Forum » Igre » Assassin's Creed Valhalla (2020)
Leta 2020 naj bi izšla nova igra Assassin s Creed in naj bi se dogajala v Rimu.
Next Assassins Creed is codenamed Legion in 2020 on current and next gen
- Set in Italy at the end of reign of Marcus Aurelius (guy from Gladiator) and during the struggles of his son Commodus and the year of 5 emperors
- Play as Cassius or Lucia, a descendent of characters from Origins and Odyssey
- Unclear which is canon, but like odyssey features choices and heavy RPG elements and same story for both characters.
- Made by Sofia to tie up some loose ends for the “Ancient Trilogy” and currently is more first civ intensive than other game.
- Main story is more involved in assassins and politics with first civ and flashbacks to other points in Rome history being secondary. Ubi wants to make it feel more like assassins creed while feeling like Odyssey to make old and new fans happy
- Map is mainland Italy and small part of Gaul and Germania like Libya in Origins
- Revised mercenary and cultist system. Big cultists and main story assassinations have those memory things
https://boards.fireden.net/v/thread/450...
- spremenil: ahac ()
Da bo triologija se je govorilo že pred izidom igre Oirigins in, da bo Egipt, Grčija in Italija.
Moderator če lahko popravite naslov teme v Assassin s Creed Legion.
Hvala
Assassin's Creed Leak Points To Next Game Called "Legion"; Set in Ancient Rome
https://www.techquila.co.in/assassins-c...
Hvala
ahac ::
FAKE NEWS
https://twitter.com/accesstheanimus/sta...
News about the "Assassin's Creed: Legion" leak / rumor:
The image attached to it (https://boards.fireden.net/v/thread/450... ...) was actually taken from a CGI model of Ancient Rome by VFX Artist Nigel Hunt, leading to even less credibility to the rumor itself
Original video:
Izi ::
Ko branjevke na trgu širite neke nepreverjene novice
Čisto nič še ni uradno znanega o naslednjem AC.
ahac ::
Ja, vsak leak ni fake.
Ampak tud ni vsak anonimen leak resničen.
Mislm... jaz grem lahko zdle na 4chan pa napišem, da bo nasledn AC v vesolju, zraven dam pa sliko Marsa iz Wikipedije. A boš verjel?
Kako narediš dober fake "leak"? Napišeš nekaj že znanih informacij, dodaš malo predvidevanja in sklepanja, nekaj se izmisliš...
Ne rečem, da naslednji AC ne bo v Rimu. Čisto možno je, da bo.
Ampak slika v "leaku" je pa očitno slab photoshop in se mi ne zdi dovolj za potrditev igre.
No ja AC igra naj bi izšla 2020 in že dlje se govori, da naj bi se dogajalo v Rimu.
Kaj zdaj boš popravil naslov vsaj, da bo pisalo z normalnimi črkami ali boš zbrisal temo ?
ahac ::
Ja, vse to se že dolgo govori, ampak pravih dokazov pa ni.
Če malo analiziramo ta "leak":
- 2020? Včasih je Ubisoft izdal novo AC igro vsako leto, potem vmes ne, 2019 tudi vemo, da je ne bo. Stava na 2020 je skoraj garantiran zadetek.
- Marcus Aurelius? vzameš popularnega voditelja in malo zgodbe okrog njega. Dost možno, da zadaneš.
- Cassius or Lucia? Popularna imena. Če se pa izkaže, da ni res lahko rečemo, da je zgrešil samo pri imenih.
- descendent of characters from Origins and Odyssey? Glede na to, da so nasledniki ena glavnih tem AC je to dost verjetno, da smo v Origins ali Odyssey vsaj srečali njihove prednike tudi če to ni Bayek ali Kassandra.
- Unclear which is canon? aka, "tega nočem ugibat"
- Made by Sofia? Te igre ponavadi dela več studijev, dost verjetno, da zadaneš če omeniš enega.
- "Ancient Trilogy"? ponavlja so stare govorice.
- more involved in assassins and politics? Če se dogaja v Rimu, je to smiselno glede na story v Origins.
- Map is mainland Italy? Verjetno res ni Avstralija.
