Prvo javno omrežje 4G bo na Švedskem
X-Bit Labs - Ericsson in TeliaSonera sta včeraj objavila, da sta sklenila pogodbo o izgradnji prvega komercialnega omrežja LTE (long term evolution) za mobilne naprave četrte generacije, ki ga bo za TeliaSonero sestavil in vzdrževal Ericsson. Z njim bodo pokrili širše področje švedske prestolnice Stockholm. Če bo slo vse po načrtih, bo omrežje nared za delovanje v letu 2010. Novo omrežje bo omogočalo bistveno višje hitrosti pri brezžičnem dostopu do interneta, tako da bodo lahko uporabniki kjerkoli npr. na svojih prenosnikih ali mobilnikih spremljali HD-televizijske programe. V prihodnosti, pravijo, nameravajo omrežje razširiti tudi po drugih delih Švedske in Skandinavije nasploh.
41 komentarjev
Tody ::
Hehe, HD na telefonih? Al je to bolj mišljen za prenosnike? Reeely me prov zanima kok od vas zdele izkorišča 3,5 G? Tko redno :)
Jst ::
Hja, no. 4G sploh še ni končno definiran standard. Sicer pa ne bom pisaril, če lahko copy-paste iz Wikipadie lep povzetek, kaj trenutno 4G je.
There is no formal definition for what 4G is; however, there are certain objectives that are projected for 4G. These objectives include: that 4G will be a fully IP-based integrated system. 4G will be capable of providing between 100 Mbit/s and 1 Gbit/s speeds both indoors and outdoors, with premium quality and high security. [1]
Many companies have taken self-serving definitions and distortions about 4G to suggest they have 4G already in existence today, such as several early trials and launches of WiMAX. Other companies have made prototype systems calling those 4G. While it is possible that some currently demonstrated technologies may become part of 4G, until the 4G standard or standards have been defined, it is impossible for any company currently to provide with any certainty wireless solutions that could be called 4G cellular networks that would conform to the eventual international standards for 4G. These confusing statements around "existing" 4G have served to confuse investors and analysts about the wireless industry.
Pa novica bi lahko malo opisala The Objectives, pri trenutnem delu definiranja standarda. Spet, wiki:
Objectives
4G is being developed to accommodate the quality of service (QoS) and rate requirements set by forthcoming applications like wireless broadband access, Multimedia Messaging Service (MMS), video chat, mobile TV, HDTV content, Digital Video Broadcasting (DVB), minimal service like voice and data, and other streaming services for "anytime-anywhere". The 4G working group has defined the following as objectives of the 4G wireless communication standard:
-A spectrally efficient system (in bits/s/Hz and bits/s/Hz/site),[2]
-High network capacity: more simultaneous users per cell,[3]
-A nominal data rate of 100 Mbit/s while the client physically moves at high speeds relative to the station, and 1 Gbit/s while client and station are in relatively fixed positions as defined by the ITU-R,[1]
-A data rate of at least 100 Mbit/s between any two points in the world,[1]
-Smooth handoff across heterogeneous networks,[4]
-Seamless connectivity and global roaming across multiple networks,[5]
-High quality of service for next generation multimedia support (real time audio, high speed data, HDTV video content, mobile TV, etc)[5]
-Interoperability with existing wireless standards,[6] and
-An all IP, packet switched network.[5]
In summary, the 4G system should dynamically share and utilise network resources to meet the minimal requirements of all the 4G enabled users.
4G @ Wikipedia
Jst ::
Tody: 4G stremi k 100MBit/s med premikanjem in 1Gbit/s kadar stojiš na mestu.
Sicer pa se naj raje malo mednarodno zmenijo in štartajo sistem (bilokateri) ob približno enakem času. Saj smo v EU, bemu!
Kaj pa japonci? Oni uporablajo že 5G? :)
krho ::
Bah, jaz sem še 3G ugasnil, ker zadeva je baterijo kot za stavo, naj najprej to rešijo, potem pa naj začnejo razmišljati o 4G.
edge540 ::
Že res, ampak za surfanje po netu kjerkoli in za branje mailov pa je zeloooo dobrodošla pridobitev, da se ne postaraš ko preko GPRSa nalagaš karkoli.
