Forum » Programiranje » WiX, dark.exe
WiX, dark.exe
DubleG ::
Z dark.exe hočem odpakirati .msi, katere datoteke bi potem uporabil v končnem msiju.
Zaženem s parametri:
dark.exe "Manager.msi" -sct -sdet -sras -sui -x "Manager_Files" -o "Manager.wxs"
Berem sicer, da je to bug... ampak nekako se ga mora dat zaobit.
dark.exe(0,0): warning DARK1065: The AdvtUISequence table is not supported by the Windows Installer XML toolset because it has been deprecated by the Windows Installer team. Any information in this table will be left out of the decompiled output.
Manager.msi(0,0): warning DARK1062: The ModuleSignature table can only be represented in Windows Installer XML for merge modules. The information in this table will be left out of the decompiled output.
Manager.msi(0,0): warning DARK1062: The ModuleComponents table can only be represented in Windows Installer XML for merge modules. The information in this table will be left out of the decompiled output.
Manager.msi(0,0): warning DARK1066: The MsiPatchHeaders table is added to the install package by a transform from a patch package (.msp) and not authored directly into an install package (.msi). The information in this table will be left out of the decompiled output.
Manager.msi(0,0): warning DARK1066: The Patch table is added to the install package by a transform from a patch package (.msp) and not authored directly into an install package (.msi). The information in this table will be left out of the decompiled output.
Manager.msi(0,0): warning DARK1066: The PatchPackage table is added to the install package by a transform from a patch package (.msp) and not authored directly into an install package (.msi). The information in this table will be left out of the decompiled output.
dark.exe(0,0): warning DARK1058: The AdvtExecuteSequence table contains an action 'MsiUnpublishAssemblies' which is not allowed in this table. If this is a standard action then it is not valid for this table, if it is a custom action or dialog then this table does not accept actions of that type. This action will be left out of the decompiled output.
Microsoft Ÿ Windows Installer Xml Decompiler version 3.5.1923.0
GA-P55M-UD2,i5,12GB RAM,Radeon HD 4850,Crucial SSD 64GB,
WD 320GB,WD 5000GB,RevoDrive X2 100GB
- spremenil: DubleG ()
DubleG ::
VS 2010 je nekako rešil ta problem.
DubleG ::
Na dialogu DirectoryBrowse od WiXa pošljem triger za custum action
To mi odpre APP, napisan v C#. Podatke, ki bi jih ta DB.exe vrnil, bi potreboval na DirectoryBrowse dialogu, da bi na koncu vedel, kaj namestiti. Kako se to počne?
<Publish Event="DoAction" Value="DataBaseConnectionString">1</Publish> <Binary Id="DB" SourceFile="DB.exe"/> <CustomAction Id="DataBaseConnectionString" BinaryKey="DB" ExeCommand="" Execute='immediate'/>
DubleG ::
Bom še četrti post napisal :)
C#/DTF vam preko MakeSfxCA zbuilda CustomAction1.CA.dll ki ga kot custom action zaženete
(DllEntry je dejansko ime metode znotraj Custom Action projekta v VS)
Triger je gumb:
Preko custom action projekta pa dostopate do spremenljivk seje
string povezava="bla";
session["connStr"] = povezava;
saj Product.wxs vsebuje:
Preko propertija pa lahko določamo tekst label in textboxov na dialogu od wixa.
Upam, da bom komu pomagal. :)
<CustomAction Id="someID" BinaryKey="someKey" DllEntry="CustomAction1" Execute="immediate" />
<Binary Id="someKey" SourceFile="CustomAction1.CA.dll" />
Triger je gumb:
<Control Id="button3" Type="PushButton" Height="19" Width="83" X="186" Y="20" Text="DatabaseOptionsOff" Bitmap="yes" >
<Publish Event="DoAction" Value="someID">1</Publish>
</Control>
<Property Id="connStr" Value=" " ></Property>
| » | Pomoč C++Oddelek: Pomoč in nasveti | 1788 (1507) | samo111 |
| » | ruterOddelek: Omrežja in internet | 1718 (1325) | Blisk |
| » | Ubuntu netbook 10.4 in particioniranjeOddelek: Operacijski sistemi | 2344 (2056) | Icematxyz |
| » | Debian Gnu/Linux kot workstation (strani: 1 2 3 4 … 37 38 39 40 )Oddelek: Operacijski sistemi | 128284 (43958) | RedDrake |
| » | Linux / ATI Radeon / problem z driverjiOddelek: Operacijski sistemi | 2225 (2042) | ahac |
