Forum » Pomoč in nasveti » Kakšna hitrost je FLOP?
Dr X ::
Pozdravljeni!
Zanima me samo, če mi zna kdo malo bolj razložiti kakšna hitrost je to FLOP (z njo je ponavadi podana hitrost super računalnikov). Zanima me kako bi to primerjali s hitrostjo osebnih računalnikov, katerih hitrost je podana v hercih.
Že v naprej se vam zahvaljujem za odgovor.
Nič ni nemogoče.
frenk ::
flops-i so floating point operacije na sekundo...torej to pomeni koliko operacij z realnimi števili lahko procesor naredi na sekundo...to je seveda bol tko simpl rečeno, sigurno se pa da to dodatno zakomplicirat
Dr X ::
To sem že nek preblral. Mene pa zanima kakšna je to hitrost v primerjavi s Hz (a se da mogoče to izrazt c hercih).
Zheegec ::
NE! Se pa najbrž da približno izraziti z IPC in MHz, samo težko in nenatančno.
Recimo CPU z 1GHz in IPC=1 je najbrž počasnejši od CPU s 500MHz in IPC=4. Seveda v večini primerov
Janez Janša, 29.04.2014
OmegaBlue ::
ekole ti podam kar v originalu:
FLOP
FLOP is an acronym for FLoating point OPeration. A floating point operation is meant to be an elementary operation (such as sum, subtraction, multiplication, division). FLOPs (the lowercase s suffix stands for the plural, and should not be confused with FLOPS) are used as measure of the amount of computation to perform.
A MegaFLOP corresponds to 106 FLOPs, a GigaFLOP is 109 FLOPs, and a TeraFLOP is 1012 FLOPs.
FLOPS
FLOPS is an acronym for FLoating point Operations Per Second. This is used to express the speed of a processor, and it measures the number of FLOPs that are processed in one second. Hence, for example, a CPU that processes 1.2 GigaFLOPs per minute, has a speed of 1.2 * 109 FLOPs / 60 seconds = 20 MegaFLOPS MegaFLOPS, GigaFLOPS, and TeraFLOPS stand for 106, 109, and 1012 FLOPSs, respectively.
FLOP
FLOPS
frenk ::
zalaufaš sandro in zmeriš koliko flopsov naredi tvoj cpu, potem pa primerjaj s superračunalniki
Arthur ::
samo popravek, tule manjkajo strešice za potenco - torej 10^6, 10^9... itd.
Dr X ::
Sam tko, če koga zanima. Če sem prov prebral rezultat v Sandri ma Pentium 4 2,4 GHz hitrost približno 19 KFLOPS/s.
Nič ni nemogoče.
| » | Najzmogljivejši superračunalnik na svetu postavlja rekorde (strani: 1 2 )Oddelek: Novice / Znanost in tehnologija | 18940 (16119) | SavoKovac |
| » | Japonci rušijo rekordeOddelek: Novice / Znanost in tehnologija | 6531 (5268) | Pyr0Beast |
| » | Novi IBM-ov superračunalnikOddelek: Novice / Ostale najave | 7454 (6482) | Monster |
| » | Cray že ponuja dvojedrne Opterone (strani: 1 2 )Oddelek: Novice / Procesorji | 9162 (8147) | Thomas |
| » | Cluster kot delovna postajaOddelek: Novice / Procesorji | 3894 (3894) | OwcA |