- Revised mercenary and cultist system? Ubisoft rad vzame popularne stvari in jih razširi v sequelu.
Vse to so lahko zelo "safe bet" ugibanja, čisto nič presenetljivega ni vmes. Če se res dogaja v Rimu (pa tudi, če se ne) bi bilo čudno, če vsaj nekaj od tega ne bi bilo res.
Počakajmo pa bomo vidl kolk je uganil.
Dobra analiza bomo videli :)
Ampak če se bo že dogajalo v Italiji bi lahko šli tudi malo v Slovenijo
Alamut is a novel by Vladimir Bartol, first published in 1938 in Slovenian, dealing with the story of Hassan-i Sabbah and the Hashshashin, and named after their Alamut fortress.
The novel and its plot were the inspiration for the popular Assassin's Creed series of video games. Many elements of the book's plot can be found in the first game, and the phrase from the novel under an alternative translation: "nothing is true; everything is permitted" is the guiding principle of the game's Order of Assassins--who are the fictionalized descendants of the Ismaili.
Berserker ::
Scenarij je preveč navezan na Origin, kjer so Rimljani že bili. Mogoče bi delovalo, če bi se dogajalo 4.stoletju, ko je Rim dosegel dokončno nadgradnjo in preobrazbo, da bi se lahko dovolj razlikoval od Brotherhooda in Origina.
Rad bi videl če bi se spet malce vrnili k realizmu prejšnih serij in hkrati obdržali mehanike iz Odiseja in Origina. Ali pa da se povsem odpovejo templarjem in assassinov ter bulshit zgodbi in ustvarijo kaj novega kot so to skorajda storili z Odisejem.
Izi ::
scipascapa je izjavil:
da bi serijo 1x zaklljučili, to pa ne?
Le zakaj, če pa je Ubisoftova paradna serija, ki ne samo nosi rekordne dobičke in to ne samo med Ubisoftovimi igrami ampak med vsemi igrami. Poleg tega za razliko od večine serij, ki z leti zvodenijo, AC postaja vedno boljša in boljša.
Od Origina naprej je AC serija postala ena najbolj kvalitetnih franšiz v igričarskem svetu. Odyssey je pa sploh igra zase popolnoma brez konkurence.
Dosedanja igričarska zgodovina: Doom, Half-Life, Witcher 3, Assassin's Creed: Odyssey, ...
Berserker ::
Ne pretiravat. Zadnji dve AC igri sta rešili detailiran svet dveh najbolj slavnih civilizacij na svetu. Igralno sta povsem generični, brez pravih inovacij, zgodba je tudi dokaj mehka, polna slabih cliffchangerjev.
Could Ubisoft be teasing a Viking themed Assassin's Creed?
https://powerup-gaming.com/2019/04/05/c...
mjolnir ::
Tole je komentar pod tem člankom, ki si ga postal: This series needs a lethal injection to put it to sleep...
Čst bi bil, da ponovno izvlečejo Perzijskega princa iz naftalina.
Ravno zaradi Assassin's Creed so Perzijca postavili na stranski tir in nanj pozabili.
Res pa je, da AC živi tako dobro, ker je že od začetka postala kura, ki nosi zlato jajce.
What Killed The Prince of Persia Series? (članek iz leta 2017)
https://gameranx.com/features/id/132482...
Did Assassins' Creed Kill Prince Of Persia? (forumsko sporočilo iz leta 2009)
https://forums.wrestlezone.com/threads/...
Kot zanimivost so tu vse informacije o predvidoma zadnjem delu Perzijskega princa, ki je naposled luč svet ugleda kot pri Assassin's Creed.
Prince of Persia: Assassin
https://princeofpersia.fandom.com/wiki/...
Tu je prototip:
Tu je prototip:
- spremenil: opeter ()
Rumor: Next Assassin's Creed Ragnarok Screenshots and Game Details Leaked, Releasing in 2020
https://www.thenerdmag.com/assassins-cr...