Pesimist ::
kaj zaj nas bojo svedi se z brezicnim prehiteli kljub nasim optikam.
blackbfm ::
Če ne zdržiš 5 minut brez neta se pejt raje zdravit:P
Mikrohard ::
Vse te nove "fency" modulacije, ki se uporabljajo v novejših mobilnih komunikacijah (CDMA, OFDMA) zahtevajo popolnoma linearne ojačevalnike, ki pa imajo eno bistveno lastnost (slab izkoristek). Posledično bodo vse novejše mobilne komunikacije zelo požrešne z baterijo.
edge540 ::
To more bit jeba če te cajt povozi :))
Eni pač znamo koristiti zadnje storitve ki jih ponuja tehnika, in si s tem maksimalno optimiziramo svoj čas. Zakaj bi recimo porabil pol ure časa v službi za to da prebereš in odpišeš na mejle, če lahko to narediš na avtobusu/vlaku na poti v službo, in zato greš lahko pol ure prej domov?
Mogoče pa nisem jaz tisti ki potrebuje zdravljenje. Bi znal preživeti tudi brez interneta, ti pa z njim ne znaš.
blackbfm ::
Na telefonu boš eno uro odpisoval maile na tisti majhni tipkonvici in zaslonu, medtem ko jih na kompu v 5-10 minut. Težka produktivnost. Nevem pa kako si v zadnjem stavku pršu do take ugotovitve.
krho ::
Od kdaj se pa vožnja v/iz službo/e šteje v delovni čas? Fino, ker vsak dan na poti preživim vsaj 1,5h si bom delovnik skrajšal :P
Matevžk ::
Pa s prenosnikom?
Ali pa ko imaš nujno delo za faks, nekdo drug v družini pa za firmo, pa se ADSL modem odloči štrajkati? UMTS, NAT, že delamo.
lp, Matevžk
Matevžk ::
Odkar se z delodajalcem tako zmeniš in med vožnjo dejansko delaš za firmo.
lp, Matevžk
edge540 ::
Telefoni s qwerty so skoray enako hitri kot računalnik, če znaš.
Ponekod šteje kaj narediš, ne kak dolgo stol v pisarni greješ.
PrimozR ::
Jest, precej redno. oz. vsaj kadar je na voljo, sicer se pa moram zadovoljiti s 3G/EDGE-om.
QWERTY.
Tody> Hehe, HD na telefonih? Al je to bolj mišljen za prenosnike? Reeely me prov zanima kok od vas zdele izkorišča 3,5 G? Tko redno :)
Na kraj pameti mi ne pade, da bi gledal HD video na telefonu, redno pa izkoriščam pasovno širino, ki jo ponuja 3.5G.
blackclw> Na telefonu boš eno uro odpisoval maile na tisti majhni tipkonvici in zaslonu
Moj Vaio TZ ima vgrajen HSDPA modem, samo vštekam not sim kartico in sem ves čas povezan v internet (stane me pa 15 ojro na mesec za 5 giga, seveda pa toliko še nisem porabil - potrebujem zgolj hitrost, ne downloadam filmov).
  • spremenilo: jype ()
vitranc ::
Tudi jaz redno uporabljam 3.5G, kjer je le možno.
Macketina ::
Bistvena razlika je, ce uporabljas mobitel za cekirat meile in online banking, potem gres pa nekam kjer ni niti 3G, ampak stari dobri (in pocasni) EGPRS oz. EDGE. To se pa vlece...
Slin slin slin !!!
Glede "640 KB je dovolj za vse", pa pliz, a je treba še enkrat imeti to "debato" ?
Tody ::
ma ja sej je cool tehnologija pa to ampak telefoni ne sledijo temu :) Ustvarjalci vsebine so pa itak 100 svetlobnih let zadaj...
blackbfm ::
Visoke hitrosti, polno nekih bv funkcij, kvaliteta zvoka med pogovorom je pa še vedno tako zanič kot pred desetimi leti.
