Forum » Na cesti » Kolesar, voznik, kolizija
kotanyi ::
To ni tisto, kar predlaga nevone, pa tudi učinkovito ni, če ni semaforizacija urejena tako, kot je na Nizozemskem (kjer imajo kolesarji križišče odprto dvakrat na interval, ko mora ves motorni promet stati).
Je pa to nasprotno tistemu, kar predlagate vi, torej, da se pretvarjamo, da mrtvi kot ne obstaja in da je vse fancy-dandy, samo še voznike avtov pretepemo pa bo...
@AndrejS: TO!
Je pa to nasprotno tistemu, kar predlagate vi, torej, da se pretvarjamo, da mrtvi kot ne obstaja in da je vse fancy-dandy, samo še voznike avtov pretepemo pa bo...Ne, ni. Statistični podatki jasno kažejo, da je za kolesarje in voznike najbolj udobno, če vzporedno vozijo skozi križišče s čim manj separacije, ker potem v desnem vzvratnem ogledalu dejansko ves čas vidiš kolesarje, ki niso že pred desnim vzvratnim ogledalom (in jih vidiš skozi vetrobransko steklo).
- spremenilo: jype ()
St235 ::
na 4, ker si jih očitno v svoji sveti križarski vojni spregledal:
https://www.avp-rs.si/wp-content/upload...
https://coloradosprings.gov/sites/defau...
http://content.tfl.gov.uk/international...
http://www.morpc.org/trans/BikePedBicyc...
kaj ko bi vsaj prebral preden linkaš? Boš izpadel precej manj neumno:
It has become clear that because details of the timing of traffic lights were omitted in the above post, some aspects of this design are causing confusion to some readers. With this design:
◾With or without cycling infrastructure, Dutch traffic lights avoid conflict in a way that those in other countries do not. Many traffic lights at a cross-roads in the UK and USA simply have two states. i.e. N->S and S->N are green simultaneously while W->E and E->W are red and vice-versa. Drivers can go straight on, left or right and those approaching in opposite directions will have to cross each others’ paths. However, in the Netherlands it is normal for the turns to have their own traffic lights which have different timings so that conflict is avoided.
◾Synchronization with cycle path traffic lights works in the same way, maximizing throughput while keeping danger at bay. When motorists have a green light for going straight ahead, cyclists also can ride straight ahead without right or left turning motorists having permission to cross their paths. However, when motorists are given a green light for a right turn this is separated in time from the cyclists’ straight on green so that conflict is avoided.
dobre prakse iz cele palete zahodnih držav govorijo o tem, da je največja neumnost, ki jo lahko narediš to, da kolesarsko stezo spelješ okrog ovinka. Tako, da rab bi videl to meko kolesarjenja, ki po tvoje tako projektira kolesarske steze.
Ja?
Clicketyclick
clack
- spremenil: St235 ()
kotanyi ::
Izpadel neumno?
Vsaj ne zagovarjam rešitve, ki dnevno zahteva smrtne žrtve. Obstoječa "rešitev" jih, kljub vajinim pobožnim željam pa umetniškim teorijam o nasprotnem ala this:
Je rekel svizec in nato zavil čokolado.
- spremenilo: kotanyi ()
nevone ::
Kako si to predstavljaš? takoj za križiščem še semafor za kolesarje? ali naj kolesarji 10m za križiščem random zavijajo levo čez dva pasova? Kako za vraga je to bolj varno?
o+ nevone
Obstoječa "rešitev" jih,Obstoječih rešitev je cela vrsta in te si med seboj niso enakovredne.
Če bi bilo po moje, bi bila križišča videti tako, da bi morala motorna vozila zapeljati na dvignjeno kolesarsko stezo, preden bi lahko nadaljevala pot. Tako bi fizično zagotovili, da bi motorna vozila zmanjšala hitrost na nivo, ki je varen za pešce in kolesarje, ter pešcem in kolesarjem dejansko ponudili udobje, ki si ga trenutno v prometu lastijo motorna vozila.
undefined naj bi izjavil:
Križišče ne izgleda več takoleJa, to je oboje že preizkušeno in se obnese zelo slabo.
nevone ::
Tega jaz ne verjamem. Zagotovo kolesarja lažje zaznaš, če ga imaš pred očmi, kot za očmi.
