Mnenja o Oknih 8
Mnenja o Oknih 8
19 / 27
Mene tudi zanima, a je mogoče na ta način (in kako) narediti upgrade iz 32-bitnih W7 na 64-bitne W8?
O.
kmetek ::
Get your Microsoft Windows 8 Pro for $14.99 by following these steps:
1). Go to this official site.
http://www.windowsupgradeoffer.com/
2). Select your PC purchase dates between 2 June 2012 - 31 January 2013 and Other in the PC Brand.
3). Fill any thing of your choice in the Name of retailer and PC Model.
4). Fill all other details and submit the form.
5). You will receive a Promo code in your mentioned email address.
6). Download Windows 8 upgrade adviser and run it on your Windows 7 activated PC (Daz Activation also works) and enter your received promo code in it to avail the offer and get your key.
Help Notes:
1). You can reinstall Windows 8 using this key from scratch without the need of Windows 7 or its key!
2). The activated system is Retail edition.
Tilen ::
@kmetek
Hvala. Uspešno pridobil promo code. ;)
kmetek ::
vam dam TRR? ;)
No pa mi je ratalo aktivirati windowse. :)
LP.
Nikonja ::
meni ni šlo to za 15eur ker sprašuje za product key in ga seveda nimam :)
Ne da se brez key-a ?
Vse se da. Malo poglej na travniku ;)
Kjer je volja tam je pot.
Nikonja ::
Ja lahko dam tuji PK ampak kaj potem ko dejanski lasnik želi upgrade ?
Assass1n ::
Zmisliš se vse, ne rabiš nič, vsaj po navodilih jaz nisem probal.
Nikonja ::
Ja zmisliš vse ostalo samo key mora bit ta pravi da te spusti skoz. Če dam "ukradeni" key in vse gre skozi pol pa spet nič nisem dobil ker je windows še vedno ilegalan. Ma bom prebolel tistih 30 eur in ga tako vzel.
čudno,da modi dovoljujejo pogovor kak nelegalno prit do windowsov
kmetek ::
to ni ilegalno, sam dobiš uraden licenčni ključ po ovinku, nobenega piratstva.
Kje specifično pa piše, kako priti do nelegalnih windowsov?
bond007 ::
Če naložiš tole za 15$(€) na piratsko win 7 - a si kej naredil s tem? Ko inšpekciji pokažeš, da si kupil upgrade, bojo verjetno hoteli videti še račun od win 7? Če pa ta upgrade kupiš, da bi imel boljšo vest, pa tudi ne vem kje je smisel, ker če Microsoft tega prehoda iz piratskih win7 na win8 ni blokiral, še ne pomeni da so to požegnali.Ali piše kje na MS sttrani kaj eksplicitno o tem?
Tocno tako kot je bond007 napisal je v primeru upgrade na Windows 8 brez obstojece veljavne original licence.
Nekaj drugega je pa 15€ popust izsilit z izmisljevanjem podatkov, v tem primeru pa samo krsis Microsoftove pogoje akcije in ne licence, kar pa kakor vem sploh ni sporno.
roCkY ::
Tole je počasi že mal noro. Za 15€ bi si nekateri luknjo v koleno vrtali. Raje malo kolena zmigat in zaslužit kak € brez jambranja.
amigo_no1 ::
kmetek je izjavil:
Help Notes:
Pa vprašanj:
Zakaj potrebujejo telefonsko (pošljejo kak sms ?), ime & priimek, ni email zadosti ?
Kaj dati pod model računalnika, če si kupil ne BRAND name (Nakup namiznega PC-ja posebej izbrane komponente skupaj sestavljene v tej trgovini) ? Mora biti kupljen v Slo ?
  • spremenilo: amigo_no1 ()
GregiB ::
Vprašanje... dobil sem promo kode za Win8, a jih ne bi instaliral. Smem ta promo kode uporabiti za upgrade na kakšnem drugem računalniku?
Tilen ::
Pomoje MS sploh ne preverja nobenih podatkov. Pomemben je le datum in email, kamor ti pošljejo promo code. Promo zahtevaj kot Janez Novak, doma pa naredi upgrade na svoje ime.
  • spremenil: Tilen ()
GregiB ::
OK... ampak kter Serial Key je treba dat za Upgrade po promo kodu??? Dobiš novega al uporabiš tistega za Win7?
