Forum » Operacijski sistemi » encryption key
encryption key
st0jko ::
Zanima me kje najdem "encryption key", ki mi bo omogočal dostop do mojih kriptiranih podatkov v primeru da se mi sistem usuje in moram formatirati.
keks?
ender ::
Nadzorna plošča -> Internetne možnosti -> Vsebina -> Certifikati. Tam boš našel certifikat, ki ima isto ime kot je uporabniško ime, s katerim se priklapljaš v Windows.
Tomay ::
Google pomaga M$
How to back up your certificate
To back up your certificates, follow these steps:
1. Start Microsoft Internet Explorer.
2. On the Tools menu, click Internet Options.
3. On the Content tab, in the Certificates section, click Certificates.
4. Click the Personal tab.
Note There may be several certificates present, depending on whether you have installed certificates for other purpose.
5. Select one certificate at a time until the Certificate Intended Purposes field shows Encrypting File System. This is the certificate that was generated when you encrypted your first folder.
6. Click Export to start the Certificate Export Wizard, and then click Next.
7. Click Yes, export the private key to export the private key, and then click Next.
8. Click Enable Strong protection, and then click Next.
9. Type your password. (You must have a password to protect the private key.)
10. Specify the path where you want to save the key. You can save the key to a floppy disk, another location on the hard disk, or a CD. If the hard disk fails or is reformatted, the key and the backup will be lost. (If you back up the key to a floppy disk or CD, you must store that disk or CD in a secure location.)
11. Specify the destination, and then click Next.
Voodoo 4Ever
| » | Šifrirana mapaOddelek: Operacijski sistemi | 2844 (2315) | amigo_no1 |
| » | Dell RecoveryOddelek: Pomoč in nasveti | 1716 (1569) | hotacid |
| » | Unencrypt...Oddelek: Pomoč in nasveti | 1646 (1539) | solatko |
| » | Ne predvaja novega audio CDOddelek: Pomoč in nasveti | 2617 (2573) | Tea Time |
| » | Kako v Win2k premakniti mapo Documents and Settings?Oddelek: Operacijski sistemi | 2542 (2508) | Mercier |
