Forum » Strojna oprema » Poraba PC v W
Poraba PC v W
Aston_11 ::
Moj Intel G620, Gigabyte GA-H61M, 4Gb, SSD, HD1TB napajalnik 600 W (LC600H), porabi:
vklopljen okrog 80 W (običajno delo, internet) (drži se okrog 80, pade do 70, naraste do 90).
od tega monitor Samsung 40 W.
Izklopljen - kišta + monitor - 6 W.
- spremenil: Aston_11 ()
SplitCookie ::
i3 2x2.3GHz, 12gb, ssd, lcd - 10W
woo fucking hoo
woo fucking hoo
SplitCookie> Prevoziš RDEČO ! jype> Ja? A to je kaj posebnega?
Ramon dekers> Ječa je lahko naravno okolje potem ko se adaptiraš.
jype> CPP ne spoštujem _NIKOLI_
b3D_950 ::
1. Pentium G620, ASUS, 8GB, SSD -> 45 W
2. Q9550, MSI, 6GB, SSD+2HD -> 70 W
in ob loadu (100%) -> 230W (GPU), 140W (CPU)
3. LCD 24" DELL -> 15 W
Sssaga ::
heh, tole bo še smeha, k bom vidu kaj jaz delam z mojo kurjavo napram drugim
Testi (BF3 ULTRA/Crysis 2 DX11+HD... gamersko obremenjeni! Torej je še fore-i7):
''RIG 1''
- CPU: Intel Core i7 920 C0 Bloomfield 2.66 Ghz Gaming OverClock = 4 cores, 8 threads @ 4011 Mhz @ 1.50 volt
- GPU: Gigabyte *470 GTX* 1280 MB Max OC ~850-1700-3700 Mhz @ 1.087v
| EX58-UD5 | Corsair DDR3 4x1GB 1.66volt | 2xHDD | TX 750W | CASE: Chieftec Dragon CH-07B-B-OP
- EK KIT H3O Supreme HF 360
Power Consumption:
CPU & GPU on stock - IDLE=165W / LOAD=397W
CPU & GPU OC'd 4Ghz & 800Mhz(@1.000volt) - IDLE=215W / LOAD =529W
''RIG 2''
- CPU: Intel Core i7 920 2.66 Ghz C0 @ 4011 Mhz 8 niti [H2O]
- GPU: PowerColor Radeon HD 6850 1GB @775 / 4000Mhz
- RAM: Corsair DDR3 4x1 GB 1333 Mhz Tri-Ch @ 1146 Mhz 7-7-7-18
- PSU: Corsair TX 750 W
- HDD: WD Caviar Black 1TB, 7200rpm, 32MB, SATAII
- CPU COOLING: EK-KIT H3O - Supreme HF 360
- CASE: Chieftec Dragon CH-07B-B-OP
IDLE: ~190W
LOAD: Peak ~390W
''RIG 3''
- Q6600 2.4 Ghz @3.00 Ghz low vcore increase | 2x2GB DDR3 | LC 550W | HD 6850 1GB @775 / 4000Mhz | 1xHDD
IDLE ~150W
LOAD: Peak ~275W
''RIG 4''
- CPU: Intel Core i3 2120 Sandy Bridge 3.3 Ghz / 4 Threads
- MOBO: Gigabyte H61MA-D2V LGA1155
- RAM: Corsair XMS3 2x4GB DDR3 ~1333 Mhz CL9
- GPU: Gigabyte HD 7770 1024 MB @1100 / 5000 Mhz
- SSD: Corsair Force 3 60GB
- HDD: Samsung F3 1000 GB
- PSU: LC600W +12v 2x20A
- CASE: LC Power 7032B (2x12cm fan)
IDLE: ~50W
LOAD: Peak ~168W
''RIG 5''
Athlon 3000+ 2.35 Ghz | Asus Nforce4 | 3xDIMM | 350W PSU | GF 9500 GT | 1xHDD
IDLE: ~85W
LOAD: ~149W
''RIG 6''
Laptop iz 2002
Dell Latitude C640: Pemtium 4 1.8 Ghz | ATi 7500 | 2x256MB | 1xHDD
IDLE: ~30W
LOAD: ~85W (včas so ga pa kr kurl)
A bo dost z moje strani?
Mam pa Silvercrestov merilnik fštekan med kablom za napajalnik in razdelilcem.
''RIG 1''
Power Consumption:
''RIG 2''
IDLE: ~190W
LOAD: Peak ~390W
''RIG 3''
IDLE ~150W
LOAD: Peak ~275W
''RIG 4''
IDLE: ~50W
LOAD: Peak ~168W
''RIG 5''
IDLE: ~85W
LOAD: ~149W
''RIG 6''
Laptop iz 2002
IDLE: ~30W
- spremenilo: Sssaga ()
BorutK-73 ::
Jaz si merim mesečno porabo za oba PC-ja.
od 16.10 - 16.11.12' 132.46 kWh, cca 15€ na mesec.
Se kar naberejo wati.
2500K, Sabertooth P67 TUF, 8GB DDR3, ATI6850,750W, 20" Benq - 14h online
Core2Duo 8200, Asus P5KC,4GB DDR2, 1TB disk, LC550W, 15"(skoraj nikoli vklopljen) - 24h
Moram še posamično zmerit dnevno porabo za vsak PC posebej.
Kako to merite? Obstaja kakšen program za tole?