Tilen ::
Po plačilu dobiš ISO ter nov ključ za Windows 8 PRO.
amigo_no1 ::
btw, na kakšen način plačaš ?
Tilen ::
Paypal.
roCkY ::
ali kartica
Saintek ::
Da vidim če jaz to zdaj prav kapiram......... :)
Imam travnik win 7 ultimate x64, upgade asistent lepo gre skozi, torej glede tega ni problem?
Če gre dobit iso tudi s travniških win 7 ali si lahko prišparam ta iso in key tudi kasneje recimo, pol leta, če bi šele tedaj formatiral in naredil clean install 8 ke, ali ima ta key časovno omejitev do kdaj bo moral bit uporabljen?
  • spremenil: Saintek ()
Tilen ::
Zakaj bi imel časovno omejitev? Nobene časovne omejitve nima. Ključ si shrani, da boš lahko ISO na ta računalnik nalagal kadar boš hotel.
KTr1sk ::
bond007 je izjavil:
ne vem kaj bi rekel, res je to da je iz piratskih windowsev,..ampak se je naložilo legalno brez kakšnih težav,ki pa ni naša težava, pa tudi kako bi težili, da naj pokažemo win7 račun, ker je to nadgradnja, če pa na računu nikjer ne piše nadgradna če samo piše pod nakup windows 8 pro in nobene nadrgadnje
jaz sem kupil in tako izgleda :)
roCkY ::
Ali je SLO inšpekcija na plačilni listi ameriške davkarije? Kdo je sploh lastnik računa kamor se plačuje. Microsoft SLO ali USA?
basket ::
ja pa itaki, tudi če bi obstajala kaka inšpekcija, rečeš enostavno,da si račun vstran vrgel, pa ti nič nebi mogel..
amigo_no1 ::
Natisni si mail.
darkolord ::
The license terms for the upgrade require upgrading from a valid "genuine" version of Windows.
in
Eligible PCs are new PCs purchased during the promotion period with a valid Windows 7 OEM Certificate of Authenticity and product key
  • spremenilo: darkolord ()
KTr1sk ::
ja potem pa ok...pc je bil veljaven valid "genuine" ker je šel postopek skozi...heh, če ne druga za domačo uporabo je samo pomemebno, da deluje vse,...vsi valid "genuine" zadeve preverjanja bo šlo skozi, ker je to enako kot "pravi" original...če boš klical na microsoft za telefonsko aktivacijo te ne bodo spraševali od kot imaš ključ, pomembno je samo da je veljaven...in če ni ukraden tudi ne bo nikoli blokiran...popravite me, če se motim
smash ::
lahko še kdo dobi ta promo kode? ker meni ga ne da
KTr1sk ::
smash je izjavil:
te probaj...drugače pa jaz sem dobil po nekej 20h urah...njihov email z promocijsko kodo
BF-G67Y-FPT8-BC6M-DGT
BF-G7D2-M3JD-B3XX-Y43
BF-G7WM-DV97-3QVM-HHP
smash ::
ne delajo te kode
Mi lahko pošlje kdo promo kodo na ZS? Hvala.
  • spremenilo: smash ()
Aramis ::
preko pomočnika mi prenaša windows 8, v iso obliki? al kako?
||_^_|| ::
Če ima kdo slučajno kakšno promo odveč, se priporočam:)
Bom še tukaj prilepil, če koga zanima.
Končno sem ugotovil, kako se znebiti aplikacij v slovenščini.
Iz menija (slika spodaj) izbrišite slovenski jezik in dodajte na primer UK + slovenski keyboard layout. Resetirajte računalnik in to je to.
Bolf3nk ::
kaj priporočate, nadgradnjo ali svežo namestitev w8?
vorantz ::
nadgradnje delajo samo mazohisti
roCkY ::
KTr1sk ::
vedno je sveža inštalacija boljše!
frudi ::
Bolf3nk je izjavil:
Sam z nadgradnjo nisem imel težav, razen par malenkosti - moral sem reinštalirati nekatere gonilnike in ponastaviti pravice na par direktorijih. Je pa res, da sem imel relativno svežo inštalacijo W7 pred tem, staro vsega par tednov.