Po mojem mnenju je bila najboljša igra oz. del Assassina Creeda druga in prva, vse ostalo je bilo kar nekaj! Danes tega sranja sploh ne igram več, ker so šli preveč v fantazijo. Malo sem igral tistega notre dame, ko je bila igra zastonj ... kar neki duhovi in ostalo. Brezveze.
ahac ::
Še en fake....
To je nekdo naredil v Unity engine z asseti iz Unity store.
Izi ::
Mora biti pa precej zanimanja za naslednji Assassin's Creed, da je toliko "leakov" in "fakeov".
Govorice on Rimljanih so se pojavile februarja, govorice o Vikingih pa marca. Ena izmed teh dveh je zelo verjetno pravilna.
Osebno se mi zdijo Vikingi bolj realna možnost kot pa Rimljani, ki smo jih že kar nekajkrat dodobra obdelali.
Assassin's Creed Ragnarok To Be Unveiled In February; Maps, Gameplay Mechanics Detailed - Rumor
https://wccftech.com/assassins-creed-ra...
Assassin's Creed Ragnarok leaked on multiple shop websites
https://metro.co.uk/2020/01/08/assassin...
Lahko popravite naslov v Assassin's Creed Ragnarok . Hvala :)
overload ::
Mah ta Odyssey in Origins sta imela zgodbo čist dolgočasno in sploh ni povlekla. Če na tem področju ne bodo kaj naredili bo vse skupaj prazno. Tolk denarja zmetat v izdelavo, pa je težko spisat kaj pametnega. Pa tudi combat je veliko prelahek. Na nightmare in autoscale lvl nasprotnikov je bilo še nekako...
Ne vem, nazadnje sem bil razočaran, ker ima potencial ampak manjka globina...
Bantani ::
Assassins Creed 2 je bil zame najboljsi potem pa black flag,origins in odyssey...pri origins pa odyssey mi je pa sploh vsec to novo bojevanje tako,da upam da ne bodo glede tega nic spreminjali.
ahac ::
Naslov teme bom spremenil, ko bo igra uradno napovedana.
Če bi vedno spreminjal naslove na podlagi govoric in leakov (ali fake leakov) bi jih večkrat napačno kot prav...
Ja, z 2020 v oklepaju. :)
Novi leak
Februarja 2020 naj bi napovedali igro 29 septembra 2020 pa naj bi igra izšla.
Igra naj bi izšla za PC, Ps4 in Xbox One in seveda za next gen Ps5 in Xbox X Series.
- spremenil: oo7 ()
Po vsejverjetnosti naslov naslednje AC igre ne bo Ragnarok in večina leakov ni točnih
No ja drugi mesec bo vse jasno, ko igro uradno napovejo.
Assassin's Creed Valhalla Achievement List Leaks Online
https://gamerant.com/assassins-creed-va...
Možno, da bo pravi naslov igre Assassin's Creed Valhalla.
ahac ::
Haha, spet leak drugačnega imena igre.
Dobro, da še nisem preimenoval teme, ker bi bilo narobe.
New Assassin's Creed Game Will Reportedly Be Revealed Very Soon
https://www.playstationlifestyle.net/20...
Rumour: Assassin's Creed PS5 Reveal Coming Later Today
http://www.pushsquare.com/news/2020/04/...
Danes ?
Danes ?
ahac ::
Danes ?![]()
To je ta 'teaser' stream:
https://www.twitch.tv/assassinscreed
https://mixer.com/AssassinsCreed
https://www.pscp.tv/w/1BdxYQQjXjoxX
| » | Assassin's Creed Mirage (strani: 1 2 )Oddelek: Igre | 8240 (4227) | Zmajc |
| » | Assassin's Creed Odyssey [2018] (strani: 1 2 3 4 5 6 7 8 )Oddelek: Igre | 78814 (49527) | oo7 |
| » | Assassin's Creed: Origins (Assassin's Creed: Empire) (strani: 1 2 )Oddelek: Igre | 21753 (13528) | Izi |
| » | Assassin's Creed Syndicate (Assassin's Creed Victory) (strani: 1 2 )Oddelek: Igre | 24787 (12915) | Gagatronix |
| » | Assassin's Creed 3 (strani: 1 2 3 )Oddelek: Igre | 23668 (12875) | scipascapa |