Mogoče če živiš v rovtah in moraš iskati signal. Drugače je kakovost zvoka povsem zadovoljiva.
blackbfm ::
Živim v okolici Ljubljane. In ne, kakovost zvoka je daleč od tega da bi bila zadovovoljiva (za moje pojme). Glede na to da tehnologija omogoča videoklice itd, bi moral bit normalen klic vsaj na ravni (če primerjam z mp3) tam nekje 160kbs.
PrimozR ::
Simobil?
3furious ::
LTE standard je bil definiran že pred enim mesecem v 3GPP Release 8
The standard includes:
* Peak download rates of 326.4 Mbit/s for 4x4 antennas, 172.8 Mbit/s for 2x2 antennas for every 20 MHz of spectrum. [2]
* Peak upload rates of 86.4 Mbit/s for every 20 MHz of spectrum.[2]
* 5 different terminal classes have been defined from a voice centric class up to a high end terminal that supports the peak data rates. All terminal will be able to process 20 MHz bandwidth.
* At least 200 active users in every 5 MHz cell. (i.e., 200 active data clients)
* Sub-5ms latency for small IP packets
* Increased spectrum flexibility, with spectrum slices as small as 1.5 MHz (and as large as 20 MHz) supported (W-CDMA requires 5 MHz slices, leading to some problems with roll-outs of the technology in countries where 5 MHz is a commonly allocated amount of spectrum, and is frequently already in use with legacy standards such as 2G GSM and cdmaOne.) Limiting sizes to 5 MHz also limited the amount of bandwidth per handset
* Optimal cell size of 5 km, 30 km sizes with reasonable performance, and up to 100 km cell sizes supported with acceptable performance
* Co-existence with legacy standards (users can transparently start a call or transfer of data in an area using an LTE standard, and, should coverage be unavailable, continue the operation without any action on their part using GSM/GPRS or W-CDMA-based UMTS or even 3GPP2 networks such as cdmaOne or CDMA2000)
* Supports MBSFN (Multicast Broadcast Single Frequency Network). This feature can deliver services such as Mobile TV using the LTE infrastructure, and is a competitor for DVB-H-based TV broadcast.
* PU2RC as a practical solution for MU-MIMO has been adopted to use in 3GPP LTE standard. The detailed procedure for the general MU-MIMO operation is handed to the next release, e.g, LTE-Advanced, where the further discussion will be held.
In the age of information, ignorance is a choice.
ReBi ::
Se strinjam z blackclwom. Zvok bi res lahko bil boljši, saj že veliko ljudi uporablja slušalke ali zvočnike v avtu, na računalniku...
Luka Percic ::
Slab zvok je tudi razlog za glavobole ob telefoniranju.
Možgani se morajo ob takih "nenaravnostih" zelo potrudit da nam tole spako iz zvočnika predstavijo kot prijateljev glas.
Večina pripomore k temu obupen bitrate (ferkvence manjkajo), pa tudi "ugašanje zvoka" (ko nihče ne govori, zvok kar izgine, tudi šumi, kar je precej "nenaravno" ter moteče).
Seveda tukaj izdatno pomagajo še švoh zvočniki ter mikrofončki, pa tudi to da je zvok le na eno uho ni še nič raziskano (če škodi/povzroča dodatno matranje možganov).
smihael ::
Na Nokiah si lahko naštimaš, da ne optimizira zvoka.
dëych ::
Signal je itak odrezan, mislm da nekje med 0.3kHz pa do 4kHz se prenaša, ostalo se odreže pred prenosom.
Brezveze!
Se 3G se ni prijel, pa ze s 4G pritiskajo.
M@ in S!mobil sta dale tezke denarce za koncesijo, pa se te zadeve se doooolgo ne bodo odplacale.
PrimozR ::
Brezveze!
Kaj ti ni jasno??? Seveda se je 3G prijel. Prijela se ni videotelefonija, ki pač izkorišča 3G. Point 4Gja so večji prenosi, enako kot 3Gja. Če kdo nima možnosti niti ADSLja in podobnih reči a ima dober 3,5G signal za 30 € mesečno dobi unlimited mobitelov internet z USB modemom. Odlična alternativa. Sicer mogoče malo bolj nestabilno in počasnejše, a vseeno.