Razen, če je rešitev potem kamera, ki ti silhueto kolesarja predvaja na prvo vetrobransko steklo, na način, da še vedno vidiš skozi, se pravi precej diskretno, a vseeno vidno.
o+ nevone
Tega jaz ne verjamem. Zagotovo kolesarja lažje zaznaš, če ga imaš pred očmi, kot za očmi.Ker napačno predvidevaš, da kolesar stoji, kar nikakor ne drži.
Tole je še en primer, podoben tvojemu, ki stalno povzroča incidente, ker je kolesarska steza toliko umaknjena od cestišča, da vozniki motornih vozil zavijejo, ne da bi se prepričali, če kdo potuje po kolesarski stezi, ter praktično vedno odvzamejo prednost kolesarju, ki po kolesarski stezi vozi vzporedno z glavno cesto.
Razen, če je rešitev potem kamera, ki ti silhueto kolesarja predvaja na prvo vetrobransko steklo, na način, da še vedno vidiš skozi, se pravi precej diskretno, a vseeno vidno.Rešitev je, da je kolesar _na cesti_, kjer je bistveno bolj opazen.
nevone ::
Saj vseeno, če ne stoji, najprej se pelje malo desno in pride v vidno polje voznika. Tudi hitrost mora precej zmanjšati, tako da voznik ima v resnici več časa, da ga opazi, tudi če se premika.
Seveda pa križišče ne sme biti narejeno tako udobno, kot je na nekaterih primerih zgoraj, ampak tako, da je hitro zavijanje na desno precej oteženo.
Kar samo pomeni, da je v bistvu treba precej malo poseganja, da se ideja realizira.
o+ nevone
o+ nevone
Saj vseeno, če ne stoji, najprej se pelje malo desno in pride v vidno polje voznika.Ne, to ni res.
Tudi hitrost mora precej zmanjšati, tako da voznik ima v resnici več časa, da ga opazi, tudi če se premika.Ne, tudi to ne drži.
Seveda pa križišče ne sme biti narejeno tako udobno, kot je na nekaterih primerih zgoraj, ampak tako, da je hitro zavijanje na desno precej oteženo.Ni problem v hitrosti avtomobila. Avtomobil lahko čisto počasi kolesarju zapre pot, pa s tem ničesar ne spremeni.
Kar samo pomeni, da je v bistvu treba precej malo poseganja, da se ideja realizira.Ja, ampak _ideja je slaba_, ker _podatki o nesrečah jasno kažejo_, da _je problem take ureditve v tem_, da _ne poveča verjetnosti, da bo voznik opazil kolesarja_, poveča pa verjetnost, da bo kolesarju zaprl pot, ne da bi pogledal desno, predvidoma zato, ker se mu bo zdelo, da je na prednostni cesti, ki jo kolesarska steza prečka, ter ima torej prednost, pa tudi možnost, da bo kolesarja opazil, je bistveno manjša, če mora kolesar pred križiščem, v katerem samo želi peljati naravnost, močno zavijati.
nevone ::
Ta primer je slab, ker je odmaknjeno premalo.
To kolizije zavijanja desno in vožnje naravnost ne rešuje, razen če boš kolesarje dal na sredo vozišča enega pasu.
o+ nevone
Ta primer je slab, ker je odmaknjeno premalo.Ne, ni, to je bistveno več kot 5 metrov. Videti je, da voznikom ocenjevanje dimenzij predstavlja velike težave.
To kolizije zavijanja desno in vožnje naravnost ne rešuje, razen če boš kolesarje dal na sredo vozišča enega pasu.Rešuje je ne, jo pa bistveno zmanjša.
darksamurai ::
Logika špecjalcev na tem forumu:
"kolesar" prevozi rdečo in ga zbije avto. Krvi je voznik avtomobila.
"kolesar" prevozi rdečo in zbije pešca. Kriv je pešec.
"kolesar" obvozi zapornice in ga zbije vlak. Kriv je strojevodja.
"kolesar" zbije zapornico. Kriva je zapornica.
Še malo pa bomo iz te teme naredili grotesko.
darksamurai je izjavil:
Logika špecjalcev na tem forumu:Lahko še citiraš? Seveda ne - če si izmisliš, kaj pišejo drugi, potem si prisiljen parafrazirat.
nevone ::
Ja morda od ravne linije roba vozišča, ne pa od tam, kjer se ovinek neha.
o+ nevone
darksamurai ::
Če samo tebe citiram, bom imel za 10 strani primerov.
