brezžični prenos (internet) hitreje al isto hitro kot optika.. kdaj bo to?
shintaro ::
A je to sploh možno?
blink ::
"Let's take London-Frankfurt as a real-world example. As the raven flies, the two cities are 396 miles apart. A radio signal travelling through air at just under the speed of light (299,700km per second) would cover that distance in 2.126 milliseconds. Through a glass or plastic fibre, where light has to bounce along the refractive index rather than travel in a straight line, the speed of light is reduced to around 200,000km/s, resulting in a theoretical minimum latency of 3.186 milliseconds."
https://arstechnica.com/information-tec...
shintaro ::
blink je izjavil:
thx
Nikonja ::
Ampak tu ni pomembna hitrost kot bandwith ampak latency, in finančnim institucijami je to zeloooo pomembno, ostalima tudi ampak niti blizu v takšni meri.
Bandwidth: Bandwidth determines how fast data can be transferred over time. Bandwidth is the amount of data that can be transferred per second.
Latency: Latency is delay. Latency is how long it takes data to travel between its source and destination, measured in milliseconds.
Najhitrejši brezžični prenos podatkov:
https://www.extremetech.com/electronics...
shintaro ::
Nikonja je izjavil:
waw zelo zanimivo branje
SaXsIm ::
Svetloba v optičnem vlaknu potuje počasneje kot radijski valovi v zraku.
SaXsIm
vostok_1 ::
Je pa bistveno bolj zanesljiva in potrebuje manj error cheking mehanizmov. Pa še precej težje za prisluškovat.
There will be chutes!
It came from the lab.
  • spremenil: vostok_1 ()
Radijski spekter se deli med vse uporabnike.
Kabel do tvojega doma ne.
Seveda je pa vprašanje kak link naprej je od end-point vozlišča.
SaXsIm ::
No shit, Sherlocka. Ampak vprašanje na takšnem nivoju pač zasluži primeren odgovor.
SaXsIm
  • spremenil: SaXsIm ()
Miha 333 ::
Kaj niso LTE hitrosti prenosa že primerljive s tistimi na optiki?
Miha 333 je izjavil:
Od kdaj pa imaš na LTE samo zase 1Gbit/s??????
Miha 333 ::
Dobro, 1 Gbit/s je luksuz. Povprečne hitrosti uporabnikov interneta na optiki so 10 - 100 Mbit/s
mojster_joni ::
odvisno, 1 gbit dl in ul je lukus, 1 gbit dl ja pa manj kot 20 eur nažalost... mar bi imeli 500/500
Prvo javno omrežje 4G bo na Švedskem
416753 (4492) PrimozR
kontrola outputa informacij
81792 (1600) Thomas
Kakšna hitrost je FLOP?
81716 (1534) Dr X
Gravitacija s svetlobno hitrostjo
Oddelek: Novice / Diski
102553 (2553) Aggressor
Nasvet
93782 (3612) Huey P
