Forum » Strojna oprema » ram PC3200 deluje kot PC2700
drejcmb ::
Imam omnejeni ram, kateremu sem hitrost nastavil na 200fsp, pa kljub temu deluje na 167,
čeprav mi ta plata podpira PC3200, probal sem že vse nastavitve v biosu, ali je možno da so mi dali nekompatibilen ram, samo so mia ga sestavili po naročili, tak da bi mogli vedet.
Hvala!
tu je izrezrek iz PC wizard 2004,
General Information :
DIMM0 (RAS 1, RAS 0) : 256 (Single Bank) - DIMM, SDRAM
DIMM1 : Empty
DIMM2 : Empty
Memory Controller Information :
Memory Controller : SIMM, DIMM, SDRAM
Number of connectors : 3
Max. Module Size : 1000 MB
Max. Memory Size : 3000 MB
Supported Speed : 70ns, 60ns, 50ns
Supported Voltages : 3.3v
Error Detection Method : 64-bit ECC
Error Correction Capability : Unspecified
Current/Supported Interleave : 1-way/1-way
Chipset Information :
Type : DDR-SDRAM PC2700
Frequency : 167 MHz
FSB/DRAM Multiplier : FSB + 66 MHz
ECC Diagnostic : Ne
Interleave : 4-way
CAS Latency (tCL) : 3.5 clocks
RAS to CAS (tRCD) : 3 clocks
RAS Precharge (tRP) : 3 clocks
Cycle Time (tRAS) : 5 clocks
Information EEPROM (DIMM0) :
Manufacturer : Kingston
Part Number : K
Serial Number : 601B4260
Type : DDR-SDRAM PC3200 (200 MHz)
Size : 256 MB (1 rows, 4 banks)
Module Buffered : No
Module Registered : No
Width : 64-bit
Error Correction Capability : No
Max. Burst Length : 8
Refresh : Reduced (.5x)7.8 µs, Self Refresh
Voltage : SSTL 2.5v
Supported Frequencies : 133 MHz, 166 MHz, 200 MHz
CAS Latency (tCL) : 2 clocks @133 MHz, 2.5 clocks @166 MHz, 3 clocks @200 MHz
RAS to CAS (tRCD) : 2 clocks @133 MHz, 3 clocks @166 MHz, 3 clocks @200 MHz
RAS Precharge (tRP) : 2 clocks @133 MHz, 3 clocks @166 MHz, 3 clocks @200 MHz
Cycle Time (tRAS) : 6 clocks @133 MHz, 7 clocks @166 MHz, 8 clocks @200 MHz
Hvala!
DIMM1 : Empty
DIMM2 : Empty
Frequency : 167 MHz
ECC Diagnostic : Ne
Interleave : 4-way
Part Number : K
Width : 64-bit
Voltage : SSTL 2.5v
MEDENA ::
to maš KINGSTON VALUERAM?
ja v biosu moraš nekaj naštimat na auto pa ne vem kaj že...sprobaj ne bit len
ČIP 008 ::
Meni pa so dali PC2700 pa mi dela kot PC3500 hahaha.... hvala. No šalo na stran, zadevo reklamiraj in vzemi PC3200 in cas vsaj 2.5.
drejcmb ::
RAM je PC3200 400MHz Kingston 184pin, drugega ne vem, aja je pa naj cenejši, kupljen v comtronu. V biosu sem že vse probaval, na avto al pa sem sam dal na 400MHz pa ne pomaga lahko samo znižam takt, kot da je maksimum 333Mhz, edino napetosti nisem dvigoval, saj ge ne navijam, pa še latency sem spreminjo.
Plata je asusova P4V8X-X, ČIP VIAPX533, 533/400 MHz FSB, 3X DDR400,333,266, 5XPCI,HT AND PRESCOTT PODPORA
PROCESOR je Celeron 2400/400 MHz
- spremenil: drejcmb ()
drejcmb ::
Lej če veš kak se to naredi bi te prosu, da mi poveš, če pa ni možno ga bom pa itak na servis pelo.
MEDENA ::
ma sej res ejga imaš ti to sploh 200FSB plato ?
3X DDR400,333,266
imaš ja...
v biosu naštimaš 1:1 pa je.....FSB:DDR
3X DDR400,333,266
imaš ja...
- spremenil: MEDENA ()
drejcmb ::
Nastavitve v biosu:
SPS: DISABLED AL ENABLED
SDRAM FREQWENCY: 200-400MHz
CAS Latency: 1.5-3
SDRAM Bank Interleave: DISABLED AL 2WAY AL PA 4WAY
SDRAM Burst Length: 4QW ALI 8QW
SDRAM Comandrate: 2T ALI 1T
CAS Latency: 1.5-3
| » | Nadgradnja DDR400 RAM-aOddelek: Strojna oprema | 1813 (1652) | ignis |
| » | Mticna plosca i845PeOddelek: Strojna oprema | 1919 (1702) | mtosev |
| » | A se da navit RAM!!!!!Oddelek: Navijanje | 1510 (1345) | JIM22 |
| » | časi na ramih (strani: 1 2 )Oddelek: Navijanje | 4797 (4022) | Boki_ |
| » | AMD 2500+ & Abit NF7Oddelek: Navijanje | 2813 (2059) | Wad@ |
