Forum » Zvok in slika » PRAKTICA DVC 5.2 FHD
Cola400 ::
Nameravam kupiti novo kamero in sem opazil tole PRAKTICO..pa me zanima, če ima kdo kakšne izkušnje in kakšne se vam zdijo specifikacije...drugače mam namen kupit prek eBaya(cca. 200€)...ker v SLO ne najdem trgovine, ki bi jo imela na zalogi... drugače pa so specifikacije:
Device type: Digital camcorder with photo function
Focal lenght: 6.8 - 34 mm
Zoom: 5x optical, 4xdiital
Focus system: contrast auto focus
Focus range: normal: 10 cm - to infinity, macro (wide): 1 - 80 cm
Sensor: 1 / 2.5" CMOS, 5.0 Mega pixels
Resolution: 3200x2400 (8M), 2592x1944 (5M), 2048x1536 (3M)
ISO speed: auto
Colour depth: 24 Bit (RGB)
Colour effects: normal, sepia, black/white, negativ
Picture sharpness: normal
White balance: auto, 3 modes
Shutter: d.b.d.
Exposure: auto
Exposure control: +/- 1.0
Metering: matrix
Flash: auto, flash off mode, red eye reduction
Flash range: 0,6 - 1 m
Self timer: 10s
Display: 3,0" TFT display ( 960x240 pixels )
Video resolution: 1440x1080, 1280x720 , 848x450 (@30fps)
TV system: NTSC / PAL / HDMI
Tripod socket: 1/4"
Additional features: nightmode, SDHC support, HD 1080P 30 fps, scenemodi skin, night, backlight
Storage: 128 MB built-in memory, SD/SDHC -card usable
File format: JPEG, MOV
Interface: USB 2.0, TV out, HDMI/mini
Energy source: Li-Ionen-rechargeable battery NP 60
Dimensions: 114x53x65 mm
Weight: 340g
Accessories: USB cable, TV/HDMI cable, CD with driver, strap, manual, Li-ion rechargeable battery, charger
OS requirements: Windows 2000 / XP/ VISTA
LINK
PS. Mogoče ve kdo za kamero istega ranka in podobne cene? In ima izkušnje z njo?
LP, Luka
ISO speed: auto
Shutter: d.b.d.
Exposure: auto
Metering: matrix
Self timer: 10s
Tripod socket: 1/4"
Weight: 340g
LINK
LP, Luka
- spremenil: Cola400 ()
Tomson ::
Tale kamera je za ta denar defenitivno bestbuy. Dobiš pa seveda tudi veliko boljše kamere v tem razredu, sam so tudi nekajkrat dražje ...
blackbfm ::
Ta kamera smrdi. To sploh ni hd kamera, razen na papirju. Barve so pa kot pri webcamu/telefonu. Skret od skreta.
st0jko ::
Kaj pa 5.4 na Mimovrste? klik
Sicer se ne spoznam na kamere, ampak mislim da ni ravno slabša od 5.2. Nevem...
keks?
blackbfm ::
Res je. Za tak denar je bolje vzet digitalca ali pa dat še nekaj zraven za kaj bolj konkretnega.
| » | LG V30 (strani: 1 2 )Oddelek: Mobilne tehnologije | 14099 (11022) | next3steps |
| » | Je ta telefon vreden 193 € ?Oddelek: Mobilne tehnologije | 3955 (3449) | francek1 |
| » | Solarni polnilec NASVETOddelek: Pomoč in nasveti | 3680 (3180) | Pyr0Beast |
| » | Pregled napovedi za iPad 3 (strani: 1 2 )Oddelek: Novice / Apple iPhone/iPad/iPod | 27756 (21357) | Icematxyz |
| » | Rotiranje fotkOddelek: Zvok in slika | 2712 (2424) | Ziga Dolhar |
