AMD RX Serije
AMD RX Serije
Fixed Issues
AMD FreeSync™ technology may experience performance issues with Borderless Fullscreen application support when a secondary display is attached and has dynamic content running such as video playback in a web browser or if other applications or game launchers are running on the primary screen in the background. A workaround if this issue is experienced is to minimize all other running applications that are on the primary desktop display or on non-primary extended displays.
Radeon ReLive may fail to install during installation on some system configurations.
Battlefield™1 may experience flashing or corruption when running in Multi GPU with Radeon RX 400 series.
Instant Replay fails to enable itself after it has been turned off due to content protection.
Radeon Settings may not load on system boot for some system configurations.
Fixed some errors in translations for Radeon Settings and Radeon ReLive.
Audio recorded by Radeon ReLive may sometimes exhibit slow motion when played back.
Radeon ReLive may experience recording issues or issues toggling the Overlay/Toolbar when Frame Rate Target Control is enabled. Users are suggested to disable Frame Rate Target Control when using Radeon ReLive.
Mouse cursor may stutter in recorded video when there is limited on screen activity outside of minor mouse movement.
In AMD Multi GPU configurations the secondary graphics product will exit the low power state when Radeon ReLive is enabled.
Radeon ReLive may sometimes not be able to take screenshots of secondary displays.
Chromium may fail to utilize hybrid decode for VP9 content.
DOTA™2 may experience game corruption when performing a task switch while recording with Radeon ReLive in AMD Multi GPU configurations.
Radeon ReLive Overlay/Toolbar will not launch or Record when running League of Legends™ in Administrator Mode and Windowed Borderless Fullscreen.
Long ping times may be experienced with some WiFi adapters.
Known Issues
A small amount of apps may still experience issues with Borderless Fullscreen mode and AMD FreeSync™ technology if other applications or game launchers are running on the primary screen in the background.
Counter-Strike™: Global Offensive and World of Warcraft™ may experience flickering or performance issues the first time the game is launched on a system boot with AMD FreeSync™ technology enabled. Workarounds include exiting and restarting the application or task switching (alt+tab) in and out of the game to fix the issue.
AMD Multi GPU configurations may experience a system hang or reboot during install when using tiled MST 4K or 5K displays.
Titanfall™2 may experience black square corruption in game menus or during game play on some Graphics Core Next products.
FIFA 17™ may experience an application hang or black screen on launch for some select Hybrid Graphics or AMD PowerXpress mobile configurations.
Radeon Settings may not show display details for connected displays in AMD X-Connect technology mode.
Mouse cursor corruption may be intermittently experienced on Radeon RX 480.
Known Issues for Radeon ReLive
The XBOX™ DVR application may cause conflicts with Radeon ReLive, users are suggested to disable XBOX™ DVR if Radeon ReLive is experiencing issues.
Radeon ReLive may fail to install on AMD APU Family products or experience a system hang or failure to record when using the recording feature on AMD APU Family products.
Battlefield™1 may experience UI flickering and/or performance drops when recording gameplay with Radeon ReLive on graphics products with 4GB or less of VRAM.
Radeon ReLive recordings may experience flicker when creating a single recording for many hours.
Radeon ReLive may experience minor graphical corruption for the first few recorded frames when launching UWP applications.
Radeon ReLive will not allow recording settings to change with Instant Replay enabled. A workaround is to disable Instant Replay and change settings then enable Instant Replay.
Vulkan™ applications may experience a game hang when using Radeon ReLive to record.
Radeon ReLive will not notify an end user of low disk space during recording.
  • spremenil: D3m ()
Predator X ::
filip007 ::
Verjetno bodo Zen APU s HBM3, ker bo cenejši.
http://arstechnica.com/gadgets/2016/08/...
Zero games, zero talk.
GenZNPC ::
Se kr najdejo neki za popravt?
skibidi
GDDR počasi nima več smisla.
Razen za low-end GPU.
  • spremenil: D3m ()
bajsibajsi ::
scipascapa je izjavil:
saj samo to je važno, pač izboljšava gonilnikov ipd....koliko napredna lahko ponudi amd, koliko nvidia...
koliko je sedaj v dx11 kdo boljši, koliko kdo v dx12, in pa pogled v prihodnost 2-3 let....
dobiš kje morda kako igro zraven grafične?
