Win xp user
Win xp user
BadB0y ::
Kako obstoječemu useru spremenit ime in komplet detajle od tega usera ?? Če v tistem meniju preimenujes usera npr. iz test v test1 ostanje se vedno folderi test za usera test1. Kako spremenit komplet vse?
StratOS ::
Hja pod Computer Management - Local Users and Groups / Users ( Start/Run compmgmt.msc )
Preimenuj userja, potem pa v Sistemskih opcijah ( Start/Run sysdm.cpl ) pod tabom Advanced/User Profiles zbrišeš oz. manipuliraš z profilom uporabnika.
Voila.
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
  • spremenila: StratOS ()
BadB0y ::
Hvala.
Win xp Administrativne pravice! Težave... Rabim pomoč!
282281 (2061) smrekca
Težave s POSTGRESQL 8.0 (TCP/IP)
Oddelek: Programiranje
82123 (2077) darh
Prijava v XP-je
Oddelek: Operacijski sistemi
71574 (1436) White666
Pereč Windows problem
191946 (1526) Dzonson
Microsoftova nova ukazna vrstica
364143 (4143) necromncr
