Forum » Strojna oprema » Nvidia GTX 900 series
TOP ::
99ghetto99 je izjavil:
Se splača zamenjati gigabyte r9 280x za eno od GTX 970?
Tukaj sploh ni uprašanje,seveda se splača pa tud poraba je občutno manša,da o temperaturi sploh ne govorimo.
FlyingBee ::
http://www.techpowerup.com/208901/kfa2-...
zanimivo 960 z 1x 8-pin priključkom, to je 225W max., očitno računajo da bo več kot 150W porabila, kar je čudno, saj je 970 na stock frekvencah tam nekje
New Sphincter Kvartet:
Ta 8-pinska bo očitno neka extreme overclock edition (EXOC), zato toliko juica.. Ostale, navadne in OC različice, bi naj imele 1x 6-pin in manj porabe.
FlyingBee ::
me prav zanima cenovna uvrstitev in ali bo ta extrem z več juica hodila v zelje 970 Oc
Mind_Game ::
pomoje bo okol 250€
i7 4790K@4.7GHz|NZXT Kraken X41 140|2x Galax GTX980 4GB SOC|8GB 2666MHz|
Asus Maximus VII Hero|120GB/256GB/480GB SSD|SeaSonic M12II 850W EVO 80+|
LG Blu-ray BH16NS40|Corsair Carbide Air 540 White|Logitech G105/G500/Z623
RejZoR ::
GTX 990 če bo, bo dual GPU kartica po vsej verjetnosti. Ali 2x 970 al pa celo 980.
trnvpeti ::
960 malo nad 280 (brez x)
http://wccftech.com/nvidia-geforce-gtx-...
. As the score posted below reveal, the GeForce GTX 960 manages to score P9960 in 3DMark 11 performance mode and X3321 in 3DMark 11 Extreme mode. A reference Radeon R9 280 scores around 9000-9500 3DMarks in performance and 2900-3100 in extreme mode. Similar gains can be seen in 3DMark Firestrike with the card scoring 6636 marks on default mode, 3438 marks in Extreme mode and 1087 marks in 4K ultra mode which is ridiculous for such a card. When overclocked, the card scores 7509 marks in the default 3DMark Firestrike benchmark at clock speed of 1398/1461 MHz up from reference speeds of 1228/1291 MHz.
- spremenil: trnvpeti ()
spet en meh. Manj rama kot amd, kastriran bandwidth in ne tako impresivna poraba za padec performanca (bi pričakoval kej okol 100W ali manj)....
Ti version it is..
Ti version it is..
Torej 960 (ker je meh) ne boš kupil, boš pa namesto tega kupil 98(7)0ti.
Tu nekaj ne štima. ?
Napajalc ::
Nevem kaj je z mojim youtube, ne najdem nobenga posnetka z watmetrom poleg monitorja, ki na njem laufa Far Cry 4, seveda na gtx 970.
gddr85 ::
za ceno 960 dobiš najbrž kej boljšega, če bo kaka 960/65Ti bo še dražja in ti potem ne manjka dost do 970, sploh če kupuješ kako rabljeno...
RejZoR ::
Kera gnila stagnacija. Upam da bo R9-380X/390X solidna zadeva, da mal premakne stvari naprej...
trnvpeti ::
mam obcutek, da so se zelo potrudili, da so zmanjsali zmogljivost
gddr85 ::
za kolk 10-15eur?
....sej se 970ke ziher lepo prodajajo, za minimalno porabo in kolker tolk zmogljivosti imaš pa tud 750ti
glede na 300W tdp in fact, da še ni teš6 bloka... yeah, i think not.
GenZNPC ::
Verjetno bo tkole. Zdle dajo ven 960ko pač, ker ni druge. Potem se počaka na R9-3XX in potem se z raznimi Ti variantami zafilajo lukne, da bo za vsakega nekaj.
Ali pa najlepše bi bilo videti, da bo R9-3XX razturala, da bo potem nvidia prisiljena hitreje it na 22nm.
Glede nato, da so bile dobro leto dni nazaj govorice, da bi danes morali že imeti v kištah 22nm tehnologijo, nas je maxwell fajn presenetil.
skibidi
RejZoR ::
iloveboobz je izjavil:
Ker TDP je seveda odraz vsega ane?
Xserces ::
Evo jovo na novo :) K da bi gledu prvo stran k se kregate
gddr85 ::
hja, človk bi si (najbrž) želel tokrat pri amd mal nižjo porabo kot 250w+ tdp ne glede na preformance, razen če mislijo it še dodatno navzgor s porabo
GenZNPC ::
Ne gre, ker je tudi treba ohladit.
Naj se lepo potrudijo in spravijo pod 300W 2x večji performance pa bo mir.
Mene bolj zanima kako bo z dx12 in mantle2 podporo, da si nebo kdo kupil kartico brez tega, recimo 3-4 mesce pred izidom.
