Obama Go
Obama Go
poweroff ::
Razen, če to reče Obami. Pol je pa hitro socializem v igri... :))
sudo poweroff
Arto ::
Pa da ne bo pomote, ne maram Obame, ker je preveč desen in stalno streže republikancem. Je pa Romney še veliko slabša možnost.
Double_J ::
http://www.blippitt.com/code-red-white-...
One can only assume that Stein is referring to the unconstitutional National Defense Authorization Act (NDAA), which was signed by Obama on New Year’s Eve, albeit “with reservations.”
The act allows for the indefinite detention of American citizens without trial and has been a hot topic among activist groups like Anonymous. Obama has since been sued for passing the NDAA.
Dve šivanki...
  • spremenil: Double_J ()
Arto ::
In kako je NDAA karkoli drugega, kot nadaljevanje Busheve politike s Patriot Act-om na čelu?
Double_J ::
As we’ve previously discussed here, the National Defense Authorization Act allows the U.S. government to indefinitely detain anyone, indefinitely and without a trial (including American citizens), so long as they are suspected of “substantially supporting Al Qaeda, the Taliban or any ‘associated forces,’” whatever that means.
OK, that all sounds well and good, but did you know that, under this act, you could be considered a terrorist if you have more than seven days’ worth of food in your house? You could be considered a terrorist if you own firearms. You could be considered a terrorist if you’re missing any fingers on your hands (I’m not making this stuff up).
No kdaj je Bush sprejel kaj takega?
Dve šivanki...
Arto ::
Patriot Act. Poleg tega, rezultati glasovanja za NDAA so sledeči:
REPUBLICAN: Y: 190, N: 43
DEMOCRAT: Y: 93, N: 93
Ne boš zdaj trdil, da republikanski predsednik ne bi sprejel tega? Razen če si bolj za libertarce.
Double_J ::
Štos je v tem, da je bil vojak odpuščen ko je komentiral sprejetje tega zakona.
Dve šivanki...
Arto ::
Double_J je izjavil:
Bi moral biti pri svojih besedah precej bolj pazljiv. Ker je njegova služba izpolnjevanje ukazov, se ne more odločiti, da jih ne bo izpolnjeval.
poweroff ::
Če bi bil na oblasti Bush pa bi verjetno končal v Guantanamu...
sudo poweroff
Mipe ::
Arto: torej vojak ne sme zavrniti ukaza, da pobije civile?
Zheegec ::
poweroff je izjavil:
V Izraelu/arabskem svetu/rusija/kitajska,...... pa še kaj hujšega :)
Mipe je izjavil:
Lahko, samo kot prvo se ga odpusti kot drugo včasih tudi vojaško sodišče, ki ga seveda lahko oprosti krivde.
  • spremenil: Zheegec ()
Arto ::
Mipe je izjavil:
Na njegovo žalost, tale vojak v svojem komentarju ni bil dovolj specifičen.
Double_J ::
Kot da se iz njega niso delali norca kakšni vojaki...
BTW, ali kdo pogreša Busha? Poglejte že 10let star govor, pa še kako aktualen danes! :)
Dve šivanki...
Arto ::
"Screw Obama. I will not follow all orders from him." ni "delanje norca", ampak trditev, da nočeš izpolnjevati ukazov. Kar je precej resno.
  • spremenil: Arto ()
Daedalus ::
Če tole rečeš vrhovnemu poveljniku vojske... ne pričakuj kaj drugega, kot nečastnega odpusta.
[J.P.Sartre]
poweroff ::
Jah, v US Army pač niso neki neokomunajzarski flower power hipiji, pač pa mora vsakdo za svoja dejanje prevzeti odgovornost. :))
sudo poweroff
Samurai ::
V vojski ni demokracije, če misli kdo drugače je to veleizdaja!
Dajmo se raje vprašat, kam vlaga amerika največ denarja za razvoj? Na prvem mestu v orožje in masovno produkcijo le tega.
Oni vedo da še nikoli niso tako dobro zaslužili, kot so po II.sv.vojni in to tako, da so okupatorjem in državobranilcem prodajali orožje, ki je imel enak izvor le drugačno znamko.
poweroff ::
Aja, pa zanima me koliko vojakov je zavrnilo mučenje v Guantanamu in pobijanje civilistov v Basri... in kolikokrat je tako zavračanje ukazov Double podpiral...
sudo poweroff
Double_J ::
http://online.wsj.com/article/SB1000142...
