AMD RX Serije
AMD RX Serije
D3m0r4l1z3d ::
Moraš potem le CoD:IW igrat pa je stvar rešena.
Drugače pa, saj če 11 mesecev kasneje hw izide, mora že biti kaj hitrejši od starejšega. Lepo.
D3m0r4l1z3d je izjavil:
Še sem pozabil dodat, da tole RX580 zdej še furajo na beta gonilnikih. Bojo še to verjetno poglancali.
  • spremenilo: Telbanc ()
D3m0r4l1z3d ::
Ni slabo, si pa le interpretiraj povprečje iger, boš videl kje si zgrešil.
Počakmo na boljše gonilnike.
Shit, rx 570, malo pa je od stock 1060 3gb, ki je od lanskega leta, hitrejša
Gre za grafo en razred nižje, ki je začela hodit u zelje 1070.
V bistvu je to zlo u redu.
Konkurenca ponavad nardi nižje cene.
Razlika v ceni je večja od "tistega povprečja".....
D3m0r4l1z3d ::
Niti ne, če je le par iger izmed tisočih.
1060 oc je isto kot 580 hitra, nič napredka, cene so tam tam
Je razlika med 30 fps in 45 fps, to je treba razumet
GenZNPC ::
Priblizala, hehe pa se vedno dalec
skibidi
D3m0r4l1z3d ::
Približala se je stock 1060 6gb :|
Ni res, maš komentarje na koncu testov, da ni več niti enega razloga sedaj, da bi pri teh cenah priporočal 1060 6gb.
In da bo mogla Nvidia nekaj storiti.
D3m0r4l1z3d ::
Lisa: Raja, Chainsmokers feat. Daya
Raja: What?
Lisa: Dont let me down, down, down.
Telbanc je izjavil:
Niti ne
AapocalypseE ::
This isn't something you buy if you already own Polaris or a 1060. These cards are meant for new builds - they're not upgrades for anything recent. If you just bought an RX 480 and you're feeling a little salty at the refresh, take solace in knowing that many of the games only post differences of 5% or thereabouts, if that. Overclocking will allow the RX 480 to mostly match an RX 580 stock card, since the stock card is just an RX 580 with a higher native frequency and more voltage to play with.
With regard to pure gaming performance, the RX 580 competes well with the GTX 1060 SSC. They're not that far apart in performance, and generally swap leadership on charts.
Nothing too exciting here, but not a bad launch. Just sort of a "meh" mid-cycle refresh that's not particularly invigorating, but also worthwhile.
D3m0r4l1z3d ::
Lol, prvih 12 pozicij geforci, res je slaba konkurenca, to mi ni všeč, feel ya Slonic
JamesBond ::
Trenutno je 35€ razlike med Powercolor rx480 in rx580. 50mhz je razlike v frekvenci. Trenutno se mi ne zdi vredno.
Grey ::
AapocalypseE je izjavil:
snip
Pa Jezus, kje te hepane najdejo za reviewe? Me zanima, kje se najdejo junaki, ki lahko overclockajo RX480 na zraku cez 1500MHz pa da lahko dela normalno za gaming...fanta, RX580 je sla cez 1500 MHz na zraku in lahko igras s tako. Z vodo pa le glejta...1600+, sej bo kmalu kdo naredu test :) V Vulkan/DX12 pa je tudi extremno blizu GTX1070 ze zdaj. Z vodnim hlajenjem pa... :) Tako kot sem rekel, dolgorocno je zmaga na strani RX580. Ce se da pa RX570 dobro navijat pa sploh, ker je potem price/perf noro dober. Sapphire pa je sploh tiha glede na to kolko Wattov trosi.
10 Mhz overclock. OC dream. :))
In pa hud intro. :P
Grey ::
DarwiN je izjavil:
In pa hud intro. :P
Lovin' the intro ROFL :D
D3m0r4l1z3d ::
Krš roba
Krš roba
Maš na netu, golden sample grejo na zraku do 1528 mhz.Na vodi zna iti do 1600.
D3m0r4l1z3d ::
Pa 280w, pozabi
dolenc ::
Ja pa kaj še, a misleš da je voda pa kr čudežna :)
Mal je razlika v tem kak čip kdo dobi. Neki so zgleda naredel na "učinkovitosti", tiste 3w ko youtube gledaš :P, prov dost pa ne, tko da je tudi bitcoiner(al kaj je že) imel prav.
Če bi rx480 launchal s 1.2v pa odprtem tdpjem bi lahko z istimi clocki prodajal. Tud moj referenčni jajček gre lepo na 1450mhz pri 1.25v
dolenc je izjavil:
Ja no, se strinjam da so lok precej napeli. In grafe niso slabe, sam da papcajo. Hladilne sisteme so spedenal. Še cene da se ustalijo pri 230 evrov...