3furious> * Sub-5ms latency for small IP packets
Tole bi pa meni zelo prav prišlo.
Matevžk ::
Za veliko večino osebnih in večino poslovnih uporab ima 3.5G zadostno pasovno širino (za zdaj; jasno se bodo potrebe večale). Mnogo grši je ping, ki vzame nekaj sto milisekund. Tako da - se strinjam in pozdravljam! :)
lp, Matevžk
Tam, kjer ni ADSL, imaš 3,5G? V kateri pravljici pa? Poglej si pokritost ADSL, nato pa še omrežja 3G. Čaka te malo presenečenje.
Na vlaku me med uporabo interneta večkrat presenetijo te "doline popolne tišine":(
kriko1 ::
Ja, na vlaku uporabljat net je en pain. Še posebej zaradi tunelov, vendar po večini je pokritost slaba, gprs komaj dela.
PrimozR ::
LJ-Radovljica do Kranja ni nobenega problema, mislim da je večinoma kar vsaj 3G, do podnarta pa pade na Edge. Naprej pa ne vem točno.
Jst ::
Pred dvemi leti sem kupil telefon. Prioritete: pogovor, pogovor in nizka cena. Nokia 6151, I think. Malo pred tem, je kolega kupil enega SonyE. Ene dva cenovna razreda višje.
(Sej to razlagam in sprašujem že n-tič tukaj)
Zadeva ima v nastavitvah GSM, UMTS, oboje. Če dam GSM, je telefon ob nakupu zdržal brez kakšnih dolgih pogovorov (ker sem bil na kampingu) deset 10 dni. Ker je bilo tisto poletje peklensko vroče, projekta tudi nisem imel nobenega aktivnega, sem bil skupaj ene tri tedne na Kolpi. Torej. GSM 10 dni. Ko sem vklopil UMTS, telefon pustil v šotoru, signal poln, mi je po treh dneh umrl.
Sem se o tem pogovarjal s kolegom s SonyE. Njemu je baterija zdržala brez kakšne konkretne uporabe dober teden dni - to na GSM. Ko je nastavil UMTS, telefon pustil pri miru, mu je baterija umrla po ene dveh do treh dneh.
Zakaj to?
In še nagradno vprašanje: Ali bo novo 4g Omrežje iz GSM.10dni -> UMTS.3dni -> 4G.23ur? Takole to meni zgleda...
No, no, malo resnosti pa le pokazi in ne kar blejat v tri dni.
Moj stric nima moznosti ADSL in je vzel ta paket, ki ga ti tako cislas. Takole bom rekel: preden maile na gmailu precekiras obupas zraven. Pa to ni osamljen primer! Pa ves, kaj drugod dobis za 30 €.
Je ze tako, da tebi marsikaj ni jasno (ko si se zacel ravno usajat).
Prijela se bo zadeva takrat, ko se bo masovno uporabljala, tako pa se niti koncesije ni pokila (kje je pa vse ostalo) in je tudi SE DOLGO ne bo.
Zheegec ::
Hitrost je čisto odvisna. Ko mi ADSL ne deluje se lepo konektam na telefon in net dela čist enako hitro, kot preko ADSL. Ampak HSDPA signala ni ravno povsod...
Janez Janša, 29.04.2014
PrimozR ::
Zakaj to?
3G res popije precej, 4G pa bo še več. To je pač standard. Jaz imam vedno vklopljen mix, torej 3G, ko je na voljo ker ga pogosto rabim. Če bi imel možnost '3G samo v tej aplikaciji' bi bilo super. zadnjič mi je namreč telefon umrl po pol dneva (muska, špili, net/irc).
Telia in Cisco potegnila 120Gbps internetno linijo za DreamHack (strani: 1 2 )
5518199 (15236) CvEtKo
2010 leto 4G
305768 (3552) slitkx
4G v pogonu na Severu
366032 (4367) Alexius Heristalski
Spama še vedno manj
Oddelek: Novice / Zasebnost
205766 (4518) lopov
Bo švedska tajna služba lahko prestrezala ves mednarodni promet?
2011638 (8604) MrStein