The U.S. Secret Service has expanded its prostitution scandal investigation to include an incident in El Salvador in 2011 in which agents allegedly visited a strip club and may have paid for sex with prostitutes, the agency told lawmakers Thursday.
Obamovi prijatelji se takole zabavajo na njegovih potovanjih. Malce čudno glede na to, kako se on bori za pravice žensk.
Pa kolikor vem Matthai, Obama ni zaprl Guantanama kot je obljubil, vendar lahko trenutno vsakega državljana kolikor hoče drži tam.
Dve šivanki...
VelikiTun ::
Od kdaj se varnostniki štejejo za osebne prijatelje?
Tvoje pisanje je nekje na nivoju 24kur.
Double_J ::
Dve šivanki...
Double_J ::
The Obama/Holder “Operation Gunwalker: Fast & Furious” was and is directly attributable to Dictator-in-Chief Obama. Since shortly after the C-span2 video was published in 2009, in my columns I have referred to Deputy Attorney General Ogden’s statement on said video that he was “directed” by “the president” to “take action” against the drug cartels. This action began as “Operation Gunrunner” and its name was changed to the infamous one we know today. However, the operation was never planned to fight against the drug cartels. Instead, it was developed as a means to fight WITH the cartels against the US citizenry. The operation was affected (and don’t forget “directed“) by Obama and his Attorney General Eric Holder to do one thing: Remove legally-owned guns from US citizen under the Obama-manipulated premise that guns were being illegally sold to the drug cartels by Americans.
Note: The only problem with this was/is that the Seller was the Obama government and the Buyer was/is the Sinaloa drug cartel leadership. The Obama syndicate openly chose the “winner” in the Mexican drug wars (which have spread to and are now being fought in the USA) to be the Sinaloa Drug Cartel over the Los Zetas cartel. Therefore, thousands of guns have been supplied by Obama, Holder, the ATF etc. to the Sinaloa gang. All of the murders and mayhem created by Obama and his syndicate have been enacted as a false excuse/reason to remove guns from US citizens so that they would be enslaved more easily or exterminated without being able to fight back against their oppressors. This is what ALL totalitarian plots have affected in world history and this is the reason Stalin and Mao were able to murder tens of millions of humans. This—and the lies believed when the truth was too ‘scary’ and painful for the German people to accept—was the reason Hitler was able to round up Jews, place them in train cattle cars and take them to their executions…with little more than whimpers.
http://www.canadafreepress.com/index.ph...
ATF gunwalking scandal @ Wikipedia
Ne bodite preveč naivni okoli Obame OK?
Dve šivanki...
Arto ::
Jaz nisem nič naiven do Obame, je kupljen od korporacij, tako kot vsi ostali ameriški politiki. Desen je pa bolj od Reagana. Ampak republikanci so pa še 100x hujši.
donfilipo ::
No zdaj ko so ultradesni geniji ugotovili da Obama nikakor ni Slovenec, saj je bilo danih v pogled 5 verzij rojstnega lista, tudi jaz ne bom volil za Obamo.
Po mojih tajnih gestapovskih vezah sem ujel na radarje, da pa ravno JJ, pa ga nekako odobrava.
Tako da mi ni nič jasno.
Pa še nekaj je. Glede na to da Obama po ostroumnih dognanjih najpreciznejših možgan na svetu ni Američan, kako ga sploh lahko kdo voli drugje, razen recimo v Keniji:))>:D
In times of Universal Deceit, telling the truth
becomes revolutionary act. Orwell
Moraš Thomasa vprašat.;)
O.
donfilipo ::
Ne upam. Thomas ima tehtne dokaze in vero, da če preživiš naslednjih 5 let si major task naredil. Pa trobil karkoli za kogarkoli8-)
To je ena takih modrosti, ki je ultrajeklena, čeravno ni v kompatibilnosti s formo nekega platonskega poštenega dialoga8-) Ki mu dodamo eno mastno inovacicijo...empirijo, ki ji gre zaupati. Pomeni ne videli sami, ker smo drobne mravljice, ampak zaupali izbranim:)
Torej Obama ne gre, ostane nam Mitt Romney.
Jaz za razliko od nekaterih najuspešnejših žensk ne pogledam pri moških najprej koliko meri:), ampak recimo religijo.
'The Church of Jesus Christ of Latter-day Saints'
Sliši se neverjetno super. To jaz ne verjamem tako od prve, da je genuine..zato bom preveril:)
Zdej Romeny je slika in prilika ene rodbine iz bližine.
