Brezžična miš nehala delovati v win8
PrihajaNodi ::
Prosim za pomoč, miš je nehala delati v win 8. Dela v ubuntuju ne pa v safe mode. Sem že probal vse deinštalerat, posodbit driverje, miš dela tudi tekoče na drugem pc-ju. Čez noč se je pc ali windows 8 odločild da je ne bo zaznal. Pod device manager sicer imam napisano wirelles mouse, a je zraven vprašaj, driverjev pa ne dobi iz neta. Prav tako driverjev ni za ta model ker piše da je on the go...
PrihajaNodi ::
Našel odgovor, zadeva dela. V primeru če se še komu zgodi da mu ne najde plug and play gonilnikov gre zadeva takole:
you go into Control Panel -> System -> Device Manager.
Device Manager will display the non working device
right click on that device
choose Update Driver Software
choose Browse my computer fro driver software
Enter "c:\windows\winsxs" in the edit field named "search for driver software in this location".
Please verify that this directory exists on your computer. If your windows directory is named or located somewhere else, replace c:\windows by whatever you have.
Driver Update will search c:\windows\winsxs for the drivers there, this will take a while.
Good news. This will also fix this issue for subsequent driver installations - at least on my computer.
Deluje 100%
Ni se mi potrebno hecati z restore pointi. Nice
tezava z win7!
Oddelek: Operacijski sistemi
9933 (809) Mare_BrainD
Šumenje.
Oddelek: Zvok in slika
142198 (1989) Tear_DR0P
Windows 7 Installer (64-bit) - težave
Oddelek: Programska oprema
153725 (3115) fr!Xy
Win XP SP2 in Blutooth
82448 (2293) jast
Iščem alternativo vuduju
122450 (2214) Arthur