Je kdo videl kaj več infota o tem?
skibidi
Skoda, da s tem gm206 cipom niso nardil 1280/80/48 in 192 bit konfiguracije. Za predvideno ceno bi bil sah mat. Pomoje se nocejo prevec norca delat iz amdja.
GenZNPC ::
Kartelni dogovori seveda niso izključeni. Saj konec koncev največ zaslužijo tako, da sodelujejo.
skibidi
Napajalc ::
Bah, ta poraba energije je pesek v oči, razlike porabe med nekaj grafičnimi merjeno kot celotni sistem:
http://www.techspot.com/review/885-nvid...
Je mal bolš, vendar nič posebnega za svežo grafično kartico.
Je odraz tega, da bo še ena nasilo narejena zadeva. Tko kot 290/x.
- spremenil: iloveboobz ()
Men se niti ne gre toliko za samo porabo, ampak za toploto. To je treba nekam odvajat, kar je pa ze tezje, se posebi z zracnim hlajenjem. Je prav grozno, ko zadaj iz kiste piha zrak, da ti kocine posmodi.
FlyingBee ::
Kupoš nvidio pa daš še 60w žarnico v kišto in zadovoljiš amd fanboya
Kje sploh smisel bit fanboy pri tehnični robi?
Kupiš pač kar je bestbuy na trgu (in trenutno je to afaik 970 v srednjem višjem rangu). Pa če bila to grafa od Iskre pa tudi ok. Tisti ki tako ne kupuje, je butelj.
RejZoR ::
Ja, radikalno nov GPU s povsem novim tipom spomina je res nekaj na silo narejeno ja. Mhm. Sploh pa ne vem iz čigave riti si spet potegnil, da je bil R9-290X na silo narejen čip. A se sploh zavedaš da se ta na silo narejen čip še vedno kosa z GTX 970 in ponekod celo z 980, ki je čist brand new sveža kartica? Pač ne znese iz cenovnega stališča, ker jih enostavno ne morejo prodajat pod ceno. Nekaj kar se vedno dogaja s karticami stare generacije. Danes sem imel namen naročit GTX 970 iz nemčije, pa sem ravno ujel novico na TPU o R9-380X in kako napredujejo stvari okoli te generacije. In sem odložil nakup, ne zato ker sem fanboy ampak zato ker dajem AMD-ju možnost da se izkaže. Še vedno lahko pol naročim 970 če se bo izkazalo, da bo boljša izbira. Ampak kar sem ujel informacij bo daleč od tega. So špekulacije, da ne bo imela noro nizke porabe ampak mi prav en drek dol visi glede tega. Vse kartice do zdej sem imel navite na mejo zmogljivosti, iz tega lahko sklepaš, da mi je poraba zadnja briga.
- predlagal izbris: FlyingBee ()
Če nebi bil na silo narejen čip, nebi mel skoraj 300W porabe. Tko so pa nabil št. stream procesorjev, do meje sprejemljivega za takratno stopnjo zrelosti procesa in zmožnosti hlajenja. in 3xx serija nebo nič boljše. Dodatno nabijane stream procov, malo potweakan GCN (smo vidl z 285, da tonga ni nič kaj pretresljivo boljši arch)..
Ja, ampak porabi opazno več. Pa 970/980 uporabljata middle range jedro, medtem ko je 290 serija topend.
RejZoR ::
Jao, in zdej ker se je NVIDII po ne vem kolk letih usralo naredil rahlo bolj varčen čip je pa vse ostalo postalo crap. Dej zbudi se no.
Tonga ni nič posebnega? Kdaj pa si prišel na PC sceno? Pol leta nazaj? Še noben new tech refresh ni bil revolucionaren, ker vedno cilja low oz mid end, da vidijo kako se zadeva obnese v praksi. Kar Tonga definitivno je bila. To, da pa ni omembe vredna pa je neumnost, ki je zrasla na tvojem zeljniku. Bandwidth ima višji od HD7970 in R9-280X čeprav ima ožje vodilo zahvaljujoč istemu framebuffer stiskanju kot ga ima behold, GTX900 serija. Enota za teselacijo je krepko bolj učinkovita in nasploh so shaderji bolj učinkoviti. Ja, kaj pa AMD ve o grafičnih čipih, riiiight?
gddr85 ::
med 285 in 280 ni po moje neke blazne razlike, kolker sem gledal dokaj enaka poraba in performance, edin 3gb vram za 280 in višja cena za 285, da bi zej glih zarad tonga kupoval 285 in gcn 1.2...
RejZoR ::
Pa sej to ni bil nikol point te kartice. Kot tud ni bil nikol point vseh kartic, ki so bile refresh mid ranga. Kaj zdej, a ste kar naenkrat pozabil, da Tonga uporablja cel kup povsem enakih bandwidth saving funkcij kot GTX 900 serija in ki jih ne najdeš na karticah starejše generacije (niti na R9-290)?