So pa že zadnje rx480 šle lepo do 1470 mhz, tko da smo prčakovali potihem na zraku najmanj 1550. Za tole 580.
Bo tud to, ko bo kakšen trofu res golden čip. Več bo prodanih, več bo možnosti, sploh čez nekaj časa..
Dejan99 ::
Nič posebnega, 23% višji tdp v zameno za 6% boosta, za 50 eur več :P
gddr85 ::
pač refresh za nove kupce
Zdej je na vrsti Nviidia z serijo 2060, potem bi lah AMD spet izdal refresh z hitrejšim ramom.......na 14nm bojo kar nekaj časa.....
gddr85 ::
eh, že zdej lahko 1060ko naviješ pa bo vsaj tolk dobra kot 580ka, če ne še bolj..
povečajo bandwidth, core clock pa bo spet panika pri amdju :P
  • spremenil: gddr85 ()
dolenc ::
Kolk sta naviti ena ob drugi:
petrus ::
Leave my Rebrandeon alone! :'(
stati inu obstati
D3m0r4l1z3d ::
Škoda, da niso Fiji spedenali, bi bila 570 Polaris, 580 Fiji in 590 Vega, hat trick
Predator X ::
LoL,
A zdej če pa GTX 1080 AMP! kuri več kot GTX 1080TI je pa neučinkovita arhitektura? Dejte fantje nehat že z P/W.
Škoda, ker niso uporabili nove arhitekture...
Sapphire back in "business"
D3m0r4l1z3d ::
Kuri več, ampak potem pogledaš p/w in vidiš kako je glede na performance, ali je izkoriščeno/opravičeno. Poba, p/w je majka.
Predator X ::
P/W je relativna stvar. Polaris je presenetljivo učinkovit... Sej tud GTX 1060 na 2100MHz pokuri blizu 200-230W. Pa je hitrejši od GTX 1080?...
Drgač pa uporabljajte AMD chill.
A nisi ti dal za grafo 550 evrov (GTX 1070) in zdej ti gre tale zadeva z RX580 malo v nos. Če gledaš še učinkovitost/glede na ceno ne vem kako se ti izide.
No sicer boš verjetno prilimal kak "zlata vreden link", ampak zdrava kmečka pamet, bi rekla, kaj misliš? :))
Razlike je v špilih še max 10-15%, poleg tega bojo pr AMD še speglali tele beta gonilnike....
Predator X ::
Problem je dobit poceni gsync monitor...
Zdej ko je dell dal ven 60Hz HDR monitor za 200/267EUR.
Predator X ::
AapocalypseE ::
Grey ::
Dej se vec starih titlov not, bos prsu do HD4870 z relative performance.
D3m0r4l1z3d ::
Telbanc je izjavil:
Ti se kar tolaži, smiley.
RejZoR ::
Gonilniki tle nimajo veze. Par stvari so spremenil, ampak to je RX480. Če je ob releasu Polarisa veljalo o izboljšanju driverjev to zdej ne more bit več nikakršen izgovor, ker je jedro isto, samo ime so spremenil v drajverjih. Lahko še kaj izboljšajo, ampak se ne moreš več obešat na to. Pri RX Vega mogoče spet, ker bo čist nova arhitektura, tle pa pač ne.
D3m0r4l1z3d ::
Grey je izjavil:
Vse glavne dx12 naslove je zajel, površno si to gledal
RejZoR je izjavil:
Vprašanje koliko nova bo.
Količina napora, ki ga nekateri vlagate v to, da serjete po AMD izdelkih, je prav neverjetna.
Prav tako je neverjetno to, kako jih eni branite.
Oboji ste pa patetični .... ko človek gleda, takole, iz distance.
Vsak naj kupi tisto, kar mu paše. Prav neverjetno je , kako ponosni so eni, da imajo nVidia/AMD grafično.
Bogi ste, res. Nezmožni normalne debate. Zato sem tudi nehal sodelovat.
RejZoR ::
Anymal, glede na to kar sem do zdej videl, bo Vega zelo drugačna. Tud če se spomniš za nazaj, pri Polarisu nihče ni omenjal drugačnega rendering pipelina. Mal so izboljšal GCN, to pa je bilo to, največ so dajal na 14nm proces. Vega po drugi strani ima čist nov rendering pipeline, torej nov pixel in vertex "procesor", nov memory kontroler z radikalno drugačnim pristopom delovanja, povsem drugačna compute enota itd. Predviden clock je 1550MHz, kar je super v primerjavi z R9 Fury 1050MHz, vprašanje je samo kako bojo rešil neizkoriščenost vseh shaderjev, kar je bil največji problem R9 Fury. Bila je zelo zmogljiva kartica, ampak samo kadar je bila polno obremenjena. Če je bila samo delno in se je od parih shaderjev pričakovalo ogromno rezultatov se ni izšlo ker ni bilo frekvence na jedru. Nekak podobno kot Ryzen vs 7700k. "Jedra" vs visoka frekvenca. Če jim uspe rešit to, da bojo lahko neobremenjeni shaderji vskočili pri izrisu kot neke vrste HT za GPU, pol zna bit zanimivo. To bomo pa še videl. Soon I guess.