Vse je odvisno od tega, ali se ti da izgubljati čas z reinštalacijo celotnega sistema in vsem ostalim s tem povezanim zapravljanjem časa (backup podatkov, prenos programov s spleta, itd.).
vorantz je izjavil:
KTr1sk je izjavil:
Prosim ne nasedati takšnim neumnostim...
smash ::
frudi je izjavil:
Bolf3nk je izjavil:
vorantz je izjavil:
KTr1sk je izjavil:
glede na to da si imel sedmico nekaj tednov, se bi ti sploh splačalo inštalirati vse nanovo, ampak ok....grem stavit da je tvoj prostor na disku z nadgradnjo manjši kot prostor na disku brez nadgradnje
Jaz sem naredil že 5+ upgradov z raznik vista/win7/win8 kombinacij. Kar sem opazil je to, da je upgrade podobno kot reinstall! Namreč vsi windows fili so sveži, kot ob sveži inštalaciji.
Upgrade priporočam ljudem, ki so kaj zasrali, recimo moj braz je en antispywere program zagnal, pa je dal kar delete all, pa je zadeva tudi določeni windows file brisala in je bila posledica kar nekaj čudnih dogajanj na sistemu. Sem naredil upgrade iz Windows 7 na Windows 7(ja smešno se sliši) in VSE se je popravilo. Upgrade je zakon, ker v bistvu naredi svežo inštalacijo, potem pa kopy pasta program files+potrebne registre od programov, windows filov se pa ne dotika!
frudi ::
smash je izjavil:
Neke blazne razlike v porabi prostora ne bi bilo - na prenosniku, kjer imam sveže inštalirane W8, mi \windows folder zasede slabih 15 GB, na desktopu po nadgradnji pa 18 GB (to s kupom že inštaliranih programov in popravkov).
Vsakokrat se z veseljem raje odpovem v najslabšem primeru trem GB prostora, če mi zato ni treba zapravljati celega dneva z reinštalacijo in rekonfiguracijo sistema. Verjamem pa, da imajo morda ljudje kot KTr1sk ali vorantz kak fetiš za inštaliranjem programov ter operacijskih sistemov in osebno jim nikakor ne bi želel kratiti tega veselja, tako da komur so inštalacije v veselje, naj jih zaradi mene izvaja kolikor želi. Ni pa treba drugih brezveze prepričevati vanje...
KTr1sk ::
vse od win95 do win8 sem osebno uporabjal in če sem se že spravljal kdaj na novo nalagat sem pač raje na novo vse inštaliral, pač to je moje osebno mnenje, saj potem ko imaš enkrat na novo naložen sistem narediš varnostno kopijo image in je zadeva rešena, rajši kot kakšen upgrade..reinstall, no vglavnem kakšna vam je volja tako naredite, tukaj ne mislim in tudi ne silimi v nekaj nobenega, sam povem svoje, več mnenj skupaj potem vedo ljudje kaj je najbolje ;)
roCkY ::
Kaj sem zgubil, ker sem zapeljal preko?
Nadgradnja iz 7 je špilala direkt v 100% na prenosniku. Na HTPC je bilo treba ročno snet in namestit gonilnik za zvočno, grafična pa se je posodobila sama ob prvem ročnem iskanju posodobitev.
Ostalo vse na mestu le ključne bljižnice je treba pripeti v metro in na desktop.
Na XP in Visti nadgradnja pospravi staro inštalacijo v svojo mapo in je seveda treba programje na novo inštalirat. Vsa struktura pa ostane.
medenko ::
kakšna struktura točno, kako to misliš?
Tilen ::
Nadgradil iz Windows 7 brez vsakega problema.
19 / 27
windows 7 ali 8 (strani: 1 2 )
Oddelek: Operacijski sistemi
8525643 (22378) Mr Johnny
Bo Windows Blue dobil nazaj startni meni in namizje? (strani: 1 2 3 4 )
19767586 (60559) Bistri007
Prava nadgradnja na Windows 8 le s Sedmice (strani: 1 2 3 )
13649153 (44996) lopov
Windows 8 prihaja v štirih inačicah (strani: 1 2 3 )
13951394 (45968) Lonsarg
Predogled Windows 8 na voljo (strani: 1 2 3 4 5 6 7 8 9 )
421139476 (121421) techfreak :)
