Forum » Strojna oprema » AMD RX Serije
AMD RX Serije
iloveboobz je izjavil:
tiki..
1316 x 1.102 = 1450Mhz... Torej točno 10% clock boost
Stock frekvenca je 1260.
D3m0r4l1z3d je izjavil:
Using a GTX Titan X, which has 12 GB of VRAM, we tested the game's memory usage. As you can see, the game uses a ton of video memory, which is in line with what we've seen from previous Call of Duty titles. However, as the performance results in the next section show, even cards with less VRAM have no problems delivering a good framerate, so it's probably just the engine trying to fill up video memory as much as possible, even with assets that might not be needed at all.
Kar se mene tice, to da zafila RAM z nepotrebno saro, ni enako uporabi, prej slabi kodi.
- spremenilo: tikitoki ()
kako se šele rx470 potem dober navija; isti čip z base 926Mhz, gre na 1400Mhz !!!!!!!
stock frekvenca je kr lepo 1316Mhz pr msi :)
Ki je ze navita, in se lepo racuna na original stock. Ker so le tako cifre med seboj primerljive.
Meni osebno se zdi, da je se najvecja prednost AMDjevih graficnih kartic freesync, k IPS 75 MHz monitro dobis za 160 EUR v Sloveniji.
D3m0r4l1z3d ::
Kje?
Kje?
A rabis al moras sam trabunjat, da si v stilu zanikanja:)'
Kje?
Ok, mimovrste, anni,... vbistvu vsak vecji trgovec.
D3m0r4l1z3d ::
Pa je freesync IPS 75 MHz monitor za 160 EUR v Sloveniji? Daj link, ne bit gnil.
GenZNPC ::
Jaz bi ga tudi kupil, kje?
23" kva je to, tablica?
skibidi
- spremenil: GenZNPC ()
PredatorX ::
RX 480 OC.
Sem si vzel par minut za OCjat. Upoštevajte, da nisem nič "optimiziral zadev".
Do cirka 1450-1480MHz/2250MHz je bilo dokaj simple...
+ 50mV
+ 20% power limit (če ne je mal throttlal)
in sem takoj dosegel stabilnih 1450MHz/2250MHz.
Še preden mi nazaj začnete, kaj si testiral testiral sem BF1,DOOM (4K), da ni CPU bottlenecka - 20 min in je zdržal z 1480MHz/2250MHz, ko sem dal z istimi nastavitvami na 1500/2250 je crashal (Ne nisem zapiraš špila ali kaj podobnega).
Zdej ali je 20min doist al ne sami presodte, jst nekak potem grafično downclockam za 20-30MHz, da sem pripričan v stabilnost. Kar pomeni, da je moja grafična nekak za 24/7 - 1450MHz/2250MHz (gaming).
Voltaža jedra =
1300MHz (0.975 ali manj) - brez optimizacije
1480MHz (1.135 ali manj) - brez optimizacije
RX 470 RS XFX nisem nič navijal in ne mislim. Če slučajno koga zanima, 4GB varijanta - tiha, hladna (vsaj z mojim ohišjem) kuri pa presenetljivo malo vsaj sodeč po MSI ABju (75-85W) - stock nastavitve. + nekak za memory 15W.
bom dodal še slike in ostalo kasneje.
Tudi probal AOC AGON 271QG in morm rečt na GTX 970 deloval odlično z Gsyncom. Pol 1 uri uporabe med gsyncom in freesyncom ne vidim razlike (na moj občutek), oba imata pa težave pri sami nastavitvi. Igral BF1 in probal doseži 144FPs z i7 6700 in GTX 970 na ultra in tudi pri nižjih resolucija to ni bilo mogoče enostavno cpu bottlenecka, prav tako je bil z stock coolerjem zelo vroč.
O tem malce kasneje.
+ 50mV
Voltaža jedra =
- spremenilo: PredatorX ()
GenZNPC ::
Za to pa ja ne rabis Freesync, vzames potlej eno 1070/1080 pa furas na konstantnih 75Hz brez sinkinga
skibidi
http://www.anandtech.com/show/10811/zot...
pa ste se norce delal, k sn reku da bo glasno z rx480... Zakaj so potem šli konkretno odvit čip ?
AMD Radeon RX480 at 1050 MHz:
2304 stream processors
144 texture units
32 ROPs
256-bit memory interface
4 GB of GDDR5 7 GT/s memory
PredatorX ::
144 texture units
32 ROPs
Zato, ker je tam zelo učinkovit. Sej sm ti govoril, nonstop ti pravim ti pa nabijaš svoje.
rx480 na 1050 ni več rx480.
Če mene vprašaš je tole false advertising.
