Forum » Problemi človeštva » NATO in Rusija
NATO in Rusija
Berserker ::
Putka je na zadnjem fotošešnu nosil ameriške škornje.
https://twitter.com/VictorKvert2008/sta...
http://uspatriottactical.com/corcoran-m...
http://www.corcoranandmatterhorn.com/ab...
Corcoran® has earned the respect of military personnel over the years. From the “Original Jump Boot” that carried paratroopers behind enemy lines in Europe to the newest “Combat Boot” currently being worn in operations in Iraq. Corcoran® has expanded its collection to include footwear designed for security personnel. Built using the best components available, the newest technology and comfort designs Corcoran® remains the brand of choice.
Dobra reklama za čevlje!Ne vem, če si ne bom kar nabavil en par. Ali dva.
BTW - zraven Putina sedi Šoigu. Pravijo, da je to človek, ki nastopi potem, če pogovori z Lavrovom niso uspešni. In, da ne govori veliko. wink, wink, if you know what I mean?![]()
Kaj je narobe pri tem? Rusija je kljub vsemu danes kapitalistična država.
Cervantes ::
Amerika rabi sovražnika, sicer gre ekonomija u kyrac.
Rusi so pri roki.
Razlika med enemy in adversary?
Predolgo se s tem šalijo.
Rusi so pri roki.
Ultimativni online vir za te zadeve:
http://www.ausairpower.net/APA-S-400-Tr...
oz. direktno na interesantni del
The second missile added to the S-400 is the new 40N6, a long range weapon with a cited range of 215 nautical miles, equipped with an active and semi-active homing seeker, intended to kill AWACS, JSTARS and other high value assets, such as EA-6B/EA-18G support jammers. Further details of this weapon remain to be disclosed. The range improvement to around twice that of the 48N6E2 suggests a two stage weapon, or a much larger motor casing with a larger propellant load. Russian media reports citing PVO senior officers in 2010 indicated that 40N6 range may be a great as 240 nautical miles, and the missile completed State Trials (Russian OpEval) in 2010, and was to enter production. To date no images of the 40N6 missile, launcher container or TEL have been made public.Lahko me popraviš. Čakam.
Ultimativni?
LOL.
Greš na rusko spletno stran pa tam poiščeš med ruskimi navdušenci za 40N6.
Rusija ima kot kaže operativno tehnologijo za GPS spoofing.
https://www.newscientist.com/article/21...
Reports of satellite navigation problems in the Black Sea suggest that Russia may be testing a new system for spoofing GPS, New Scientist has learned. This could be the first hint of a new form of electronic warfare available to everyone from rogue nation states to petty criminals.
On 22 June, the US Maritime Administration filed a seemingly bland incident report. The master of a ship off the Russian port of Novorossiysk had discovered his GPS put him in the wrong spot - more than 32 kilometres inland, at Gelendzhik Airport.
After checking the navigation equipment was working properly, the captain contacted other nearby ships. Their AIS traces - signals from the automatic identification system used to track vessels - placed them all at the same airport. At least 20 ships were affected.
https://themoscowtimes.com/articles/the...
Bakunov says he got so fed up with all the speculation about what is happening with geolocation near the Kremlin that he loaded a backpack full of devices that use GPS and GLONASS, hopped on a segway, and set off to do laps around central Moscow, measuring the strength and accuracy of his geolocation signals.
He spent three hours rolling around the Kremlin, starting at 9 a.m. and wrapping up at noon. "Cutting across the city on a segway for three hours in 2-degree weather was quite the rush," Bakunov recalled.
The reason this stunt was more than just another vague complaint about malfunctioning geolocation is that Bakunov mapped his entire experiment. He was able to measure, in blue and red, where his GPS and GLONASS devices succumbed to location-spoofing. Take a look at his map, and you'll see that the epicenter of the geolocation interference is somewhere inside the Kremlin. Bakunov says he believes there is a powerful transmitter operating at random times inside the Kremlin, spoofing geolocation signals on the L1 frequency, which is what civilian devices rely on for geolocation. (According to Bakunov, the transmitter is also jamming the L2 and L5 frequencies, which militaries use for increased accuracy and reliability.)
When Bakunov's devices came under the influence of the spoofing transmission, they suddenly thought they were at the center of Vnukovo airport, roughly 30 kilometers southwest of the Kremlin.
datum 8.8 Lockheed Martin begins modernising receivers for US Air Force's GPS signal monitoring
datum 2.8 US Air Force extends GPS OCX baseline by nine months
OH MY GOD. THIS JUST IN!!!!
