React native - ne dobim parametrov v header.
mihy11 ::
Pozdrav vsem.
Imam 2 screena.
1. Login screen,
2. Main screen (bottomTabNavigator z dvema taboma)
Želje?
Iz login screena želim preko parametrov prenesti uporabnika preko
navigation.navigate('Main',{user: user});
Problem nastane, ker v headerju v enem izmed tabov ne dobim teh parametrov. Vsak izmed tabov pa naj bi imel drugačen header, medtem pa Login screen naj ne bi imel headerja torej
header: null
v
navigationOptions
. Kako naj naredim, da bom imel custom header v obeh tabih in da se bodo parametri prenesli uspešno.
Naj omenim še to, če v bottomTabNavigator v enega izmed tabov ne dodam stack navigatorja(homeStack) se parametri prenesejo uspešno, vendar ni potem custom headerja.
Moj object zgleda takole: primer brez konkretnih podatkov
var user: {
  lastname: '...',
  email: '...',
Moja koda v app.js
const homeStack = createStackNavigator({
    screen1: {
      screen: Home,
      navigationOptions: {
                  headerStyle: {
                    backgroundColor: '#f4511e',
                  headerTintColor: '#fff',
                  headerTitleStyle: {
                    fontWeight: 'bold',
},{ initialRouteName: 'screen1'});
const Routes = createStackNavigator({
        Login: {
          screen: Login,
            header: null,
        Main: {
            screen: createBottomTabNavigator({
                Home: { screen: homeStack },
                Profile: { screen: Settings },
              initialRouteName:'Home',
      initialRouteName: 'Login',
export default class App extends React.Component {
  render() {
    return (
      <Routes />
Koda v screenu, kjer ne dobim parametrov;
export default class Home extends React.Component {
  static navigationOptions = ({ navigation, navigationOptions }) => {
    console.log(navigationOptions);
    console.log(navigation);
    // Notice the logs ^
    // sometimes we call with the default navigationOptions and other times
    // we call this with the previous navigationOptions that were returned from
    // this very function
    /*return {
      title: navigation.getParam('user', 'A Nested Details Screen'),
      headerStyle: {
        backgroundColor: navigationOptions.headerTintColor,
      headerTintColor: navigationOptions.headerStyle.backgroundColor,
      headerTitle: navigation.state.params.user.name,
    return {
  render() {
    return (
     <View style={styles.container}>
        <Text>Open up App.js to start working on your app!</Text>
        <Text>Changes you make will automatically reload.</Text>
        <Text>Shake your phone to open the developer menu.</Text>
      </View>
"Computers are good at following instructions, but not at reading your mind."
by Donald Knuth
Vse, kar ste si želeli vprašati o CSS, pa si niste upali. (strani: 1 2 3 4 … 23 24 25 26 )
Oddelek: Izdelava spletišč
1299390411 (7943) filip007
PM2 (Node.js Process Manager) in uporabniki
Oddelek: Operacijski sistemi
61129 (1065) dunda
Bootstrap pomoč- Preheader
51129 (960) zbrisan
Jquery
152212 (1936) mk818764
AJAX neznana težava
Oddelek: Programiranje
81567 (1361) luksorzi