- spremenil: iloveboobz ()
GenZNPC ::
Kaj mate to neke igracke, ce se kaj takega vzame se vzame ornk:
Magnus EN1060 ali EN1070 oz. se bolje:
EN1080 https://www.zotac.com/de/product/mini_p...
skibidi
kupi vecjega, trotl.
je tt2 to naredil.
PredatorX ::
Pa ker ***** si ti. Sej zato pa smo tm k smo. Eni bi radi neki naredil, drugi pa sam iščejo težave in j*b*jo svet.
Kako Zotac advertizira in kako AMD mi je vseeno.
Ostali zotac boxi z nvidio imajo tud downclocke tam te pa ni nič motilo.
Pa prosim enga moderatoja, da blokira hojnikbja in molnarja ter anymala pa ostale ki nonstop težžijo z neumnostmi.
Bullshit, ni enako. Pravzaprav je lahko ogromna razlika. Sem vceraj gledal primerjavo in sedaj me mika, k prej sem enako mislil.
amd se je sam zaklal, niso drugi za to krivi. Imajo pač inferiorne produkte, zato pa tudi nimajo tako veliko design winov
Ja ? pokaži enega takega z pascalom
nehi jokat. Kaj misliš, da se bo vsako drugačno mnenje od tebe zdej brisalo al kaj ?
144 texture units
32 ROPs
Mobile čip. A je problem?
oznaka rx480 defenenitivno napeljuje da gre za desktop čip.
pač to je scam s strani zotaca, če mene vprašaš.
PredatorX ::
Kdo joka če ti pišeš bedarije. Zdej to je tvoje mnenje in že to, da je ZOTAC uporabil AMD config te moti. K, da jst trollam v "pascal" temi itd. Klel pa se najdeš ti ki nonstop govoriš kako je AMD slab.... nehi jokat če te moti, da nekateri uporabljamo AMD.
mene ne moti, da so uporabl amd (hell, rad bi vidu da bi tut amd proce začel uporabljat; recimo kakšen stoney ridge za poceni pcje). Moti me da oglašujejo desktop rx480, ki je performančno mogoče na rx470 ali še manj (nevemo kako se throttla zadeva).
Če ne piše ne moremo vedeti. Lahko pa napeljujeva to pa.
ti najdedaš, ker vedno jokaš, ko izpostavimo kakšno amd slabost.
Sj razumem, maš pač sindrom underdoga.
PredatorX ::
Tebe moti, da sem svojo RX navil na stabilnih 1450MHz... če bi pa šla sam na 1350MHz bi pa ti: saj sem vedel etc. Pejt drugam smetit.
moti me, da izpostavljaš to kot nek jaki overclock, kar ni. Jaki overclock je bil v času fermija pa tahitija, kjer si navil za 25% ko keks. Tule pa neki onanirate na 10%. TO je mišji kakec. To velja tako za pascal kot za polaris.
Napajalc ::
Bolj malo ljudi zanima dx11, dokler AMD ne izda nekaj v tem rangu je to maček v žaklju (1070/80), za 1060 že vemo da ni to to.
011011100111010101100010
jst še vedno čakam pasiven amd mini pc, zaenkrat nič pametnega. Zotac ma pasivno i5 recimo
Napajalc ::
Za 1080p resolucijo je več kot dovolj hi-end gpu iz 2013 oz rx 470-80.
GenZNPC ::
Lani si rekel, da je komot za 2K
Sicer res nebi blo svoh met na trgu tale Quantum z 2xFury X, bi blo mogoce celo za 4K, samo za vse to ohladit bi moral bit BIG Quantum
skibidi
15% če smo natančni.
Je pa hecno, da rabiš pri Pascalu 40% boost zato, da lahko sploh konkurira 1450 MHz od Polarisa.
Žalost.
- spremenil: D3m ()
MacGyver141 ::
Žalost.
Še dober, da je pascal drugačna arhitektura.......
PredatorX ::
Žalost.
Večina GTX 1060 laufa na 1900MHz+- Tko, da ni nekega jakeka OCja. Ko se je pa navil 7850 na 1150MHz je bil pa jak OC.
A bo? Bodo na TSMC ali Samsung?
Ne, naredi še tako, kot si pri AMD zdaj še nvidia Fermi naprej.
| » | Grafična kartica (strani: 1 2 3 4 … 206 207 208 209 )Oddelek: Kaj kupiti | 1731879 (9877) | FlyingBee |
| » | Gtx 1060 ali RX 480 (strani: 1 2 3 4 … 25 26 27 28 )Oddelek: Kaj kupiti | 278419 (242131) | Predator X |
| ⊘ | AMD Radeon R9 400 Series (strani: 1 2 3 4 … 118 119 120 121 )Oddelek: Strojna oprema | 978937 (835593) | gddr85 |
