nadgradnja?
nadgradnja?
Picero ::
Pozdravljeni,
prosil bi vas za nasvete glede nadgradnje racunalnika. Sicer je zadeva na splošno hitra, zatika pa se v Lightroomu, ko obdelujem fotografije. Pocasnost se mi pojavalja v Lightroomu (5.7, 64 bit) odkar sem si nabavil 4k monitor, hkrati sem dokupil tudi mocnejso graficno kartico, vendar kaksne pohitritve ni. Morda bi nadgradil RAM (trenutno v 3 slotih po 2 GB RAMa), vendar pa le v primeru, ce bi se to poznalo ali pa se morda da kaj narediti se s kaksnim navijanjem?
Trenutna konfiguracija:
Operating System Windows 10 Home 64-bit
CPU Intel Core i7 920 @ 2.67GHz 50 °C
Bloomfield 45nm Technology
RAM 6,00GB Triple-Channel DDR3 (8-8-8-20)
Motherboard Gigabyte Technology Co. Ltd. EX58-UD4 (Socket 1366) 34 °C
Graphics LG 27MU67 (3840x2160@60Hz)
2048MB NVIDIA GeForce GTX 960 (ASUStek Computer Inc) 33 °C
Storage 238GB Crucial_CT256MX100SSD1 (SSD) 27 °C
931GB Western Digital WDC WD1002FAEX-00Z3A0 (SATA) 31 °C
RAM natancneje:
RAM
Memory slots
Total memory slots 6
Used memory slots 3
Free memory slots 3
Memory
Type DDR3
Size 6144 MBytes
Channels # Triple
CAS# Latency (CL) 8 clocks
RAS# to CAS# Delay (tRCD) 8 clocks
RAS# Precharge (tRP) 8 clocks
Cycle Time (tRAS) 20 clocks
Command Rate (CR) 1T
Physical Memory
Memory Usage 44 %
Total Physical 6.00 GB
Available Physical 3.32 GB
Total Virtual 12 GB
Available Virtual 8.02 GB
SPD
Number Of SPD Modules 3
Slot #1
Type DDR3
Size 2048 MBytes
Manufacturer Mushkin
Max Bandwidth PC3-10700H (667 MHz)
Part Number 998659
Week/year 12 / 09
Timing table
JEDEC #1
Frequency 444.4 MHz
CAS# Latency 6,0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 16
tRC 22
Voltage 1,500 V
JEDEC #2
Frequency 592.6 MHz
CAS# Latency 8,0
RAS# To CAS# 8
RAS# Precharge 8
tRAS 22
tRC 30
Voltage 1,500 V
JEDEC #3
Frequency 666.7 MHz
CAS# Latency 9,0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 24
tRC 33
Voltage 1,500 V
Slot #2
Type DDR3
Size 2048 MBytes
Part Number 998659
Week/year 12 / 09
Timing table
JEDEC #1
Frequency 444.4 MHz
CAS# Latency 6,0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 16
tRC 22
Voltage 1,500 V
JEDEC #2
Frequency 592.6 MHz
CAS# Latency 8,0
RAS# To CAS# 8
RAS# Precharge 8
tRAS 22
tRC 30
Voltage 1,500 V
JEDEC #3
Frequency 666.7 MHz
CAS# Latency 9,0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 24
tRC 33
Voltage 1,500 V
Slot #3
Type DDR3
Size 2048 MBytes
Part Number 998659
Week/year 12 / 09
Timing table
JEDEC #1
Frequency 444.4 MHz
CAS# Latency 6,0
RAS# To CAS# 6
RAS# Precharge 6
tRAS 16
tRC 22
Voltage 1,500 V
JEDEC #2
Frequency 592.6 MHz
CAS# Latency 8,0
RAS# To CAS# 8
RAS# Precharge 8
tRAS 22
tRC 30
Voltage 1,500 V
JEDEC #3
Frequency 666.7 MHz
CAS# Latency 9,0
RAS# To CAS# 9
RAS# Precharge 9
tRAS 24
tRC 33
Voltage 1,500 V
ram in ssd obvezno.
Picero ::
TNX
na koliko in kaksen RAM svetujes? Ali naj samo dokupim ali zamenjam, prostora imam 3 x 2 slota po 4 GB max.
SSD imam, po mojem je OK, a ni? 238GB Crucial_CT256MX100SSD1 (SSD)
pa res, potem pa samo ram...
Najboljše da ram prej potestiraš v kaki trgovini...
Picero ::
Hmmm, mal problem mi je cel sistem nosit po trgovini, ker je to kista + velik monitor.
Koliko RAMa bi pa potreboval? Ali bi bilo dovolj 3 x 4GB dodatnega RAMa, bi riskiral teh 60-80 EUR, pa ce bi bilo kompatibilno z mojimi starimi moduli bi potem imel 18 GB, kar bi ze moralo zadostovati, kajne? Ali lahko kaj pomagas kater RAM kupiti?
Na RAMe se ne spoznam in mi je bila vedno nerazrešena uganka koliko se dejansko pozna razlika med njimi in kaj je s čim kompatibilno:
Je razlika med tema dvema oz. na kaj naj gledam pri nakupu RAMa (vem da mora biti DDR3, koliko pa pomeni CAS latenca in hitrost?):
CRUCIAL RAM DDR3 4GB PC3-12800 1600MHz CL11 SR (CT51264BA160BJ) za 18 EUR in
CRUCIAL RAM Ballistix Tactical 4 GB, DIMM 240-pin, DDR3, 1866 MHz (Hitrost: 1866 MHz ( PC3-14900 ) Latenca: CL9 ( 9-9-9-24 ) za 25 EUR
štos je, ker nemorš vedet. Te stare plate so zbirčne za ddr3 rame in dokler ne probaš, neveš...