Tako da po mučkah z rojstnimi listi, bi zlahka bil Slovenec.
Ampak tole mormon, tole mi je pa malce sumljivo:)
  • spremenilo: donfilipo ()
donfilipo ::
Aha Angel Moroni. Ki je obiskal Josepha Smitha jr. in se mu razodel.
Tu nekje se sum začne debeliti.
Mi je pa morda bližje od kje koren besede moron:))
Še malo resneje.
Jasen split o katerem sem že večkrat govoril, idejo pa pobral od Žikovih razlag fetišističnega splita:)
Empatijo prepustimo prostovoljni religiji, država ostane konzervativno liberalna, torej zagotavlja samo okvire za možen uspeh, ne zagotavlja pa uspeti niti preživeti.
V jedru to pomeni manj sociale in več neoliberalizma.
Zdaj če bi ga fajmošter javno na TV oklufutal in ozmerjal...on pa pokesal...bi ga pa morebiti celo šel volit:))
Double_J ::
http://www.mcclatchydc.com/2012/04/24/1...
Koliko ima Romney šans? Če se poslabša ekonomija ter bo imel dobro kampanijo, pomojem kar precej.
Dve šivanki...
Double_J ::
http://www.jpost.com/USPresidentialrace...
'NYT': Netanyahu, Romney friends for 36 years
If Romney is elected, he will unleash hell on Iran.;)
Dve šivanki...
VelikiTun ::
Samo ta hell se bo kot bumerang vrnil v US, ko bodo na račun vojnega dobičkarstva prisiljeni v še večje zadolževanje do Kitajske.
donfilipo ::
V tej računici dobičkarstva je ena velika luknja.
Če sešteješ vse profite velikih vojnih dobičkarjev iz Iraka recimo, so sicer lepe miljardice a niti približno ne dosežejo triljončka, kolikor so (bodo) donirali davkoplačevalci. Skupaj z nekaj mrliči, invalidi in duševno popačenimi veterani.
Na pogled izgleda, kot da je cel show ravno zaradi tistih miljard, ki so si jih vrhunski smooth operatorji okoli Busha (Dick:) zatlačili okoli riti v varžet8-), še nekaj spremljave in ploskanje celega sveta za zmago nenadkriljive tehnike. In seveda opozorilo vsem nadebudnim oponaševalcem Husseina...predvsem tistim z nafto8-)
Ali pa smo kaj debelo spregledali.
Double_J ::
(CBS News) -- House Republicans investigating the Fast and Furious scandal plan to pursue a contempt citation against Attorney General Eric Holder, senior congressional aides told CBS News.
The resolution will accuse Holder and his Justice Department of obstructing the congressional probe into the allegations that the government let thousands of weapons fall into the hands of Mexican drug cartels.
http://www.cbsnews.com/8301-31727_162-5...
http://www.cbsnews.com/stories/2011/03/...
http://www.cbsnews.com/8301-503544_162-...
Obammy se očitno res bavi z mamilarstvom...
Dve šivanki...
donfilipo ::
To ni samo Obama.
Poglej letnice tokov dogodkov. Zadeve tu tečejo od 2004 najmanj naprej.
Naivno je pričakovati, da bi tovrstni palicajski mišmaš, ki deloma zaradi obveščevalnih razlogov zgleda mafijsko....deloma pa zaradi mafijskih direktnih groženj nekaterim agentom in policistom in seveda profita, potem tudi JE mafijski, bil prej bistveno drugačen.
Ameriške agencije (CIA in FBI) na videz ves čas najmanj od 60-ih, so stalno vpletene v trgovanje z drogami in orožjem. Kaj od tega je covert mission, kaj pa postranski mafijski zaslužek, je pa večna skrivnost. In tu celo sveto sveta ...dejansko stroga in relativno uspešna, kar se drog tiče, naša bivša UDBA, ni izjema. Priče, ..skesani vrhovni udbaši pričajo, da so agenti udbe, ki so bili tudi likvidatorji tipa Arkan, redno skrbeli za šverc droge po balkanski poti. Edini dodatni zadatak jim je bil, da se nič tu ne ustavi. Danes seveda je ta del odpadel8-)
Je pa seveda jasno, da je Obama predvsem primeren za šverc orožja mamilarjem ponoči8-)
Double_J ::
Malo mešaš gunrunner, ter fast&furious. Tukaj meni izgleda, da so si izbrali določen kartel, ki so hoteli da zmaga. Na tisoče kosov orožja in bomb so poslali temu kartelu, pod pretvezo sledenja.