Ne vem, ce je bilo to vprasanje namenjeno vajini kregariji, ker nisem vsega bral... V primeru, da je bilo resno vprasanje lahko povem, da sem pri nakupu Asusove GTX 1060 6GB na Caseking na mejl prejel aktivacijsko kodo za https://redeem.geforce.com/ kjer lahko izberem eno izmed treh ponujenih iger za Steam (Maize, Redout, Raw Data). Slednja, ki zahteva VR ocala, trenutno ni na voljo.
Miha20 ::
Danes dobil rx460 4Gb gigabyte dal sem 140€ izredno zadovoln prej sm radeon hd 4500 512Mb. Farming simulator 17 deluje odlično in še nekaj drugih
dost dnarja za lowend karto... to bi dobil že x2 bolšo 290ko
BT52 ::
iloveboobz je izjavil:
Težje. Prej za 170. Za 150 bi mogel imet presneto srečo.
nič sreče, samo tečen morš bit... rx470 se je prodajala za 179€, pa je to nova karta z garancijo, performance pa isti. Torej 290ka ni vredna več kot 140-150e
BT52 ::
To je res. Danes sem gledal na ebayu je en tip prodajal 280x za 380eur!!! Rabljeno.
Miha20 je izjavil:
BIOS update za Gigabyte še niso naredili, da bi jo odklenil na polno 1024SP.
Tukaj imaš link, če te bo zanimalo v bližnji prihodnosti.
http://overclocking.guide/amd-radeon-rx...
  • spremenil: D3m ()
BT52 ::
Miha20 je izjavil:
Danes dobil rx460 4Gb gigabyte dal sem 140EUR izredno zadovoln prej sm radeon hd 4500 512Mb. Farming simulator 17 deluje odlično in še nekaj drugih
Samo, da ne bo razočaran in narobe razumel komentarjev. Imaš kartico z majhno porabo in garancijo.
  • spremenilo: BT52 ()
Miha20 ::
Hvala za informacije se mi je šlo da ma popolno podporo za dx12 pa da malo porabi k mam samo 250w napajalnik, sem se bal da ne bo delovalo. Za cpu bom zen počaku. Ja 3 leta garancije. Sm gledu na bolhi rabljene pa so sami zlatarji.
NightHawk ::
Ima kdo to Asus 480 8gb?
https://www.mindfactory.de/product_info...
Malo sumljivo se mi zdi, da je ravno Asus najbolj poceni od 8GB verzij.
Izbiram med tem dvema
scipascapa ::
super cena še 20e pa imaš za 265€ super grafo.
NightHawk je izjavil:
Zanimivo, ker se je prej gibala pri dobrih 300 eur.
Odloči se sam. Jaz bi sam vzel Asusa, če cena drži.
klinker ::
Asus definitivno.
D3m0r4l1z3d ::
To pa je dobra cena.
TOP ::
Sevada pa še 3 leta garancije.
D3m0r4l1z3d ::
Logično. Bolj je vprašanje ali velja za Slo. za ASUS Heisse Winter Deals, ko je cashback 30 eur ali izbereš kakšen artikel od ASUSa???
TOP ::
Prinas ima Asus grafična 3 lete garancije in pomoje velja tudi prinas,zakaj pa ne.
D3m0r4l1z3d ::
Za garancijo, ja, samo ali je ASUS Heisse Winter Deals, ko je cashback 30 eur ali izbereš kakšen artikel?
NightHawk ::
Na mindfactory imajo2 asus 8gb s tremi venti. Eden je 240 in drugo 300€ pa sploh ne najdem razlik....
bajsibajsi ::
Asus je imel v tujini okoli novega leta akcije oz. posebne cene.
D3m0r4l1z3d je izjavil:
Moj odgovor iz druge teme:
bajsibajsi je izjavil:
bajsibajsi: a te akcije & cashbacke veljajo samo za de?
