good look with the sales figures
wolverine22 ::
Meni prvi Alan Wake na rx7900xtx laufa brez problema all maxed out 1440p 60fps konstantno...
2jka bo pa pizdarija, izgleda
ahac ::
Alan Wake 2 -- Launch Trailer
edit: Trailer so spremenil v private na youtube. Mogoče so ga prekmalu objavil.
edit2: Ni več private.
edit3: Zamenjal link za tistega na Remedy kanalu, ker ni age-restricted.
Haha, ne vem komu bodo to prodajal, če moraš imeti grafično za 500EUR za normalno igranje. Sej to ni tak problem, če 3/4 gamerjev na PCju nima dovolj dobre mašine. A na konzolah bo te laufalo 30fps? Verjetno jih je AMD in Nvidia presenetila s svojo nesposobnostjo, ko so v treh letih naredili napredek šele v rangu 1000EUR. Pa še tam le toliko, da 4090 zmore 40fps na vse max.
- spremenil: Magic1 ()
tiborrr ::
A lahko preimenujemo temo v alan woke 2
A si malo edgy najstnik ali si dejansko igral?
ahac ::
Alexander Battaglia od Digital Foundry pravi:
https://twitter.com/Dachsjaeger/status/...
1.
Alan Wake 2 is here. The hullabaloo about its recommended settings on PC is unfounded. Alan Wake 2 has very scalable graphical settings and when set to the PS5's perf mode settings an RTX 3070 outperforms it by nearly 50%. 1440p FSR2 Balanced.
The RTX 3070 has room for resolution or settings improvements depending on what you like to mix and match. The "medium" preset that everyone freaked out about at is indeed the name of a preset in the game that also includes settings set to high and ultra.
1.
yayo ::
Zvečer bom testiral.
Sem ob 6.30 šel dolpotegnit tistih 90gb igre pa je šlo v petnajstih minutah (75mbs/s se mi zdi). Prepričan sem bil, da bo komaj kmaj šlo.
tiborrr ::
Sicer pa Kayzon, kako si lahko že včeraj igral, meni je še ob devetih zvečer pisalo, da se odklene šele čez 9 ur...
ahac ::
PS5 performance in primerjava s PCjem:
Alan Wake 2 - PlayStation 5 DF Tech Review - Remedy Raises The Bar Yet Again
wolverine22 ::
V vglavnnem, 1440p, vse maxed up, RT off, framerate limited to 60...
Rx7900xtx, no frame drops...
Sporocim kasneje še za RT performance :)
wolverine22 ::
1440p...all maxed out 60fps no prob...
Če pa enaiblam raytracing preset on low mi pa pade framerate na 30 and below... Damn
yayo ::
ravno zagnal, zahteva takoj gpu driver update in, da dizejblam vsakršen game overlay. Gremo še enkrat.
wolverine22 ::
V glavnem, 7700x proc in rx7900xtx, na 1440p vse na max laufa smooth..
Ko se pa vklopi RT, je pa potrebno nekaj tweekinga :)
yayo ::
meni noče zagnat igro, če imam RivaTuner za spremljanje fpsjev in temperatur vključen. Pretentam tako, da potem, ko sem že v meniju igre alt-tabam in šele tedaj zaženem MSI Affterburner.
ahac ::
Skoraj 30let razlke v ogledalih. Takrat in danes :D
V starih igrah so menda ogledala naredili tako, da so postavili še eno celo (zrcalno) sobo na drugi strani.
Ampak takrat je bilo to bolj enostavno kot bi bilo sedaj, ko je toliko efektov in stvari, ki se lahko dogajajo zadaj.
yayo ::
preigral tisti uvodni del v gozdu, ko preiskuješ truplo. Baje spada me strojno najzahtevnejše scene.
Z RTX3080/1440p sem dal preset na high, raytracing pa dizejblal. Fpsji gredo od 60 navzgor proti 90 kar je zaenkrat lepo igralno. Tudi grafika zelo lepo zgleda. Če vključim karkoli kar spada pod raytracing smo na 30 in manj. Kakih 7fps, če vse dam na najvišjo vrednost.
Sem pa precej zadovoljen s tem kako igra zgleda, ko imam optimalne nastavitve za svoj sistem.
yayo ::
Tole je ena zelo cool igra. Ampak stilistično je napram AW1 to kar je bil Twin Peaks 2016 napram TP 1990-91.
Kot kaže se igra ne prodaja dobro.
Alan Wake 2 Failed to Rank in the Top 150 Games in Terms of Active Users for October
https://gamerant.com/alan-wake-2-failed...
Alan Wake 2 fails to lure 54% of first game's huge PS Plus audience
https://www.truetrophies.com/n24492/ala...
Kayzon ::
Ja ni cudno ce je pa woke garbage,niti se ne igra podobno originalu.
ahac ::
Članek je o tem, da so na PS5 vsi raje igrali Spider-mana. Ja, točno tega Spider-mana, za katerega so veliko govorili, da je "woke"...
yayo ::
Škoda, ker gre za zelo ambiciozen projekt, ki ni brez pomanjkljivosti ampak uspe dvigniti videoigro kot medij na nek bolj avtorski nivo. So pa triple A naslovi narejeni za masovno tržišče in morajo prinesti denar. Masovna publika pa želi le "igrce" nabijat in jih nič drugega ne zanima. Tako, da AW2 pade v eno čudno nišo, naj bi prinesel zaslužek a je istočasno preveč "umetniški" za povprečnega igričarja. Upam, da pride skozi finančno, ker želim zaključek zgodbe.
Da pa je "woke" jaz tega ne vidim nikjer. Ima dva protagonista od katerih je en temnopolta ženska rojena od švedske matere, pa namiguje se, da naj bi bila reinkarnacija nekega nordijskega božansktva. To je to, nikjer ni feministk, ne veganov, ne transeksualcev, nihče te ne sili v istospolni seks ali v podpisovanje peticij za Palestino.
ahac ::
Ja, Call of Duty (metascore 58/100) se bo vedno dobro prodajal za 80€. Alan Wake 2, ki ni tolk mainstream igra, se bo pa dost slabše za 50€.
Jaz sem sicer še vedno presenečen, da je Baldurs Gate 3 taka uspešnica (čeprav je menda dost bolj "woke" od AW2). Mogoče je še upanje za kvaliteto.
Nikonja ::
Da pa je "woke" jaz tega ne vidim nikjer. Ima dva protagonista od katerih je en temnopolta ženska rojena od švedske matere, pa namiguje se, da naj bi bila reinkarnacija nekega nordijskega božansktva. To je to, nikjer ni feministk, ne veganov, ne transeksualcev, nihče te ne sili v istospolni seks ali v podpisovanje peticij za Palestino.![]()
Napisal si točno to kaj mislim, ampak danes je popularno hejtat "woke" tudi če ne veš kaj woke sploh pomeni!
Kayzon ::
Kaj hoces reci,da ce veliko ljudi igra goyslop je ta goyslop dober? ha
| » | Control (strani: 1 2 )Oddelek: Igre | 17523 (120) | Gregor459 |
| » | PS6 (strani: 1 2 3 4 )Oddelek: Konzole | 24616 (363) | oo7 |
| » | Hellblade (strani: 1 2 3 )Oddelek: Igre | 19511 (822) | Gregor459 |
| » | turokOddelek: Igre | 3796 (564) | oo7 |
| » | Alan Wake (strani: 1 2 3 4 5 6 )Oddelek: Igre | 35036 (13654) | oo7 |
