Forum » Igre » EverQuest Next
EverQuest Next
Tr0n ::
Popolnoma unicljiv persistenten MMO. Minecraft + MMO = EverQuest Next. :)
http://www.pcgamer.com/previews/everque...
http://www.polygon.com/2013/8/2/4582742...
http://massively.joystiq.com/2013/08/02...
http://www.shacknews.com/article/80467/...
Mipe ::
Meh. Ko drevesa poskočijo in razpadejo, namesto da bi se upognila in šele nato pod silo prelomila, se zavem, da smo še zelo daleč od realističnega virtualnega okolja.
No, vsaj korak naprej je. May the griefing commence!
Tr0n ::
Par zanimivosti:
# "Blow up anything, anytime, anywhere."
# nic vec levelov
# vec kot 40 poklicev
# mesanje skillov med poklici
# vsak character ima lahko dve orozji (predvidevam da gre za weapon switching)
# EverQuest Next Landmark, F2P tool s katerim bodo igralci gradili svet, podobno kot v Minecraftu
# nic vec levelov
- spremenilo: Tr0n ()
kr?en ::
Zakaj imam obcutek, da bo to nakoncu samo en gimmick, ki bo deloval samo na dolocenih obmocjih oz. tam, kjer bodo devi zeleli. GW2 (in Rift s tistimi rifti) se je hvalil z dinamicnim questanjem, ki je izpadlo bolj ali manj skriptana zadeva, ki se sprozi, ko je dovolj folka/ob dolocenem casu in se itak zacne kmalu ponavljat.
tt2 ::
Zgleda res obetavno. Upam, da ne bo tako kot pri gw2, ki ni bil tisto kar sem upal, da bo. Mam raje igre v smeri L2. :D
- spremenil: tt2 ()
Ahiles ::
En komentar z kerim se strinjam 100%
BELIEVE IT WHEN WE SEE IT!
There is so much promised there in which other games have tried and failed. There are so many things... I don't even want to start typing it all. But now they have to keep track of every voxel and keep everyone's system seeing the same thing, like millions of other players on the screen at once, where all games choke when even 100 players are on the screen keeping track of.
The went with the GW2 marketing model and then times it by 10. HYPE!!! Get everyone in a frenzy etc. For this to work as they say, would be a complete reinvention of gaming. The good news is I'll expect 10% of what was said and base my enjoyment from that.
Many of these ideas sound so much more realistic if you could make personal servers and have say 1-32 players in it, not millions over years.
BELIEVE IT WHEN I SEE IT!
The programmers have to be drinking profusely with every word this guy says.
kr?en ::
Z SOE imam slabe izkusnje (rip Vanguard: Saga of Heroes :(), tako da bom raje pocakal na feedback beta testerjev preden se nahypam.
Haha SoE, imam leta slabih izkušenj z njimi že iz EQja, to bo taki rip-off da temu blizu ne pridem.
ahac ::
Pa bo vsej mozno delati to vse EQN ko lahko v tem sandboxu?
Ne.
Kar je čisto smiselno, ker EQN je MMO z zgodbo, itemi, itd... če bi vsakdo lahko načaral kar hoče, bi vse ostalo bilo malo brezveze. Zato je pa ločeno na bolj klasičen MMO in na "Minecraft". Oboje združeno ne bi šlo.
- spremenil: ahac ()
Pesimist ::
mislo sem kopanje lukne do resursov ali oz ustvarjanje unikatnega dungeona. Ce tega ni sem v trenutku zgubil interes. Ker nevem kak je pol drugacno od ostalega shita.
- spremenilo: Pesimist ()
Ahiles ::
ahac mal si poglej kaksen lanski film ko so predstavl EQ Next lahko bos ril pod zemljo in iskal razlicne skrite, zaklade, mesta etc prav tako bo podobn crafting kot je v landmark tudi v next če igralci ne bojo odkril sami pa bo kakšen event np potres odprl razpoko in bo lažje najdt zadevo cez določen cajt.
Tuki je concept art za Next in landmark. V lendmark bojo testiral ta tired underground potem ga tweekal in dal v Next.
Tuki lepo vse pokaze
Tko da landmark ni nič drugega kot testing ground and building block za Next. Jest predvidevam da bo celo možno zgradit player housing ala landmark v Next.