Rusi so bili majkemi!!!
Samuel ::
noticably not worth noticing.
Bom pogledal.
Je bilo samo lapanje v luno, ane... D3m. Dokazov nič.
The ability to ensure uninterrupted satellite-based navigation and timing are essential in modern military platforms, the companies noted in their statement, “Despite this dependency, still many platforms do not use anti-jamming systems to protect those essential assets.
Bom pogledal.
Tega je 40. strani.
Lahko pomagaš ti bom dal kar vir
http://www.russiadefence.net/t410-s-300...
No sedaj pa lahko s Pac-manom lahko sodelujeta.
Samuel ::
Kaj mi daješ to iz leta 2009/2010??
?!?!? WTF naj bi to bilo in kakšno povezavo naj bi to imelo z S-400???
Bom pogledal.
- spremenil: Samuel ()
Samuel ::
Bom pogledal.
Tega je 40. strani.
V tej temi ni nobenih konkretnih dokazov o 40N6.
Ne bluzi več.
Samuel ::
Začetek teme.
Tukaj imaš pa še preostalo.
http://www.russiadefence.net/t6302-s-30...
Good luck.
V tej temi tudi ni ničesar. Prenehaj s temi avtističnimi klobasarijami.
Začetek teme.
Good luck.
Torej da potrdimo pravljice , al nbe
So, on one of the slides of the presentation, the authors clearly presented, what types of missile complexes of Russia deployed in Crimea: “Iskander-M”, 3К55 “Bastion”, System S-400 40N6 missiles and cruise missiles “Caliber”.
The S-500, intended to provide a wider anti-air/anti-missile capability, including potentially an ability to intercept ICBMs, will have an engagement range of 500-600 km with an upgraded variant of the 40N6 – the 40N6M and two new anti-missile interceptors – the 77N6-N and 77N6-N1.
40N6 SAM would be sufficient from launch sites in mainland Russia and the exclave of Kaliningrad to cover the entirety of their territories. Similarly, from launch positions in north-western Russia and Kaliningrad respectively,
ADVANCED Russian S-400 AIR DEFENCE heading to UKRAINE .... 2014 Russian Missile Defense
The S-400 deployment to Crimea is part of a major rearmament plan that has been in place since the Black Sea Peninsula joined Russia following the March 2014 referendum.
Ukraine Crimea: Russia sends new air defence missiles
Russia reacts on Ukraine’s intention to carry out missile drills near Crimea with Antey-2500 anti-aircraft missile system deployment - video spotted weapons movement... S-300V4: in service since 2013 with 400 km range
Within a few months 40 new military units appeared on the peninsula. Importantly, in the
Crimea a series of A2AD systems have been installed, such as S-300PM, S-400 Triumf and
Pancyr missile systems as well as Iskander. The K-300P Bastion-P has been significantly
developed to increase coastal defense.
Začetek teme.
Good luck.
Vse strani si pregledal?
Ker avtist si ti majkemi.
Samuel ::
Ti daj samo nek relevanten link direktno do dokaza. Ne bomo mi iskali zate. A si tupast?
@Mr B.
Ponovno en kup smetja, ki ne dokazuje, da so rakete 40N6 v operativni rabi. Bluzenje in megla, kot vedno od tebe.
Samuel ::
@Mr B.
Mi daš kakšno sliko okoli Moskve, da preveriva ? Ker jaz resnično ne vidim imeti , kot na primer v Siriji, imete rakete za targetiranje mirv ciljev. Zato pa imajo tam 9M82MD, ki ima isti dosega, za seveda isti cilj, ki bi jih imela famozna 40N6. Lahko pa preverimo , če obstajajo kakšne slike okoli moskve ?
Top šit. ZDA imajo petokolonaše ;)
https://twitter.com/MollyMcKew/status/8...
We need to have a conversation about what is happening today in Charlottesville & Russian influence, and operations, in the United States. Because this is a condemnation of nothing. And a few days ago, favorite presidential aide said "the left" is conducting false flag terrorist attacks in US
http://edition.cnn.com/videos/politics/...
Hatred and bigotry "on all sides" the president says, are the problem. How do we make sense of any of this?