Če samo tebe citiram, bom imel za 10 strani primerov. ;)Potem ti vsaj enega ne bo težko poiskati.
Ja morda od ravne linije roba vozišča, ne pa od tam, kjer se ovinek neha.Aha, razumem: Ti bi za 100 metrov podaljšala pot kolesarja ob vsakem križišču, posledica pa bi bila, da kolesar efektivno nikjer več ne bi imel prednosti, saj bi tam moral ustaviti in počakati na prosto pot, namesto da bi se peljal naravnost.
Sliši se kot odlična rešitev za čim več kolesarjev prepričati, da naj si raje kupijo lasten osebni avtomobil, kot da se sami sebi zdijo butasti, ko poskušajo potovati skozi gosta urbana naselja.
nevone ::
Najprej ni 100 metrov, potem pa kolesar bi še vedno imel prednost, tako kot jo ima sedaj, ker bi še vedno voznik moral počakati, da gre kolesar preko.
Slamnati mož.
o+ nevone
Vanquish ::
kateri zakon da prednost kolesarju prednost, ko po desni prehiteva avto, ki zavija desno?Vrni vozniško dovoljenje, če ga imaš, ker ga ne bi smel imeti:
Kolikor vem ima prednost avto?
3. odstavek 58. člena ZPrCp:
Voznik, ki zavija na križišču desno, mora pustiti mimo vozila, ki vozijo v isti smeri po kolesarskem pasu ali kolesarski stezi, ki jo prečka.
kje sem govoril o kolesarski stezi? V primeru kolesarske steze bi napisal - prehitevanje po kolesarski stezi ne pa po desni strani.
Citiram:
Ampak tu mi ni logike...zakaj je kolesarju, ki je udeleženec v prometu in enako na cesti kot jaz - dovoljeno PREHITEVATI po desni strani?
govora je bilo o cesti. Kolesarska steza je kolesarska steza ne glede na to, ce je locen del cestisca ali ne in ima kolesar tam prednost in to mislim, da je vsem jasno?
V praksi pa se dogaja, da stojis na semaforju na normalni cesti, kjer se kolesar prebije med avti in plocnikom do tebe, tezava pa nastane, ko ti zavijes desno on pa hoce ravno.
Se pravi svojo majhnost izkorisca, da te prehiteva znotraj tvojega pasa. S specialkami pa vecina kolesarjev vozi po cesti, ker so prehodi iz ceste na kolesarske steze narejeni tako, da unicijo celo kolo.
kotanyi ::
Aha, razumem
Slabo razumeš. Kot ponavadi, zanalašč.
Resnica pa je taka, da je daleč največ nesreč posledica obstoječe in s tvoje strani zagovarjane ureditve, ki ne upošteva preprostih fizikalnih zakonitosti. Resnica je tudi, da je nevonina rešitev skupaj z dvignjenim voziščem in vidnimi označbami najbolj varna za oboje in ne zmanjšuje pomembno tvojega udobja kot kolesarju - ga pa zato avtomobilistom. Ampak ja, žal bodo morali gospod presvetli najbrž na parih koncih malce zaviti in voziti počasneje kot pa 25kmh.
Skratka, ti bi imel udobje pa kurc gleda varnost in vse ostale. Zakua nisi že takoj povedal?
kolesar bi še vedno imel prednost, tako kot jo ima sedaj,Ne ga lomt, no. A tako, kot imajo prednost pešci na prehodu? Nihče ne bi ustavil.
Slamnati mož.Ne, dejstvo.
kje sem govoril o kolesarski stezi? V primeru kolesarske steze bi napisal - prehitevanje po kolesarski stezi ne pa po desni strani.Potem imaš prav - prehitevanje po desni je prepovedano. Če motorno vozilo stoji, potem ni prehitevanje.
V praksi pa se dogaja, da stojis na semaforju na normalni cesti, kjer se kolesar prebije med avti in plocnikom do tebe, tezava pa nastane, ko ti zavijes desno on pa hoce ravno.Ko stojiš pri semaforju, se mora kolesar prebiti _pred_ avtomobile in speljati prvi, ker je to najbolj varno. Žal zgolj redka križišča to spodbujajo.
