core2duo in dual core
anze9 ::
kupil sm procesor e6600 pa me zanima kaj je razlika med dual core in core2duo?
mastah ::
mislim da core2duo ima dejansko 2 jedra, dual core pa ne
Zako ::
dualcore ni bil pravi dvojedrni procesor, mislim, da ni imel direktno 2 jedri v procesorju, pravtako dualcore nima VT in ima samo 1MB L2 cache.
http://www.tomshardware.co.uk/forum/pag...
"The Pentium Dual Core, which we found to be an excellence choice for overclockers on a low budget, is based on the popular Core 2 architecture. In fact, the processor cores are the same, but the CPU comes with only 1 MB L2 cache instead of 2 MB or even 4 MB. In addition, some features, such as Intel's Virtualization Technology (VT) are disabled. The result is a castrated Core 2 Duo processor, using the small cache size and limited to 1.6 to 2.0 GHz clock speed at FSB800 system speed."
Zako je zakon!!!
energetik ::
Jao kakšne klatite, priporočam tale link, je takoj na začetku ena poučna tabela...
anze9 ::
sry zmotu sm se že v naslovu e6300 dual core imam
Lenovo R61i Procesor ?
112964 (2800) solatko
acer aspire 5315 procesor
323432 (3111) jonyyy
Dual Core AMD/Intel (strani: 1 2 3 4 … 19 20 21 22 )
107598711 (34019) Isotropic
pentium dual core vs core2duo
357109 (6334) Steinkauz
Razlika med procesorji
133145 (2345) Blinder