This is what the Gerasimov Doctrine, Russia's hybrid warfare doctrine, says: Again, Russia specifies it aims to use "internal opposition to create a permanently operating front [in] the enemy state". There are countless examples of this in Georgia, Ukraine, Moldova, the Baltics -- all former captive nations. We refuse to believe this tactic could ever be applied to the US. We have nukes and democracy and an economy 14x as big as Russia. Right?
So, whole point of Gerasimov: it is about guerrilla mindset. Cheap, easy, confusing ways to fight more powerful opponent (us). So who are the Kremlin's American compatriots -- their "internal opposition"? We can start with "Alt-Right"
http://www.chicagotribune.com/news/opin...
As Russia invaded Crimea, changing borders of Europe by force for first time since WWII Groups thrilled w/ Putin "restoring traditional values" met in Crimea to praise him.
https://medium.com/war-is-boring/as-rus...
This is what famous Nazi Richard Spencer said about Ukraine:
https://www.buzzfeed.com/rosiegray/amer... David Duke attends Kremlin compatriot conferences. In Charlottesville he called on POTUS to keep to promise to "take the country back". Because the KKK, "Alt-Right", and other "white nationalists" (aka Nazis) all supported candidate Trump and want him to deliver.
The NRA was huge Trump supporter. Here's the NRA in Moscow. Btw the guy they met with? He wants Alaska back.
http://www.thedailybeast.com/top-trump-...
Just after inauguration, NRA did ad, "organized anarchy," which said fighting jihad-like resistance in US is same as fighting fascism. That's a straight up Kremlin script. Others around POTUS have used this argument. See: Bannon/Desouza meeting
https://twitter.com/christinawilkie/sta...
That's right. They are arguing the REAL fascists want freedom and equality.
Ok. Sure.
You know who else fits in that category?
American evangelicals. Evangelicals are friendly with Russia, helped Russian govt (and many African nations) write anti-LGBT laws. They also, inexplicably, campaigned for Trump.
Here's some evangelicals helping Russia gain access to the WH
http://time.com/4776717/mike-pence-russ...
Why does any of that matter?
Alt-Right was involved in trying to get hacked oppo docs from the Russians.
https://www.splcenter.org/hatewatch/201...
The Alt-Right has been promoting disinformation about the Trump/Russia investigation
http://www.wnyc.org/story/how-alt-right...
The Alt-Right loves Putin and advocates that the US abandon its treaty alliances and security posture in Europe
http://www.businessinsider.com/russia-c...
The Alt-Right is working with Russia to attack the National Security Adviser
http://www.businessinsider.com/hr-mcmas...
Alt-Right is unregistered agent of Russia (where critics are murdered) & fanboy of Assad (killed hundreds of thousands of own people). The NRA has also lobbied against Russia sanctions. They argue that Russian election interference is nonsense. Evangelicals argue Russia is the greatest guarantor of "traditional" rights, have used their political clout to promote Russian agenda.
Ok, so, Russia has relationships with loathsome groups, and they then do things in their interests. So what?
Well, turns out Russia routinely hosts the hate/fringe to empower them, connect them, train them.
https://www.nytimes.com/2015/03/23/worl...
Russia has also trained domestic extremists from other countries to conduct attacks at home
http://www.thedailybeast.com/russian-ex...
It was just the 9th anniversary of Georgian-Russian war. Russia didn't win Georgia in that traditional war. It won Georgia in 2012 with political and information and economic warfare. The unraveling I witnessed afterward so eerily reminds me of patterns and actions I am seeing in the US...It's worth thinking about.
Look at the links between Russia, and Russian money, and the factions who promote the Russian agenda in the United States and then look at who the president won't condemn.
And wonder what is being done to us under his watch.
Adding to be clear: What Russia does is exploit weaknesses of opponents.
Not saying they created this problem in America. Fanning flames.
Ok. Sure.
Sicer je še v sprejemanju, ampak v Rusiji je to ponavadi formalnost. Od julija 2018 bo FSB za vsakega uporabnika družabnih omrežij zahteval:
https://meduza.io/en/feature/2017/08/11...
Konec ljubezni, Trump je nacistični prasec. Zaenkrat samo na državnem radiu.
https://twitter.com/Alexey__Kovalev/sta...