Se pravi svojo majhnost izkorisca, da te prehiteva znotraj tvojega pasa. S specialkami pa vecina kolesarjev vozi po cesti, ker so prehodi iz ceste na kolesarske steze narejeni tako, da unicijo celo kolo.Drži. Lane splitting @ Wikipedia je v večini zakonodaj legalen, ker poveča varnost za motoriste in kolesarje.
nevone ::
Za ta način dojemanja ni dobra nobena rešitev, razen taka, da avtomobile spraviš s ceste, kar je očitno tvoja agenda.
Ne, dejstvo.
Praviš, it's war out there? Samo, če pretiravaš.
o+ nevone
nevone ::
Upam si trditi, da je moja rešitev varnejša in zelo jasno pušča kolesarjem prednost, ki jo je na ta način lažje varno zagotavljati in dopušča manj dvoumnih situacij.
Mislim pa tudi, da je lane splitting lahko učinkovit, ampak šele pri večjem številu kolesarjev.
o+ nevone
darksamurai ::
@jype
Si že prebral?
vir: policija.si
Si že prebral?
Vozniki koles so v najhujših prometnih nesrečah v več kot polovici primerov povzročitelji nesreče. Kolesarji najpogosteje povzročijo prometne nesreče zaradi:
- nepravilne strani in smeri vožnje (vozijo preblizu roba vozišča ali celo po nasprotni polovici), kar je pogosto povezano tudi z vožnjo pod vplivom alkohola,
- vožnje pod vplivom alkohola,
- neupoštevanja pravil o prednosti (največkrat na križiščih, saj pozabljajo, da tamkajšnji "stop" znak ali znak "križišče s prednostno cesto" velja tudi zanje, in ne le za voznike motornih vozil,
- pogostokrat pa tudi hitrosti ne prilagodijo stanju in lastnostim ceste, še posebej na posameznih odsekih cest z večjim naklonom.
vir: policija.si
- spremenilo: darksamurai ()
krneki0001 ::
Unknown_001 ::
Facts:
Trenutna infrastruktura je povečini za sočasen mešan promet popolnoma zanič.
Slaba infrastruktura je neučinkovita in tudi izjemno naporna za koncentracijo udeležencev.
Zanič infrastruktura je nevarna za vse udeležence.
Zato prosim ne nakladajte v smislu *zamahnem z roko in ignorantsko feham: "Ehhhh, bodo pa malo bolj okoli sebe gledali". Seveda! To je rešitev, ko se nobememu ne da ubadat s problemom. Najlažje dvignit roke vstran in mogoče v najboljšem primeru postavit kakšno tablo, to je pa to. Vedno je izgovor "denarja ni", ljudje bi morali bolj pazit. OPA!!! Če se nesreče dogajajo zaradi slabe preglednosti, bi morali odgovarjati tudi vsi tisti, ki so ustvarili nevarne odseke, privoze na glavno cesto, križišča...
Seveda v našem slikovitem primeru blokiranja kolesarske poti je več dejavnikov
1. nepreglednost in mrtvega kot, ker je kolesarska pot preblizu vozišča in speljana tako, da se avtomobil ne more niti obrniti tako, da bi voznik imel pregled na levo in desno. Mene je bilo s kombijem po Ljubljani vedno strah zavijati desno, ker enostavno drugače kot v špegu pod nekim kotom ne moreš vedno videti kolesarja, zato vedno 100m pred križiščem pogledam ali vštric vozi kak kolesar, spremljam pločnik in če ga ni, počasi odvijem, gledam špegu, desno in upam na najboljše.
2. nešolani zabiti kolesarji, ki ne razumejo, da morajo voziti v pravo smer po kolesarski, tako da imajo cestišče na svoji levi, ne pa da vozi v napačno smer. Problem posameznih mentalno przadjth oseb.
3. Nespremljanje okolice in raba telefona, kar je seveda problem posameznih voznikov in ne toliko kulture.
4. Neuporaba smernikov, neopazovanje okolice in slepo zaupanje v prednost. Ja, veliko trkov bi se lahko preprečilo, če ljudje ne bi kar rinili s polno brzino z mislijo "jst mam prednost, jst mam prednost"... v takem primeru namerno povzročijo "nesrečo" (kjer seveda niso krivi), ki bi se ji lahko ognili. Ampak zaradi počasne pameti in kokošjih možganov pač impossibru dojeti, da odgovornost ni črno bela kot piše po zakonu. Navadno sta za pizdarijo potrebna 2 idiota.
