[Python] HTTPS na desktopu dela, na Arduinu ne
N4g4c3N ::
Pozdrav,
Napisal sem kodo s katero lahko pošiljam SMS sporočila prek portala najdi.si. V prvem delu pošlje username/password, da dobi pravi cookie, v drugem delu pa pošlje request z SMS vsebino, telefonsko itd.
#!/usr/bin/python
import httplib,urllib
con=httplib.HTTPSConnection("www.najdi.si")
params=urllib.urlencode(XXXX)
headers={XXXX}
con.request("POST","/prijava.jsecloginform",params,headers)
data=con.getresponse()
data.read()
cookie=data.getheader("set-cookie").split(";")[0]
payload=[XXXX]
params=urllib.urlencode(payload, doseq=True)
headers={XXXX,"Cookie":cookie}
con.request("POST","/najdi.shortcutplaceholder.freesmsshortcut.smsform",params,headers)
Koda na desktop računalniku dela brez problema, na Arduinu Yun pa vrže ven tale error:
Traceback (most recent call last):
  File "./sms.py", line 7, in <module>
  File "/usr/lib/python2.7/httplib.py", line 958, in request
    self._send_request(method, url, body, headers)
  File "/usr/lib/python2.7/httplib.py", line 992, in _send_request
    self.endheaders(body)
  File "/usr/lib/python2.7/httplib.py", line 954, in endheaders
    self._send_output(message_body)
  File "/usr/lib/python2.7/httplib.py", line 814, in _send_output
    self.send(msg)
  File "/usr/lib/python2.7/httplib.py", line 776, in send
    self.connect()
  File "/usr/lib/python2.7/httplib.py", line 1161, in connect
    self.sock = ssl.wrap_socket(sock, self.key_file, self.cert_file)
  File "/usr/lib/python2.7/ssl.py", line 381, in wrap_socket
    ciphers=ciphers)
  File "/usr/lib/python2.7/ssl.py", line 143, in __init__
    self.do_handshake()
  File "/usr/lib/python2.7/ssl.py", line 305, in do_handshake
    self._sslobj.do_handshake()
ssl.SSLError: [Errno 1] _ssl.c:504: error:14077410:lib(20):func(119):reason(1040)
Da bi bila zadeva še bolj čudna, je do nedavnega koda tudi na Arduinu delala. Mogoče kdo ve, kaj pomeni ta napaka in kako se jo odpravi - sumim, da ima Arduino neke težave s HTTPS. Na googlu sem zapravil že precej časa, odprtje tele teme je moje zadnje upanje! :)
Alternativna rešitev bi bila, kako server prepričati, da zadevo spelje prek HTTP.
Druga alternativa bi bila, če kdo pozna kako stran prek katere lahko pošiljaš zastonj SMSe (brez HTTPS in captcha).
Hvala in LP
MUC ::
HTTPS je skupno ime za cel kup šifriranj. Kot ti javi python, kot kaže nimaš na Arduinu ustrezne podpore. Preveri verzijo openssla. Glede na to, da najdi.si uporablja TLS 1.2 pomeni, da moraš na Arduinu imeti openssl verzijo vsaj 1.0.2.
  • spremenil: MUC ()
N4g4c3N ::
Imam nameščen python-openssl verzija 2.7.3-2
MUC ::
python -c 'import ssl; print ssl.OPENSSL_VERSION'
Ali "openssl ciphers"
Kaj dobis?
N4g4c3N ::
root@Arduino:~# python -c 'import ssl; print ssl.OPENSSL_VERSION'
OpenSSL 1.0.1e 11 Feb 2013
Edit:
root@Arduino:~# openssl ciphers
SRP-DSS-AES-256-CBC-SHA:SRP-RSA-AES-256-CBC-SHA:DHE-DSS-AES256-GCM-SHA384:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA256:DHE-RSA-AES256-SHA:DHE-DSS-AES256-SHA:AES256-GCM-SHA384:AES256-SHA256:AES256-SHA:PSK-AES256-CBC-SHA:SRP-DSS-3DES-EDE-CBC-SHA:SRP-RSA-3DES-EDE-CBC-SHA:EDH-RSA-DES-CBC3-SHA:EDH-DSS-DES-CBC3-SHA:DES-CBC3-SHA:PSK-3DES-EDE-CBC-SHA:SRP-DSS-AES-128-CBC-SHA:SRP-RSA-AES-128-CBC-SHA:DHE-DSS-AES128-GCM-SHA256:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES128-SHA256:DHE-DSS-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA:DHE-RSA-SEED-SHA:DHE-DSS-SEED-SHA:AES128-GCM-SHA256:AES128-SHA256:AES128-SHA:SEED-SHA:PSK-AES128-CBC-SHA:RC4-SHA:RC4-MD5:PSK-RC4-SHA:EDH-RSA-DES-CBC-SHA:EDH-DSS-DES-CBC-SHA:DES-CBC-SHA:EXP-EDH-RSA-DES-CBC-SHA:EXP-EDH-DSS-DES-CBC-SHA:EXP-DES-CBC-SHA:EXP-RC2-CBC-MD5:EXP-RC4-MD5
  • spremenil: N4g4c3N ()
HotBurek ::
Za test sem preveril na dveh računalnikih; eden dela (OpenSSL 1.0.1t), drugi ne (OpenSSL 0.9.8zh). Error code je isti error:14077410.
openssl version
openssl s_client -connect www.najdi.si:443
root@debian:/# iptraf-ng
Please resize your window
N4g4c3N ::
Na desktopu imam verzijo 1.0.1f (dela), na Arduinu 1.0.1e (ne dela). Je to problem? Kako se to updejta?
Pa še output na Arduinu, če se probam connectat...
root@Arduino:~# openssl s_client -connect www.najdi.si:443
CONNECTED(00000003)
1996489800:error:14077410:lib(20):func(119):reason(1040):NA:0:
no peer certificate available
No client certificate CA names sent
SSL handshake has read 7 bytes and written 170 bytes
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
HotBurek ::
Mislim, da je problem verzija, ja. Je tudi MUC zgoraj napisal.
Sam ne uporabljam ne Arduino, ne opg, ne pip. Vseeno, mogoče ti spodnja linka pomagata, da narediš update preko pip update/upgrade xxx na novejšo verzijo.
https://codybonney.com/installing-pip-o...
http://samjbrenner.com/notes/using-pip-...
MUC ::
najdi.si uporablja ECDHE-RSA-AES256-GCM-SHA384, tega šifriranja pa ni na tvojem seznamu, ki si ga dobil z ukazom "openssl ciphers" ->upgrade
N4g4c3N ::
Hvala obema! Sicer sem se že včeraj neuspešno trudil z updejtom, ampak bom še poskušal. Če mi bo zmanjkalo idej, se pa spet javim.
Avtolog.si (strani: 1 2 3 4 … 7 8 9 10 )
Oddelek: Na cesti
478154820 (23848) mugen999
OpenVPN na DD-WRT
Oddelek: Omrežja in internet
91277 (1074) ExSpirit
4096-bitni ključi ne bodo dovolj?
93480 (2205) zee
LinkedIn spam?
113539 (2971) kunigunda
Linux sendmail - Problem !!!??
152314 (2075) n0name