Morning show on state-owned Vesti FM, pro-Putin pundit absolutely destroys Trump: "complete bastard", "compulsive liar" etc. "We pushed ourselves into a corner by whitewashing everything Trump says/does. Now he's openly siding with Nazis, what are we going to do?" "Does Trump expect us to just pat him on the back every time, no matter how vile his actions? Does he think Russia is a fascist state?" woah
This is no ordinary govt pundit, Krasheninnikova is high in Russian propaganda hierarchy. And she's flooring Trump right now live on air. On Daily Stormer's incursion into .ru: "This blackshirt scum has no place in Russia. Our country defeated fascism". I repeat, this is one of the most popular morning talk shows on Russia's state radio network, all above said by a top pro-govt pundit.
"How could we be so blind as to believe our own propaganda? It was clear from the start that Trump was extremely dangerous". woah woah
So, a very high-profile, pro-Putin pundit just said:
1) Trump is a liar, he's is no friend of Russia
2) Nazis, you suck, go away.
Okay, just to clarify: it's not an overnight U-Turn for this pundit. But she's v influential so I'd start worrying if I were Trump.
Ah. Ironija je moja najljubša oblika humorja.
http://www.newsweek.com/leaders-charlot...
Tole zgoraj je bila zgolj manjša motnja v magnetnem polju, še naprej vse poteka po programu.
Tonight on Russian state TV:
1) Whitewashing Trump
2) Obsessing with Ukraine + drawing inane comparisons
3) Whitewashing the Confederacy
4) Blaming the violence in Charlottesville on "rabid leftist students"
5) Lee statues are "symbols of shared history", just like Lenin's
And now your typical Putin pundit with her hot take: "Not every KKK sympathizer was a racist who considered negroes [yes, N-word] subhuman" Hot take: "Violent leftists protesting global economic forums are probably paid by globalists themselves to make protest unattractive"
Russian TV provides a handy graphic on US's "escalating war on memorials", from "decades-old historical legacy" to "symbols of neo-Nazism And, of course, uncritically and sympathetically parroting Trump's statements: "Washington & Jefferson were slave-owners too"
Putinova propagandistka, Narotchnitskaya, je tudi zvezda tega intervjuja. Kljub trumpovim izvajanjem še vedno izvrsten primerek neutemeljene samozavesti. Ponosno je prišla predstavljat ruska stališča, končalo pa se je z obilo momljanja.
Angleški obveščevalni veterani via NYT o Steelovem dosjeju.
https://www.nytimes.com/2017/08/25/book...
Ruski freakšov dneva.
https://twitter.com/loogunda/status/901...
Gospod v rdeči majici je bivši župan Arhangelska, "kuža" ima trumpovo masko, dogaja se v Sankt Peterburgu.
G. župan ni povsem gladek.
Alexander Donskoy @ Wikipedia
Je lastnik supermarketov, možno, da je to počel v svoji trgovini.
Prejšnji teden je bil umorjen predstavnik v čečenskem parlamentu.
https://themoscowtimes.com/news/communi...
Zdaj je prišel ven dashcam.
https://www.instagram.com/p/BYVW4-HBSZn/
Ruska nacionalka navaja Alexa Jonesa in njegovo idejo o trans-seksualnosti Michelle Obama.
http://www.vesti.ru/doc.html?id=2925587...
Scaramouche ::
NATO že začela infoktrinirati vendar ni uspelo...
http://www.globalresearch.ca/nato-drill...
During the shooting at the training grounds, the Bulgarian soldiers flatly refused to shoot as "Russian identification marks have been placed on the targets, and they won't shoot at Russians!
Scaramouche je izjavil:
http://www.globalresearch.ca/the-social...
When the great statesman, Lakhdar Brahimi was asked why the United Nations premises and personnel are attacked, repeatedly, in recent years, Brahimi replied that the UN is no longer perceived as an impartial organization, but is now perceived as a party to disputes. There is no more glaring example of the United Nations craven servility to the United States dictate than the Security Council's unanimous support of the viciously punitive sanctions against the DPRK, a country that must be described as a paradise for children, providing excellent, up-to-date health care and education, free of charge, an achievement that few western capitalist countries can demonstrate.
Zdi se mi, da vir ni med najbolj kredibilnimi.
- spremenil: Smrekar1 ()
Operacija Trump-Rusija jim je lepo eksplodirala v obraz. Kar naenkrat so v središču pozornosti in mediji bodo končno začeli poročat o hroščih v (ruskem) sistemu.
Buzzfeed je sklenil partnerstvo z Meduzo.
http://www.niemanlab.org/2017/08/storie...
Ruski vojaki so "airheads"?
