Forum » Programska oprema » PHP in CSS
PHP in CSS
Ales47 ::
Halo, mogoce kdo ve, kako vstavim v PHP css? v css-ju sem ze dolgo nic ni delal in sem cist pozabil kako kaj, sploh pa zdaj v PHPju, mislim da ni isto kot v HTML-ju.
deklaracija v css npr tako:
.ozadje
background-color:0012#;
in kako to v PHP vstavim?
in kako je koda za background image?
kako bi lahko oblikoval polja kamor vnasam npr pri registraciji uporabnisko ime.
Hvala
EDIT: Se opravicujem , ta tema velja k Programiranju.... sem se spregledal.
.ozadje
Hvala
- spremenil: Ales47 ()
Ales47 ::
Kam naj vstavim potem to kodo v index.php ... Meni javlja errore potem...Ce dam cista zgoraj v 1 vrstico, mi javlja napako z session start...
<?php
ob_start();
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<html>
<head>
<meta http-equiv="content-type" content="text/html; charset=iso-8859-1"/>
<meta name="description" content="description"/>
<meta name="keywords" content="keywords"/>
<meta name="author" content="author"/>
<link rel="stylesheet" type="text/css" href="slog.css" media="screen"/>
<title>Superior Species</title>
<?php
include 'baza_inc.php';
include 'class_lib.php';
session_start();
</head>
<!-- default margin = default layout -->
<body style="margin: 0 12%;">
<?php
if (isset($_COOKIE['MojKuki']))
$_SESSION['user'] = $_COOKIE['MojKuki'];
<div class="container">
<div class="header">
<a href="index.html"><span>Superior Species</span></a>
</div>
<div class="subnav">
<?php
if (isset($_SESSION['user']))
echo " Willkommen: " . $_SESSION['user'];
</div>
<div class="stripes"><span></span></div>
<div class="nav">
<class="current_page_item"><a href="index.php">Home</a>
<a href="index.php?stran=forum">Forum</a>
<a href="index.php?stran=streams">Streams</a>
<?php
if (isset($_SESSION['user'])){
echo "<a href='index.php?stran=bewerbung'>Bewerben</a>";
echo "<a href='index.php?stran=logout'>Logout</a>";
} else {
echo "<a href='index.php?stran=bewerben'>Bewerben</a>";
echo "<a href='index.php?stran=registrieren'>Registrieren</a>";
echo "<a href='index.php?stran=login'>Login</a>";
<div class="clearer"><span></span></div>
</div>
<div id="page">
<!-- start content -->
<div id="content">
<div class="post">
<?php
if (isset($_GET['stran']))
$x = $_GET['stran'];
include $x . ".php";
} else {
include "home.php";
</div>
</div>
<!-- end content -->
<!-- start sidebars -->
<div class="main">
<div class="left">
</div>
<div class="right">
</div>
</div>
</body>
</html>
<?php
ob_end_flush();
MisterR ::
Če že tako delaš potem v head ampak raje uporabljaj samostojno css datoteko in jo potem samo kličeš.
mihaelf3 ::
Kar imaš CSS-ja ga prilepi v tvoj 'slog.css', ampak še vedno...previdno s takimi rečmi:
LFI @ Wikipedia
} else {
include "home.php";
LFI @ Wikipedia
- spremenil: mihaelf3 ()
Lion29 ::
cist tko btw... tisti css v prvem postu je faljen...
barva se pise s hashem na zacetku.... #000000 ... in ima 6 stevilk (za vsako barvo 2... R G B)...lahko pa tudi skrajsas na 3 heksa (0-8,a-f) znake #af0 recimo...
mihael ti pa je pametno svetoval, da ne delas takih bedarij, ki so zelo nevarne!
drugace pa ne vem, zakaj bi CSS vstavljal v php?
ce hoces kaksno spremeljivko notri vstulit oz. kaksno abrvo dinamicno potem je ok, ce pa ne, pa naredi tako kot so ti predlagali...
zunanjo datoteko recimo "slogi.css" in notri vpises svoje sloge...
in potem jo znotraj tvojega index.php pozoves v HEAD html bloku, tako kot mas zdaj na vrstici #13
Ales47 ::
eno vprasanje se imam, kaj je narobe z tistim Mihael? To kodo smo v soli uporabljali itd oz ne vem kaj mislite stem.
Ales47 ::
} else {
include "home.php";
}Kaj mislite stem? Zakaj naj pazim?
mihaelf3 ::
Local file inclusion. Nekdo z malo znanja in sreče bi lahko bral poljubne datoteke na disku in s še malo več znanja (in sreče) poganjal poljubno kodo.
| ! | Vse, kar ste si želeli vprašati o CSS, pa si niste upali. (strani: 1 2 3 4 … 23 24 25 26 )Oddelek: Izdelava spletišč | 389366 (6898) | filip007 |
| » | Izdelava spletnih strani v PhotoshopuOddelek: Izdelava spletišč | 4632 (3680) | DiTi |
| » | php image borderOddelek: Izdelava spletišč | 861 (811) | -=aVa=- |
| » | Kontaktni ObrazecOddelek: Izdelava spletišč | 2693 (2062) | c3p0 |
| » | Mambo portal in flash animacijaOddelek: Izdelava spletišč | 2086 (1915) | aVToV|S|On |
