Forum » Navijanje » r9500 --> r9700 Utvara ali realnost?
THX ::
če ma kdo flashrom za radeone, nej mi ga prosm pošle. jst sm že skor obupu ker ga iščem po malem že cel dan
aja... mail je v profilu
- spremenil: THX ()
THX ::
dobu, hvala ti
zadeva čudežno dela, tko da si mi mal mn ka lajf rešu...
zgleda pa tale flashtom dost bl dodelan kot atiflash... tko precej več opcij in vsega
Clemento ::
Pri Jae majo neke nove radeone firma excalibur? je
ze kdo slisal? kdo kupil? se da modat?
*Epox 8rda+, XP2600+@stock speed, TT Silent Boost, AS5, Ati AH3650
*Abit NF7-S, XP2500+@2425Mhz, 1.85V(220x11), TT Volcano 12, AS5, Rage128PRO
Clemento ::
HIS Excalibur Radeon 9500
Evo to je ta karta....ali je mozen soft mod pa nimam pojma...
sam zgleda da tud ta ni uporabna ker ima 64mb rama(ali kdo ve zakaj ni mozen soft mod na 64mb verziji)!
Ok sem si sam najdu odgovor...
NO differences from the PCB of the RADEON 9700 Pro! Note that each chip of the above mentioned marking has a 32bit access. That is why having mounted all 8 chips the manufacturer leaves the 256bit bus as well!
The RADEON 9700 64MB card was left with 128 bits when they took off 4 chips - taking into account that each of four remaining chips was 32bit, the total capacity amounted to 128 bits.
And this card comes with the 256-bit interface! That is why the readers should remember this surprise from ATI:
Until they develop a design specially for the RADEON 9500 based cards (and it's probable that they will never do it, because production of cards based on the current design becomes cheaper with time), we should remember that the 64MB and 128MB cards differ only in the memory exchange interface: 128 and 256 bits. This can't help having an effect on the performance, though the VPU is stripped off markedly, and even a 256-bit bus would hardly help the 4-pipeline chip change its speed considerably (but our tests will show that the speed gain is noticeable).
Se pravi dad pri 128mb r9500 ne bojo nikoli spremenili PCBja?
- spremenil: Clemento ()
|ZUTI| ::
No, preden kupin 9500 (navadno :)) še enkrat prašam, da sem 100% zihr. Se da Sapphire Radeona 9500 128MB softversko modat? Da ne bom pol u luft gledal :) Aja, kje se dobi tist flash program? Bi potemtakem tudi jaz rabil. Da še navijemo. Je treba.
boštjan ::
da se samo zdaj več ni 9500 ki so na bazi 9700 delane,ampak boš svojo 9500 z 128MB lahko največ modal v 9500pro,kar tudi ni mačji kašelj.
boštjan ::
ja če je PCB ćrn pol ti ne bo ratalo v 9700 zmodat,ampak samo v 9500pro,če pa še boš dobil 9500 128MB z rdečim PCB pol pa bi moralo it,ampak ni 100% da bo delalo vse
AtaStrumf ::
ZUTI jaz ti lahk zrihtam enga Sapphire 9500, ki se 100% zmoda v 9700 in še navije na 310/290 (ni ravno nevem kaj a je dovolj za cca 14500 3D Markov). Problem je le, da ima v nekaterih igrah mini (ampak res mini) šahovnice, v večini nič ne opaziš (recimo Unreal II ipd.), v 3D Marku pa ima samo v enem testu manjkajoče pixle. Malo poglej nazaj po tej temi sem jih tudi pripopal. Skartka če nisi pikolovski kot jaz, pol komot živiš s tem, v ATI testih tist avto in medved ipd. dela vse popolnoma brez artefaktov, tako da se za DX9 ni bati :). Če hočeš za ugodno ceno, je to bolj kot pa iti tvegat, ker lahko, da ti po modu čist lomi sliko in gre vse v PM in zadeva sploh ni uporabna in si primoran modat nazaj v 9500, kar pa totalno sux. Aja pa še to, te probleme imam samo jaz, dvema drugima pa dela kao brez problema, samo imata že odst dobre grafike pa ne rabta nove, tako da mogoče ti celo dela brez problemov. Jaz sem inštaliral kar čez detonatorje in nisem naredil clean instal, mogoče je to krivo, samo saj pravim, jaz sem pikolovski, pa ne mislim winsow z milijon programi še enkrat inštalirat, tako da zame ne pride v poštev, tebi bi pa morda ustrezala.