Hayabusa ::
Lahko da ima pc na ups-u.
Zakaj ne downclockaš Core2Duo 8200 ali kupiš intel atoma & kaj podobnega ?
- spremenilo: Hayabusa ()
BorutK-73 ::
Hvala obema za informacije!
kixs ::
Lenovo X61s+Dock: IDLE=21W, LOAD CPU=33W, LOAD CPU&GPU=41W (z ekranom, eksterni LCD pa cca 4-5W manj). Ob normalni uporabi porabi cca 22W.
Phenom-II X6 1055, 12GB DDR3, SDD + 3xHDD, 460GTX, WiFi, Audigy, USB 3.0 kartica: IDLE=155W, LOAD CPU= 255W, LOAD CPU&GPU=330W. Ob normalni uporabi porabi cca 180W.
Test CPU = Prime95, CPU&GPU = Prime95+rthdribl
Uporabljam pa isti merilec kot daxwsi, kupljen pred nekaj leti v Sparu za 10EUR.
- spremenil: kixs ()
RutS ::
I5-4570S
Zalman CNPS11x Performa cooler
H87 Pro4
Ram 4gb 1600 mhz 1.5v
XFX 450W
3 ventilatorji v ohišju
WD Blue
Idle, internet 35-40W
Prime 95 Torture test-inplace large FTTs 125W
H87 Pro4
XFX 450W
WD Blue
s1m0n ::
Sistem v podpisu:
Idle: 60-80W (AV, DLNA server, Skype, FF ca. 50 procesov)
Load: 250-270W igre (BF4 Multiplayer)
Poraba do naloženega OSa ca. 100W
gazibo ::
So merilci elektricne porabe, ki jih omenjate v temi tocni ? V dolocenih temah, kot sem bral, imajo pripombe cez te poceni merilce ces da ne merijo cisto tocno.
Bi tudi sam rad preveril porabo mojega HTPC/serverja, ki laufa 24/7
Hayabusa ::
Če kupuješ, vzemi tega http://www.conrad.si/VOLTCRAFT-merilnik... .
gazibo ::
Super, hvala, skoda le da nimajo zaloge
"Trenutno ni zaloge! Naslednja dobava po 14.03.2014"
klkkkkkkkkkk ::
FX 6300 4.5GHz + R9 270X (1100/1450 -stock OC/V)
1 HDD
GA-990XA-UD3
1x 8GB 1.5V
CPu-fan 140MM
3X5V Fans
PSU: Seasonic G 550W
MAX-PC (stress)PEAK - 360-370W
Gaming 260-290W (BF4 MP/Crysis3/BF3 MP)
Iddle 70-80W
1 HDD
GA-990XA-UD3
1x 8GB 1.5V
CPu-fan 140MM
3X5V Fans
Iddle 70-80W
GA-990XA-UD3, FX 6300 4.6GHz, R9 270X, 8Gb Ram, 1TB, G-550W, Win7
- spremenilo: klkkkkkkkkkk ()
BorutK-73 ::
Jaz kar stojim za svojim in so kar točni. Mogoče je odstopanja 2-3%.
Blinder ::
athlon xp #1, idle 90W, load pri predvajanju youtube(itak šteka, cpu nabit na 100%) 120W
athlon xp #2 2.0ghz, idle 127W, load ...................................................... 145W
pentium III 900, idle 45W
pentium IV 2.8, podobne specifikaciej kot athlon xp, idle 49W, load upto 117W
15" lcd, 20W. 18" lcd 50W
celeron G1610 lga1155, GT440, zloglasni lc420 80mm,idle 40W
Maestral ::
Točnost precej zavisi od načina merjenja in karakteristike porabnika. Tudi low-cost elektronski merilniki porabe so kar točni, če je breme uporovno (pečice, štedilniki, bojlerji,..), pri bolj induktivnih/kapacitivnih porabnikih (el.motorji, stikalni napajalniki (PC),..) pa lahko "lažejo na veliko"...
BorutK-73 ::
Uporabljam to
Poraba 2500K+20" monitor:
idle/net: 125W
Core2Duo je priklopljen na ups in ne kaže porabe.
Update: Po menjavi napajalnika na 80+ je poraba padla za skoraj 50W
sedaj imam idle: 72W
game (crysis3): 220W (prej 270-300W)
PSU: Corsair TX850 V2, stari psu je pa bil Inter Tech FP-750W
ostalo: 2500K | Sabertooth P67 | Venegance 8GB |
Sapphire HD6850 | 830-64GB | 1TB blue WD
2x120mm in 1x80mm fani
- spremenil: BorutK-73 ()
klkkkkkkkkkk ::
Lepo bi prosil, če vsak še napiše zraven PSU-nujno- pa tudi če lahko ostale info. o PC-ju
| » | Poraba elektrike računalnika (strani: 1 2 )Oddelek: Loža | 14792 (12703) | Spajky |
| » | Ali je 180 W napajalnik dovolj za Core i3?Oddelek: Kaj kupiti | 8571 (7586) | amigo_no1 |
| » | a8-3870k vs i3-2100Oddelek: Kaj kupiti | 5981 (5142) | x45 |
| » | Poraba računalnika in dodatkov..Oddelek: Strojna oprema | 5404 (4603) | toplakd |
| » | Radeon HD 5970 res prijazen navijanju (strani: 1 2 )Oddelek: Novice / Grafične kartice | 9756 (7426) | PrimozR |
