Nasvet
Nasvet
Pretorijanec ::
Preberte spodnji slovar, da bost vedl pojme.:D
"Glossary Of PC Terms"
If you have a term that you want to add or want like to see added, drop us a line.
AGP - Accelerated Graphics Port (strictly for video cards)
ATA - Advanced Technology Attachment
BIOS - Basic Input / Output System (on bootup you can access it usually with the "del" key or F10 key)
CACHE - A special high-speed storage mechanism. It can be either a reserved section of main memory or an independent high-speed storage device. Two types of caching are commonly used in personal computers: memory caching and disk caching.
cBO - The stepping of P3 that failed to reach 1Ghz
cCO - The embarrasment of the decade when Intel had to remove it's 1.13Ghz chips from the market place as they weren't fit for the speed.
COLD BOOT - The reboot of a computer by electrical switch. (actually shutting off the power)
CPU - Central Processing Unit (main processor for your system)
DIMM - Dual Inline Memory Module
EB - Denotes a Coppermine processor running on a 133Mhz bus. E meant coppermine and B meant Bus!
ECC Error - Correcting Code memory, a type of memory that includes special circuitry for testing the accuracy of data as it passes in and out of memory.
FC - Flip Chip
FCPGA - Flip Chip Pin Grid Array. Intel named it the "flip chip" because the cache was soldered on the underside of the chip. (hence you had to flip it over to see it)
FSB - Front Side Bus
FPS (not the games) Floating Point Scheduler
FPS (the games) Frames per second
FPS (also the Games) - First Person Shooter
FPU - Floating Point Unit a specially designed chip that performs floating-point calculations. Computers equipped with an FPU perform certain types of applications much faster than computers that lack one. In particular, graphics applications are faster with an FPU.
GHZ Gigahertz = 1000 Megahertz
GPU - Graphical Processing Unit (processor on your video card)
HD - Hard Drive
HSF - Heat Sink & Fan
ISA - Industry Standard Architechture (old school and runs at 1/2 the speed of PCI)
LNK = Lovely New Kit - New hardware that enhances a user's computer, life and brag factor!
MHZ - MegaHertz
MOBO - Motherboard
MTBF = Mean Time Before Failure - The average time (in hours usually) you can expect a hard-disk/Cd-Rom drive to work before it dies.
OEM - Original Equipment Manufacturer destined - a chip or component is OEM when it doesn't come in fancy retail packaging and is usually in a white box. Usually cheaper as a conseuqence. These articles aren't meant for retail sale - but they end up there..
OS - Operating System
PARITY - Comparing data for odd or even numbers. Used for error correction.
PCI - Peripheral Component Interconnect (occasionally called Peripheral Component Interface)
PSU or PS - Power Supply Unit
PS2 - Not a Playstation2 - but relates to a range of IBM PC's from the early nineties that used their own kind of connectors instead of AT type connectors for keyboards and serial connectors for mice.
PPGA - Plastic Pin Grid Array
RAID - Redundant Array of Inexpensive Disks (system to use several disk to secure against data loss and speed data access)
Retail - This is the fancy box and full mfg warranty. Intel chips have a 3 year warranty where OEM is anywhere from a week to a year.
SCSI - Small Computer System Interface. Much faster and more expensive. Replaces IDE but usually is only commercially used.
SIMM - Single Inline Memory Module
Soft Boot - To force a reboot of the computer by software command - this may be by Ctrl+Alt+Del or by a command or simply Start....Shutdown....Restart. Rebooting w/o actually shutting down power to the system.
Socket 370 - The Intel socket that originated as home for the Celeron PGA and is now home for coppermine celerons and P3's. Will soon become home to TualatinSocket A - The socket of the Duron, Thunderbird and soon the Morgan, Palamino and Mustang
Slocket - An adapter to enable the use of socket 370 PPGA or FCPGA chips in a slot 1 motherboard environment
Slot 1 - A 242pin slot adapter for Celerons, Pentium 2's and 3's
Socket 7 - A 321 pin socket that formed the home of chips from Pentium classics, Cyrix UDMA - Ultra Direct Memory Access 6x86 chips, Winchips and AMD K6 series chips. Now obsoleted officially. Vcore - Core Voltage of the CPU
USB - Universal Serial Bus
Huey P ::
ATX - AT Extendet
ISP - Internet Service Provider
RPM - Rotations Per Minute
..::DOOM III: The Legacy::..
R@C@ ::
DJD - Deejay_duck
:D
Pretorijanec ::
Ej, Huey, a greva nardit slovar, pa receva pol luniju da ga objau na slo-tech? Mislm, da prevedeva kokr se da u slovenscino. Al pa tut kr tko pustiva sam mal urediva iskanje, pa se mal razsirva besedilo? Si za?
R@C@ ::
Tole sploh ni slaba ideja...
Mal se potrudta....pa recimo prevedta še kaj je to BUS!
Recimo v stavku: BUS Ratio select!
Dax ::
BUS ni kratica in besedo prevedemo v "vodilo".
_fim_ ::
Kul ej stari...:)) Tot šit je baje treba znat...:(
Huey P ::
Oprosti, da ti pišem tako pozno (7 dni pozno), ampak šele zdaj sem opazil!
Malo bolj mi razloži kva misliš s tem. A da prevedeva računalniške kratice v SLO pa jih pol dava luniju da jih objavi?? Za prevajanje sem "The Man" (ne da bi se hvalil ampak angleščino redno obvladam).
Pretorijanec ::
Ja. Neki tazga. Če maš nedeljo prosto, pa nimaš nč za delat, mi piš pa grva prevajat. Lahk še kere pojme dodava,...
Huey P ::
O.K. It´s a DEAL!!!
Naslove strani, kje lahko dost tega najdeš sem ti že poslal...
Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )
Oddelek: Novice / Nova vsebina
13820331 (17171) arrigo
athlon64 VS sempron64 (soc.754)
91642 (1474) mtosev
Novi IBM-ov superračunalnik
267454 (6482) Monster
Tisto, kar je ostalo od obširne najave procesorjev GF4
Oddelek: Novice / Procesorji
73244 (3244) Alec999