Clemento ::
Ata štrumf: Mene bi zanimala ampak za kaksno ceno?
AtaStrumf ::
Pomoje nekje malo pod 50k, samo točno ne vem. Morm lastnika povprašat. Če si resen mi kar piši na mail pa se bova tam naprej menila, da ne bova tu smetila po nepotrebnem. Jaz bom spet on-line najbrš šele po polnoči, tko da bo mal za počakat, na odgovor
Muflon1 ::
Torej parkrat sem že vprašal pa bom še enkrat ker nisem dobil odgovora. Imam Sapphire Radeon 9500@9700 ki dela kot raketa. RivaTunner prepozna 128 MB RAM-a na kartici in 256-bitno vodilo. Tudi v System properties mi prepozna 128 MB RAM-a. Problem mi delajo le 3D Marki kjer mi konstantno javlja da imam 64 MB RAM-a. Kako je o mogoče? 3D Mark 2001 SE javi da imam 64 MB Total Video memory ampak se to pri testih ne pozna in dobim lepo do 14.000 Markov. Problem se pojavi pri 3D Mark 2003 kjer mi prav tako javi da imam 64 MB total video memory in mi zaradi tega ne dela test Nature kjer mi vrže ven error out of memory. Poskusil sem različne različice hekanih gonolnikov trenutni pa so 6.14.1.6292. Driver file pa je datoteka ati2dvag.dll a bi se dal tle kej narest in jo poštimat?
Drugače mam pa v 3D Mark 2003 System Info napisano tole:
Total Local Video Memory 64 MB
Total Local Texture Memory 64 MB
Total AGP Memory 24 MB ?? a je to kolk AGP-ja ma share-anga v BIOS-u?
Driver File ati2dvag.dll
Driver Version 6.14.1.6292
Driver Details 7.83-030120a1-007447C-ATI
Driver Date 1-20-2003
Driver WHQL Certified false
Max Texture Width 2048 px
Max Texture Height 2048 px
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Textures In Single Pass 8
Vertex Shader Version 2.0
Pixel Shader Version 2.0
Max Vertex Blend Matrices 37
Max Texture Coordinates 8
VGA Memory Clock 270.0 MHz
VGA Core Clock 276.8 MHz
PCI
Name RADEON 9700 SERIES
Vendor ID 0x1002
Device ID 0x4144
SubSystem ID 0x00021002
Revision ID 0x00
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit A [8]
8-bit YUV [800]
FourCC [UYVY]
FourCC [YUY2]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
P.S.
In vsem tistim ki se bodo spraševali zakaj se ubadam s tem če mi vse lepo dela in me samo 3D Mark jebe. Zato ker bi rad samo enkrat videl novi Nature test ki mi ga sedaj edinega ne požene pol bom pa lahko mirno spal
PCI
Vendor ID 0x1002
Device ID 0x4144
Revision ID 0x00
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit A [8]
8-bit YUV [800]
FourCC [UYVY]
FourCC [YUY2]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
P.S.
- spremenilo: Muflon1 ()
AtaStrumf ::
To s 3D Markom je pa res čudno. Meni dela nature tudi v 3D Marku 2003 in imam oz. sem imel isto 9500@9700, ki pa je v nekatrih špilih (ne v 3D Marku) delal majhne šahovnice oz. manjkajoče pixle (to pa tudi in le v Advanced Pixel Shader tesu v 2001SE), samo s 3D Markom pa nisem imel nobenih težav z nature ne v 2001SE, ne v 2003.
Aja če ga kdo hoče, ga tipo prodaja za 48k SIT in obljublja demonstracijo brez artefaktov. Kako, jaz ne vem, ampak baje njemu dela vse OK. Jaz pa še kar čakam mojega 9700 :(.
Dante ::
tudi moja kartica ima res drobne , ampak res drobne artefakte, vidijo kot crne pike, so komaj vidni in samo na nekaterih mestih. Opazil sem jih samo na ATI demo od atomobila.
