Kako fleshat HD6950
Kako fleshat HD6950
BigSmoke ::
Imam problem pri flešanju grafične kartice. Držim se teh navodil vendar mi ne uspe. Ko naredim 5. korak mi napiše OnlineiID mismatch.
1. Grab ATI Winflash from here (32 & 64-bit).
2. Download HD 6970 BIOS. The Sapphire one I linked to will work on all reference design cards from any vendor.
3. Make sure the BIOS switch on the card is set to the 1 position (pictured further down if you don't know where it is).
4. Run ATI Winflash, click Save to save your BIOS, so you have a backup in case something goes wrong.
5. Load the HD 6970 BIOS into Winflash by clicking Load Image, followed by Program.
6. Let the flashing process complete and reboot your system.
7. Check the shader count using GPU-Z, it should show 1536. Make sure you use version 0.5.0 or newer, the official 0.4.9 version does not support HD 6900 Series properly. If you see a shader count of 1600, your GPU-Z version is outdated.
8. To ensure maximized performance open Catalyst Control Center, go to the Overdrive tab and set the PowerTune slider to the +20% setting. The "Testing" section of this article has more data on that.
9. Check stability in Windows desktop applications and games.
  • spremenil: BigSmoke ()
BigSmoke ::
Ali mogoče treba premaknt stikalo na 2? Tuki nč ne piše.
RES NOBEN NE VE???
BigSmoke ::
Najdu sm rešitev za flešat, sam k napišem v cmd "cd %Miki%\desktop\winflash" napiše da navedene poti ni mogoče najti. Kaj je problem?
http://forums.techpowerup.com/showpost....
http://www.techpowerup.com/articles/ove...
Iz HD6950 1GB v HD6970 (shader mod)
82278 (1724) r3dkv1c4
BIOS flash Radeon HD 6950
263067 (2544) r3dkv1c4
Zamrznitev iger pri Radeonih HD4850 / 4870 (strani: 1 2 3 4 5 6 7 8 )
39132654 (16534) erzy
Ati Sapphire HD 4870 bios/ pomoč
181809 (1503) delfinus
Kako flešat bios brez disketnika?
51462 (1319) m.i.h.a.
