mailboxde.com
mailboxde.com
smacker ::
Prohibited & Restricted Goods:
Deliveries handed to collective store cannot contain following items:
Shipment whose value exceeds 1000 EUR or maximal value of responsibility of carrier procured in the Forwarding order. This shipment has to be declared and insured correctly during entering into the Forwarding order. In case of unauthorized handing of the shipment exceeding value 1000 EUR or maximal value of responsibility of the carrier, the Forwarder is not responsible for damage of the shipment exceeding 1 000 EUR or the maximal value of responsibility of procured carrier. If the real value of the shipment is lower than it was declared by the Customer, the Forwarder is not responsible for damage of the shipment exceeding its real value.
zancek0 ::
Se opravičujem za še eno vprašanje glede tega, kako zapolnit okenčka, ampak to delam prvič in nočem zajebat. Ali naj izberem private addresse ali firmenaddresse in kako naj zapolnim okenčka?
 "What should I do..."?
mitkos ::
Kako je naprimer pri plačevanju s PayPal om v tuji spletni trgovini in naslovom preko mailboxde? Nekje imam v glavi da gre plačilo z PayPal om naprej le če je naslov za pošiljanje enak naslovu na paypalu oziroma bančni kartici???
Ales ::
Odvisno od prodajalca, nekateri pošiljajo kupljeno le na dejanski naslov, vpisan pri PayPalu. Pri takih Mailboxde odpade.
panja003 ::
Pozna kdo podobno stran kot je mailboxde tudi za Avstrijo?
Cheetah ::
Je že kdo uporabil mailboxde (posredovanje pošte) za notebooksbilliger?
Ko probam naročit z billing address iz Slovenije (domač naslov) in naslov za dostavo od mailboxde piše, da fizičnim osebam iz slo ne pošiljajo. Se pravi, da se pač ne da, ali lahko billing address tudi spremenim (verjetno bi zavrnilo kartico I guess?)?
  • spremenil: Cheetah ()
Jaco P. ::
Mailboxde ima kar nekaj restrikcij..TVs over 21 inch, LCDs over 21 inch, packaged furniture above 15 kg, subwoofers and speakers over 5 kg, toilet bowls, sinks, mirrors, white goods over 5 kg (especially kitchen appliances, washing machine, refrigerator, hood, hobs, ovens etc.)
Kaj se zgodi s pošiljko, če vseeno naročiš eno izmed naštetega?
Rad bi naročil nek kitchen appliance, ampak je tam 10kg.. Je katera druga "reshipping" stran, ki bi mi to omogočala?
darkolord ::
Lahko gre skozi, lahko zavrnejo že ob sprejemu, lahko jim zavrne dostavna služba (v tem primeru imaš ti dodatne stroške).
Alternativa je cheaperandmore.com
Jaco P. ::
Sem pisal na Mailboxde support in so rekli, da lahko naročim in bodo sprocesiral (kljub omejitvam, ki jih omenjajo na strani)...ampak zapletlo se je na MediaMarkt strani.
Že 2x so mi reject-al naročilo "Your order unfortunately did not meet one of the test criteria and therefore had to be automatically rejected for security reasons." (google translate),
s tem da sem prvič dal za "Vorname" = Mailboxde.com GmbH, v drugo samo moje ime in priimek & moj Mailboxde ID, pa tudi ni šlo..
Čeprav je bilo naročilo reject-ano pa refound še vedno nisem dobil (in to 2x)..upam, da se ne zakomplicira :)
Je že kdo imel podobne probleme?
Cheetah ::
Jaco P. je izjavil:
Možno je, da nočejo poslati na mailboxde.com naslov zgleda. Jaz sem probal s notebooksbilliger in so mi tudi zavrnili naročilo s mailboxde naslovom (ampak že pred plačilom), iz saturn.de pa so poslali. Sicer pa močno dvomim da boš imeu probleme z refundom, včasih pač traja nekaj časa da ti vrnejo denar (zdi se mi da sem pred leti čakal tudi več kot teden, ko sem preklical naročilo pri nekem tujem trgovcu).
darkolord ::
Ne, tile ne pošiljajo več preko posrednikov. Tudi od saturn.de vsaj sedaj dobiš povsem enako sporočilo.
darkolord je izjavil:
Ali http://mygermany.com
ETI3n ::
Ali kdo ve, zakaj za vraga se paket nahaja na Češkem (v tranzitu).Izbral sem dostavo z GLS, mi je kar mal žal glede izbire za dostavo...
ETI3n je izjavil:
Mailbox.de skladišče se nahaja na meji med Nemčijo in Češko (na Nemški strani). Včasih gre paket preko Češke, če ima paketna družba tam krajšo pot ali postanke, ne bi smelo vplivati na čas dostave kaj dosti.
Še nekaj z njihove strani o nastanku mailbox.de:
In 2004, when I was 17 years old, I developed my first online transportation system. The company INTEL invited me to the science fair INTEL ISEF in the USA, which was the impulse for me to start my business in transportation. Then there was the financial crisis of 2008 and I could barely cover my living expenses. Our customers were looking for a cheap way to get small packages delivered from Germany. At that time, I was also putting my mountain bike together and I bought the components on eBay.de. The tranportation to the Czech Republic was expensive and slow. One day I went to Germany to try to change that. Today through our warehouses we handle up to 135 000 shipments annually for 100 000 customers.