GenZNPC ::
Načeloma imate oboji prav, ampak glede nato, da porabi 40W več (gledamo uradne specse- gpudb) kot 970 in je bistveno počasnejša,
bi bilo fajn da nam nekdo pove kaj je point te kartice?
Brez TDP regulacije ni napredka, that's simple je to, ker se prej ali slej pride do thermal walla.
Torej, če ma navita 285 200W kolko bo potem mela 390X ?
Imam 300W 80Plus GOLD napajalc in tiho ohišhe z low rpm 12cm fanom?
Xeona+970 (230W)
ali pa varčni remake
FX-3870E + R9-285 (290W)
ali staro
FX-8350 - R9-290 (400W)
Kje dobim manj toplote, tišino in več muzike, brez tega da mi odpihne gold napajalc???
Pa dajte mal objektivno gledat, prosim.
Xeona+970 (230W)
ali staro
skibidi
- spremenil: GenZNPC ()
GenZNPC ::
Ne razumem tvojega odgovora in kaj ima veze z zastavljenimi vprašanji. Takle mamo. Napajlnik je že od prej.
skibidi
FlyingBee ::
trenutno je 900 serija quantum leap glede na 290/x, ki je le do rel. max. TDP-ja našponana serijsko
- spremenil: FlyingBee ()
Napajalc ::
Eni si še zmerom zatiskate oči, pardni konj od nvidie gtx 980 TI bo žgal ravno toliko kot vse hi end grafične kartice malo starejšega letnika.
ampak te bandwidth saving fukcije so bolj ali manj cost saving kot kej druga (tudi pri nvidiji). Tonga je pa kjub temu, da gre za novo stvar, še vedno isto hitra na stream proc kot gcn 1.0
FlyingBee ::
ne, napaka! .... prilagodili bodo toliko, da bo P enak ali večji od AMD paradnega konja, W pa manj ali enako, če bo P večji
za nas, kupce, je problem, ker pomanjkanje konkurence vodi v taktiko nvidie, da s Ti varijanto iste arhitekture povozi konkurenta, ne pa da jo le-ta prisili v čimprejšnjo izdajo nove arhitekture in ali proizvodnega procesa (Kepler, 8000/9000 serija, ..)
al1976 ::
Ja nvidia je tehnološko sedajle korak v prednosti. Sploh ideja no fan v idle mode me je presenetila prav tako same performance 970. Kdor zmore naj ta trenutek to kupi. Drugace pa res ATI R9 280X rabljeno z garancijo za 140EUR vs najcenejša 970 za 300 pa bi se moral konkretno potruditi...
Mislim, da zame in vsem ki jim kaj priporočim je ta anomalija vsaj kakor gledam večinoma na slovenskem trgu več kot dobrodošla :)
Napajalc ::
Točno tako, maximalna "dovoljena" poraba.
Poglej tale link in si zamisli koliko bo poraba gtx 980 ti.
Zdej govorit a bo hitrejša od AMD paradnega konja na isti porabi je pa še malo prezgodaj.
niti ne. Glede na to da ma nvidia bolj power efficent arhitekturo, tukaj sploh ni dvomov.
FlyingBee ::
fora je v tem, da high-end GPU, še posebej v OC ne-stock varijanti, še nikoli ni bil na vrhu p/W grafov, to je enostavno neverjetno kaj jim je uspelo http://www.techpowerup.com/reviews/Giga...
Napajalc ::
Upošetevaj še faktor napredka ki je 1 leto in vidiš da je to normalna grafična kartica:
r9 2xx september 2013
AMD Radeon Rx 200 Series @ Wikipedia
gtx 9xx september 2014
GeForce 900 series @ Wikipedia
SuperVeloce ::
Pozabljaš, da pri tem napredku ni bilo prehoda na nižjo litografijo. Sicer je pa Rx 2xx serija bolj ali manj ista ahitektura, kot HD77xx, HD78xx in HD79xx iz leta 2011
FlyingBee ::
ne, zgrešena miselnost, površno in ne premišljeno
GenZNPC ::
Se podpišem pod tole. Če ga AMD nebi sral, nas tudi nvidia nebi mogla podjebavat (sicer trenutno nas ne).
Tako pa, ker ni _konkretne konkurence v razvoju ni konkretnega napredka.
@stojan
kaj pa se stabo zgodilo, da si se prekrstil v bivšega -klkkkkkkkkkk?
skibidi
| » | AMD pokazal svojo najhitrejšo grafično kartico Radeon R9 Fury X2 (strani: 1 2 3 4 5 )Oddelek: Novice / Grafične kartice | 79997 (73176) | Napajalc |
| » | grafična kartica?katero kupiti (strani: 1 2 3 4 … 8 9 10 11 )Oddelek: Kaj kupiti | 113713 (43389) | PredatorX |
| ⊘ | R9 380 prenizka frekvenca... (strani: 1 2 )Oddelek: Strojna oprema | 14615 (12938) | D3m |
