Nginx TLS 1.3 | Qualys SSL "Cipher Suites"=100%?
HotBurek ::
Pozdravljeni.
Zanima me, če je komu uspelo postavit Nginx z TLS 1.3 podporo in doseči 4x 100% na Qualys SSL testu.
https://www.ssllabs.com/ssltest/
Men uspe 4x 100% v primeru, da je vkloplejn samo TLS 1.2. Ko pa vklopim še TLS 1.3, pa pod "Cipher Strength" pade na 90%.
Ima kdo TLS 1.3 in 100% na "Cipher Strength"?
nginx.cofig
server {
        listen 127.0.0.1:443 http2 ssl;
        server_name example.cum;
        server_tokens off;
        add_header Strict-Transport-Security 'max-age=31536000; includeSubDomains; preload' always;
        add_header X-Frame-Options SAMEORIGIN;
        add_header X-Content-Type-Options nosniff;
        add_header X-XSS-Protection "1; mode=block";
        access_log /var/log/nginx/example.cum/access-https.log;
        error_log /var/log/nginx/example.cum/error-https.log;
        ssl_certificate /var/certificates/example.cum.pem;
        ssl_certificate_key /var/certificates/example.cum.key;
        ssl_protocols TLSv1.3 TLSv1.2;
        ssl_prefer_server_ciphers on;
        ssl_ciphers 'TLS13-CHACHA20-POLY1305-SHA256:TLS13-AES-256-GCM-SHA384:TLS13-AES-128-GCM-SHA256:EECDH+AESGCM:EDH+AESGCM:EDH+AESCCM:ECDHE+CHACHA20:DHE+CHACHA20!aNULL';
        ssl_session_cache shared:TLS:2m;
        ssl_buffer_size 4k;
        ssl_stapling on;
        ssl_stapling_verify on;
        resolver 213.136.95.11 213.136.95.10 valid=300s;
        resolver_timeout 5s;
        ssl_ecdh_curve secp384r1;
        ssl_dhparam /etc/nginx/dhparam.pem;
        root /usr/share/nginx/example.cum/;
        location / {
                        try_files $uri /test.txt =404;
 Cipher Suites
Cipher Suites
root@debian:/# iptraf-ng
Please resize your window
  • spremenilo: HotBurek ()
HotBurek je izjavil:
Pobriši ven TLS13-AES-128-GCM-SHA256 pa poizkusi še enkrat (imo gre samo za nepomembno obliko točkovanja na testu - v resnici ta šifra ni na bistven način slabša od AES-256 različice).
  • spremenilo: jype ()
Javascript DOM based XSS vulnerability
Oddelek: Programiranje
154426 (3848) MrStein
[Python] HTTPS na desktopu dela, na Arduinu ne
91969 (1582) N4g4c3N
Nginx ne pošlje vseh HTTP headerjev
Oddelek: Izdelava spletišč
51620 (1487) BaRtMaN
Pošiljanje emaila na @siol.net
297086 (6255) SeMiNeSanja
LinkedIn spam?
113520 (2952) kunigunda