Ondrej Krabs
CEO
  • spremenil: LeQuack ()
Vuli ::
kaka panika, če bi pogledal kje sploh mailbox je, bi ti bilo vse jasno.
Cheetah ::
Zanimivo... dober mesec nazaj sem naročil od njih preko mailboxde.
Trubar ::
Zivjo, z amazona kupujem hladilno skrinjo 16kg 50x50x50cm. Za dostavo amazon zeli 65€. Po naljucju sem izvedel za mailboxde.com. Trenutno ima Amazon prime membership 30 dni zastonj. To pomeni, da je dostava na mailboxde.com skladisce zastonj, ker je lokacija skladisca v Nemciji. Iz mailboxde.com pa naj bi bila dostava slabih 20€ po njihovem kalkulatorju. Ali ima kdo kaksne izkusnje s tem?
Na mailboxde.com sem se ze prijavil. Ce sem prav razumel sedaj na amazon vpisem svoj "novi mailboxde.com" naslov. Ko mailboxde.com dobi, paket mi ti posljejo paket, da placam postnino oz. vidim, da lahko nastavim automatic dispatch za 6.9€. Tu sem malo zgubljen...
Skratka, sem kaj spregledal? :)
Ref exchange link:
https://my.okx.com/en-eu/join/35464995
https://www.kucoin.com/r/rf/Hu6Rx2
Tole najbrž ne bo šlo skozi, ker skrinja spada med prepovedano blago za pošiljanje prek Mbox.. Lahko jih pa vprašaš. Ponavadi hitro odgovorijo.
prohibited goods: TVs over 21 inch, LCDs over 21 inch, packaged furniture above 15 kg, subwoofers and speakers over 5 kg, toilet bowls, sinks, mirrors, white goods over 5 kg (in particular, kitchen appliances, washing machines, refrigerators, cooker hoods, hobs, ovens etc.), bumpers, spoilers, car fenders, car exhausts, large car parts, bicycles (except children\'s bikes).
Trubar ::
Gre se vbistvu za vecjo hladlino skrinjo za v avto oz. kar prikolico. Polni se na 220V ali 12V in celo na plin. Sem jim poslal povprasevanje.
Ref exchange link:
Vuli ::
ko pride paket na mailbox vidiš kolk bo poštnina in naložiš tolk dnara preko Paypal-a, odkljukaš par svtari, izbereš kero pošto itn
  • spremenil: Vuli ()
Namesto mailboxde lahko probaš še pri mygermany , cheaperandmore ali kateri drugi konkurenci.
Včasih imajo bolj ugodne pogoje.
martincek1 ::
Se je že komu zgodilo, da na sledenju pošiljke piše, da je že vročena (s podpisom), ampak paketa ni v Mailboxde? Vročena je bila 7.12 ob 12:29
Sprašujem zato, ker sem po tem na Mailboxde dobil še eno pošiljko (po tracking kodi vročena včeraj).
kixs ::
Pisi jim email, da si dobil obvestilo o dostavi paketa, vendar ga ni na seznamu. Ce lahko preverijo.
Na C&M se to vcasih zgodi, pa se je se vse naslo.
Blazz ::
ima kdo idejo, katero forwarding stran naj uporabim, če je prodajalec na poljskem in dostavlja samo tam?
modelno1 ::
Nekje na forumu sem zasledil EuropeMailbox, nisem še sprobal.
Respect the bacteria! They are the only culture some people have.
Blazz je izjavil:
Lol kje najdeš stvari, ki so dobavljive samo na Poljskem.
acookook ::
Kakšna je trenutna situacija s Saturn/MediaMarkt DE? Pošiljata že na mailbox predale?
Jaz sem sicer prejšnji teden nekaj naročil na Mailboxde, en paket iz Avstrije in en paket iz Nemčije. Začuda sta prišla na isti dan tja, potem pa sem oba forwardiral preko GLS in sta šla še isti dan naprej. Zdaj pa GLS zavlačuje, res pa da so prazniki.
acookook ::
Od kje si naročil ta iz nemčije?
acookook je izjavil:
Bike24.com
acookook ::
aja, me konkretno zanima za omenjeni trgovini.
Naročil prejšnji mesec iz MediaMarkt na mailbox in so skenslali naročilo.
Blazz ::
LeQuack je izjavil:
Blazz je izjavil:
https://www.proshop.pl/Procesor/AMD-Ryz...
pa mi ti najdi alternativo v DE za to ceno...
Blazz ::
modelno1 je izjavil:
sem probal, pa imajo zaklenjene registracije...
martincek1 ::
Za obstoječe uporabnike MailboxDe normalno deluje?
Zanima me, če je mogoče kupiti Kindle (ki se načeloma prodaja samo v Nemčiji) na ta Mailboxde račun? Preko Ebaya. Al mi ne bodo pustili naročiti?