Joaqu%C3%ADn Guzm%C3%A1n Loera @ Wikipedia
Joaquín Archivaldo Guzmán Loera (b. April 4, 1957)[2] is a fugitive Mexican drug lord who heads the world's largest and most powerful drug trafficking organization, the Sinaloa Cartel,[5] an organization named after the Mexican Pacific coast state of Sinaloa where it was initially
formed.
Edgardo Buscaglia, a professor at the ITAM, believes that Guzmán's capture may also help Barack Obama's reelection campaign, since there have been suspicions that his government "provided protection" to the Sinaloa Cartel.[39]
Dve šivanki...
Double_J ::
Zakaj pa je to tako nemogoče... Obama pač hoče en kartel da bo z njim potem vodil dialog. Saj tudi z talibani trenutno vodi dialog v pisarni, ki so jo talibani odprli v Katarju.:D
Dve šivanki...
Double_J ::
Operation Wide Receiver @ Wikipedia
In December, documents revealed that some ATF agents discussed using Fast and Furious to provide anecdotal cases to support controversial new gun rules. The regulation, called Demand Letter 3, would require some gun stores to report the sale of multiple rifles.
Obammy je tole zlorabljal za neke svoje ideje, to se dobro vidi. Kartel je sedaj še bolj močan, mrtvih pa ogromno ljudi.
Dve šivanki...
Double_J ::
Še malo...
http://www.humanevents.com/article.php?...
http://minx.cc/?post=323260
(Emphasis mine.) Devoted students of the Operation Fast and Furious scandal will recall that its predecessor, Operation Wide Receiver, actually did try to monitor the weapons at all times, through an ill-fated attempt to wire them with radio transmitters. The cartels swiftly figured out how to defeat the radio tracking system, largely through the simple expedient of driving around in circles until the ATF’s monitoring aircraft went bingo fuel and had to return home.
Operation Fast and Furious, on the other hand, did not make any attempt to monitor the guns at all. In fact, ATF agents were actively dissuaded from trying to follow the weapons. The entire strategy was to wait for people in Mexico to get killed by those ATF guns, and then pick them up from the crime scene. Several hundred Mexicans were duly gunned down, along with at least one American law-enforcement official, Border Patrol Agent Brian Terry.
Fast and Furious “worked” as designed, because its guns were indeed retrieved from the crime scenes. Hundreds of guns are still missing, but they’ll doubtless turn up eventually, at future crime scenes. They’ve started popping up at crimes on the American side of the border, which will make collecting them even easier. We just have to be patient.
Dve šivanki...
donfilipo ::
Nekako nisem imel časa vse pregledati.
In ne trdim da je to nemogoče. Nasprotno! Trdim da se to dogaja v eni ali drugi obliki ne glede na to kdo je predsednik.
Če bo kdo končno zadeve razkril, pa makar to bil Romneys, je velik revolucionar. Res velik.
Problem je v tem, da ne verjamem da je Romney in desnica velik revolucionar:))
Ampak ok. Študiram konkretni primer.
Nekaj je pa treba vedeti.
Tako razkritje je naloga demokracije in niti čisto prvič, pa res ne bi bilo. Mogoče je čas, da proradi tudi tokrat:)
Double_J ::
Gre za nekoga, ki bi rad veliko smrti, da bi se posledično lahko omejila prodaja orožja. Kar pa je najbolj zanimivo, kjub temu da smo ga odkrili še vedno nadaljuje po tej poti.
In November, the president signed the Justice Department appropriations bill, which included language from Sen. John Cornyn, Texas Republican, prohibiting federal agencies from facilitating the transfer of an operable firearm to an individual known or suspected to be in a drug cartel, unless they monitor the weapon at all times.
Now Mr. Obama is proposing to remove that provision from the 2013 spending bill, thus making it legal to revive gun-walking operations in the future. The White House justification is merely that the prohibition is “not necessary.”
Oh, and the cartel big shots ostensibly targeted by this disastrous and lethal operation? They were FBI informants all along.
Sedajle me je prešinilo, da imamo opravka z nečem zlobnim. Inteligentnim vendar zlobnim. Is it possible?
Dve šivanki...
poweroff ::
Ja Dublek, a si ogledalo našel? :))
sudo poweroff
Double_J ::
Obama: 'If I had a son, he'd look like Trayvon'
Sedaj pa si predstavljajte, da bi Bush, ko bi prišlo do nekega incidenta v katerem bi črnec ubil belca rekel... da če bi on imel sina, potem bi ta sin izgledal tako kot ta belec.