@2:35
@2:35
- spremenilo: Pac-Man ()
@bolgarski vojaki
Originalni vir je News-Front s Krima, kjer je ustanovitelj bivši član duginove evrazijske mladine. Fašist, v nazorih in dejanjih.
Eurasian Youth Union @ Wikipedia
http://time.com/4889471/germany-electio...
Among the most aggressive fixtures on this list is a small but growing Russian operation known as News Front, a multimedia outlet that pumps out content in several languages, including German, Spanish, and English. With about ten staff members and a few dozen contributors around the world, it is among the better-resourced players in the Russian media ecosystem – even though its sources of funding are opaque.
Konstantin Knyrik, the 28-year-old founder and editor of News Front, thinks of himself less as a journalist than an information warrior for the digital age, and he has the career and the connections to prove it. As a teenager in the mid-2000s, he became an active member of the Eurasian Youth Union, a group of hardline Russian nationalists who campaign for Moscow to restore the empire it lost after the fall of the Soviet Union. When he was just 16 years old, Knyrik became its representative in the region of Crimea, a vast peninsula in southern Ukraine. In spring 2014, as Russian troops invaded the region and prepared to annex it, Knyrik led a column of pro-Russian paramilitaries to seize the headquarters of the Crimean Center for Investigative Journalism, the region’s leading independent news source. The troops forcibly expelled the Center’s journalists and confiscated their equipment. Knyrik then created News Front in its place.
V drugih novicah - vohuni sledijo vohunom. Organizatorji neuspelega državnega udara v Črni Gori so bili posneti.
http://www.telegraph.co.uk/news/2017/08...
The pictures obtained by European intelligence agencies allegedly show two officers of Russia’s GRU military spy service visiting the Balkans and overseeing the man they hired to orchestrate the bloody overthrow of Montenegro’s government.
The photographs are believed to have been taken in a Belgrade park around the time of the foiled coup and are a key part of evidence prosecutors say links the plot to Russian “state bodies”.
Ruski paravojaški kamp v ZDA.
https://twitter.com/A_SHEKH0VTS0V/statu...
http://nashdom.us/home/sootechestvennik...
Na Poljskem, 30km od meje s Kaliningradom, je menda padlo dol nekaj z ruskimi oznakami.
https://twitter.com/akihheikkinen/statu...
gtranslate:
According to our information, this was not a typical dron, which can be bought in a regular store, but a small unmanned aircraft. As reported by the journalists RMF FM, on the plating were signs in Russian.
These facts do not want to officially endorse any service. I can not really say anything about it, "says the representative of the Olsztyn prosecutor's office.
It is also taken by the servants to take into account the version that the machine belonged to the smugglers.
gtranslate:
US tells Russia to close consulate -> unwarranted
https://slo-tech.com/script/forum/vnoss...
gtranslate:
Sedaj so pa še golobi pismonoše pro-ruski?
Bolj nato kot Rusija, ampak vseeno. Odličen članek.
http://www.armyupress.army.mil/Journals...
Weaponizing Ridicule
J. Michael Waller, PhD
V Rusiji sta se v zadnjih dveh dnevih zgodila 2 teroristična incidenta
Včeraj je nekdo poskušal s kombijem zapeljati v kino, kjer je potekal filmski festival, ampak se na srečo vrata niso vdala. Notri je imel tudi 3 plinske jeklenke.
https://themoscowtimes.com/news/explosi...
Vzrok je bila šundasta biografija o balerini, ki je bila v vezah s tremi iz rodbine Romanovih. Glavna težava je Nikolaj II, ki je proglašen za svetnika. Posledično hardcore pravoslavce močno meče, tudi Naša Maša je čisto preč.
http://www.bbc.com/news/world-europe-39...
Matilda (2017 film) @ Wikipedia
Danes pa se je petnajstletnik šel Columbine. Z zračko.
https://meduza.io/en/feature/2017/09/06...
Ne vem kaj se sliši, če gre za strele, vsekakor niso z zračne puške.
"You can't touch saints. You can't show them having sex because that offends the feelings of believers," Natalia Poklonskaya argues, a fervent young MP leading the campaign to block the release of Matilda.
| » | Skripal (strani: 1 2 3 )Oddelek: Loža | 42418 (28167) | Pac-Man |
| ⊘ | Dr. Drumpflove (strani: 1 2 3 4 … 33 34 35 36 )Oddelek: Problemi človeštva | 384567 (344586) | OmegaBlue |