A
rtefakti popolnoma izginejo, ce vklopim Anti-Aliasing.
Sem pa zasledil na tujih forumih, da se je nekaterim srecnezem v celoti, ali vsaj do neke mere uspelo znebiti artefaktov, tako da so kartico za nekaj ur zamrznili! (nimam linka pri roki, vendar mislim da je to v temi, ki jo je objavil WIZARD na rage3d)
D.
A
D.
Malecky ::
Situacija je taka da kmalu dobim iz garancije novo R9500 kartico verjetno sapphire zdaj me pa zanima kakšna je verjetnost da so tanve vse na novem unmoddable R9500pro PCB-ju? Na njihovi strani je slika lepa na designu R9700 drugače pa opažam da črne niso za kupit...
Kolk jih je že kdo videl?? Kako je stem?
Clemento ::
vsepovsod prodajajo uno na crnem PCBju..
Malecky ::
Damn... js pa že optimist ratu, ker sem videl sliko na sapphiretech in ima 9700 layout...
Dobim najnovešo pošiljko se pravi ta teden in zato bom verjetno jebal ježa:) Sicer pa 9500pro je tud super kartica:)
boštjan ::
že ko sem jaz na začetku februara v nemčiji naročal 9500 se več ni dalo dobiti 9500 na PCB od 9700,še 9500pro sem komaj dobil.Logično pa da je 9500pro zelo dobra karta saj se ob bok postavi 4600
Clemento ::
Malecky: Jst bi zahteval tako karto kot sem jo dal...
se pravi na PCB r9700....
AtaStrumf ::
Zanimivo, pol pa 9500 128MB ni več za kupovati. Sedaj bo pa cena starim 9500 mal narasla a? Boljš 9700 z kakim artefakčkom tu in tam kot pa 9500 (Pro).
Clemento ::
jih je treba pa nekje dobit...
|ZUTI| ::
A mi lhako kdo pove, kako se da nardit (če se sploh da :)) da ti piše pod video device da maš radeona 9700 in ne 9500 (ko je zmodano?). Drugače sem dobil pri AGT-ju le tega na rdečem PCB-ju, L rami, ploščica zadi, skratka, na 9700 zgrajen :) 3D mark 2003 je pokazu veliko razliko (9500: 2770, zmodan: 3820, obakrat nč navita).
planetparty ::
Ti si pa dobil nekam nizek rezultat!
Kakšen procesor rame in ploščo maš?
Jaz sem z isto grafično dobil 4400, ko sem jo pa še malo predelal in navil (360/310) pa sem dobil 5150 z gonilniki 3.0
Po moje maš ti neke nastavitve napačne...
katere gonilnike maš?
mogoče se ti pa kaj pregreva na grafični...
|ZUTI| ::
Athlon XP 2100+ @ 1850 Mhz, plata K7S5A, 256MB SDram :) Pomoje je kar dost. GLede na to, da tud sistem že ni bil spucan nekaj mesecev. Bi rabi clean install, sam se mi ne da.
No, kaka ideja kako bi naredu, da bi pisal lepo radeon 9700
Clemento ::
Dante: daj link o tem zmrzevanju
karte....danes sem kupil r9500(eno kupljeno 20.1.2003) in
imam prav tako sahovnivo v 3dmarku
v le enem testu....
v le enem testu....
Tito ::
Kaj mislte da se v Mlacomu še da rdeče radeone kupt?
Jst bi ga prec kupu... A pa sam da je rdeče pa ima isti pcb kot 9700 al je še na kaj treba merkat?
rap3r ::
Clemento tanx za tist!
Pa dej nared screen shot artefaktov
Za herculesa se pol nezanimaš več?Al kako...
Ne droga, ne trava me ne mika, le kakšna promilja alkohola se učasih po krvi mi potika:)
AtaStrumf ::
Vidim, da se še vedno najdejo junaki, ki hočejo tvegat. Samo vedite, da VSAJ 2x večja možnost, da dobite zanič čip kot pa dobrega in da je lahko na 9700 popolnoma neuporaben tudi na 2D, ne samo da dela sem pa ke kake šahovnice. Drugače pa lahk jaz še vedno zrihtam enga, ki dela res minimalne šahovnice in še to le v nekaterih špilih, recimo UT2003 in Ureal II, F1 2002 vsi delajo brez problemov, tudi v 3D Marku ima le v enem testu manjkajoče pixle, šahovnic nikjer (sem slike pripopal na 14. strani te teme in tudi prej, če si hoče kdo ogledat). Cena 48k SIT, e-mail.
