Forum » Operacijski sistemi » [Ubuntu 13.04] Bluetooth serial brez super user
DuleKrtola ::
A zna kdo odgovorit na tole?
http://askubuntu.com/questions/430273/h...
V glavnem, z BT napravo bi komuniciral preko serijskega protokola, brez root accessa. Root dostop na mašini imam, ampak nočem, da se vsa koda poganja s sudo. Očitno so to pokvarili nekje med 12.04 in 13.04. Ima kdo izkušnje s tem?
Hayabusa ::
http://www.openbsd.org/cgi-bin/man.cgi?...
http://forums.debian.net/viewtopic.php?...
-u user The -u (user) option causes sudo to run the specified command
as a user other than root. To specify a uid instead of a
user name, use #uid. When running commands as a uid, many
shells require that the `#' be escaped with a backslash
(`\'). Note that if the targetpw Defaults option is set (see
sudoers(5)), it is not possible to run commands with a uid
not listed in the password database.
If you place an ampersand (&) after your command, the deluge-web process will be detached from the parent (and the sudo process will exit):
sudo -u User deluge-web &
- spremenilo: Hayabusa ()
DuleKrtola ::
Sm se spet lotu tega problema in ga rešu z uporabo toola blueman. Ko ta ustvari serial port v /dev/rfcomm0, fajlu spremenim dostop z
sudo chmod +rw. Tko da sedaj lahko uporabljam "screen /dev/rfcomm0" kot user.
DuleKrtola ::
Evo, zdej pa spet ne dela :( Tudi
sudo -u m screen /dev/rfcomm0
ne dela (m je ime userja). Še kakšna ideja? Nobenga linuxaša ni naokoli?
driver_x ::
Mogoče se moraš dati v pravo grupo. SuSE včasih ni hotel snemati CDjev, če uporabnik ni bil v grupi disk.
- spremenil: driver_x ()
| » | Strestirate nov HDD pred uporabo?Oddelek: Strojna oprema | 3196 (2366) | MrStein |
| » | Ubuntu 12.04 Precise Pangolin (strani: 1 2 3 4 … 21 22 23 24 )Oddelek: Operacijski sistemi | 279284 (214418) | Zvezdica27 |
| » | Debian Gnu/Linux kot workstation (strani: 1 2 3 4 … 37 38 39 40 )Oddelek: Operacijski sistemi | 128274 (43948) | RedDrake |
| » | Kako instalirat NVIDIA-driverje v Ubuntu? (strani: 1 2 )Oddelek: Operacijski sistemi | 6532 (5461) | r5r |
| » | Feisty Fawn je tukaj (strani: 1 2 )Oddelek: Novice / Ostala programska oprema | 9691 (7905) | Matevžk |
