Forum » Loža » Obama Go
Obama Go
Jst ::
Area code je lahko tudi iz Texasa. Kar pomeni samo to, da je tam zaprosil za SSN.
In kaj potem, če je zaprosil za SSN v Conneticutu/Texasu?
Thomas ::
Tam je moral imeti stalni naslov. Nikoli ni omenil tega.
Jst ::
Ni res. To je bilo uvedeno šele recently (desetletje).
edit: OMG, kaj bo šele, ko bo El Presidente ženska ali Mehičan.
- spremenil: Jst ()
Thomas ::
Ne vem jaz, zakaj naj ne bi bilo res. Ti trdiš, da si tiste časa lahko dvignil svojo "davčno" kjerkoli v Ameriki?
In če tako, kaj je Obamo neslo takrat v Conneticut, saj naj bi bil na Havajih, ane?
Je vse skupaj izmišljija in ima Obama "normalno Havajsko" številko?
frudi ::
Zeh, ker Thomas trpi za Obamafobitisom, ki očitno preprečuje, da bi prebral in/ali razumel linke, ki se mu jih predloži, je očitno treba eksplicitno napisat:
The SSN Numbering Scheme
Number Has Three Parts
The nine-digit SSN is composed of three parts:
- The first set of three digits is called the Area Number
- The second set of two digits is called the Group Number
- The final set of four digits is the Serial Number
Area Number
The Area Number is assigned by the geographical region. Prior to 1972, cards were issued in local Social Security offices around the country and the Area Number represented the State in which the card was issued. This did not necessarily have to be the State where the applicant lived, since a person could apply for their card in any Social Security office. Since 1972, when SSA began assigning SSNs and issuing cards centrally from Baltimore, the area number assigned has been based on the ZIP code in the mailing address provided on the application for the original Social Security card. The applicant's mailing address does not have to be the same as their place of residence. Thus, the Area Number does not necessarily represent the State of residence of the applicant, either prior to 1972 or since.
Generally, numbers were assigned beginning in the northeast and moving westward. So people on the east coast have the lowest numbers and those on the west coast have the highest numbers.
Note: One should not make too much of the "geographical code." It is not meant to be any kind of useable geographical information. The numbering scheme was designed in 1936 (before computers) to make it easier for SSA to store the applications in our files in Baltimore since the files were organized by regions as well as alphabetically. It was really just a bookkeeping device for our own internal use and was never intended to be anything more than that.
Še gov link kot vir.
Move along now, no conspiracy here...
Area Number
Thomas ::
In Obama ima to iz katere Area?
frudi ::
Kot ti gori na dolgo piše - nima veze.
Thomas ::
Ja, ma vezo, če ima Obama Connecticut area kodo. Kje jo je dobil?
V svojih življenjepisih (izdal je svoj življenjepis že davno, pa mensezdi ne samo enega), pa nič ne omenja Connecticut.
Now I wonder. Do you mind?
Yes, you do.
http://www.huffingtonpost.com/2010/06/1...
Yes, you do.
- spremenil: Thomas ()
poweroff ::
Prior to 1972
Katere besede od teh treh točno ne razumeš?
Prior?
Mislim, move along. Zadeva je približno taka kot obtožbe, da je bil Bush imenovan za predsednika ZDA s strani očkovih prijateljčkov na Vrhovnem sodišču. Povsem mogoče (čeprav po mojem mnenju malo verjetno), vendar nerelevantno. Tip je izvrševal predsedniško funkcijo in jo tudi pripeljal do konca. In ni bilo načina, da se mu funkcijo odvzame - niti to ni bilo smiselno.
Zapadaš v boleznih skrajnih ameriških levičarjev, Thomas!
sudo poweroff
frudi ::
Nič me ne moti tvoja obsedenost z Obamo in z vsako novo birthersko slamico; mi je pa prav zabavno opazovati simptome Obamafobitisa.
Od kod pa Obami Connecticut-ski SSN? Koga briga, mogoče je bil pa ravno na počitnicah ali pri kom na obisku. Kup trivialnih razlogov je lahko, zakaj so mu SSN kartico poslali ravno v Connecticut. Privzeto tule iskati neko zaroto, je paranoično in iracionalno. Čeprav precej tipično za conspiracy frike (pa naj gre za pristanek na luni, 9/11, NWO ali birtherje).
Thomas ::
Če bi bil to recimo Clinton. Bi se pojavil v Beli Hiši na tiskovni konferenci sam in kazal povečano shemo svoje številke in razlagal, kako je do nje prišlo. "This women has nothing to do with my SS number!" V tem stilu.