Zdaj lahko odgovorim. V mojem primeru (narocilo na Caseking) ni slo (izbral sem sicer misko). Smo se nekaj casa se po mejlu "pogajali" ampak se pri asus-deals.de niso dali. V spletnem obrazcu so bile sicer pri registraciji navedene samo naslednje drzave: Dänemark, Deutschland, Finnland, Großbritannien, Norwegen, Österreich, Schweden, Schweiz.
scipascapa ::
nighthawk: frekvenci.
https://www.asus.com/Product-Compare/?p...
ceneješa 240€
Engine Clock
1286 MHz (OC Mode)
1266 MHz (Gaming Mode)
*Retail goods are with default Gaming Mode, OC Mode can be adjusted with one click on GPU Tweak II
dražja 300€
1330 MHz (OC Mode)
1310 MHz (Gaming Mode)
Ja samo, to lahko tudi sam naredi. Je pa draga storitev za malo višji tovarniški OC in 1 vent več.
  • spremenil: D3m ()
Sami ::
Mi lahko priporočite kakšen lahek program, da bi med igranjem videl FPS-je?
Včasih sem uporabljal Fraps, a vidim da ni novih relisov...
gddr85 ::
afterburner
  • spremenil: gddr85 ()
fraps dela čisto dobro
Sami ::
Sem zdele probal, vidim da je Fraps še vedno OK.
Hvala obema.
tt2 ::
Je bila neka tedenska akcija. Cena je že poskočila na 308€. xD
Ponovni re-test iger 2016
http://gamegpu.com/test-video-cards/opr...
Cena:
Napajalc ::
R9 380x dobro pleza po lestvici, neverjetno, dobro da ni fury + obeh r9 390 + dx12 vključeno.
011011100111010101100010
Polpismeni: podnapise, prosim!
MATiCEK ::
Napajalc je izjavil:
Res je, kje sta obe R9 390 :|
NightHawk ::
Sepravi taki ruski testi so verodostojni, techpowerup ali tomshardware pa ne?
Kdo to pravi? Vsi testi so verodostojni. Samo po vašem eni bolj, kot drugi.
D3m0r4l1z3d ::
D3m je izjavil:
Pravi se je oglasil :))
No vidite. S tem ste potrdili moj prav.
Kajti Anymal je šel v defenzivo.
NightHawk ::
Če rečeš, da so vsi testi verodostojni, potem očitno ne veš kaj beseda pomeni. No, saj, če ne veš kaj pomeni beseda "vsaj", potem je to dokaj normalno.
Kar se pa testa tiče - nevem kaj ti gledaš napajalc, ampak 380x je 16% hitrejša od nvidia 960, bila je pa 25% dražja. Nvidia 950 2gb poseka novega radeona 460 4gb (da ne govorimo kaj bi potem bilo 460 vs 1050).
380X je še kar konkretno zadej za "gimpano" nvidio 970.
Aja, pa 1060 cenijo višje kot pa radeona 480.
Meni se zdijo stvari takšne kot so bile in dokaj podobne drugim stvarem. AMD FineWine se ni prišel na vrsto, počakajmo se kake 3 leta.
Easy nočni sokol.
Predator X ::
AMD RX 480 8GB stock = 1200MHz
GTX 1060 6GB stock = 1850MHz
Pa upoštevajmo na izbiro iger... kamot lahko pokažeš GTX 1060 10% hitrejšo ali obratno.
Zelo zelo male razlike med RX 480 in GTX 1060.
Je pa RX 470 p/p
Predator X ::
Edin kar je narobe pri tech benchmarkih je, da niso benchmarkal po patchih.
So to omenili?
Predator X ::
Pa ni GTX 770 tolk gimpana...
D3m je izjavil:
Je pa RX 470 p/p
nope, rx480 ua 199€ je p/p
Če gledaš na cente, RX 470 4gb.
Napajalc ::
Nope, nvidija ram je bil strašno darg takrat, gtx 960 4gb je imel isto ceno kot r9 380x 4gb, verjetno veš od kje razlog zakaj se je forsiralo gtx 960 2 gb v dobi 4gb in dx12?
42 / 94
Grafična kartica (strani: 1 2 3 4 … 206 207 208 209 )
104251718743 (13573) mtosev
Gtx 1060 ali RX 480 (strani: 1 2 3 4 … 25 26 27 28 )
1395276155 (239867) Predator X
AMD Radeon R9 400 Series (strani: 1 2 3 4 … 118 119 120 121 )
6004972967 (829623) gddr85
