Ob vsakem zagonu CHDSK
strijcmarko ::
Pozdravljeni !
Imam težavo, v svoj računalnik ( Dell Pentium 4 2.0 1G RAM-a) sem dodal
še en disk(WDC 80GB). Disk mi sicer dela vredu vendar se mi ob vsakem ponovnem zagonu Windows XP pojavi CHDSK in preverja ta disk, to traja precej časa zato me moti.
Prosim če mi lahko kdorkoli pomaga z nasvetom.
Hvala v naprej
V command prompt(run--> cmd) napiši chkdsk C: /r.
Tam, kjer sem napisal C: napiši svojo črko od particije.
strijcmarko ::
napiše Neveljaven parameter - /r.
StratOS ::
CHKDSK [volume[[path]filename]]] [/F] [/V] [/R] [/X] [/I] [/C] [/L[:size]]
volume Specifies the drive letter (followed by a colon),
mount point, or volume name.
filename FAT/FAT32 only: Specifies the files to check for fragmentation.
/F Fixes errors on the disk.
/V On FAT/FAT32: Displays the full path and name of every file
on the disk.
On NTFS: Displays cleanup messages if any.
/R Locates bad sectors and recovers readable information
(implies /F).
/L:size NTFS only: Changes the log file size to the specified number
of kilobytes. If size is not specified, displays current
size.
/X Forces the volume to dismount first if necessary.
All opened handles to the volume would then be invalid
(implies /F).
/I NTFS only: Performs a less vigorous check of index entries.
/C NTFS only: Skips checking of cycles within the folder
structure.
The /I or /C switch reduces the amount of time required to run Chkdsk by
skipping certain checks of the volume.
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
Če ti to ven vrže potem nisi dobro napisal. Klikni na Start --> Run --> cmd --> napiši chkdsk C: /r
strijcmarko ::
tenks, sem piko zadaj pisu sedaj dela ko strela
HVALA TI ZA POMOČ !
AJDI BOK
Blue Screen error
61605 (1402) F-22
disk boot failure
81853 (1756) amigo_no1
Zakaj mi ne ponudi opcije formatiranja v FAT32 ?
51565 (1486) sinko999
? spremeniti FAT32 particijo v NTFS, ne da bi formatiral? Help!
Oddelek: Operacijski sistemi
113286 (3062) ZLOky
w2k in NTFS quick format?
Oddelek: Programska oprema
71864 (1738) CaqKa