Bistvo Landmarka je pa itak da bojo dobil tono free shita od epic zgradb, propov, spomenikov in ostalih stvari ki jih bojo lahko importal v Next. Tko da igralci bojo zastonj delovna sila.
Seveda obljub je malo morje in kot se v resnicnosti izkazejo ponavadi prenapihnjene.
Drugače pa:
Tole je kr sick pick trenutno zadnji tier navoljo v landmark ker next tier ore se ni v gajmu zdi se mi da sta edin še epic pa lagendery proca možna(seveda z dobimi in slabimi prefixi)
Drugače pa:
- spremenilo: Ahiles ()
ahac ::
To že, ampak sigurno ne bo (v Next) tolk prosto gradit kot Landmark in npr. Minecraftu.
Če bo... potem lahko kmalu pričakujemo ogromne penise sredi pokrajine... v mainstream MMOju.
Ahiles ::
Jah omejitve bojo to itak kaksne pa še sony vrjetno ne ve sam to bojo vidl v landmark kva bo vse folku na pamet padl in kva bo treba v next preprečit.
Tr0n ::
V Next ne bos mogel nic gradit. Cisto locena produkta. Mogoce bodo kaj vzeli iz Landmarka in ga dali v MMO, to je pa tudi vse.
Ahiles ::
Tr0n greva stavt da bojo dal notr guild/player houses podobno kot ma wildstar pa wow v naslednem exp. Tko da mi vrjam da bojo na nek način iz ladnmarka uzel nekatere zadeve gradnje tud.
Tr0n ::
Cisto mozno, ceprav potem me cudi, da bodo vzdrzevali dva produkta, tudi po releasu EQ Next-a.
Ahiles ::
Jah ladnmark je bol minecraft next bo pa mmo z kančkom landmarka in vrjetno nimajo še dlih ideje kako bojo to izvedli ker seveda ne morš kar okol po svetu hodit pa random claime postavt pa začet gradit v mmoju. Tko da ja next bo v prvi vrsti mmo building part pa bo mogu bit zelo omejen mrbit celo phased/instanca/subserver odvisno kakšno tehnologijo majo in vizijo.
Sej zdele v landmark se vidi da so šele zelo na začetku razvoja trenutno so različni tiri razbiti po razlicnih subzonah in pod zemljo še ni ničesar lahko koples 2-3 ure dirket dol sam je sam stone/dirt. Nej bi pa kmalu začel stackat tire pod zemljo.
Pa trenutno so mape kvadratne pa okoli 10% velikosti kar predvidevam je maximalna možna velikost trenutno.
Kvadrat je na sredi večjega kvadrata.
Video me ni noben prepričal ... edino kar mi je všeč, je to karakter leva in opcija, da se tvoj karakter odziva preko tvoje kamere ... se pravi, če se ti nasmejiš, se karakter tudi nasmeji, če mežikaš, tudi karakter mežika ... edino vidim v tem videu, da so dodali še jezik zraven, tako da se še lahko sliniš. ;)
Tr0n ::
Bolj slabo kaze trenutno, saj so kar dosti folka odpustili, med drugim tudi David "Smokejumper" Georgeson-a, ki je vodil EQ francizo.
http://www.reddit.com/r/Games/comments/...
Pesimist ::
vprasanje ce je to blo soniju res treba nardit.
Tr0n ::
Mnja, merger firm pac. Zakaj so pa najbolj talentirane in najbolj pomembne ljudi kar se tice EQN in Landmarka odpustli, je pa drugo vprasanje.
ahac ::
EverQuest Next is cancelled, but Landmark will go on
http://www.pcgamer.com/everquest-next-i...
https://www.daybreakgames.com/news/dayb...
ahac ::
Zdaj gre pa še Landmark...
EverQuest Landmark has been cancelled and servers will close 21st February.
http://www.eurogamer.net/articles/2017-...
https://www.landmarkthegame.com/news/im...
| » | Aion (strani: 1 2 3 4 … 14 15 16 17 )Oddelek: Igre | 70663 (32958) | Meizu |
| » | Landmark Education in njihov forum, scam ali resničnost?Oddelek: Loža | 5213 (138) | deanm |
| » | MMORPGOddelek: Igre | 4940 (4380) | bdoxx |
| » | Lineage 2 accountOddelek: Igre | 1654 (1330) | Tilen |
| » | Igra kriva za smrt?Oddelek: Loža | 1895 (1231) | BigWhale |