Vsak normalen tko nekako. Tukaj pa stvar obvisi v zraku. IMHO, ker je še kako povezana z BC zadevo in "nočejo drezat".
PaX_MaN ::
Ne, ni. Ker je že bilo na sodišču, pa le-to ni dalo na to pol pizde mrzle vode.
Double_J ::
Ah, tle je stvar jasna. Thomas, z Obamo se razlikujeta po barvi kože, ter po tem, da je bil on rojen v ZDA.
Približno tako preprosto je.
Dve šivanki...
Thomas ::
http://www.socialsecurity.gov/employer/...
Tle se vidi, kako so številke razporejene.
Ne pristajam na idejo, da se ne sme niti vprašat, če Obama ima ali nima številke iz države, kjer ni nikoli živel.
In če jo ima, kako je do nje prišel.
Zakaj bi bili poslušni?
poweroff ::
Ker ko gre pa za neoliberalne ideje (prosti trg FTW) pa moramo biti poslušni?
sudo poweroff
Thomas ::
Vedno lahko zahtevaš argumente, vedno.
In jih tudi dobiš. Vsak berač vsaj malo hvali svojo malho, pa naj bo neocon ali pa Mirovni Inštitut. Z veseljem vsi razlagajo svoje poglede.
Obamin tiskovni predstavnik pa ni hotel povedati nič o tisti številki. Nič.
Večina ljudi smatra, da je tako prav in dobro.
Jst ::
Da bodo imeli ObamaHoaxerji novo kost a glodat:
kltv.com: CNN poll on Obama: 6 of 10 doubt U.S. birth story
Prav zabavam se ob branju "razlogov," zakaj Obama ni primeren za POTUSa.
Sicer pa: Obama je začel kampanjo na internetu, lahko bi sedaj spet uporabil to komunikacijsko sredstvo za support.
Jst ::
Medtem, ko sedaj delam na racunalniku, imam prizgan TV (slucajno) na Fox News ter sem ujel/slisal to novico in mnenje:
Bush je Februarja 2005 odpoklical ambasadorja iz Sirije, ker naj bi Sirija podpirala terorizem. Obama je pa sedaj spet v Sirijo postavil ambasadorja z obrazlozitvijo, da si Amerika s tem popravlja svetovni ugled.
Republikanci pravijo temu "kapitulacija Obame (in Obamine administracije)." Pravijo, da povprecni Americani temu niso naklonjeni.
Double_J ::
Opa, Trump je bil pa le dovolj vztrajen. Je pošiljal dol na Havaje svoje ljudi.
Sedaj pa je Obama le objavil celoto?
Dve šivanki...
PaX_MaN ::
Če bodo Američani zadovoljni, bom tud jest.
Yeahhh, about that:
only took two+ years to forge this....
REALLY, this is the best they can do? The WH sends over a picture, where is the REAL ONE?
:rolleyes:
Tilen ::
Zgleda precej cheap vse skupaj.
V original PDF-ju sem izbral vse + copy/paste v slikarja in dobil tole :
Original
A je to normalno? :p
- spremenil: Tilen ()
Ja kaj bi pa rad, da se ti pozlati monitor, ko odpreš ta dokument, v ozadju pa zaigrajo štirje letni časi?
Thomas ::
Ne ... ni tega mislu. Mislu je, kar je napisal in ilustriral. Probejte narest isto, dokler je dokument še dostopen.
A je to normalno? Ne vem. Zgleda res hecna ta reč.
(Vsi se umirte, ne šizite ko pobesneli in mirno recite, da je to čist okay, da se iz pdf dokumenta tkole skopira, kakor je Tilen povedal.)
Thomas ::
Ja, ja Tron, že vemo. Se že čudimo, kako je dokument napravljen iz vsaj dveh layerjev od katerih se ededntko lepo skopira v MS Paint.
Hehe ...
Hehe ...
Bellatrix ::
Torej kaj nej bi to pomenlo ?
Za računalništvo nisem ekspert, tko da nevem če je to običajno ?
Sem poskusil narediti isti postopek in tudi meni pride zabrisano.
People are quick to judge and slow to correct themselves.
WarpedGone ::
Samo po sebi nič. Je le (zanimiv) artefakt kopiranja prikazane slike iz PDF v BMP.
