Kako flešat bios brez disketnika?
KontraCepec ::
Imam ploščo Epox 8RDAi. Rad bi sflešal bios, pa v navodilih in povsod piše, da je potrebno utility in bin posnet na disketo in sflešat.
Jaz pa disketnika nimam!
Kako torej stvar pripravit do flešanja brez disketnika?
Krijejtiv
DominusSLO ::
utility in bin posnameš na cd ;)
seveda moraš naredit štartni cd.... je pa tle 1 problem-backup biosa moreš dat na hdd
KontraCepec ::
kaj pa winflash? A to vredu deluje?
Krijejtiv
Han ::
Deluje, če nimaš sesut Windows...
KontraCepec ::
V varnem zagonu pridem not, ko pa štartam program (winFlash.exe) pa ta javi napako, da ta plošča nima Awarda Bioasa.
V dosu pa dela AWFlash?!?! Kako to... pa seveda 8RDA imajo awarda flash.
Krijejtiv
m.i.h.a. ::
Tole je navodilo za nadgarditev biosa na TYAN platah, mogoče bi znala delovat tudi na drugih.
USB Flash Key Method:
BIOS must be able to boot to USB bootable devices. Not all core bios versions have USB as a bootable option. Double check your documentation if you are unsure if this option is supported.
1. Make the USB Flash key bootable
2. Insure that you have the command.com, IO.sys and MSDOS.sys files on the USB key so that it will be bootable.
3. Place the unzipped batch files (batch file, flash utility, bios file and .txt file) on the USB key.
4. Make sure that the USB Flash Key is at the top of the boot order in your bios so that when the motherboard is turned on it will immediately boot to the USB Flash Key and boot cleanly to an A: prompt.
5. Simply type in flash at the A: prompt and the rest will be handled by the batch file itself.
6. Clear the CMOS. Reboot system and the flashed version of the BIOS should now be present on your monitor.
Še disklejmer::D
...za vso nastalo škodo s tem postopkom na drugih platah nisem jaz nič kriv in jo delate na lastno odgovornost.
Malo za duso malo za res :)
262859 (1609) T-Mac
usb bootable image windows
82128 (2042) T-Mac
Inštaliranje Windows7 iz usb
144431 (3988) king67
OS na USBju
Oddelek: Operacijski sistemi
152674 (2345) Spajky
Bios 8rda+
Oddelek: Navijanje
71352 (1250) kuglvinkl