Po moje ne bi smelo biti težav. Kako pa da se samo v Nemčiji prodaja?
Ales ::
Kindle se prodaja tudi pri nas. In tudi neposredno z Amazona se ga da naročiti k nam, samo ne z nemškega Amazona oz. vsaj včasih se ga ni dalo.
martincek1 ::
Že, ampak v Sloveniji stane 140-150e. V Nemčiji 104e + cca 12e MBXde. Mal preveč marže imho. Sploh, ker je bil ta model (Paperwhite) mesec nazaj 77eur.
Ales ::
Po moje bo najbolje, da prej vprašaš prodajalca na ebayu ali bo hotel poslati na Maliboxde. Sploh če plačuješ s PayPalom.
Edit: ne vem če je prav ta model kdaj bil 77 EUR. Kaj je bil to kak poseben popust? Vodoodporni Paperwhitei, model 2018, so po moje bili ves čas dražji... razen če je bil kak izjemen popust, to ne vem. Navadnega Kindla, model 2020, imaš pa tudi pri nas za 90-95 EUR.
  • spremenil: Ales ()
fopi ::
Kako dolgo pa lahlo cakajo stvari na mailbox.de da zdruzis pakete?
2 meseca lažji paketi do 2kg, 1 mesec težji paketi.. Nekaj takšnega, po spominu. Preveri pogoje in se prepričaj.
Najbrž je mislil koliko časa rabijo da združijo več paketov v enega. Ponavadi en dan rabijo.
fopi ::
DarwiN je izjavil:
To sem mislil. Naročil bi iz različnih trgovin in da mi potem združijo. Bi pa iz ene trgovine dobava bila 2-4 tedne in potem ne vam kdaj naj naročim, da se bo vse srečalo na mailboxe.de.
fopi ::
A je za združevanje potrebno kaj javiti na mailboxde ali samo počakaš, da oba paketa prispeta?
fopi je izjavil:
To je prav plačljiva storitev. Mislim da stane ene par evrov na leto, potem ko sta oba (oz. več) paketov tam v sistemu imaš tudi nek gumb za združitev paketov, ki ga nato klikneš in potem od tam naprej. Ampak ja prvo moraš počakati da sta oba paketa tam.
cortez ::
3€ stane.
javiš za consolidation, in to je to...pol plačaš za 1 paket.
Tista letna opcija je opcija - 12,50€ /leto .
Slayer69 ::
A se da mailboxde naslov nastavit v paypalu? Torej, da že v paypalu poleg naslova za plačilo (ta je domač iz Slo. saj se mora ujemat, če ne že kartico zavrne) in še enega za dostavo (mailboxde). In da bi potem pri trgovini kjer naročaš izbral plačilo s paypalom in naslov na mailboxde?
Drugače sem nekaj že gledal in našel možen vnos dodatnih naslovov, ampak tam sem lahko vpisal samo od ulice naprej (ne pa samega naziva, tako da sklepam, da je ta vedno moje ime in ne morem nikjer napisat "Mailboxde.com GmbH").
  • spremenil: Slayer69 ()
Vuli ::
pri mindfactory imam na Paypal računu napisan naslov od Mailboxa, čeprav je ponavadi slovenski naslov. Imam pa na MF paač naslov za dosotavlo mailbox. Zgleda samo popravi zna bit pa odvisno od trgovine same, i guess
Slayer69 ::
Aha torej Mailbox naslov si vpisal na sami MF strani in ne že v PayPal nastavitvah, če prav razumem?
Drugače na tak način sem želel naročit iz cyberport.de pa mi je zavrnilo, da ne more bit SI naslov (sam ok to je verjetno specifika cyberporta), zato sem mislil, če bi poizkusil, da že direkt v PayPal vnesem (in bi tudi poenostavilo zadevo, če naročaš iz različnih trgovin).
Lolita7 ::
Živjo vsem :)
Naročila bi iz cyberporta (Apple artikli), vse skupaj bi me prišlo cca. 100EUR ceneje (znesek 1000EUR). Pa vem, da itak ne pošiljajo k nam kot fizični osebi... Bi se dalo prek mailbox.de - je komu uspelo nedavno ali tudi to nikakor ne gre več? Imamo sicer s.p. vendar ne vem, če bi šlo skozi prek mojega paypala - naslov je sicer isti? Pa tudi davek bi plačala, smo davčni zavezanci, vendar tega raje ne bi dali v olajšave, v izogib nevšečnostim z kontrolami, če po njihovem mnenju to niso primerni artikli... Vnaprej se lepo zahvaljujem za kakšen nasvet in pomoč...
  • spremenilo: Lolita7 ()
MindFactory mnenje (strani: 1 2 3 4 … 54 55 56 57 )
2812710628 (16010) PrimozR
cheaper & more (strani: 1 2 )
6829204 (1373) kixs
Preusmeritev paketa iz Nemčije v Slovenijo
3410222 (4095) starfotr
Spisek trgovin katerih robo je mogoče dobiti, le preko posrednikov
289113 (6166) pe3c
Spletni trgovec noče prodati naročenega blaga (strani: 1 2 )
5218843 (15374) DeeJay