Begabt
Begabt
nevone ::
Že, že ... ampak s tehničnimi rešitvami skušaš pomagati tistim, ki so te rešitve voljni sprejeti, ker se zavedajo, da se tudi njim lahko kaj zalomi. In če se s tehnično rešitvijo poveča varnost ljudi, bodo odpadle vsaj nesreče ljudi, ki so jih pripravljeni upoštevati in prepoznajo v njih izboljšavo zase.
Vse prepričati, da se bodo vedno in v vsakem trenutku optimalno obnašali zaenkrat ni možno, in (vedno) bo nekaj tudi takšnih, ki so tako zagledani vase, da mislijo, da se njim ne more nič zgoditi, ker itak obvladajo u nulo.
o+ nevone
o+ nevone
bambam20 ::
Nekaj mi sicer ni jasno...zakaj je kolesarju dovoljeno prehitevati po desni??
Sej jim ni dovoljeno prehitevanje po desni. Nikomur ni. S kolesom , ker je ozek pač to lahko narediš. Z avtom pa ne moreš.
o+ nevone
Možno je možno. Samo kazni so prenizke in izpirtna dovoljenja se talajo kot čokolade.
- spremenilo: bambam20 ()
nevone ::
Tukaj ni govora o prehitevanju po desni, ampak o problemu, ko imata kolesar in voznik oba zeleno luč, eden za vožnjo naravnost, drugi za zavijanje desno. Takrat je predpisana prednost tistega, ki gre naravnost, torej kolesarja.
o+ nevone
bambam20 ::
o+ nevone
Kje ti vidiš problem? Prednost ima tisti, ki gre naravnost. Pa to ne pomenim da lahko kar voziš in gledaš v zrak kot en kurčev zbezneli konj! Če imaš prednost je treba tudi opazovat promet okoli sebe. Jao, kakšne otroške teme imate na tem forumu.
Če ne ta pa avto povozi pa vpiješ, da si imela prednost! Ja pa zlomljeno nogo in poškodbo možganov.
Na cesti najbolje uspeva tistim, ki poznajo pravila se jih držijo in opazujejo promet okoli sebe.
Brez kršenja pravil pa ne bo šlo. V tem primeru bi morali imeti 100% nadzor s kamerami , tudi v samih vozilih in bi se v primeru beleženja prekrška takoj posnetek prenesel v varnostni center, kjer bi takoj posredovali in spisali kazen.
o+ nevone
A sedaj bo mel pesec se daljso pot, da tvoja riti na sedezu ne bo morala biti tako skoncentrirana med voznjo? Res, cudno, da tega niso se uvedli.
Unknown_001 ::
o+ nevone
Zato pa je bil prvi del traktata posvečen infrastrukturi ki je pošteno povedano zanič. Kolesarska steza ne bi smela biti speljana direktno naravnost ampak bi morala biti speljana rahlo desno, da se lahko vozilo , ki zavija zravna pravokotno, preden prispe do nje. Tako lahko voznik pravi čas opazi kolesarja, kolesar pa ima prav tako boljšo preglednost in več maneverskega prostora, da lahko upočasni, če ga voznik "izsili" in nato nadaljuje pot.
IDIOTIZEM
CIVILIZIRANA REŠITEV
Hint: bodite pozorni na kolesarske steze.
Begabt
Begabt
bambam20 ::
Kako rešiti, da bi se neprijetno križanje voznika, ki v križišču zavija desno in kolesarja, ki po njegovi desni strani vozi naravnost, dogajalo čim redkeje ali pa sploh ne?
To se enostavno reši, da se v vsa križišča postavi 4K kamere in se pošiljajo položnice. Verjemi, da ne bo nikomur niti na pamet prišlo, da bi kršil predpise.
Unknown_001 ::
S tem si dokončno potrdil vse dvome o tvoji vredostojnosti. Štempl BUKSL
Begabt
Begabt
bambam20 ::
Problem je, ker vsepovsod ni možno v Ljubljani dodati kolesarskih stezm ker ni prostora.