Edit:
Če PDF odpreš v editorju, ugotoviš, da je zadeva iz dveh plasti - "barvno" ozadje in plast črnega teksta. Kjer je črna črka, je ozadje belo. Ko kopiraš iz PDF v Paint se skopira le barvno ozadje, črn tekst pa ne: Tole se ne skopira:
Zbogom in hvala za vse ribe
- spremenilo: WarpedGone ()
XsenO ::
No na koncu so pa le zmagali nezaupniki v USA varnostne mehanizme. Čeprav kot pričakovano niso vsi zadovljeni.
1 + 1 = 1
A je sploh kdo pričakoval, da bo rojstni list koga zadovoljil? Ker kdo lahko zagotovi, da ni fake?
O.
O.
Ziga Dolhar ::
Adobe Acrobat in drugi podobni programi lahko [ob prikazu - banju] nad dokumentom poženejo provizoričen OCR. Acrobat to (lahko) stori tudi ob skeniranju dokumenta. (Sama kvaliteta prepoznave je sicer dokaj slaba.)
Kako programi berejo kompleksno PDF datoteko, ne pove ničesar o tem, kako je bila sama datoteka dejansko sestavljena. Sam vpogled v "surovo" pdf datoteko prav tako ne pove ničesar o naravi izvorne podlage [skena], obdelavi ob skeniranju [post-scan OCR] in morebitnih naknadnih spremembah ("ročne" spremembe v urejevalniku pred distribucijo datoteke).
Torej - zanašati se na omenjeno obnašanje programov ne more dokazovati ne avtentičnosti, ne poneverbe.
https://dolhar.si/
Double_J ::
To je jasno... ker se je že tudi meni kdaj zgodila zanimiva transformacija.
Dve šivanki...
Manu ::
Takšen napad na Obamo je neverjetno otročje.
Ne vem, kako to gre v ZDA, ampak sem prepričan, da obstajajo mehanizmi, da se preveri ali je nekdo državljan ZDA. Če je po ustavi ZDA lahko predsednik le državljan ZDA, potem bi v primeru dvoma nasprotniki gotovo imeli pravno podlago za ukrepanje in ugotavljanje ali je nekdo, ki kandidira za predsednika sploh primeren (pravno gledano) da se poteguje za to funkcijo.
Zakaj torej tega ne naredijo? Verjetno zato, ker nimajo kaj reči čez njega, potem se spuščajo na tako banalne napade.
Karkoli bi objavili ... skeptike ni mogoče zadovoljiti.
Sredi spečih in nepazljivih je modrec buden in pazljiv -
po poti gre kot hiter konj, ki je prehitel šibko kljuse.
Thomas ::
Ne vem kaj dosti o pdf fajlih. Niti o tem, kako lahko piše "African", če lahko piše.
Čakam, kaj bodo povedali stručni v naslednjih dneh. Če bo overall rezultat kazal na to, da je to pravi certifikat - so be it. Če ne, so be it!
SomethingEls ::
Tale reč z rojstnimi listi mu bolj koristi kot ne... upajmo, da bodo Američani dovolj pametni in ga itak iz mnogih drugih razlogov ne bodo volili.
No saj ne, da je kakšna dobra alternativa ampak vsaj malo manj škode bi kdo drug delal. Ron Paul bi bil mogoče še kar kandidat... kljub njegovi porazni zunanji politiki in nekaj čudnih pogledov kot naprimer nasprotovanje splavu.
SomethingEls ::
Manu ::
Ne bi rekel, da Obama dela kakšno škodo. Mislim, da kljub temu, da je predsednik nima toliko politične moči, da opravi zadane naloge. Opozicija je premočna.
Manu ::
Ne vem, zakaj ne bi smelo pisat "African"? Polje zahteva podatek "race of father".
Enako piše pri njegovi materi ... "Caucasian".
Nič spornega.
SomethingEls ::
Podržavljeno zdravstvo?
| » | Sovražniki razuma (strani: 1 2 3 4 5 )Oddelek: Problemi človeštva | 32202 (29973) | sprasujem |
| » | Sorodstvene vezi predsednikov ZDA (strani: 1 2 3 4 5 )Oddelek: Loža | 17929 (12710) | Gandalfar |
| ⊘ | Ali Obama sme postati predsednik ZDA?Oddelek: Problemi človeštva | 2376 (2248) | OmegaBlue |
| » | Will Hillary own some republican ass? (strani: 1 2 3 4 … 20 21 22 23 )Oddelek: Problemi človeštva | 68077 (36378) | poweroff |
| » | V ZDA kršijo tudi zasebnost predsedniških kandidatov?Oddelek: Novice / Zasebnost | 4639 (3289) | jype |
