Forum » Operacijski sistemi » dfs.vxd, vredir.vxd in msnp32.dll
Kozliček ::
Imam en problem. Nevem kaj sem delal.... ampak sigurno ni moja krivda :) ... ti Windowsi so bedni...
... v glavnem ko zaženem računalnik, mi prvo v DOSu se javi error da manjkata fajla dfs.vxd in vredir.vxd. Potem pa mi se pred začetkom Windowsov hitro vrže popup da manjka msnp32.dll.
Sem šel na net in najdel na tono istih problemov. Npr:
http://www.annoyances.org/exec/forum/wi...
http://www.driverguide.com/boards/micro...
http://www.driverforum.com/network4/53....
Torej nisem edini. Nekako dela vse v redu... ampak vseeno bi blo dobr popravit.
Mam pa winse 98.
ce ima kdo te fajle naj mi jih please poslje na stepan@volja.net .... pa se zraven pripise kje se nahajajo.
thanx
Mam pa winse 98.
thanx
Kozliček ::
Heh, sem ze nasel resitev....
... no pa ce ima kdo tak problem ---->
1."Start" Menu > "Run" and type in sfc. This starts the "System file checker".
2.Select the "extract one file" option.
3.Type in the name of the first file you are missing (with the .vxd extension) and press "start".
4.A window will appear with the destination and source paths requested. Type in :\win98 for the source and C:\windows\system for the destination.
5.Repeat the process again substituting C:\windows\system\vmm32 for the destination path.
6.Do this for every file reported missing.
za .dll pa --->
1."Start" Menu > "Configurations"/"Settings" > "Control Panel" > "Network" > "Configurations"/"Setting" Guide
2.CLIC "Microsoft network client" AND "Microsoft products logon"
3.CLIC "Remove" button
4.CONFIRMS AND RESTARTS THE MACHINE.
za .dll pa --->
| » | Intel Core i5 3210M kateri OS priporočate 32 ali 64Oddelek: Operacijski sistemi | 1983 (1628) | #000000 |
| » | Wireless kartica ne deluje na win 7Oddelek: Omrežja in internet | 2360 (2202) | kratos |
| » | Windows 7 Installer (64-bit) - težaveOddelek: Programska oprema | 3725 (3115) | fr!Xy |
| » | Microsoft pravi, da mu Ubuntu predstavlja konkurenco (strani: 1 2 3 )Oddelek: Novice / Android | 15252 (11701) | noraguta |
| » | encryption keyOddelek: Operacijski sistemi | 1554 (1389) | poweroff |