Clemento ::
rap3r: ma mislu sem kak dober deal bom naredu.....dobu sem ga za 45ksit....za
herculesa pa se ne vem ker sploh ne vem ce bom tega r9500 obdrzal
. Saj ne da ni
hiter....hitrejsi ze nenavit kot r8500 samo
s softmodom ne dela tko kot sem si predstavljal.....z p2 400, 265mb vse na
defoult(brez softmoda) sem dobu 3700 pik
v 3dmarku2001 kar sploh ni slabo za tak sistem
Trenutno se hahaja v zmrzovalniku
....pa da vidimo ce ga bom k pameti spravu
rap3r ::
No boš povedu a je kej drgač pa a si dobu un link k piše kaj so z njim nardil?
Tito ::
A potem še vedno prodajajo radeone, katere se da modat?
Lepo bi prosil, če mi poveste na kaj moraš biti pazliv pri nakupu.
Hvala!
Hvala!
Malecky ::
Heh danes dobim iz garancije R9500 nikjer v okolici pa od ATI, Sapphire ipd.. nimajo 9700pcb tko da bom obstal na 9500 ali pa 9500pro.
Dobil bom pa sapphire iz zadnje pošiljke.
Dante ::
Clemento:
ne vem koliko je v tem zamrzovanju resnice, poskušaj malo pobrskati po tejle sicer ogromni temi
ko sem takrat to bral je mislim da debata o zamrzovanju tekla nekje od 50 strani dalje....
klik
D.
klik
D.
Tito ::
Men so rekl da so dobil celo pošiljko rdečih radeonov... Zdej me samo zanima če je to edini pogoj da je na 9700 PCB-ju?
boštjan ::
od kere firme in kera trgovina.pogoj je še da ma kartica rame v obliki L(dva čipa zgoraj desno,dva čipa ob strani desno)
Clemento ::
Hm....kot kaze zamrzovanje deluje za nekatere ljudi...zgleda pa da je odvisno od casa kok dold jo zmrzujes.....bom povedal zdele ko jo dam v kisto, zdele sem jo imel ene 5ur v hladilniku ki ima noter tisti mali predal na vrhu kao skrinjo sam mogoce ni dost mrzlo
bom probu doma kjer imam skrinjo kot skrinjo ce ne bo dobro...
rap3r ::
Hm
Norc
Sam usen poroči kaj je blo
Norc
Clemento ::
za cel teden v skrinjo pa bomo vidl kaj bo...
spet isti artefakti samo v enem testu 3dmarka2001 v Advanced Pixel Shaders
je šahovnica....a ma kdo se kaksno idejo?
Še to:
Everyone here remember the problem Gainward was having with their GF4 Ti4200? They concluded that it was from some bad capacitors. People were getting artifacts and checkboarding, just like some of us with the 9500np. What if our 9500np didn't pass for 9700 b/c of some bad capacitors and binned as 9500np? Anyone in here know how to test for bad capacitors? I've seen another thread where a guy replaced the capacitors off the Gainward with some from Radio Shack b/c he didn't want to RMA it. He fired it up and it worked like a CHAMP! Any inputs would be greatly appreciated by everyone that has done the mod and got artifacts and checkerboarding. If no one discovers anything soon, I may just try the freezer trick.
| » | Radeon 9500 in čudna slika (črtna koda)Oddelek: Strojna oprema | 2511 (1862) | mi_c_ho |
| » | Radeon-Nemčija? (strani: 1 2 )Oddelek: Kaj kupiti | 10534 (9314) | ferdo |
| » | Sapphire Atlantis Radeon 9500 Pro ali Enmic HIS Excalibur Radeon 9500 Pro?Oddelek: Kaj kupiti | 2168 (1685) | falotXP |
| » | soft mod 9500 non proOddelek: Navijanje | 4374 (3837) | boštjan |
| » | Radeon 9500 v Radeon 9700Oddelek: Novice / Grafične kartice | 3230 (3230) | TESKAn |