Osebno upam, da se bo Vega izkazala, da AMD prekine dominanco NVIDIE in jih preseneti tko nekako kot so z Ryzen presenetili Intel. Tud če ne gre za totalni prevzem hitrostne krone, da vsaj mal podrezajo trg, ker smo pol mi na boljšem. In seveda potem upa, da bojo Vego oklestili in spravili v nižje razrede in povsem nadomestil Polarisa...
Brane22 ::
RejZoR je izjavil:
Folk dela dramo okol te porabe kot da vsi furate neke 300W napajalnike v ITX ohišjih...
Moj namizni strojček trenutno laufa na 60W napajalniku.
D3m0r4l1z3d ::
Ja, Vega je žarek upanja, bo pa samo high end, ker ima hbm2.
RejZoR ::
Brane22 je izjavil:
RejZoR je izjavil:
Moj laptop pa na 15W. Your point being?
Pa sej če so naredil memory controller modularen, da ni striktno vezan na HBM, bi lahko gor obesli GDDR5(X), oklestili čip in prodajali kot nižji part. Oz da gor obesijo 2 stacka starega HBM1, torej 2GB in razširijo spomin s HBC. Pač, odvisno kako daleč lahko klestijo preden tud HBC ne more več delat čudežev...
GenZNPC ::
Telbanc je izjavil:
Krš roba
Grejo ja, kot 6+1 na loteriji:
Predator se je tut neki hvalil s svojim overclockom nad 480ko,
pa ni zdrzala nobenga benchmarka na slo-tech OC oddelku, samo CS:GO je laufala
skibidi
Brane22 ::
RejZoR je izjavil:
Da mnogi laufamo ekonomične strojčke in nam poraba nekaj pomeni.
NightHawk ::
Zakaj je AMD čutil potrebo po izdaji novih starih kartic? Nvidia pripravlja 2xxx serijo?
  • spremenilo: NightHawk ()
AapocalypseE ::
570 bo dosegala up-to 1.4GHz na coru in okoli 2GHz na ramih.
Maximum overclock of our sample is 2039 MHz on the memory (17% overclock) and 1380 MHz on the GPU (7% overclock).
580 bo dosegala up-to 1.5GHz na coru in okoli 2.25GHz na ramih.
Maximum overclock of our sample is 2250 MHz on the memory (13% overclock) and 1480 MHz on the GPU (5% overclock).
NightHawk je izjavil:
Nvidia ima vedno že kaj pripravljenega za amd 8-)
Mitja358 ::
Zelo razočaran nad porabo kartice, škoda no. Naj vsaj čimprej izdajo Vego.
Ker nimajo pripravljenega nič novega v nižjem/srednjem segmentu in so si tako brez vloženega truda in sredstev "kupili" dodatnih 12-18 mesecev časa.. Vega naj bi izšla junija, ampak tisto bo višji razred, oziroma srednji/višji, če izdajo še "majhno Vego". Zadnji čas je vse potihnilo in uradno ni potrjeno prav nič.
Nvidia pripravlja Volto, a se jim nikamor ne mudi. Dejansko bi lahko pocenili 1070/1080 kartice za ~100€ in bi s tem takorekoč efektivno "lansirali novo serijo kartic".. 30-40% več zmogljivosti za mainstream trg v sweet spot cenovnem rangu (250-300€). Zdaj je pač vse odvisno od konkurence. Od AMDja in Vege. Ampak še vedno je jasno, da bo Nvidia s Pascalom vsaj konkurenčna Vegi, v najslabšem primeru, tko da lahko z Volto mirno počakajo še leto dni.
AapocalypseE ::
Vega pride kot konkurenca Pascalu, tako da Volta bo spet razred zase kot je Pascal še zdaj :))
68 / 94
Grafična kartica (strani: 1 2 3 4 … 206 207 208 209 )
104111680403 (12646) Magic1
Gtx 1060 ali RX 480 (strani: 1 2 3 4 … 25 26 27 28 )
1395271245 (234957) Predator X
AMD Radeon R9 400 Series (strani: 1 2 3 4 … 118 119 120 121 )
6004951837 (808493) gddr85