A je to normalno? Meni se zdi sprevrženo.
Dve šivanki...
Arto ::
Kaj? Zakaj bi bilo pa to kaj spornega? Aja, Obama je rekel, "moj sin bi zgledal kot ta črnec!".
Double_J ::
Jao... ko bo nek črnec pri nas ubil Slovenca, pojdi ti v družbo ter pokomentiraj, da če bi imel ti sina, bi sin izgledal kot ta ubiti Slovenec. Me zanima kako te bodo gledali...
To je povedal Obama, jaz pa sem samo obrnil barve ja?
Dve šivanki...
To ti seveda ni jasno, da je v ameriški policiji neproporcionalno veliko belcev, in da vsako leto ustrelijo neproporcionalno veliko črncev, ne? Rasizem se dogaja samo v eno smer. Ti sicer lahko obračaš barve, ampak jih neumno obračaš.;((
O.
Double_J ::
Sploh ni šlo za policista, temveč kar nekoga.
Črncev je tudi neproporcionalno veliko v zaporu, tako da je logično da jih je tudi ustreljenih več. Dvomim da zapirajo nedolžne ljudi, zaradi rasizma. Zagrešijo pač več kriminalnih dejanj, zato jih je več ustreljenih ter obsojenih.
Dve šivanki...
donfilipo ::
Hm torej tisto s sinom je čisto ok. PR.
In ker gre za rasističen incident, se tokrat ne bom delal purista, ampak rasista in dodal bodico:
'Če je George Zimmerman čistokrven belec, sem jaz Litvanec8-)
Konec koncev mešanje genov deluje super, samo s čisto barvo so še problemi8-)
Bemti se vidi kako je popolnoma razpadel napredni znanstveni um 'Verrein-a Socialistiche Aertzte':))
Resneje pa takole. S tem primerom se je Obama spoprijel zelo moderate. Nobenega posebnega ognja na rasno mržnjo, nobene posebne Malcolm X retorike. V takem primeru je zagotovo boljše socialno pomirjevalo, kot bi bil recimo lahko Romney.
In vaške straže, ki oprezajo za črnci s kapucami in streljajo, ne spadajo v civilizirano družbo.
Kar se pa škandala Fast and Furious tiče, je pa tu nekaj hudo narobe ali pa manjka. Hudo narobe. Pa sem ga nekako do danes spregledal, kar pa spet ni dober znak. Ali je enostransko potiskan, ali pa zataušan podobno kot naš šverc z vseh političnih strani. In je Pavličeva s svojo knjigo samo nekakšen 'lone rider'.
Double_J ::
To bo sodišče odločilo kakšen incident je bil. Zimmerman je imel razbito glavo. Kako pa Obama kar ve preden je razsojeno?
Zimmerman naj bi mu res sledil, potem je Martin za kratek čas izginil, nato pa se je pojavil ter ga napadel in ga z glavo butal ob tla. Pacienta sta lahko tudi obadva?
Dve šivanki...
Ti lahko dvomiš, ampak fora je ravno v tem, da dejansko jih (dokazano).
George Zimmerman is a 28-year-old multi-racial Hispanic American
O.
  • spremenil: Okapi ()
Double_J ::
Obama torej misli da so črnci zapostavljeni in potem komentira kar tako na slepo nek primer, ki ga zagotovo ne bi če bila vpletena ravno nasprotnih barv.
Zimmerman črn, Martin pa bel. Potem enostavno nič ne bi slišali.
Dve šivanki...
Arto ::
Ni komentiral primera. Komentiral je dejstvo, da Zimmerman sploh ni bil aretiran potem, ko je ubil človeka. Sploh ne bi bilo preiskave, če ne bi bilo javnega zgražnja.
30 / 34
Sovražniki razuma (strani: 1 2 3 4 5 )
Oddelek: Problemi človeštva
24232148 (29919) sprasujem
Sorodstvene vezi predsednikov ZDA (strani: 1 2 3 4 5 )
23317919 (12700) Gandalfar
Ali Obama sme postati predsednik ZDA?
72374 (2246) OmegaBlue
Will Hillary own some republican ass? (strani: 1 2 3 4 … 20 21 22 23 )
112368051 (36352) poweroff
V ZDA kršijo tudi zasebnost predsedniških kandidatov?
Oddelek: Novice / Zasebnost
474635 (3285) jype