Unknown_001 ::
Eh...
Begabt
Begabt
nevone ::
Iz česa ti pobiraš takšne ideje, kot so to, da jaz mislim, da ni treba nič gledati okoli sebe, potem pa to, da me avto povozi pa vpijem, da imam prednost?
Jaz sem samo povedala, kako je urejeno, in kdo ima prednost _po predpisih_ in da to ni isto, kot med vožjo prehitevati po desni, ker se nanaša na križanje vozila in kolesa v samem križišču, ne pa na vožnjo obeh naravnost.
o+ nevone
- spremenila: nevone ()
St235 ::
Unknown_001 je izjavil:
o+ nevone
IDIOTIZEM
In se kar ponavljas idiotizme ki temeljijo na lastnih blodnjah in mirno ignoriras konkretne raziskave, ki jasno kazejo kaj so dobre prakse. Res zalostno. In potem taki vozijo po cesti in si domisljajo da so varni vozniki na podlagi lastnih dusevnih motenj in ocitnih resnih tezavah v kriticnem mislenju.
nevone ::
Kritično mišljenje je tisto, ki v raziskavah poskuša najti napako ali izboljšavo, ne pa se je oklepa kot pijanec plota, samo zato, ker ima naslov Raziskava. So že bile napake in pomankljivosti v raziskavah, zato to ni noben garant.
Lahko se pa vsaj kulturno pogovarjaš in oponiraš, če se ne strinjaš.
o+ nevone
Raptor, ti si tko al tko bedak in mi tvoje mnenje nic ne pomeni. Seveda pa krizisca po Ljubljani dokazujejo, da se drugi strinjajo z menoj. Lahko pa seveda dokazes nasprotno:).
Unknown_001 ::
Za razliko od tebe sem vsaj šolan bedak :)
Begabt
Begabt
O fuck, a mas bolonjsko diplomo? Kak dosezek!
Brez zamere, sam glede na dolocene tvoje prijave, mislim, da tvoj faks ni vreden pocenga grosa.
- spremenilo: tikitoki ()
Unknown_001 ::
Sine... kaj te je zbodlo? Je treba popihat kje? :) Ne vem ti pomagat, če mi ne poveš, kaj te moti.
Begabt
Begabt
- spremenilo: Unknown_001 ()
Unknown_001 ::
Jezen? Ker si izobrazeno teslo? Prav zabavno se slisi:).
Ne, ti si zabaven. Kot sem ti že rekel. Najbolj idiotska stvar pri tebi je, da rečeš: "Zaključila sva" nato pa se vračaš za tvoj */s on* FULLLL epic!!!! */s off* comeback
Sicer pa bi te kap, ko bi videl, kako uspem folgat vse stvari hkrati.
Begabt
Begabt
@jypeNe bo nič s citiranjem? Se mi je zdelo.
Vse prepričati, da se bodo vedno in v vsakem trenutku optimalno obnašali zaenkrat ni možno, in (vedno) bo nekaj tudi takšnih, ki so tako zagledani vase, da mislijo, da se njim ne more nič zgoditi, ker itak obvladajo u nulo.Zato je najbolj smiselno fizično omejiti tiste, ki trenutno povzročajo daleč največ škode. Avtomobili naj vozijo počasi in skačejo na grbine in z njih ves čas, ko so v urbanem okolju, ostali pa imejmo en udoben nivo, ki je tudi varen pred visokohitrostnimi morilci v jeklenih napravah.
Rok Woot ::
Lahko bi uvedli obvezno ustavljanje avtomobilov na lokalnih in regionalnih cestah pri zavijanju v desno. Že tako kolesarska zavija, včasih pelješ celo gor pa dol, ker so dovozi. Naj omgočijo lepe kolesarske poti in glede na njih prilagodijo ceste za avtomobile in ne obratno.
Pa taka križišča bi morala biti povsod, vem pa samo za eno v Ljubljani.
- spremenilo: Rok Woot ()
| » | Semafor velja tudi za kolesarje (strani: 1 2 3 )Oddelek: Šport | 24218 (12514) | Invictus |
| » | Na kolesu me je zbil avto (strani: 1 2 3 4 )Oddelek: Na cesti | 63847 (59127) | jype |