Picero ::
Hmmm, potem mi je varianta, da narocim preko spletne trgovine, probam in ce ne dela vrnem in potem ponavljam vajo do takrat, ko dela. :)
Samo kje zaceti, da bo cim manj ponovitev... ;)
dominuspro ::
Kaj pravi task manager ob zatikanju? Ni slučajno procesor takrat na 100%?
Picero ::
Procesor skoči na 60% iz običajnih cca 10%, memory pa je stalno na cca 70%.
Bom še malo testiral in poizkusil še kaj drugega, pa potestiral z več odprtimi programi.
Sem pa opazil, da je problem pri obdelavi fotografij v Lightroomu v celozaslonskem načinu (lightroom odprt cez cel 4K monitor), ce lightroom odprem cez pol monitorja v zmanjsanem oknu, potem zatikanja ni, oz. ga je zelo malo... pri prejsnjem monitorju z resolucijo 1600x1200 točk je bilo procesiranje v celozaslonskem načinu brez zatikanja. 4k je le malo več podatkov za obdelat, a sem mislil, da bo to prevzela nova grafična, pa očitno temu ni tako.
Vsekakor kakšen GB RAMa več ne bo škodil, ker se je s prehodom na 4K monitor upočasnil tudi InDesign.
gddr85 ::
grafična bo težko prevzela, ker lr5 slabo nuca gpu afaik
Picero ::
gddr85, tudi to sem že prebral po forumih... Menda pa tudi 6tka ni najboljša in včasih celo počasnejša kot 5tka, zato je zaradi tega in zaradi pomanjkanja časa še nisem testiral.
gddr85 ::
kar ti rabiš je cc ;)
Picero ::
no ja, saj bistvu naj bi bilo isto na 6 ali CC? Bom pa nalozil trial in videl, ce je pri CC res kaj boljse.
Picero ::
CC je hitrejši in brez zatikanj, TNX. Dodaten RAM pa imam vseeno v planu za dokup, samo ne vem še katerega naj vzamem.
Riff ::
dobre firme po mojih izkušnjah: patriot, ocz, samsung, kingston, drugače pa poglej katere firmo so kompatibilne s tvojo ploščo na specififikacijah od plošče
klinker ::
Kolegu sem leta nazaj sestavu skoraj enak sistem za foto obdelavo...takrat PS, sedaj pa dela v LR. Pred par leti smo nadgradili iz HDD Velociraptor na SSD Samsung Pro in malo pred tem ze vgrajenim 3x2GB dodali se 3x 4GB rama. Od te nadgradnje pa do danes se ni pomislu kaj nadgradit, naj pa povem za zanimivost da med delom on kuri ogromno rama. Dokler je imel 6gb je imel porabo vedno okoli 5gb, po nadgradnji mu ga zre med 12 in 15gb brez problema, je pa reku da je bla zelo opazna razlika v performansu.
Je pa njegov 920 navit na 3,66Ghz ze od zacetka, grafa je pa se takratna 8800GT.
No, letos bo pa verjetno sel v nakup nove kiste, ampak samo zato ker hoce neko malo itx kistico, ker trenutni Define XL mu gre ze na jetra saj zaseda en kup placa. Se pa caka na izid nove i7 z IrisPro.
Btw, kak zaslon imas to? Ker bo tudi on menjal saj je se vedno na 21,5" FHD ips Lenovo na katodo in mu je to trenutno prioriteta za zamenjat. Sam nad 4k zasloni se nisem preprican za ta namen, tako da za sedaj se oziramo bolj po kaki 27" 1600p, ceprav ga srbi za 4k.
Picero ::
Tudi jaz sem imel Velociraptor, odličen disk, ki ga je nasledil SSD. Najbolj opazna razlika v hitrosti do sedaj.
Ali imaš morda kakšen recept za upgrade na 3,66 GHz?
Zaslon imam pa tale: http://www.lg.com/us/monitors/lg-27MU67... - 27", 4K
Na začetku mi je bilo vse nekako majhno (ikone, črke...), delovne površine je bilo ogromno. Takrat sem celo razmišljal, da bi zaslon prodal in si kupil 27" z resolucijo 2560x1440. Sedaj sem se na to navadil in mi je OK, res pa je bila potrebna kakšna prilagoditev, da sem nekoliko prilagodil velikosti pisav v določenih programih.
gddr85 ::
btw za os imaš scaling opcijo, daš ene 120% in ne rabiš povečevalnih stekel ;)
Ali pa kupiš proper 4k monitor
gddr85 ::
Darvin super, edin če maš normalno cca 60cm mizo, najbrž veš kako bo to potem zgledal ane, nimamo vsi radi "kino" style v prvi vrsti :D
Jah, pol pač ne kupiš 4k. Jaz na moji 40tki uporabljam povečavo, kaj šele potem neka 27tka.. To naprezanje oči na dolgi rok ne more prinest nič dobrega.
DarwiN je izjavil:
Sam delam na velikih ločljivostih že čez 30 let. Vidim bolje od večine folka. Kdo napreza oči?
Kot bi za tvojo 40tko rekel da boš imel probleme z vratom.
Ta dva frajerja tut že 30 let delata v gradbeništvu in sta v boljši fizični kondiciji od večine. :D
gddr85 ::
čaki ko bosta v penziji, če jo dočakata :D
Uporabno samo 50 % RAM računalnika
275971 (5172) solo5
ddr3 nadgradnja
111762 (1559) mat xxl
Gonilniki
Oddelek: Programska oprema
122381 (2264) Housy
časi na ramih (strani: 1 2 )
Oddelek: Navijanje
534775 (4000) Boki_
ram PC3200 deluje kot PC2700
81777 (1684) drejcmb
